H3C S7500 Series Operation Manual(Release 3100 Series)-(V1.04)
HomeSupportSwitchesS7500 SeriesConfigure & DeployConfiguration GuidesH3C S7500 Series Operation Manual(Release 3100 Series)-(V1.04)
01-CLI Configuration
01-CLI Configuration 119 KB
Chapter 1  CLI Overview
Go to these sections for information you are interested in:
l           Introduction to the CLI
l           Command Level/Command View
l           CLI Features
1.1  Introduction to the CLI
H3C series Ethernet switches provide command line interfaces (CLI) and commands for you to configure and manage the Ethernet switches. The CLI features the following:
l           Commands are grouped by levels. This prevents unauthorized users from operating the switch with relevant commands.
l           Users can gain online help at any time by entering the question mark ?.
l           Commonly used diagnosing utilities (such as Tracert and Ping) are available.
l           Debugging information of various kinds is available.
l           The command history is available. You can recall and execute a history command easily.
l           You can execute a command by only entering part of the command in the CLI, as long as the keywords you input uniquely identify the corresponding ones.
1.2  Command Level/Command View
To prevent unauthorized accesses, commands are grouped by command levels.
Commands fall into four levels: visit, monitor, system, and manage:
l           Visit level: Commands at this level are mainly used to diagnose network and change the language mode of user interface, and cannot be saved in configuration files. For example, the ping, tracert, and language-mode commands are at this level.
l           Monitor level: Commands at this level are mainly used to maintain the system and diagnose service problems, and cannot be saved to configuration files. For example, the display and debugging commands are at this level.
l           System level: Commands at this level are mainly used to configure services. Commands concerning routing and network layers are at this level. You can utilize network services by using these commands.
l           Manage level: Commands at this level are associated with the basic operation of the system, and the system supporting modules. These commands provide supports to services. Commands concerning file system, FTP/TFTP/XModem downloading, user management, and level setting are at this level.
Users logging into a switch also fall into four levels, each of which corresponding to one of the above command levels. Users at a specific level can only use the commands of the same level and those of the lower levels.
1.2.1  Switching Between User Levels
A user can switch the user level from one to another by executing a related command after logging into a switch. The administrator can also set user level switching passwords as required.
I. Setting a user level switching password
Follow these steps to set a user level switching password:
To do...
Use the command...
Remarks
Enter system view
Set a password for switching from a lower user level to the user level identified by the level argument
super password [ level level ] { simple | cipher } password
Optional
A password is necessary only when a user switches from a lower user level to a higher user level.
II. Switching to another user level
Follow these steps to switch to another user level
To do...
Use the command...
Remarks
Switch to the user level identified by the level argument
super [ level ]
Required
Execute this command in user view.
If a password for switching to the user level identified by the level argument is set and you want to switch to a lower user level, you will remain at the lower user level unless you provide the correct password after executing this command.
&  Note:
l      If the user level is not specified when user level switching and the switching password are set, the user level is 3 by default.
l      For security purposes, the password a user enters when switching to a higher user level is not displayed. A user will remain at the original user level if the user has tried three times to enter the correct password but fails to do this.
1.2.2  Configuring the Level of a Specific Command in a Specific View
You can configure the level of a specific command in a specific view. Commands fall into four command levels: visit, monitor, system, and manage, which are identified as 0, 1, 2, and 3 respectively. The administrator can change the command level to which a command belongs.
Follow these steps to configure the level of a specific command in a specific view:
To do...
Use the command...
Remarks
Enter system view
Configure the level of a specific command in a specific view
command-privilege level level view view command
Required
Use this command with cautions to prevent inconvenience on maintenance and operation.
1.2.3  CLI Views
CLI views are designed for different configuration tasks. They are interrelated. You will enter user view once you log into a switch successfully, where you can perform operations such as displaying operation status and statistical information. And by executing the system-view command, you can enter system view, where you can enter other views by executing the corresponding commands.
