H3C S7500 Series Operation Manual(Release 3100 Series)-(V1.04)
HomeSupportSwitchesS7500 SeriesConfigure & DeployConfiguration GuidesH3C S7500 Series Operation Manual(Release 3100 Series)-(V1.04)
24-ACL Configuration
24-ACL Configuration 264 KB
Table of Contents
Chapter 1 ACL Configuration. 1-1
1.1 ACL Overview. 1-1
1.1.1 ACL Match Order 1-2
1.1.2 Ways to Apply ACL on a Switch. 1-3
1.1.3 ACLs Based on Time Ranges. 1-3
1.1.4 Types of ACLs Supported by Ethernet Switches. 1-4
1.2 Choosing ACL Mode for Traffic Flows. 1-4
1.2.1 Configuration Procedure. 1-4
1.2.2 Configuration Example. 1-4
1.3 Specifying the Match Order of ACL Rules. 1-5
1.3.1 Configuration Procedure. 1-5
1.3.2 Configuration Example. 1-5
1.4 Configuring Time Ranges. 1-5
1.4.1 Configuration Procedure. 1-6
1.4.2 Configuration Example. 1-7
1.5 Defining Basic ACLs. 1-7
1.5.1 Configuration Prerequisites. 1-7
1.5.2 Configuration Procedure. 1-8
1.5.3 Configuration Example. 1-8
1.6 Defining Advanced ACLs. 1-9
1.6.1 Configuration Prerequisites. 1-9
1.6.2 Configuration Procedure. 1-9
1.6.3 Configuration Example. 1-14
1.7 Defining Layer 2 ACLs. 1-15
1.7.1 Configuration Prerequisites. 1-15
1.7.2 Configuration Procedure. 1-15
1.7.3 Configuration Example. 1-18
1.8 Defining User-Defined ACLs. 1-18
1.8.1 Configuration Prerequisites. 1-18
1.8.2 Configuration Procedure. 1-18
1.8.3 Configuration Example. 1-19
1.9 Applying ACLs on Ports. 1-19
1.9.1 Configuration Preparation. 1-19
1.9.2 Configuration Procedure. 1-20
1.9.3 Configuration Example. 1-21
1.10 Displaying ACL Configuration. 1-22
1.11 ACL Configuration Examples. 1-22
1.11.1 Basic ACL Configuration Example. 1-22
1.11.2 Advanced ACL Configuration Example. 1-23
1.11.3 Layer 2 ACL Configuration Example. 1-25
1.11.4 User-Defined ACL Configuration Example. 1-26
&  Note:
Type A line processing units (LPUs) include LS81FT48A, LS81FM24A, LS81FS24A, LS81GB8UA, LS81GT8UA, LS81FT48, LS81FM24, LS81FS24, LS81GB8U and LS81GT8U.
When configuring ACL, go to these sections for information you are interested in:
l           ACL Overview
l           Choosing ACL Mode for Traffic Flows
l           Specifying the Match Order of ACL Rules
l           Configuring Time Ranges
l           Defining Basic ACLs
l           Defining Advanced ACLs
l           Defining Layer 2 ACLs
l           Defining User-Defined ACLs
l           Applying ACLs on Ports
l           Displaying ACL Configuration
l           ACL Configuration Examples
1.1  ACL Overview
An access control list (ACL) is used primarily to identify traffic flows. In order to filter data packets, a series of match rules must be configured on the network device to identify the packets to be filtered. After the specific packets are identified, and based on the predefined policy, the network device can permit/prohibit the corresponding packets to pass.
ACLs classify packets based on a series of match conditions, which can be the source addresses, destination addresses and port numbers carried in the packets.
The packet match rules defined by ACLs can be referenced by other functions that need to differentiate traffic flows, such as the definition of traffic classification rules in QoS.
According to the application purpose, ACLs fall into the following four types:
l           Basic ACL: rules are made based on the Layer 3 source IP addresses only.
l           Advanced ACL: rules are made based on the Layer 3 and Layer 4 information such as the source and destination IP addresses of the data packets, the type of protocol over IP, protocol-specific features, and so on.
l           Layer 2 ACL: rules are made based on the Layer 2 information such as the source and destination MAC address, VLAN priority, Layer 2 protocol, and so on.
l           User-defined ACL: such rules specify a byte in the packet, by its offset from the packet header, as the starting point to perform logical AND operations, and compare the extracted string with the user-defined string to find the matching packets for processing.
