H3C S7500 Series Operation Manual(Release 3100 Series)-(V1.04)
HomeSupportSwitchesS7500 SeriesConfigure & DeployConfiguration GuidesH3C S7500 Series Operation Manual(Release 3100 Series)-(V1.04)
32-SSH Terminal Service Configuration
32-SSH Terminal Service Configuration 190 KB
Chapter 1  SSH Terminal Service Configuration
1.1  SSH Terminal Services
This section covers these topics:
l           Introduction to SSH
l           Configuring an SSH Server
l           Configuring an SSH Client
l           Displaying SSH Configuration
l           SSH Server Configuration Example
l           SSH Client Configuration Example
1.1.1  Introduction to SSH
Secure shell (SSH) can provide information security and powerful authentication to prevent such assaults as IP address spoofing, plain-text password interception when users log on to the Switch remotely in an insecure network environment.
As an SSH server, a switch can connect to multiple SSH clients; as an SSH client, a switch can establish SSH connections with switches or UNIX hosts that support SSH server.
Currently, the S7500 series switches support SSH2.0 (compatible with SSH1.5).
The communication process between the server and client includes the following five stages:
1)         Version negotiation stage. The following operations are completed at this stage:
l           The client sends TCP connection requests to the server.
l           When a TCP connection is established, both ends begin to negotiate the SSH version.
l           If they can work together in harmony, they enter the key algorithm negotiation stage. Otherwise the server removes the TCP connection.
2)         Key and algorithm negotiation stage. The following operations are completed at this stage:
l           The server and the client send key algorithm negotiation packets to each other, which include the supported server-side public key algorithm list, encryption algorithm list, MAC algorithm list, and compression algorithm list.
l           Based on the received algorithm negotiation packets, the server and the client figure out the algorithms to be used.
l           The server and the client use the DH key exchange algorithm and parameters such as the host key pair to generate the session key and session ID.
Through the above steps, the server and the client get the same session key, which is to be used to encrypt and decrypt data exchanged between the server and the client later. The server and the client use session ID in the authentication stage.
3)         Authentication stage
The client sends to the server an authentication request, which includes the username and authentication method, and the server starts to authenticate the client.
SSH provides two authentication methods: password authentication and RSA authentication.
For password authentication:
l           The client encrypts the username and password, encapsulates them into a password authentication request, and sends the request to the server.
l           Upon receiving the request, the server decrypts the username and password, compares them against those it maintains, and then informs the client of the authentication result.
For RSA authentication:
l           The client sends to the server an RSA authentication request containing its RSA public key modulus.
l           The server validates the modulus. If the modulus is invalid, the authentication fails; otherwise, the server generates a 32-byte random number, converts it to a multiple precision (MP) integer (MSB first), encrypts it using the RSA public key from the client, and then sends a challenge to the client.
l           Upon receiving the challenge, the client decrypts it with its private key and gets an MP integer, creates an MD5 value using the MP integer and the session ID, and then encrypts and sends the MD5 value to the server.
l           After receiving the encrypted MD5 value, the server decrypts it to obtain the MD5 value and compares it with that locally calculated. If they match, the authentication succeeds.
4)         Session request stage. The client sends session request messages to the server which processes the request messages.
5)         Interactive session stage. Both ends exchange data till the session ends.
1.1.2  Configuring an SSH Server
The following table describes SSH server configuration tasks.
Table 1-1 Configure SSH2.0 server
To do…
Use the command…
Remarks
Configure supported protocols
protocol inbound
See Configuring supported protocols
Generate a local RSA key pair
rsa local-key-pair create
See Generating or destroying RSA key pairs
Destroy a local RSA key pair
rsa local-key-pair destroy
Create an SSH user
ssh user username
See Creating an SSH user
Specify a default authentication type for SSH users
ssh authentication-type default
See Configuring authentication type
Configure authentication type for SSH users
ssh user username authentication-type
Set SSH authentication timeout time
ssh server timeout
See Configuring SSH attributes for the server
Set SSH authentication retry times
ssh server authentication-retries
Set the update interval for the server key
ssh server rekey-interval
Specify the server to be compatible with the SSH1.x-supported client.
ssh server compatible-ssh1x enable
Allocate public keys for SSH users
ssh user username assign rsa-key keyname
See Configuring client public keys
I. Configuring supported protocols
Table 1-2 Configure supported protocols
To do...
Use the command...
