H3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
48-VXLAN over IPsec Configuration Examples
48-VXLAN over IPsec Configuration Examples 109.86 KB
H3C Routers
Introduction
The following information provides VXLAN over IPsec configuration examples for the router.
The following information applies to Comware 9-based router. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of IPsec and VXLAN.
Example: Configuring VXLAN over IPsec
As shown in Figure 1, HQ gateway Device A and branch gateway Device B transmit data to each other through a VXLAN tunnel. Use IPsec to encrypt the data passing through the VXLAN tunnel.
Figure 1 Network diagram
Analysis
·     To establish a Layer 2 interconnect between the HQ and branch, you must complete VXLAN-related configurations on Device A and Device B.
·     To use IPsec to encrypt data passing through the VXLAN tunnel, define the IPsec-protected data flows on both Device A and Device B.
·     To establish an IPsec tunnel between the HQ and the branch, complete IKE and IPsec configurations on Device A and Device B.
Software versions used
This configuration example was created and verified on R9141P16 of the MSR2630E-X1 device.
Before starting the configuration, make sure IPv4 packets can be forwarded at Layer 3 between GE1/0/2   of HQ gateway Device A and GE1/0/2   of branch gateway Device B.
Procedures
Configuring Device A
1.     Configure interface GigabitEthernet 1/0/2:
# Assign an IP address to interface GigabitEthernet 1/0/2.
<DeviceA> system
[DeviceA-GigabitEthernet1/0/2] ip address 10.1.1.1 255.255.255.0
2.     Configure VXLAN:
# Create VXLAN tunnel interface Tunnel 1.
[DeviceA] interface tunnel 1 mode vxlan
# Specify the source address of the tunnel as the IP address of GigabitEthernet 1/0/2.
[DeviceA-Tunnel1] source 10.1.1.1
# Specify the destination address of the tunnel as the IP address of GigabitEthernet 1/0/2.
[DeviceA-Tunnel1] destination 10.1.2.1
[DeviceA-Tunnel1] quit
# Enable L2VPN.
[DeviceA] l2vpn enable
# Create VSI instance 1 and VXLAN 1.
[DeviceA] vsi 1
[DeviceA-vsi-1] vxlan 1
# Assign Tunnel 1 to VXLAN 1.
[DeviceA-vsi-1-vxlan-1] tunnel 1
[DeviceA-vsi-1-vxlan-1] quit
[DeviceA-vsi-1] quit
# Map interface GigabitEthernet 1/0/1, which connects to the HQ server, to VSI instance 1.
[DeviceA-GigabitEthernet1/0/1] xconnect vsi 1
3.     Configure an ACL:
# Create ACL 3100 to define the data flow that requires IPsec protection from VXLAN tunnel source address 10.1.1.1 to VXLAN tunnel destination address 10.1.2.1.
[DeviceA] acl advanced 3100
[DeviceA-acl-adv-3100] rule 0 permit ip source 10.1.1.1 0 destination 10.1.2.1 0
[DeviceA-acl-adv-3100] quit
4.     Configure an IPsec transform set:
# Create IPsec transform set 1.
[DeviceA] ipsec transform-set 1
# Specify the encryption and authentication algorithms as DES-CBC and HMAC-MD5, respectively.
[DeviceA-ipsec-transform-set-1] esp encryption-algorithm des-cbc
[DeviceA-ipsec-transform-set-1] esp authentication-algorithm md5
[DeviceA-ipsec-transform-set-1] quit
5.     Configure an IKE keychain:
# Create an IKE keychain named 1.
[DeviceA] ike keychain 1
# Set the pre-shared key to be used for IKE negotiation with peer 10.1.2.1 to 123456.
[DeviceA-ike-keychain-1] pre-shared-key address 10.1.2.1 255.255.255.255 key simple 123456