An ACL may contain a number of rules, which specify different packet ranges. This brings about the issue of match order when these rules are used to filter packets.
An ACL supports the following two types of match orders:
l           Configured order: ACL rules are matched according to the configured order.
l           Automatic ordering: ACL rules are matched according to the “depth-first” order.
I. IP ACL depth-first order
With the depth-first rule adopted, the rules of an IP ACL (basic and advanced) are matched in the following order:
1)         Protocol range of ACL rules. The range of IP protocol is 1 to 255 and those of other protocols over IP are the same as the corresponding protocol numbers. The smaller the protocol range, the higher the priority.
2)         Range of source IP address. The smaller the source IP address range (that is, the longer the mask), the higher the priority.
3)         Range of destination IP address. The smaller the destination IP address range (that is, the longer the mask), the higher the priority.
4)         Range of Layer 4 port number, that is, of TCP/UDP port number. The smaller the range, the higher the priority.
If rule A and rule B are the same in all the four ACEs (access control elements) above, and also in their numbers of other ACEs to be considered in deciding their priority order, weighting principles will be used in deciding their priority order.
The weighting principles work as follows:
l           Each ACE is given a fixed weighting value. This weighting value and the value of the ACE itself will jointly decide the final matching order. The weighting values of ACEs rank in the following descending order: DSCP, ToS, ICMP, established, precedence, fragment.
l           The weighting value of each ACE of the rule is deducted from a fixed weighting value. The smaller the weighting value left, the higher the priority.
l           If the number and type of ACEs are the same for multiple rules, then the sum of ACE values of a rule determines its priority. The smaller the sum, the higher the priority.
II. Layer 2 ACL depth-first order
With the depth-first order adopted, the rules of a Layer 2 ACL are matched in the order of the mask length of the source MAC address and destination MAC address, the longer the mask, the higher the match priority. If two mask lengths are the same, the priority of the match rule configured earlier is higher. For example, the priority of the rule with source MAC address mask FFFF-FFFF-0000 is higher than that of the rule with source MAC address mask FFFF-0000-0000.
I. ACLs activated directly on the hardware
In a switch, an ACL can be directly activated on the switch hardware for packet filtering and traffic classification in the data forwarding process. You can use the acl order command to specify the match order for the rules in the ACL. For detailed configuration, refer to Specifying the Match Order of ACL Rules.
ACLs are directly activated on the switch hardware in the following situations: the switch references ACLs to implement the QoS functions, and forwards data through ACLs.
II. ACL referenced by the upper-level modules
The switch also uses ACLs to filter packets processed by software and implements traffic classification. In this case, there are two types of match orders for the rules in an ACL: config (user-defined match order) and auto (the system performs automatic ordering, namely according to the “depth-first” order). In this scenario, you can specify the match order for multiple rules in an ACL. You cannot modify the match order for an ACL once you have specified it. You can specify anew the match order only after all the rules are deleted from the ACL.
ACLs can also be referenced by route policies or be used to control login users.
A time range-based ACL enables you to implement ACL control over packets by differentiating the time ranges.
A time range can be specified in each rule in an ACL. If the time range specified in a rule is not configured, the system will give a prompt message and allow such a rule to be successfully created. However, the rule does not take effect immediately. It takes effect only when the specified time range is configured and the system time is within the time range. If you remove the time range of an ACL rule, the ACL rule becomes invalid the next time the ACL rule timer refreshes.
The following types of ACLs are supported by Ethernet switches:
l           Basic ACL
l           Advanced ACL
l           Layer 2 ACL
l           User-defined ACL
A switch can only choose one ACL mode for traffic flows, Layer 2 ACL mode or Layer 3 ACL mode. In Layer 2 ACL mode, only Layer 2 ACL can be activated or imported by other applications, and Layer 3 ACL mode is similar.
Table 1-1 Choose ACL mode for traffic flows
To do…
Use the command...