Remarks
Enter system view
Enter one or multiple user interface views
user-interface [ type-keyword ] number [ ending-number ]
Required
Set the login authentication method
authentication-mode scheme [ command-authorization ]
Required
Configure the protocols supported in the user interface view(s)
protocol inbound { all |ssh | telnet }
Optional
By default, the system supports both Telnet and SSH.
  Caution:
l      When SSH protocol is supported in the current user interface, to ensure a successful login, you must use the authentication-mode scheme command to configure the AAA authentication for login to the user interface.
l      The protocol inbound ssh configuration fails if you configured the authentication-mode password command or the authentication-mode none command. When you configure SSH protocol successfully for the user interface, then you cannot configure the authentication-mode password command or the authentication-mode none command any more.
II. Generating or destroying RSA key pairs
This configuration task is used to generate or destroy the RSA key pairs on the server end. Generating RSA key pairs on the server end is a prerequisite for SSH login. After you execute this command, the system will prompt you to specify the key length in bits. The length range is from 512 bits to 2048 bits, and defaults to 1024 bits. If there already exist key pairs, the system will prompt you whether to replace the old ones.
&  Note:
Server RSA key pairs (H3C_Server) is not used in SSH2.0; therefore, when the rsa local-key-pair create command is executed, the system only prompts you the host RSA key pair (H3C_Host) is generated, and does not inform you the information about the server RSA key pair even if the server RSA key pair is generated in the background for the purpose of SSH1.x compatibility. You can use the display rsa local-key-pair public command to display the generated key pairs.
Table 1-3 Generate or destroy RSA key pairs
To do...
Use the command...
Remarks
Enter system view
Required
Optional
&  Note:
Configuration of the rsa local-key-pair create can survive a reboot. You only need to configure it once.
III. Creating an SSH user
Table 1-4 Create an SSH user
To do...
Use the command...
Remarks
Enter system view
Create an SSH user
ssh user username
Required
For an SSH user created by using this command, if you do not specify an authentication type by using the ssh user authentication-type command for this user, this SSH user adopts the default authentication type.
IV. Configuring authentication type
An authentication type must be specified for new SSH users. Otherwise, they cannot access the switch.
Table 1-5 Configure authentication type
To do...
Use the command...
Remarks
Enter system view
ssh authentication-type default { password | rsa | password-publickey | all }
Optional;
By default, the password authentication type is specified.
ssh user username authentication-type { password | rsa | password-publickey | all }
Optional;
By default, the system does not specify available authentication types for SSH users, that is, they can not access the switch
Note that:
l           Use the ssh authentication-type default command to configure the default authentication type for all users.
l           Use the ssh user username authentication-type command to specify the authentication type for a user.
l           When the two commands are configured simultaneously, and the authentication types configured for the user (specified by username) are different from each other, comply with the configuration of the ssh user username authentication-type command.
  Caution:
l      If the RSA authentication type is specified, then the RSA public key of the client user must be configured on the switch.
l      For the password-publickey authentication type: SSH1 client users can access the switch as long as they pass one of the two authentications. SSH2 client users can access the switch only when they pass both the authentications.
l      For the password authentication, the username argument should be consistent with the effective user name defined in AAA; for the RSA authentication, the username argument is the local SSH user name, so that there is no need to configure a local user in AAA.
V. Configuring SSH attributes for the server
Configuring SSH authentication timeout time, retry times, server key update interval and SSH compatible mode for the server can effectively assure security of SSH connections by avoiding illegal actions such as malicious password guessing.
Table 1-6 Configure SSH attributes for the server
To do...
Use the command...
Remarks
Enter system view
ssh server timeout seconds
Optional
The authentication timeout time defaults to 60 seconds.
ssh server authentication-retries times
Optional
The authentication retry times defaults to 3.
Set server key update interval
ssh server rekey-interval hours
Optional
By default, the system does not update server keys.
Set the SSH server to be compatible with SSH1.x clients
Optional
By default, the SSH server is compatible with SSH1.x clients.
VI. Configuring client public keys
You can configure RSA public keys for client users on the switch and specify RSA private keys, which correspond to the public keys, on the client. The client public keys are generated randomly by the SSH2.0 client software.
This operation is not necessary for password authentication type.
Table 1-7 Configure client public keys
To do...
Use the command...
Remarks
Enter system view
Enter public key view
rsa peer-public-key key-name
Required
Enter public key code view
public-key-code begin
You can key in a blank space between characters, since the system can remove the blank space automatically. You can also press the <Enter> key and then key in characters continuously. But the public key should be composed of hexadecimal characters.