The following CLI views are provided:
l           User view
l           System view
l           M-Ethernet interface view
l           Ethernet port view
l           Null interface view
l           Tunnel interface view
l           VLAN view
l           VLAN interface view
l           Loopback interface view
l           Local user view
l           User interface view
l           FTP client view
l           SFTP client view
l           Cluster view
l           DHCP address pool view
l           MST region view
l           RRPP domain view
l           MSDP region view
l           Port-isolate-group view
l           HWping view
l           Public key view
l           Public key code view
l           PIM view
l           RIP view
l           OSPF view
l           OSPF area view
l           BGP view
l           BGP IPv4 family multicast view
l           IS-IS view
l           ES-IS view
l           Routing policy view
l           Basic ACL view
l           Advanced ACL view
l           Layer 2 ACL view
l           User-defined ACL view
l           Traffic-group view
l           QoS view
l           QinQ view
l           RADIUS scheme view
l           HWTACACS scheme view
l           ISP domain view
Table 1-1 lists information about CLI views (including the operations you can perform in these views, how to enter these views, and so on).
Table 1-1 CLI views
View
Available operation
Prompt example
Enter method
Quit method
Display operation status and statistical information
<H3C>
Enter user view once logging into the switch.
Execute the quit command in user view to log out of the switch.
Configure system parameters
[H3C]
Execute the system-view command in user view.
Execute the quit or return command to return to user view.
Configure M-Ethernet interface parameters
[H3C-M-Ethernet0/0/0]
Manage Ethernet port view.
Execute the interface m-ethernet 0/0/0 command in system view.
Execute the quit command to return to system view.
Execute the return command to return to user view.
Ethernet port view
Configure Ethernet port parameters
[H3C-Ethernet3/0/1]
100 M Ethernet port view
Execute the interface ethernet 3/0/1 command in system view.
[H3C-GigabitEthernet4/0/1]
Gigabit Ethernet port view
Execute the interface gigabitethernet 4/0/1 command in system view.
Null interface view
Configure null interface parameters
[H3C-NULL0]
Execute the interface null 0 command in system view.
Configure tunnel interface parameters
[H3C-Tunnel0]
Execute the interface tunnel 0 command in system view.
VLAN view
Configure VLAN parameters
[H3C-vlan1]
Execute the vlan 1 command in system view.
VLAN interface view
Configure IP interface parameters for VLANs
[H3C-Vlan-interface1]
Execute the interface vlan-interface 1 command in system view.
Configure Loopback interface parameters
[H3C-LoopBack0]
Execute the interface loopback 0 command in system view
Local user view
Configure local user parameters
[H3C-luser-user1]
Execute the local-user user1 command in system view.
User interface view
Configure user interface parameters
[H3C-ui0]
Execute the user-interface 0 command in system view.
FTP client view
Configure FTP client parameters
[ftp]
Execute the ftp command in user view.
Execute the quit command to return to user view.
SFTP client view
Configure SFTP client parameters
sftp-client>
Execute the sftp 10.1.1.1 command in system view.
Cluster view
Configure cluster parameters
[H3C-cluster]
Execute the cluster command in system view.
Configure DHCP address pool parameters
[H3C-dhcp-pool-1]
Execute the dhcp server ip-pool 1 command in system view.
MST region view
Configure MST region parameters
[H3C-mst-region]
Execute the stp region-configuration command in system view.
RRPP domain view
Configure RRPP domain parameters
[H3C- rrpp-domain1]
Execute the rrpp domain 1 command in system view.
MSDP domain view
Configure MSDP domain parameters
[H3C-msdp]
Execute the msdp command in system view.
Configure port-isolate-group parameters
[H3C-port-isolate-group1]
Execute the port-isolate group 1 command in system view.
HWping view
Configure HWping test group parameters
[H3C-hwping-administrator-test]
Execute the hwping administrator test command in system view
Public key view
Configure RSA public keys for secure shell (SSH) users
[H3C-rsa-public-key]
Execute the rsa peer-public-key h3c003 command in system view.
Execute the peer-public-key end command to return to system view.
