H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Examples All-in-One-R9141-6W100
HomeSupportRoutersSR6602-I[IE] SeriesConfigure & DeployConfiguration ExamplesH3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
67-PBR Configuration Examples
67-PBR Configuration Examples 102.76 KB
H3C Routers
Policy-Based Routing Configuration Examples
Copyright © 2024 New H3C Technologies Co., Ltd. All rights reserved
Introduction
The following information provides examples for configuring policy-based routing (PBR).
PBR uses user-defined policies to route packets. A policy can specify parameters for packets that match specific criteria such as source address, destination address, IP precedence, and protocol type.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of PBR.
When configuring the action of redirecting packets to a next hop, you cannot redirect IPv4 packets to an IPv6 address or redirect IPv6 packets to an IPv4 address.
Example: Configuring PBR
As shown in Figure 1, by default, Router A forwards all packets received on Ten-GigabitEthernet 0/0/6 destined for the server to next hop 10.4.1.2 according to routing table lookup.
Configure PBR on Router A to forward packets destined for the server as follows:
·     Forward packets received on Ten-GigabitEthernet 0/0/6 matching source IP address 10.2.1.1 to next hop 10.5.1.2.
·     Forward HTTP packets received on Ten-GigabitEthernet 0/0/6 to the next hop 10.3.1.2.
Figure 1 Network diagram
Analysis
·     To forward two types of packets to different next hops, configure two ACLs. Use one ACL to match packets sourced from 10.2.1.1 received on Ten-GigabitEthernet 0/0/6. Use the other ACL to match HTTP packets received on Ten-GigabitEthernet 0/0/6. In addition, create two PBR policy nodes to redirect the matching packets separately.
·     Each node is identified by a node number. A smaller node number has a higher priority. To preferentially forward HTTP packets received on Ten-GigabitEthernet 0/0/6 sourced from 10.2.1.1 to next hop 10.5.1.2, configure a smaller number for the policy node (specify number 0 for this node, and number 1 for the other node).
Software version used
This configuration example was created and verified on R9141P16 of the SR6602-I device.
# Assign an IP address to Ten-GigabitEthernet 0/0/6.
[RouterA] interface ten-gigabitethernet 0/0/6
[RouterA-Ten-GigabitEthernet0/0/6] ip address 10.1.2.1 255.255.255.0
[RouterA-Ten-GigabitEthernet0/0/6] quit
# Assign IP addresses to other interfaces in Figure 1 in the same way. (Details not shown.)
# Configure three static routes with default next hop 10.4.1.2, and make sure all the paths are reachable.
[RouterA] ip route-static 192.168.1.0 24 10.3.1.2
[RouterA] ip route-static 192.168.1.0 24 10.4.1.2 preference 40
[RouterA] ip route-static 192.168.1.0 24 10.5.1.2
# Configure ACL 3005 to match packets sourced from 10.2.1.1.
[RouterA] acl number 3005
[RouterA-acl-adv-3005] rule 0 permit ip source 10.2.1.1 0
[RouterA-acl-adv-3005] quit
# Configure ACL 3006 to match HTTP packets.
[RouterA] acl number 3006
[RouterA-acl-adv-3006] rule 0 permit tcp destination-port eq www
[RouterA-acl-adv-3006] quit
# Configure Node 0 for policy pbr1 to forward packets matching ACL 3005 to next hop 10.5.1.2.
[RouterA] policy-based-route pbr1 permit node 0
[RouterA-pbr-pbr1-0] if-match acl 3005
[RouterA-pbr-pbr1-0] apply next-hop 10.5.1.2
[RouterA-pbr-pbr1-0] quit
# Configure Node 1 for policy pbr1 to forward packets matching ACL 3006 to next hop 10.3.1.2.
[RouterA] policy-based-route pbr1 permit node 1
[RouterA-pbr-pbr1-1] if-match acl 3006
[RouterA-pbr-pbr1-1] apply next-hop 10.3.1.2
[RouterA-pbr-pbr1-1] quit
# Configure interface PBR by applying policy pbr1 to Ten-GigabitEthernet 0/0/6 on Router A.
[RouterA-Ten-GigabitEthernet0/0/6] ip policy-based-route pbr1
# Execute the display ip policy-based-route command to verify that PBR is successfully configured.
[RouterA] display ip policy-based-route policy pbr1
Policy name: pbr1
  node 0 permit:
    if-match acl 3005
  node 1 permit:
    if-match acl 3006
# Use the tracert command to identify following paths (enable sending of ICMP time exceeded messages on intermediate devices, and enable sending of ICMP destination unreachable messages on the destination device):
·     Verify that non-HTTP packets sourced from 10.1.1.1 are forwarded to next hop 10.4.1.2.
<Router> tracert -a 10.1.1.1 192.168.1.1
traceroute to 192.168.1.1 (192.168.1.1) from 10.1.1.1, 30 hops at most, 40 bytes
 each packet, press CTRL_C to break
 1  10.1.2.1 (10.1.2.1)  2.178 ms  1.364 ms  1.058 ms
 2  10.4.1.2 (10.4.1.2)  1.548 ms  1.248 ms  1.112 ms
 3  192.168.1.1 (192.168.1.1)  1.594 ms  1.321 ms  1.093 ms
·     Verify that packets sourced from 10.2.1.1 are forwarded to next hop 10.5.1.2.