Remarks
Enter system view
acl mode { ip-based | link-based }
Required
By default, a switch chooses ip-based ACL mode for traffic flows, that is, ACL classifies the traffic flows based on Layer 3 information.
Display the ACL mode for traffic flows
display acl mode
Optional
The display command can be executed in any view
&  Note:
This configuration is only effective on Type A line processing units (LPUs).
# Configure the ACL mode for traffic flows as link-based.
<H3C> system-view
[H3C] acl mode link-based
[H3C] display acl mode
 The current acl mode: link-based.
The acl match-order { config | auto } command is used to set the matching order of ACL rules when they are configured. The acl order command is used to set the matching order of ACL rules in the case that they are applied to a port. The S7500 Switches support three matching orders of ACL rules applied to a port: depth-first, first-config-first-match, and last-config-first match. You can specify one of the three orders.
Table 1-2 Set the matching order of ACL rules sent to a port
To do...
Use the command...
Remarks
Enter system view
Set the matching order of the configured ACL rules sent to a port
acl order { auto | first-config-first-match | last-config-first-match }
Required
By default, the configured ACL rules sent to a port match in the depth-first order, that is, the auto mode.
Display the traffic flows ACL mode
display acl order
Optional
# Specify the matching order of ACL rules applied to a port as first-config-first-match.
<H3C> system-view
[H3C] acl order first-config-first-match
[H3C] display acl order
the current order is first-config-first-match
The time range configuration tasks include configuring periodic time ranges and configuring absolute time ranges. A periodic time range recurs periodically on the day or days of the week, while an absolute time range takes effect only in a period of time (the start time to the end time) and does not recur.
&  Note:
An absolute time range on an H3C S5600 switch can be within the range 1970/1/1 00:00 to 2100/12/31 23:59.
Table 1-3 Configure a time range
To do...
Use the command...
Remarks
Enter system view
Create a time range
time-range time-name { start-time to end-time days-of-the-week [ from start-time start-date ] [ to end-time end-date ] | from start-time start-date [ to end-time end-date ] | to end-time end-date }
Required
Display a specified time range or all time ranges
display time-range { all | time-name }
Optional
This command can be executed in any view.
Note that:
If only a periodic time section is defined in a time range, the time range is active only when the system time within the defined periodic time section. If multiple periodic time sections are defined in a time range, the time range is active only when the system time is within one of the periodic time sections.
If only an absolute time section is defined in a time range, the time range is active only when the system time within the defined absolute time section. If multiple absolute time sections are defined in a time range, the time range is active only when the system time is within one of the absolute time sections.
If both a periodic time section and an absolute time section are defined in a time range, the time range is active only when the periodic time range and the absolute time range are both matched. Assume that a time range contains an absolute time section ranging from 00:00 January 1, 2004 to 23:59 December 31, 2004, and a periodic time section ranging from 12:00 to 14:00 on every Wednesday. This time range is active only when the system time within the range from 12:00 to 14:00 on every Wednesday in 2004.
If the start time is not specified, the time section starts on the earliest date available in the system and ends on the specified end date. If the end date is not specified, the time section starts from the specified start date to 2100/12/31 23:59.
# Define a periodic time range that will be active from 8:00 to 18:00 on Monday through Friday.
<H3C> system-view
[H3C] time-range test 8:00 to 18:00 working-day
[H3C] display time-range test
Current time is 13:27:32 4/16/2005 Saturday
Time-range : test ( Inactive )
 08:00 to 18:00 working-day
# Define an absolute time range from 15:00 1/28/2000 to 15:00 1/28/2004.
<H3C> system-view
[H3C] time-range test from 15:00 1/28/2000 to 15:00 1/28/2004
Current time is 13:30:32 4/16/2005 Saturday
 From 15:00 Jan/28/2000 to 15:00 Jan/28/2004
A basic ACL defines rules only based on the Layer 3 source IP addresses to analyze and process data packets.
The value range for basic ACL numbers is 2,000 to 2,999.
Before configuring an ACL rule containing time range arguments, you need to define the corresponding time ranges. For the configuration of time ranges, refer to Configuring Time Ranges
The value of the source IP address information in the rule has been defined.
Table 1-4 Define a basic ACL rule
To do...
Use the command...