Return to public key view from public key code view
public-key-code end
The system saves public key data when exiting from public key code view
Return to system view from public key view
peer-public-key end
Allocate public keys to SSH users
Required
The keyname argument is the name of an existing public key. If the user already has a public key, the new public key overrides the old one.
1.1.3  Configuring an SSH Client
Follow these steps to configure an SSH client:
To do...
Use the command...
Remarks
Enter system view
Create the connection between an SSH client and an SSH server
ssh2 { host-ip | host-name } [ port-num ] [ prefer_kex { dh_group1 | dh_exchange_group } | prefer_ctos_cipher { des | aes128 } | prefer_stoc_cipher { des | aes128 } | prefer_ctos_hmac { sha1 | sha1_96 | md5 | md5_96 } | prefer_stoc_hmac { sha1 | sha1_96 | md5 | md5_96 } ] *
Required
You can use this command to enable the connection between an SSH client and an SSH server, define the preferential key exchange algorithm, the preferential encryption algorithm and the preferential HMAC algorithm between the server and client.
Allocate a public key to the server
ssh client server-ip assign rsa-key keyname
Required
You can specify on the client the public key for the server to be connected to guarantee the client can be connected to a reliable server.
Configure the client to run the first-time authentication for the server
ssh client first-time enable
Optional
By default, the client runs the first-time authentication.
&  Note:
With the first-time authentication, if the SSH client does not have the public key of the server which the SSH client accesses for the first time, the client continues to access the server and save the public key of the server locally. Then at the next access, the client can authenticate the server through the public key saved locally.
1.1.4  Displaying SSH Configuration
Use the display commands in any view to view the running status of SSH and verify the configuration.
Table 1-8 Display SSH configuration
To do...
Use the command...
Remarks
Display the public keys of the host key pair and the server key pair on the server
The display commands can be executed in any view.
Display the public key of the specified RSA key pair on the client
display rsa peer-public-key [ brief | name keyname ]
Display SSH status and session information
display ssh server { status | session }
Display SSH user information
Display the mappings between host public keys and SSH servers saved on a client
display ssh server-info
1.1.5  SSH Server Configuration Example
I. Network requirements
As shown in Figure 1-1, the PC (SSH Client) runs the client software supporting SSH2.0, establishes a local connection with the switch (SSH Server) and ensures the security of data exchange.
II. Network diagram
Figure 1-1 Network diagram for SSH server configuration
III. Configuration procedure
1)         Generate a local RSA key pair.
<H3C>system-view
[H3C] rsa local-key-pair create
&  Note:
If the local RSA key pair has been generated in previous operations, skip this step here.
2)         Set authentication type.
Settings for the two authentication types are described respectively in the following section:
l           Password authentication
# Set AAA authentication on the user interfaces.
[H3C] user-interface vty 0 4
[H3C-ui-vty0-4] authentication-mode scheme
# Set the user interfaces to support SSH.
[H3C-ui-vty0-4] protocol inbound ssh
# Configure the login protocol for the client001 user as SSH, specify commands of level 3, authentication type as password and the authentication password as abc.
[H3C] local-user client001
[H3C-luser-client001] password simple abc
[H3C-luser-client001] service-type ssh level 3
[H3C-luser-client001] quit
[H3C] ssh user client001 authentication-type password
&  Note:
Select the default SSH authentication timeout time and authentication retry times. After these settings, run the SSH2.0-supporting client software on other terminals connected to the switch. These terminals can log in to the switch using user name client001 and password abc.
l           RSA public key authentication
# Set the command level for the login users to 3.
[H3C-ui-vty0-4] user privilege level 3
[H3C-ui-vty0-4] quit
# Configure the login protocol for the client002 user as SSH and authentication type as RSA public key.
[H3C] ssh user client002 authentication-type rsa
# Generate randomly RSA key pairs on the SSH2.0 client and send the corresponding public keys to the server.
# Configure client public keys on the server, with their name as H3C002.
[H3C] rsa peer-public-key H3C002
[H3C-rsa-public-key] public-key-code begin
[H3C-rsa-key-code] 308186028180739A291ABDA704F5D93DC8FDF84C427463
[H3C-rsa-key-code] 1991C164B0DF178C55FA833591C7D47D5381D09CE82913
[H3C-rsa-key-code] D7EDF9C08511D83CA4ED2B30B809808EB0D1F52D045DE4
[H3C-rsa-key-code] 0861B74A0E135523CCD74CAC61F8E58C452B2F3F2DA0DC
[H3C-rsa-key-code] C48E3306367FE187BDD944018B3B69F3CBB0A573202C16
[H3C-rsa-key-code] BB2FC1ACF3EC8F828D55A36F1CDDC4BB45504F020125
[H3C-rsa-key-code] public-key-code end
[H3C-rsa-public-key] peer-public-key end
[H3C] ssh user client002 assign rsa-key H3C002
# Start the SSH client software on the host which stores the RSA private keys and perform corresponding configurations to establish an SSH connection.