<Router> tracert -a 10.2.1.1 192.168.1.1
traceroute to 192.168.1.1 (192.168.1.1) from 10.2.1.1, 30 hops at most, 40 bytes
 1  10.1.2.1 (10.1.2.1)  1.721 ms  1.226 ms  1.050 ms
 2  10.5.1.2 (10.5.1.2)  4.494 ms  1.385 ms  1.170 ms
 3  192.168.1.1 (192.168.1.1)  1.448 ms  1.304 ms  1.093 ms
Configuration files
 if-match acl 3005
 if-match acl 3006
interface Ten-GigabitEthernet0/0/6
port link-mode route
interface Ten-GigabitEthernet0/0/7
 ip address 10.3.1.1 255.255.255.0
interface Ten-GigabitEthernet0/0/8
 ip address 10.4.1.1 255.255.255.0
interface Ten-GigabitEthernet0/0/9
 ip address 10.5.1.1 255.255.255.0
acl number 3005
acl number 3006
Example: Configuring IPv6 PBR
As shown in Figure 2, by default, Router A forwards all packets received on Ten-GigabitEthernet 0/0/6 destined for the server to next hop 2004:: 2 according to routing table lookup.
Configure IPv6 PBR on Router A to forward packets destined for the server as follows:
·     Forward packets received on Ten-GigabitEthernet 0/0/6 matching source IPv6 address 2002::1 to next hop 2005::2.
·     Forward HTTP packets received on Ten-GigabitEthernet 0/0/6 to the next hop 2003::2.
Figure 2 Network diagram
Analysis
·     To forward two types of packets to different next hops, configure two ACLs. Use one ACL to match packets sourced from 2002::1 received on Ten-GigabitEthernet 0/0/6. Use the other ACL to match HTTP packets received on Ten-GigabitEthernet 0/0/6. In addition, create two IPv6 PBR policy nodes to redirect the matching packets separately.
·     Each node is identified by a node number. A smaller node number has a higher priority. To preferentially forward HTTP packets received on Ten-GigabitEthernet 0/0/6 sourced from 2002::1 to next hop 2005::2, configure a smaller number for the policy node (specify number 0 for this node, and number 1 for the other node).
Procedures
# Assign an IPv6 address to interface Ten-GigabitEthernet 0/0/6.
[RouterA-Ten-GigabitEthernet0/0/6] ipv6 address 2007::1 64
# Assign IPv6 addresses to other interfaces in Figure 2 in the same way. (Details not shown.)
# Configure three IPv6 static routes with default next hop 2004::2/64, and make sure all the paths are reachable.
[RouterA] ipv6 route-static 3001::1 64 2003::2
[RouterA] ipv6 route-static 3001::1 64 2004::2 preference 40
[RouterA] ipv6 route-static 3001::1 64 2005::2
# Configure IPv6 ACL 3005 to match packets sourced from 2002::1.
[RouterA] acl ipv6 number 3005
[RouterA-acl6-adv-3005] rule 0 permit ipv6 source 2002::1/128
[RouterA-acl6-adv-3005] quit
# Configure IPv6 ACL 3006 to match HTTP packets received on Ten-GigabitEthernet 0/0/6.
[RouterA] acl ipv6 number 3006
[RouterA-acl6-adv-3006] rule 0 permit tcp destination-port eq www
[RouterA-acl6-adv-3006] quit
# Configure Node 0 for policy pbr1 to forward packets matching IPv6 ACL 3005 to next hop 2005::2.
[RouterA] ipv6 policy-based-route pbr1 permit node 0
[RouterA-pbr6-pbr1-0] if-match acl 3005
[RouterA-pbr6-pbr1-0] apply next-hop 2005::2
[RouterA-pbr6-pbr1-0] quit
# Configure Node 1 for policy pbr1 to forward packets matching IPv6 ACL 3006 to next hop 2003::2.
[RouterA] ipv6 policy-based-route pbr1 permit node 1
[RouterA-pbr6-pbr1-1] if-match acl 3006
[RouterA-pbr6-pbr1-1] apply next-hop 2003::2
[RouterA-pbr6-pbr1-1] quit
# Configure IPv6 interface PBR by applying policy pbr1 to Ten-GigabitEthernet 0/0/6 on Router A.
[RouterA-Ten-GigabitEthernet0/0/6] ipv6 policy-based-route pbr1
# Execute the display ipv6 policy-based-route command to verify that IPv6 PBR is successfully configured.
[RouterA] display ipv6 policy-based-route policy pbr1
Policy name: pbr1
  node 0 permit:
    if-match acl 3005
  node 1 permit:
    if-match acl 3006
# Verify that Router A forwards received packets sourced from 2002::1 as follows:
·     Forwards packets to IPv6 address 2005::2 when this IPv6 address is reachable.
·     Forwards packets to next hop 2004::2 according to routing table lookup when IPv6 address 2005::2 is unreachable.
# Verify that Router A forwards received HTTP packets as follows:
·     Forwards packets to IPv6 address 2003::2 when this IPv6 address is reachable.
·     Forwards packets to next hop 2004::2 according to routing table lookup when IPv6 address 2003::2 is unreachable.
Configuration files
 if-match acl 3005
 if-match acl 3006
 ipv6 address 2007::1/64
 ipv6 address 2003::1 64
 ipv6 address 2004::1 64
 ipv6 address 2005::1 64
 ipv6 route-static 3001:: 64 2003::2
 ipv6 route-static 3001:: 64 2004::2 preference 40
 ipv6 route-static 3001:: 64 2005::2
Related documentation
·     Layer 3IP Routing Configuration Guide in H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Guides (V9)
·     Layer 3IP Routing Command Reference in H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Command References (V9)