Remarks
Enter system view
Create or enter basic ACL view
acl { number acl-number | name acl-name [ advanced | basic | link | user ] } [ match-order { config | auto } ]
Required
By the default, the match order is config.
Define an rule
rule [ rule-id ] { permit | deny } [ source { source-addr wildcard | any } | fragment | time-range time-name ]*
Required
Display ACL information
display acl config { all | acl-number | acl-name }
Optional
In the case that you specify the rule ID when defining a rule:
l           If the ACL is created with the config keyword specified and the rule identified by the rule-id argument exists, the settings specified in the rule command overwrite the counterparts of the existing rule (other settings of the rule remain unchanged). If the ACL is created with the auto keyword specified, the rules of the ACL cannot be edited. In this case, the system prompts errors when you execute the rule command.
l           If the rule corresponding to the specified rule ID does not exist, you will create and define a new rule.
l           The content of a modified or newly created rule must not be identical with the content of any existing rule; otherwise the rule modification or creation will be failed, and the system will prompt that the rule already exists.
If you do not specify a rule ID, you will create and define a new rule, and the system will assign an ID for the rule automatically.
# Configure ACL 2000 to deny packets with source IP address being 1.1.1.1.
<H3C> system-view
[H3C] acl number 2000
[H3C-acl-basic-2000] rule deny source 1.1.1.1 0
[H3C-acl-basic-2000] display acl config 2000
Basic ACL  2000, 1 rule
 rule 0 deny source 1.1.1.1 0 (0 times matched)
Advanced ACLs define classification rules according to the source and destination IP addresses of packets, the type of protocol over IP, and protocol-specific features such as TCP/UDP source and destination ports, ICMP protocol type, code, and so on.
The value range for advanced ACL numbers is 3,000 to 3,999. Note that ACL 3998 and ACL 3999 cannot be configured because they are reserved for the cluster management.
Advanced ACLs support analysis and processing of three packet priority levels: type of service (ToS) priority, IP priority and differentiated services codepoint Priority (DSCP).
Using advanced ACLs, you can define classification rules that are more accurate, abundant, and flexible than those defined with basic ACLs.
Before configuring an ACL rule containing time range arguments, you need to define the corresponding time ranges. For the configuration of time ranges, refer to Configuring Time Ranges.
The values of source and destination IP addresses, the type of the protocols over IP, and protocol-specific features in the rule have been defined.
Table 1-5 Define an advanced ACL rule
To do...
Use the command...
Remarks
Enter system view
Create or enter advanced ACL view
Required
Define an rule
rule [ rule-id ] { permit | deny } rule-string
Required
Optional
rule-string: rule information, which can be combination of the parameters described in Table 1-6. You must configure the protocol argument in the rule information before you can configure other arguments.
Table 1-6 Rule information
Parameter
Function
Remarks
protocol
Protocol type
Type of protocol over IP
When expressed in numerals, the value range is 1 to 255.
When expressed with a name, the value can be GRE, ICMP, IGMP, IP, IPinIP, OSPF, TCP, and UDP.
source { sour-addr sour-wildcard | any }
Source address information
Specifies the source address information in the rule
sour-addr sour-wildcard is used to specify the source address of the packet, expressed in dotted decimal notation.
any represents all source addresses.
destination { dest-addr dest-wildcard | any }
Destination address information
Specifies the destination address information in the rule
dest-addr dest-wildcard is used to specify the destination address of the packet, expressed in dotted decimal notation.
any represents all destination address.
precedence precedence
Packet precedence
IP priority
Value range: 0 to 7
tos tos
Packet precedence
ToS priority
Value range: 0 to 15
dscp dscp
Packet precedence
DSCP priority
Value range: 0 to 63
fragment
Fragment information
Specifies that the ACL rule is effective for non-initial fragment packets
Time range information
Specifies the time range in which the ACL rule is active
&  Note:
sour-wildcard and dest-wildcard represent the wildcard masks of the destination subnet masks, provided in dotted decimal notation. For example, if you want to specify the subnet mask as 255.255.0.0, you need to input 0.0.255.255. The wildcard mask can be 0, representing the host address.
To define DSCP priority, you can directly input a value ranging from 0 to 63, or input a keyword listed in Table 1-7.
