H3C S7500 Series Operation Manual(Release 3100 Series)-(V1.04)
HomeSupportSwitchesS7500 SeriesConfigure & DeployConfiguration GuidesH3C S7500 Series Operation Manual(Release 3100 Series)-(V1.04)
11-Port Isolation Configuration
11-Port Isolation Configuration 72 KB
Chapter 1  Port Isolation Configuration
When configuring port isolation, go to these sections for information you are interested in:
l           Port Isolation Overview
l           Configuring Port Isolation
l           Displaying Port Isolation Configuration
l           Port Isolation Configuration Example
1.1  Port Isolation Overview
1.1.1  Introduction to Port Isolation
Through the port isolation feature, you can add the ports to be controlled into an isolation group to isolate Layer 2 and Layer 3 data between ports in the isolation group. Thus, it can improve network security and deliver flexible networking solutions.
Currently, you can configure 64 isolation groups on a switch. The number of Ethernet ports an isolation group can accommodate is not limited.
&  Note:
l      An isolation group only isolates the member ports in it.
l      The port isolation function is independent of VLAN configuration.
1.1.2  Port Isolation and Link Aggregation
l           When a port in an aggregation group joins an isolation group, the other ports in the aggregation group join the isolation group automatically.
l           When a port in an aggregation group leaves an isolation group, the other ports in the aggregation group leave the isolation group automatically.
1.2  Configuring Port Isolation
Follow these steps to configure port isolation:
To do…
Use the command…
Remarks
Enter system view
Create an isolation group
port-isolate group group-id
Required
Specify a description string for the current isolation group
Optional
Add the specified port into the isolation group
port interface-list
Optional
By default, an isolation group contains no Ethernet port.
Enter Ethernet port view
Add the current Ethernet port to the specified isolation group
port isolate group group-id
Optional
&  Note:
l      An Ethernet port belongs to only one port isolation group. If you add an Ethernet port to different isolation groups, the port belongs to only the latest isolation group to which the port is added.
l      Currently, cards of Type A (LS81FT48A, LS81FM24A, LS81FS24A, LS81GB8UA, and LS81GT8UA) do not support the Port Isolation feature.
1.3  Displaying Port Isolation Configuration
To do…
Use the command…
Remarks
Display the configuration of the created isolation group
display isolate port [ group group-id ]
Available in any view.
1.4  Port Isolation Configuration Example
I. Network requirements
l           PC 2, PC 3 and PC 4 connect to the switch ports Ethernet 2/0/2, Ethernet 2/0/3, and Ethernet 2/0/4 respectively.
l           It is desired that PC 2, PC 3 and PC 4 are isolated from each other so that they cannot communicate with each other.
II. Network diagram
Figure 1-1 Network diagram for port isolation configuration
III. Configuration procedure
# Create isolation group 1.
<H3C> system-view
[H3C] port-isolate group 1
# Add Ethernet 2/0/2, Ethernet 2/0/3, and Ethernet 2/0/4 to the isolation group 1.
[H3C-port-isolate-group1] port Ethernet2/0/2 to Ethernet2/0/4
# Display information about the ports in the isolation group.
[H3C-port-isolate-group1] display isolate port
 Isolate group ID: 1
 Isolated port(s) in group 1:
             Ethernet2/0/2  Ethernet2/0/3  Ethernet2/0/4