1.1.6  SSH Client Configuration Example
As shown in Figure 1-2:
l           Switch A serves as an SSH client with user name being client003.
l           Switch B serves as an SSH server, with its IP address being 10.165.87.136.
l           The SSH client authenticates the SSH server to ensure that the server end is legal.
II. Network diagram
Figure 1-2 Network diagram for SSH client configuration
The following configurations are performed on Switch B.
&  Note:
The SSH client does not authenticate the SSH server for the first time access. It is necessary to configure on the SSH client the RAS host public key of the SSH server.
1)         Configure the client not to perform first-time authentication to the SSH server.
<H3C> system-view
[H3C] undo ssh client first-time
2)         Configure server public keys on the client.
[H3C] rsa peer-public-key public
[H3C] ssh client 10.165.87.136 assign rsa-key public
3)         Start SSH client
l           Adopt the password authentication and start the client using the default encryption algorithm.
[H3C] ssh2 10.165.87.136
username: client003
Trying 10.165.87.136 ...
Press CTRL+K to abort
Connected to 10.165.87.136 ...
Enter password:
*  Copyright(c) 2004-2007 Hangzhou H3C Tech. Co., Ltd. All rights reserved.*
*  Without the owner's prior written consent,                                  *
*  no decompiling or reverse-engineering shall be allowed.                     *
<H3C>
l           Adopt the RSA public key authentication and start the client using the defined encryption algorithm.
[H3C] ssh2 10.165.87.136 perfer_kex dh_group1 perfer_ctos_cipher des perfer_ctos_hmac md5 perfer_stoc_hmac md5
username: client003
Trying 10.165.87.136...
Connected to 10.165.87.136...
<H3C>
1.2  SFTP Service
1.2.1  SFTP Overview
Secure FTP (SFTP) is a new feature introduced in SSH2.0.
SFTP is established on SSH connections to secure remote users’ login to the switch, file management, and file transfer (such as upgrade the system), thus providing much securer data transfer. An SFTP client enables you to securely log onto another remote device to transfer files.
1.2.2  SFTP Server Configuration
The following sections describe SFTP server configuration tasks:
l           Configuring service type for an SSH user
l           Enabling the SFTP server
I. Configuring service type for an SSH user
Table 1-9 Configure service type for an SSH user
To do...
Use the command...
Remarks
Enter system view
ssh user username service-type { stelnet | sftp | all }
Required
By default, the available service type is stelnet.
&  Note:
For SFTP login users, it is necessary to set their service type to sftp or all.
II. Enabling the SFTP server
Table 1-10 Enable the SFTP server
To do...
Use the command...
Remarks
Enter system view
sftp server enable
Required
By default, the SFTP server is not enabled.
1.2.3  SFTP Client Configuration
The following sections describe SFTP client configuration tasks:
Table 1-11 Configure SFTP client
To do...
Command Key word
View
Remarks
Enable the SFTP client
sftp
Required
Disable the SFTP client
bye
SFTP client view
Optional
exit
SFTP directory -related operations
Change the current directory
cd
SFTP client view
Optional
Return to the upper-level directory
cdup
Display the current directory
pwd
Display the list of the files in a directory
dir
ls
Create a new directory
mkdir
Delete a directory
rmdir
SFTP file-related operations
Rename a file on the SFTP server
rename
SFTP client view
Optional
Download a file from the remote SFTP server
get
Upload a local file to the remote SFTP server
put
dir
ls
Delete a file from the SFTP server
delete
remove
Get help information about SFTP client commands
help
SFTP client view
Optional
I. Enabling the SFTP client
You can enable the SFTP client, establish a connection to the remote SFTP server and enter STP client view.
Table 1-12 Enable the SFTP client
To do...
Use the command...