Table 1-7 Description of DSCP values
Keyword
DSCP value in decimal
DSCP value in binary
ef
46
101110
af11
10
001010
af12
12
001100
af13
14
001110
af21
18
010010
af22
20
010100
af23
22
010110
af31
26
011010
af32
28
011100
af33
30
011110
af41
34
100010
af42
36
100100
af43
38
100110
cs1
8
001000
cs2
16
010000
cs3
24
011000
cs4
32
100000
cs5
40
101000
cs6
48
110000
cs7
56
111000
be (default)
0
000000
To define the IP precedence, you can directly input a value ranging from 0 to 7, or input a keyword listed in the following table.
Table 1-8 Description of IP precedence value
Keyword
IP Precedence value in decimal
IP Precedence value in binary
routine
0
000
priority
1
001
immediate
2
010
flash
3
011
flash-override
4
100
critical
5
101
internet
6
110
network
7
111
To define the ToS value, you can directly input a value ranging from 0 to 15, or input a keyword listed in the following table.
Table 1-9 Description of ToS value
Keyword
ToS value in decimal
ToS value in binary
normal
0
0000
min-monetary-cost
1
0001
max-reliability
2
0010
max-throughput
4
0100
min-delay
8
1000
If the protocol type is TCP or UDP, you can also define the following information:
Table 1-10 TCP/UDP-specific rule information
Parameter
Function
Remarks
source-port operator port1 [ port2 ]
Source port(s)
Defines the source port information of UDP/TCP packets
The value of operator can be lt (less than), gt (greater than), eq (equal to), neq (not equal to) or range (within the range of). Only the “range” operator requires two port numbers as the operands, and other operators require only one port number as the operand.
port1, port2: TCP/UDP port number(s), expressed with name(s) or numerals; when expressed with numerals, the value range is 0 to 65,535
destination-port operator port1 [ port2 ]
Destination port(s)
Defines the destination port information of UDP/TCP packets
established
“TCP connection established” flag
Specifies that the rule is applicable only to the first SYN segment for establishing a TCP connection
TCP-specific argument
&  Note:
If the protocol type is ICMP, you can also define the following information:
Table 1-11 ICMP-specific rule information
Parameter
Function
Remarks
icmp-type icmp-type icmp-code
Type and message code information of ICMP packets
Specifies the type and message code information of ICMP packets in the ACL rule
icmp-type: ICMP message type, ranging 0 to 255
icmp-code: ICMP message code, ranging 0 to 255
If the protocol type is ICMP, you can also directly input the ICMP message name after the icmp-type argument. The following table describes some common ICMP messages.
Table 1-12 ICMP messages
Name
ICMP TYPE
ICMP CODE
echo
Type=8
Code=0
echo-reply
Type=0
Code=0
fragmentneed-DFset
Type=3
Code=4
host-redirect
Type=5
Code=1
host-tos-redirect
Type=5
Code=3
host-unreachable
Type=3
Code=1
information-reply
Type=16
Code=0
information-request
Type=15
Code=0
net-redirect
Type=5
Code=0
net-tos-redirect
Type=5
Code=2
net-unreachable
Type=3
Code=0
parameter-problem
Type=12
Code=0
port-unreachable
Type=3
Code=3
protocol-unreachable
Type=3
Code=2
reassembly-timeout
Type=11
Code=1
source-quench
Type=4
Code=0
source-route-failed
Type=3
Code=5
timestamp-reply
Type=14
Code=0
timestamp-request
Type=13
Code=0
ttl-exceeded
Type=11
Code=0
l           If the ACL is created with the config keyword specified and the rule identified by the rule-id argument exists, the settings specified in the rule command overwrite the counterparts of the existing rule (other settings of the rule remain unchanged). If the ACL is created the auto keyword specified, the rules of the ACL cannot be edited. In this case, the system will prompt errors when you execute the rule command.