[DeviceA-ike-keychain-1] quit
6.     Configure an IKE profile:
# Create an IKE profile named 1.
[DeviceA] ike profile 1
# Specify IKE keychain 1 for the IKE profile.
[DeviceA-ike-profile-1] keychain 1
# Configure the local ID with the identity type as IP address and the value as 10.1.1.1.
[DeviceA-ike-profile-1] local-identity address 10.1.1.1
# Configure the peer ID as IP address 10.1.2.1/32.
[DeviceA-ike-profile-1] match remote identity address 10.1.2.1 255.255.255.255
[DeviceA-ike-profile-1] quit
7.     Configure an IPsec policy:
# Create an IKE-based IPsec policy entry. Specify the policy name as 1 and set the sequence number to 1.
[DeviceA] ipsec policy 1 1 isakmp
# Specify IPsec transform set 1 for the IPsec policy.
[DeviceA-ipsec-policy-isakmp-1-1] transform-set 1
# Specify ACL 3100 to identify the traffic to be protected.
[DeviceA-ipsec-policy-isakmp-1-1] security acl 3100
# Specify local IP address 10.1.1.1 for the IPsec tunnel.
[DeviceA-ipsec-policy-isakmp-1-1] local-address 10.1.1.1
# Specify remote IP address 10.1.2.1 for the IPsec tunnel.
[DeviceA-ipsec-policy-isakmp-1-1] remote-address 10.1.2.1
# Specify IKE profile 1 for the IPsec policy.
[DeviceA-ipsec-policy-isakmp-1-1] ike-profile 1
[DeviceA-ipsec-policy-isakmp-1-1] quit
8.     Apply the IPsec policy to GigabitEthernet 1/0/2:
# Apply IPsec policy 1 to GigabitEthernet 1/0/2.
[DeviceA-GigabitEthernet1/0/2] ipsec apply policy 1
Configuring Device B
<DeviceB> system
[DeviceB-GigabitEthernet1/0/2] ip address 10.1.2.1 255.255.255.0
2.     Configure VXLAN:
[DeviceB] interface tunnel 1 mode vxlan
# Specify the source address of the tunnel as the IP address of GigabitEthernet 1/0/2, 10.1.2.1.
[DeviceB-Tunnel1] source 10.1.2.1
# Specify the destination address of the tunnel as the IP address of GigabitEthernet 1/0/2, 10.1.1.1.
[DeviceB-Tunnel1] destination 10.1.1.1
[DeviceB-Tunnel1] quit
# Enable L2VPN.
[DeviceB] l2vpn enable
[DeviceB] vsi 1
[DeviceB-vsi-1] vxlan 1
[DeviceB-vsi-1-vxlan-1] tunnel 1
[DeviceB-vsi-1-vxlan-1] quit
[DeviceB-vsi-1] quit
# Map interface GigabitEthernet 1/0/1, which connects to the branch server, to VSI instance 1.
[DeviceB-GigabitEthernet1/0/1] xconnect vsi 1
# Create ACL 3100 to define the data flow that requires IPsec protection from the VXLAN tunnel source address 10.1.2.1 to the VXLAN tunnel destination address 10.1.1.1.
[DeviceB] acl advanced 3100
[DeviceB-acl-adv-3100] rule 0 permit ip source 10.1.2.1 0 destination 10.1.1.1 0
[DeviceB-acl-adv-3100] quit
[DeviceB] ipsec transform-set 1
[DeviceB-ipsec-transform-set-1] esp encryption-algorithm des-cbc
[DeviceB-ipsec-transform-set-1] esp authentication-algorithm md5
[DeviceB-ipsec-transform-set-1] quit
[DeviceB] ike keychain 1
# Set the pre-shared key to be used for IKE negotiation with peer 10.1.1.1 to 123456.
[DeviceB-ike-keychain-1] pre-shared-key address 10.1.1.1 255.255.255.255 key simple 123456
[DeviceB-ike-keychain-1] quit
[DeviceB] ike profile 1
[DeviceB-ike-profile-1] keychain 1
# Configure the local ID as IP address 10.1.2.1.
[DeviceB-ike-profile-1] local-identity address 10.1.2.1
# Configure the peer ID as IP address 10.1.1.1/32.
[DeviceB-ike-profile-1] match remote identity address 10.1.1.1 255.255.255.255
[DeviceB-ike-profile-1] quit
[DeviceB] ipsec policy 1 1 isakmp
[DeviceB-ipsec-policy-isakmp-1-1] transform-set 1
[DeviceB-ipsec-policy-isakmp-1-1] security acl 3100
# Specify local IP address 10.1.2.1 for the IPsec tunnel.
[DeviceB-ipsec-policy-isakmp-1-1] local-address 10.1.2.1
# Specify remote IP address 10.1.1.1 for the IPsec tunnel.
[DeviceB-ipsec-policy-isakmp-1-1] remote-address 10.1.1.1
[DeviceB-ipsec-policy-isakmp-1-1] ike-profile 1
[DeviceB-ipsec-policy-isakmp-1-1] quit
[DeviceB-GigabitEthernet1/0/2] ipsec apply policy 1
# Initiate a connection from Host B to the HQ server to trigger IKE negotiation. Verify that you can successfully ping 192.168.1.10 from 192.168.1.21 after the IPsec tunnel is successfully established.
