H3C S7500 Series Operation Manual(Release 3100 Series)-(V1.04)
HomeSupportSwitchesS7500 SeriesConfigure & DeployConfiguration GuidesH3C S7500 Series Operation Manual(Release 3100 Series)-(V1.04)
12-Port Binding Configuration
12-Port Binding Configuration 49 KB
Chapter 1  Port Binding Configuration
When configuring port binding, go to these sections for information you are interested in:
l           Port Binding Overview
l           Configuring Port Binding
l           Displaying Port Binding Configuration
l           Port Binding Configuration Example
1.1  Port Binding Overview
Port binding enables the network administrator to bind the MAC address and IP address of a user to a specific port. After the binding, the switch forwards only the packets received on the port whose MAC address and IP address are identical with the bound MAC address and IP address. This improves network security and enhances security monitoring.
1.2  Configuring Port Binding
Follow these steps to configure port binding:
To do…
Use the command…
Remarks
Enter system view
Bind the legal MAC addresses and IP addresses to the specified port
am user-bind { mac-addr mac-address | ip-addr ip-address }* interface-list
Optional
Enter port view
Bind the legal MAC addresses and IP addresses to the current port
Optional
&  Note:
You can bind up to 100 MAC addresses and IP addresses to one port.
1.3  Displaying Port Binding Configuration
To do…
Use the command…
Remarks
Display the information about port binding
display am user-bind [ interface interface-type interface-number | mac-addr | ip-addr ]
Available in any view.
1.4  Port Binding Configuration Example
I. Network requirements
In order to prevent illegal use of the IP address of PC 1, you may bind the MAC address and IP address of PC 1 to port Ethernet 2/0/1 on Switch A.
II. Network diagram
Figure 1-1 Network diagram for port binding configuration
III. Configuration procedure
# Enter system view.
<H3C> system-view
# Enter Ethernet 2/0/1 port view.
[H3C] interface Ethernet2/0/1
# Bind the MAC address and the IP address of PC 1 to Ethernet 2/0/1.
[H3C-Ethernet2/0/1] am user-bind mac-addr 0001-0002-0003 ip-addr 10.12.1.1