# Configure ACL 3000 to permit TCP packets to pass. The port number of the packets is 80, the source network segment of packets is 129.9.0.0, and the destination network segment is 202.38.160.0
<H3C> system-view
[H3C] acl number 3000
[H3C-acl-adv-3000] rule permit tcp source 129.9.0.0 0.0.255.255 destination 202.38.160.0 0.0.0.255 destination-port eq 80
[H3C-acl-adv-3000] display acl config 3000
Advanced ACL  3000, 1 rule
rule 0 permit tcp source 129.9.0.0 0.0.255.255 destination 202.38.160.0 0.0.0.255 destination-port eq www (0 times matched)
Layer 2 ACLs define rules based on the Layer 2 information such as the source and destination MAC address information, VLAN priority and Layer 2 protocol to process packets.
The value range for Layer 2 ACL numbers is 4,000 to 4,999.
The values of the source and destination MAC addresses, VLAN priority and Layer 2 protocol in the rule have been defined.
Table 1-13 Create a Layer 2 ACL rule
To do...
Use the command...
Remarks
Enter system view
Create or enter layer 2 ACL view
Required
By default, the match order is config.
Define an ACL rule
rule [ rule-id ] { permit | deny } [ rule-string ]
Required
If you do not specify the rule-string argument, the switch will choose ingress any egress any by default.
Optional
rule-string: rule information, which can be combination of the parameters described in Table 1-14.
Table 1-14 Rule information
Parameter
Function
Remarks
protocol-type
Protocol type
Defines the protocol type over Ethernet frames
protocol-type: the value can be ip, arp, rarp, ipx, nbx, pppoe-control, or pppoe-data. When the protocol type is arp, the rules cannot match the ARP packets with the destination MAC address as the MAC address of Layer 3 interface or with the destination MAC address being all Fs.
format-type
Link layer encapsulation type
Defines the link layer encapsulation type in the rule
format-type: the value can be 802.3/802.2, 802.3, ether_ii, or snap.
ingress { { source-vlan-id | source-mac-addr [ source-mac-mask ] }* | any }
Source MAC address information
Specifies the source MAC address range in the ACL rule
source-mac-addr: source MAC address, in the format of H-H-H
source-mac-mask: source MAC address mask, in the format of H-H-H, defaults to ffff-ffff-ffff.
source-vlan-id: source VLAN ID, in the range of 1 to 4,094
any represents all packets received from all ports.
egress { dest-mac-addr [ dest-mac-mask ] | any }
Destination MAC address information
Specifies the destination MAC address range in the ACL rule
dest-mac-addr: destination MAC address, in the format of H-H-H
dest-mac-mask: destination MAC address mask, in the format of H-H-H, defaults to ffff-ffff-ffff.
any represents all packets forwarded by all ports.
cos cos
Priority
Defines the 802.1p priority of the ACL rule
cos: ranges from 0 to 7
Specifies the time range in which the rule is active
time-name: name of a time range in which the ACL rule is active; a string of 1 to 32 characters
&  Note:
source-mac-mask and dest-mac-mask represent the MAC address masks. For example, if you want to specify a MAC address range from 0011-0011-0000 to 0011-0011-00ff, you can specify ffff-ffff-ff00 as the MAC address mask. The mask can be all Fs, representing the host address.
To define the CoS, you can directly input a value ranging from 0 to 7, or input a keyword listed in the following table.
Table 1-15 Description of CoS value
Keyword
CoS value in decimal
CoS value in binary
best-effort
0
000
background
1
001
spare
2
010
excellent-effort
3
011
controlled-load
4
100
video
5
101
voice
6
110
network-management
7
111
# Configure ACL 4000 to deny packets whose 802.1p priority is 3, source MAC address is 000d-88f5-97ed, and destination MAC address is 011-4301-991e.
<H3C> system-view
[H3C] acl number 4000
[H3C-acl-ethernetframe-4000] rule deny cos 3 source 000d-88f5-97ed ffff-ffff-ffff dest 0011-4301-991e ffff-ffff-ffff
[H3C-acl-ethernetframe-4000] display acl config 4000
Ethernet frame ACL  4000, 1 rule
rule 0 deny cos excellent-effort source 000d-88f5-97ed ffff-ffff-ffff dest 0011-4301-991e ffff-ffff-ffff (0 times matched)
Using a byte, which is specified through its offset from the packet header, in the packet as the starting point, user-defined ACLs perform logical AND operations on packets and compare the extracted string with the user-defined string to find the matching packets for processing.
User-defined ACL numbers range from 5,000 to 5,999.