Edit RSA public keys of SSH users
[H3C-rsa-key-code]
Execute the public-key-code begin command in public key view.
Execute the public-key-code end command to return to public key view.
PIM view
Configure PIM parameters
[H3C-pim]
Execute the pim command in system view.
Use the multicast routing-enable command in system view to enable multicast routing if multicast routing is disabled.
RIP view
Configure RIP parameters
[H3C-rip]
Execute the rip command in system view
OSPF view
Configure OSPF protocol parameters
[H3C-ospf-1]
Execute the ospf command in system view
OSPF area view
Configure OSPF area parameters
[H3C-ospf-1-area-0.0.0.1]
Execute the area 1 command in OSPF view
Execute the quit command to return to OSPF view.
BGP view
Configure parameters for the border gateway protocol (BGP) protocol
[H3C-bgp]
Execute the bgp 100 command in system view
Configure parameters for BGP IPv4 family multicast
[H3C-bgp-af-mul]
Execute the ipv4-family multicast command in BGP view.
IS-IS view
Configure IS-IS parameters
[H3C-isis]
Execute the isis command in system view.
ES-IS view
Configure parameters for the ES-IS protocol
[H3C-esis]
Execute the esis command in system view.
Routing policy view
Configure routing policies
[H3C-route-policy]
Execute the route-policy policy1 permit node 10 command in system view
Basic ACL view
Define rules for a basic ACL (ACLs with their IDs ranging from 2000 to 2999 are basic ACLs.)
[H3C-acl- basic-2000]
Execute the acl number 2000 command in system view.
Advanced ACL view
Define rules for an advanced ACL (ACLs with their IDs ranging from 3000 to 3999 are advanced ACLs.)
[H3C-acl- adv-3000]
Execute the acl number 3000 command in system view.
Layer 2 ACL view
Define the sub-rules of Layer 2 ACLs, which is numbered from 4,000 to 4,999.
[H3C-acl-link-4000]
Execute the acl number 4000 command in system view.
Define the sub-rules of user-defined ACLs, which are in the range of 5000 to 5999
[H3C-acl-user-5000]
Execute the acl number 5000 command in system view
Traffic-group view
Configure traffic group parameters
[H3C-traffic-group-1]
Execute the traffic-accounting traffic-group 1 command in system view.
QoS view
Configure QoS parameters
[H3C-qoss-GigabitEthernet4/0/1]
or:
[H3C-qosb-GigabitEthernet4/0/1]
Execute the qos command in Ethernet port view.
QinQ view
Create QinQ instances and configure parameters for QinQ
[H3C-GigabitEthernet4/0/1-vid-1000]
Execute the vlan-vpn vid 1000 command in Ethernet port view.
RADIUS scheme view
Configure RADIUS parameters
[H3C-radius-1]
Execute the radius scheme 1 command in system view.
Configure parameters for the HWTACACS protocol
[H3C-hwtacacs-1]
Execute the hwtacacs scheme 1 command in system view.
ISP domain view
Configure parameters for an ISP domain
[H3C-isp-aabbcc.net]
Execute the domain aabbcc.net command in system view.
1.3  CLI Features
1.3.1  Online Help
CLI provides two types of online help: complete online help and partial online help. They assist you with your configuration.
I. Complete online help
1)         Enter a ? character in any view on your terminal to display all the commands available in the view and their brief descriptions. The following takes user view as an example.
<H3C> ?
User view commands:
  backup         Backup current configuration
  boot           Set boot option
  cd             Change current directory
  clock          Specify the system clock
  cluster        Run cluster command
  copy           Copy from one file to another
  debugging      Enable system debugging functions
  delete         Delete a file
  dir            List files on a file system
  display        Display current system information
  <omitted>
2)         Enter a command, a space, and a ? character (instead of a keyword available in this position of the command) on your terminal to display all the available keywords and their brief descriptions. The following takes the clock command as an example.
<H3C> clock ?
  datetime     Specify the time and date
  summer-time  Configure summer time
  timezone     Configure time zone
3)         Enter a command, a space, and a ? character (instead of an argument available in this position of the command) on your terminal to display all the available arguments and their brief descriptions. The following takes the interface vlan command as an example.