<HostB> ping 192.168.1.10
Ping 192.168.1.10 (192.168.1.10): 56 data bytes, press CTRL_C to break
Request time out
56 bytes from 192.168.1.10: icmp_seq=1 ttl=255 time=2.000 ms
56 bytes from 192.168.1.10: icmp_seq=2 ttl=255 time=1.000 ms
56 bytes from 192.168.1.10: icmp_seq=3 ttl=255 time=2.000 ms
56 bytes from 192.168.1.10: icmp_seq=4 ttl=255 time=2.000 ms
--- Ping statistics for 192.168.1.10 ---
5 packet(s) transmitted, 4 packet(s) received, 20.0% packet loss
round-trip min/avg/max/std-dev = 1.000/1.750/2.000/0.433 ms
# Execute the display ike sa command to view the IKE SA on Device A.
<DeviceA> display ike sa
    Connection-ID  Remote                Flag     DOI
    6              10.1.2.1/500          RD       IPsec
Flags:
RD--READY RL--REPLACED FD-FADING RK-REKEY
# Execute the display ipsec sa command to view IPsec SA information on Device A.
<DeviceA> display ipsec sa
  IPsec policy: 1
  Sequence number: 1
  Mode: ISAKMP
    Tunnel id: 0
    Encapsulation mode: tunnel
    Perfect Forward Secrecy:
    Inside VPN:
    Extended Sequence Numbers enable: N
    Traffic Flow Confidentiality enable: N
    Transmitting entity: Responder
    Path MTU: 1444
    Tunnel:
        local  address/port: 10.1.1.1/500
        remote address/port: 10.1.2.1/500
    Flow:
        sour addr: 10.1.1.1/255.255.255.255  port: 0  protocol: ip
        dest addr: 10.1.2.1/255.255.255.255  port: 0  protocol: ip
    [Inbound ESP SAs]
      SPI: 1526547107 (0x5afd42a3)
      Connection ID: 124554051585
      Transform set: ESP-ENCRYPT-DES-CBC ESP-AUTH-MD5
      SA duration (kilobytes/sec): 1843200/3600
      SA remaining duration (kilobytes/sec): 1843199/3314
      Max received sequence-number: 5
      Anti-replay check enable: Y
      Anti-replay window size: 64
      UDP encapsulation used for NAT traversal: N
      Status: Active
    [Outbound ESP SAs]
      SPI: 314817206 (0x12c3bab6)
      Connection ID: 124554051584
      Max sent sequence-number: 5
      Status: Active
# Execute the display interface tunnel 1 command to view information about the traffic transmitted through the VXLAN tunnel on Device A.
<DeviceA> display interface Tunnel 1
Tunnel1
Current state: UP
Line protocol state: UP
Bandwidth: 64 kbps
Maximum transmission unit: 1300
Output queue - Urgent queuing: Size/Length/Discards 0/1024/0
Tunnel source 10.1.1.1, destination 10.1.2.1
Last 300 seconds input rate: 3 bytes/sec, 24 bits/sec, 0 packets/sec
Last 300 seconds output rate: 3 bytes/sec, 24 bits/sec, 0 packets/sec
Input: 92 packets, 7525 bytes, 0 drops
Output: 94 packets, 7274 bytes, 0 drops
# Initiate a connection from Host A to the branch server to verify the connectivity. (Details not shown.)
Configuration files
·     Device A:
 l2vpn enable
vsi 1
 vxlan 1
  tunnel 1
 port link-mode route
 xconnect vsi 1
interface Tunnel1 mode vxlan
 source 10.1.1.1
acl advanced 3100
 transform-set 1
 security acl 3100
 ike-profile 1
ike profile 1
 keychain 1
ike keychain 1
 pre-shared-key address 10.1.2.1 255.255.255.255 key cipher $c$3$nWZsiVDLZOBOD4Vx7wrVutbEj5VbQIoURQ==
return
·     Device B:
 l2vpn enable
vsi 1
 vxlan 1
  tunnel 1
 xconnect vsi 1
 source 10.1.2.1
acl advanced 3100
 transform-set 1
 security acl 3100
 ike-profile 1
ike profile 1
 keychain 1
ike keychain 1
 pre-shared-key address 10.1.1.1 255.255.255.255 key cipher $c$3$nFvmDw8+uUDHgvYTW3FdZoijFc0jH6C9jQ==
return
Related documentation
·     IP Tunneling and Security VPN Configuration Guide in H3C MSR1000[2600][3600] Routers Configuration Guides (V9)
·     VXLAN Configuration Guide in H3C MSR1000[2600][3600] Routers Configuration Guides (V9)
·     IPsec Command Reference and VXLAN Command Reference in H3C MSR1000[2600][3600] Routers Command References (V9)
·     VXLAN Command Reference in H3C MSR1000[2600][3600] Routers Command References (V9)