To configure a time range-based ACL rule, you need first to define the corresponding time range, as described in Configuring Time Ranges.
Table 1-16 Define a user-defined ACL rule
To do...
Use the command...
Remarks
Enter system view
Create or enter user-defined ACL view
Required
Define an ACL rule
rule [ rule-id ] { permit | deny } { rule-string rule-mask offset } &<1-8> [ time-range time-name ]
Required
Optional
When you specify the rule ID by using the rule command, note that:
&  Note:
Only LPUs other than Type A support the user-defined ACL.
# Configure ACL 5001 to deny all TCP packets.
<H3C> system-view
[H3C] time-range t1 18:00 to 23:00 sat
[H3C] acl number 5001
[H3C-acl-user-5001] rule 25 deny 06 ff 27 time-range t1
[H3C-acl-user-5001] display acl config 5001
User defined ACL  5001, 1 rule
 rule 25 deny 06 ff 27 time-range t1 (0 times matched) (Inactive)
By applying ACLs on ports, you can filter certain packets.
You need to define an ACL before applying it on a port. For operations to define ACLs, refer to Defining Basic ACLs, Defining Advanced ACLs, Defining Layer 2 ACLs, and Defining User-Defined ACLs.
Table 1-17 Apply an ACL on a port
To do...
Use the command...
Remarks
Enter system view
Enter Ethernet port view
Enter QoS view
qos
Apply an ACL on the port
packet-filter { inbound | outbound } acl-rule [ system-index ] [ not-care-for-interface ]
Required
This command is supported by Type A LPUs.
packet-filter inbound acl-rule [ system-index ]
Required
This command is supported by LPUs other than Type A.
Display information about ACLs applied to a port or all ports.
display acl running-packet-filter { all | interface interface-type interface-number }
Optional
acl-rule: Applied ACL, which can be a combination of different types of ACL rules. Table 1-18 and Table 1-20 describe the ACL combinations on Type A LPUs and the corresponding parameter description. Table 1-19 and Table 1-20 describe the ACL combinations on LPUs other than Type A and the corresponding parameter description.
Table 1-18 Combined application of ACLs on service Type A LPUs
Combination mode
Form of acl-rule
Apply all rules in an IP type ACL
ip-group { acl-number | acl-name }
Apply one rule in an IP type ACL
ip-group { acl-number | acl-name } rule rule-id
Apply all rules in a link type ACL
link-group { acl-number | acl-name }
Apply one rule in a link type ACL
link-group { acl-number | acl-name } rule rule-id
Table 1-19 Combined application of ACLs on LPUs other than Type A.
Combination mode
Form of acl-rule
Apply all rules in a user-defined ACL
user-group { acl-number | acl-name }
Apply one rule in a user-defined ACL
user-group { acl-number | acl-name } rule rule-id
Apply one rule in an IP type ACL and one rule in a link type ACL simultaneously
ip-group { acl-number | acl-name } rule rule-id link-group { acl-number | acl-name } rule rule-id
Table 1-20 Parameters description of ACL combinations
Parameter
Remarks
Basic and advanced ACL.
acl-number: ACL number of basic and advanced ACL, ranging from 2,000 to 3,999.
acl-name: ACL name, up to 32 characters long, beginning with an English letter (a to z or A to Z) without space and quotation mark, case insensitive.
Layer 2 ACL
acl-number: ACL number of the Layer 2 ACL, ranging from 4,000 to 4,999.
User-defined ACL
acl-number: ACL number of the user-defined ACL, ranging from 5,000 to 5,999.
rule-id
ACL rule number, ranging from 0 to 127. If this argument is not specified, all rules in the specified ACL will be applied.
# Apply ACL 2100 on Ethernet 2/0/1 to filter inbound packets.
<H3C> system-view
[H3C] interface Ethernet 2/0/1
[H3C-Ethernet2/0/1] qos
[H3C-qoss-Ethernet2/0/1] packet-filter inbound ip-group 2100
To do…
Use the command…
Remarks
Display a time range or time ranges
These commands can be executed in any view.