Remarks
Enter system view
sftp { host-ip | host-name } [ port-num ] [ prefer_kex { dh_group1 | dh_exchange_group } | prefer_ctos_cipher { des | aes128 } | prefer_stoc_cipher { des | aes128 } | prefer_ctos_hmac { sha1 | sha1_96 | md5 | md5_96 } | prefer_stoc_hmac { sha1 | sha1_96 | md5 | md5_96 } ] *
Required
II. Disabling the SFTP client
Table 1-13 Disable the SFTP client
To do...
Use the command...
Remarks
Enter system view
Enter SFTP client view
bye
The three commands have the same function.
exit
III. Operating with SFTP directories
SFTP directory-related operations include: changing or displaying the current directory, creating or deleting a directory, and displaying files or information of a specific directory.
Table 1-14 Operate with SFTP directories
To do...
Use the command...
Remarks
Enter system view
Optional
cd [ remote-path ]
cdup
pwd
Optional
The dir and ls commands have the same function.
Create a directory on the SFTP server
mkdir remote-path
Optional
Delete a directory from the SFTP server
rmdir remote-path&<1-10>
IV. Operating with SFTP files
SFTP file-related operations include: changing file name, downloading files, uploading files, displaying the list of the files, and deleting files.
Table 1-15 Operate with SFTP files
To do...
Use the command...
Remarks
Enter system view
Optional
Change the name of a file on the remote SFTP server
rename old-name new-name
Upload a file to the remote SFTP server
Display the list of files in a directory
Optional
delete remote-file&<1-10>
Optional
The delete and remove commands have the same function.
remove remote-file&<1-10>
V. Displaying help information
You can display help information about a command, such as syntax and parameters.
Table 1-16 Display help information about SFTP client commands
To do...
Use the command...
Remarks
Enter system view
help [ all | command-name ]
Optional
1.2.4  SFTP Configuration Example
As shown in Figure 1-3:
l           An SSH connection is present between Switch A and Switch B.
l           Switch B serves as an SFTP server, with IP address being 10.111.27.91.
l           Switch A serves as an SFTP client.
l           An SSH user named abc with password being hello is created.
II. Network diagram
Figure 1-3 Network diagram for SFTP configuration
1)         Configure Switch B (SFTP server)
# Enable the SFTP server.
[H3C] sftp server enable
# Specify SFTP service for SSH user abc.
[H3C] ssh user abc service-type sftp
2)         Configure Switch A (SFTP client)
# Establish a connection to the remote SFTP server and enter SFTP client view.
[H3C] sftp 10.111.27.91
# Display the current directory on the SFTP server, delete file z and verify the operation.
sftp-client> dir
-rwxrwxrwx   1 noone    nogroup      1759 Aug 23 06:52 config.cfg
-rwxrwxrwx   1 noone    nogroup       225 Aug 24 08:01 pubkey2
-rwxrwxrwx   1 noone    nogroup       283 Aug 24 07:39 pubkey1
drwxrwxrwx   1 noone    nogroup         0 Sep 01 06:22 new
-rwxrwxrwx   1 noone    nogroup       225 Sep 01 06:55 pub
-rwxrwxrwx   1 noone    nogroup         0 Sep 01 08:00 z
sftp-client> delete z
The following File will be deleted:
flash:/z
Are you sure to delete it?(Y/N):y
This operation may take a long time. Please wait...
File successfully Removed
sftp-client> dir
# Create directory new1 and verify the operation.
sftp-client> mkdir new1
New directory created
sftp-client> dir
drwxrwxrwx   1 noone    nogroup         0 Sep 02 06:30 new1
# Change the name of directory new1 to new2 and verify the operation.
sftp-client> rename new1 new2
File successfully renamed
sftp-client> dir
drwxrwxrwx   1 noone    nogroup         0 Sep 02 06:33 new2
# Download the file named pubkey2 and rename it to public.
sftp-client> get pubkey2 public
Remote  file:flash:/pubkey2 --->  Local file: public..
Downloading file successfully ended
# Upload the file named pu to the SFTP server and rename it to puk. Verify the operations.
sftp-client> put pu puk
Local file: pu --->  Remote file: flash:/puk
Uploading file successfully ended
sftp-client> dir
-rwxrwxrwx   1 noone    nogroup       283 Sep 02 06:35 pub
-rwxrwxrwx   1 noone    nogroup       283 Sep 02 06:36 puk
sftp-client>
# Exit from SFTP.
sftp-client> quit
Bye
[H3C]
