H3C S7500 Series Operation Manual(Release 3100 Series)-(V1.04)
HomeSupportSwitchesS7500 SeriesConfigure & DeployConfiguration GuidesH3C S7500 Series Operation Manual(Release 3100 Series)-(V1.04)
29-UDP-Helper Configuration
29-UDP-Helper Configuration 74 KB
Chapter 1  UDP-Helper Configuration
When configuring UDP-Helper, go to these sections for information you are interested in:
l           Introduction to UDP-Helper
l           Configuring UDP-Helper
l           Displaying and Maintaining UDP-Helper Configuration
l           UDP-Helper Configuration Example
1.1  Introduction to UDP-Helper
UDP-Helper is designed to relay specified UDP broadcast packets. It enables a device to operate as a UDP packet relay. That is, it can convert UDP broadcast packets into unicast packets and forward them to a specified server.
Normally, all the received UDP broadcast packets are passed to the UDP module. With the UDP-Helper function enabled, the device checks the destination port numbers of the received UDP broadcast packets and duplicates those with their destination port numbers being that configured for UDP-Helper to the UDP-Helper module. The UDP-helper module in turn modifies the destination IP addresses of the packets and then sends the packet to the specified destination server.
&  Note:
The DHCP Relay module uses UDP port 67 and 68 to relay BOOTP/DHCP broadcast packets, so do not use port 67 and 68 as UDP-Helper destination ports.
With UDP-Helper enabled, the device relays the UDP broadcast packets whose destination ports are one of the six UDP ports list in Table 1-1 by default.
Table 1-1 List of default UDP ports
Protocol
UDP port number
Trivial file transfer protocol (TFTP)
69
Domain name system (DNS)
53
Time service
37
NetBIOS name service (NetBIOS-NS)
137
NetBIOS datagram service (NetBIOS-DS)
138
TACACS (terminal access controller access control system)
49
1.2  Configuring UDP-Helper
Follow these steps to configure UDP-Helper:
To do…
Use the command…
Remarks
Enter system view
Enable UDP-Helper
udp-helper enable
Required
UDP-Helper is disabled by default
Configure a UDP port as a UDP-Helper destination port
udp-helper port { port | dns | netbios-ds | netbios-ns | tacacs | tftp | time }
This operation is unnecessary if the port is among the default UDP ports listed in Table 1-1.
With UDP-Helper enabled, UDP broadcast packets destined for the ports listed in Table 1-1 are relayed by default.
Enter VLAN interface view
interface vlan-interface vlan-id
Configure the destination server to which the matched UDP broadcast packets are to be forwarded
udp-helper server ip-address
Required
By default, no destination server is configured
  Caution:
l      You need to enable the UDP-Helper function before specifying a UDP-Helper destination port.
l      The dns, netbios-ds, netbios-ns, tacacs, tftp, and time keywords refers to the six default UDP ports. You can configure a default port to be a UDP-Helper destination port by specifying the corresponding port number or the corresponding keyword. For example, udp-helper port 53 and udp-helper port dns specify the same port as a UDP-Helper destination port.
l      The display current-configuration command does not display the default UDP ports that are configured to be UDP-Helper destination ports.
l      After UDP-Helper is disabled, all the configured UDP ports are cancelled, including the default ports.
l      You can configure up to 40 UDP ports as UDP-Helper destination ports on a device.
l      You can configure up to 20 destination servers on a VLAN interface.
l      If the destination server is configured on a VLAN interface, the UDP broadcast packets received from the ports in the VLAN with specific UDP-Helper destination ports are forwarded to the destination server configured on the VLAN interface.
1.3  Displaying and Maintaining UDP-Helper Configuration
To do…
Use the command…
Remarks
Display the information about the destination servers and the number of the packets forwarded to each destination server
display udp-helper server [ interface vlan-interface vlan-id ]
Available in any view
Clear the statistics about packets forwarded by UDP-Helper
reset udp-helper packet
Available in user view
1.4  UDP-Helper Configuration Example
1.4.1  Network requirements
The IP address of VLAN 1 interface is 10.110.1.1/16. The VLAN interface is connected to the network segment 10.110.0.0/16. Configure to forward the broadcast UDP packets whose destination UDP port number is 55 to the server with its IP address being 202.38.1.2/24.
1.4.2  Network diagram
Figure 1-1 Network diagram for UDP-Helper configuration
1.4.3  Configuration procedure
&  Note:
This example assumes that the route between the switch and the network segment 202.38.1.0/24 is reachable.
# Enable UDP-Helper.
<H3C> system-view
[H3C] udp-helper enable
# Configure port 55 as a UDP-Helper destination port.
[H3C] udp-helper port 55
# Configure the server with the IP address of 202.38.1.2 as a destination server for the UDP broadcast packets.
[H3C] interface Vlan-interface 1
[H3C-Vlan-interface1] ip address 10.110.1.1 16
[H3C-Vlan-interface1] udp-helper server 202.38.1.2