Display the configured ACL rule(s)
Display the statistics information about the configured ACL rules
display acl config statistics
Display the remain ACL resource of a specified slot
display acl remaining entry slot slot-number
Display the ACL mode of traffic flows
display acl mode
Display information about the ACL rules applied to port(s)
Display the matching order of the applied ACL rules
display acl order
I. Network requirements
Through basic ACL configuration, packets from the host with the source IP address of 10.1.1.1 (the host is connected to the switch through Ethernet 2/0/1) are to be filtered within the time range from 8:00 to 18:00 everyday.
II. Network diagram
Figure 1-1 Network diagram for basic ACL configuration
III. Configuration procedure
&  Note:
Only the commands related to the ACL configuration are listed below.
1)         Define the time range
# Define a periodic time range that takes effect from 8:00 to 18:00 everyday.
<H3C> system-view
[H3C] time-range test 8:00 to 18:00 daily
2)         Define an ACL for packets with the source IP address of 10.1.1.1.
# Create ACL 2000 and enter ACL 2000 view.
# Define an access rule to deny packets with their source IP addresses being 10.1.1.1.
[H3C-acl-basic-2000] rule 1 deny source 10.1.1.1 0 time-range test
[H3C-acl-basic-2000] quit
3)         Apply the ACL on the port
# Apply ACL 2000 on the port.
[H3C] interface Ethernet2/0/1
[H3C-qoss-Ethernet2/0/1] packet-filter inbound ip-group 2000
Different departments of an enterprise are interconnected on the intranet through the ports of a switch. The IP address of the wage query server is 192.168.1.2. Devices of the R&D department are connected to Ethernet2/0/1 of the switch. Apply an ACL to deny requests sourced from the R&D department and destined for the wage server during the working hours (8:00 to 18:00) of the working days.
II. Network diagram
Figure 1-2 Network diagram for advanced ACL configuration
&  Note:
# Define a periodic time range that takes effect from 8:00 to 18:00 every working day.
<H3C> system-view
2)         Define an ACL for filtering requests destined for the wage server.
# Create ACL 3000 and enter ACL 3000 view.
# Define an ACL rule for requests destined for the wage server.
[H3C-acl-adv-3000] rule 1 deny ip destination 192.168.1.2 0 time-range test
[H3C-acl-adv-3000] quit
3)         Apply the ACL on a port.
# Apply ACL 3000 on Ethernet 2/0/1.
[H3C-qoss-Ethernet2/0/1] packet-filter inbound ip-group 3000
Through Layer 2 ACL configuration, packets with the source MAC address of 0011-0011-0101 and destination MAC address of 0011-0011-0303 are to be filtered within the time range from 8:00 to 18:00 everyday. Apply this ACL on Ethernet 2/0/1.
II. Network diagram
Figure 1-3 Network diagram for Layer 2 ACL configuration
&  Note:
# Define the periodic time range from 8:00 to 18:00 everyday.
<H3C> system-view
2)         Define an ACL rule for packets with the source MAC address of 0011-0011-0101 and destination MAC address of 0011-0011-0303.
# Create ACL 4000 and enter ACL 4000 view.
# Define an ACL rule to deny packets with the source MAC address of 0011-0011-0101 and destination MAC address of 0011-0011-0303, specifying the time range named test for the ACL rule.
[H3C-acl-link-4000] rule 1 deny ingress 0011-0011-0101 ffff-ffff-ffff egress 0011-0011-0303 ffff-ffff-ffff time-range test
[H3C-acl-link-4000] quit
# Apply ACL 4000 on the Ethernet 2/0/1.
[H3C-qoss-Ethernet2/0/1] packet-filter inbound link-group 4000
Create a user-defined ACL to deny all TCP packets within the time range from 8:00 to 18:00 everyday. Apply the user-defined ACL on Ethernet 2/0/1.
II. Network diagram
Figure 1-4 Network diagram for user-defined ACL configuration
&  Note:
1)         Define the time range.
2)         Create an ACL rule to filter TCP packets.
# Create ACL 5000 and enter ACL 5000 view.
[H3C] acl number 5000
# Define a rule for TCP packets.
[H3C-acl-user-5000] rule 1 deny 06 ff 27 time-range test
# Apply ACL 5000 on port Ethernet 2/0/1.
[H3C-qosb-Ethernet2/0/1] packet-filter inbound user-group 5000