[H3C] interface vlan-interface ?
  <1-4094>  VLAN interface number
[H3C] interface vlan-interface 1 ?
  <cr>
The string <cr> means no argument is available in the position occupied by the ? character. You can execute the command without providing any other information.
II. Partial online help
1)         Enter a string followed directly by a ? character on your terminal to display all the commands beginning with the string. For example:
<H3C> pi?
ping
2)         Enter a command, a space, and a string followed by a ? character on your terminal to display all the keywords that belong to the command and begin with the string (if available). For example:
<H3C> display ver?
  version
3)         Enter the first several characters of a keyword in a command and then press <Tab>, the complete keyword will be displayed on the terminal screen if the input characters uniquely identify a keyword; all the keyword that match the input characters will be displayed on the terminal screen if the input characters match more than one keywords.
You can use the language-mode command to translate the help into Chinese.
1.3.2  Terminal Display
CLI provides the following display features:
l           The online help and prompt information can be displayed in either Chinese or English.
l           Display suspending, that is, the displaying of output information can be paused when the screen is full and you can then perform the three operations listed in Table 1-2 as needed.
Table 1-2 Displaying-related operations
Operation
Function
Press <Ctrl + C>
Suspend displaying and executing.
Press the space key
Scroll the output information up by one page.
Press <Enter>
Scroll the output information up by one line.
1.3.3  Command History
CLI can store the latest executed commands as history commands so that users can recall and execute them again. By default, CLI can store 10 history commands for each user. Table 1-3 lists history command-related operations.
Table 1-3 Access history commands
To do...
Command or key
Remarks
Display history commands
Execute the display history-command command
This command displays valid history commands.
Recall the previous history command
Press the up-arrow key or <Ctrl + P>
This operation recalls the previous history command (if available).
Recall the next history command
Press the down-arrow key or <Ctrl + N>
This operation recalls the next history command (if available).
&  Note:
l      As the Up and Down keys have different meanings in HyperTerminal running on Windows 9x, these two keys can be used to recall history commands only in terminals running Windows 3.x or Telnet running in Windows 3.x. You can press <Ctrl + P> or <Ctrl + N> in Windows 9x to achieve the same purpose.
l      If you enter and execute the same command successively for multiple times, only the first command is saved in the CLI as a history command.
1.3.4  Error Messages
If the command you enter passes the syntax check, it will be successfully executed; otherwise, an error message will appear. Table 1-4 lists the common error messages.
Table 1-4 Common error messages
Error message
Remarks
Unrecognized command
The command does not exist.
The keyword does not exist.
The parameter type is wrong.
The parameter value is out of range.
Incomplete command
The command entered is incomplete.
Too many parameters
You have entered too many parameters.
Ambiguous command
The parameters entered are ambiguous.
Wrong parameter found at '^' position.
The parameter labeled by '^' is unrecognizable.
1.3.5  Command Edit
The CLI provides basic command edit functions and supports multi-line editing. The maximum number of characters a command can contain is 256. Table 1-5 lists the CLI edit operations.
Table 1-5 Edit operations
Press…
To…
A common key
Insert the character the key represents at the cursor and move the cursor one character to the right if the edit buffer is not full.
The Backspace key
Delete the character on the left of the cursor and move the cursor one character to the left.
The left arrow key or <Ctrl + B>
Move the cursor one character to the left.
The right arrow key or <Ctrl + F>
Move the cursor one character to the right.
The up arrow key or <Ctrl + P>
The down arrow key or <Ctrl + N>
Access history commands.
The Tab key
Utilize the partial online help. That is, when you enter an incomplete keyword and the Tab key, if the input keyword uniquely identifies an existing keyword, the system completes the keyword and displays the command on the next line. If the input keyword matches more than one keyword, all the keywords are displayed on the terminal screen, with each keyword on a line. If the input keyword matches no keyword, the system displays your original input on a new line without any change.
