H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Examples All-in-One-R9141-6W100
HomeSupportRoutersSR6602-I[IE] SeriesConfigure & DeployConfiguration ExamplesH3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
57-Load Sharing NAT Server Configuration Examples
H3C Routers
Introduction
This document provides load sharing NAT server configuration examples.
This document applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
This document assumes that you have basic knowledge of NAT.
Example: Configuring load sharing NAT server
As shown in Figure 1, the internal network address is 10.110.0.0/22. The company has three public IP addresses 61.16.0.1 to 61.16.0.3. Internal users use IP addresses 10.110.0.0 to 10.110.2.255. Three FTP servers in the intranet use IP addresses 10.110.3.1 to 10.110.3.3 to provide FTP services.
Configure the network to meet the following requirements:
·     Internal users use public IP addresses 61.16.0.2 and 61.16.0.3 to access the Internet.
·     External and internal hosts use IP address 61.16.0.1 to access the FTP servers in the intranet.
·     Three FTP servers implement load sharing but cannot initiate connections to the external network.
Figure 1 Network diagram
Analysis
·     For internal users to access the Internet, configure an ACL to identify packets from subnets 10.110.0.0 to 10.110.2.255, and configure PAT to translate these private addresses to public addresses 61.16.0.2 and 61.16.0.3.
·     For three FTP servers to provide services at the same time, configure a NAT server group to implement load sharing.
·     For internal users to access FTP servers by using IP address 61.16.0.1, enable NAT hairpin on Ten-GigabitEthernet 0/0/6 of the device.
Software versions used
This configuration example was created and verified on R9141P16 of the SR6602-I device.
To enable NAT hairpin, make sure all of the interfaces configured in the nat server, nat outbound, and nat hairpin commands are on the same interface module.
Procedures
Configuring IP addresses for interfaces on the device
# Configure IP addresses for Ten-GigabitEthernet 0/0/6 and Ten-GigabitEthernet 0/0/7.
[Device] interface ten-gigabitethernet 0/0/6
[Device-Ten-GigabitEthernet0/0/6] ip address 10.110.0.1 255.255.252.0
[Device-Ten-GigabitEthernet0/0/6] quit
[Device] interface ten-gigabitethernet 0/0/7
[Device-Ten-GigabitEthernet0/0/7] ip address 61.16.0.1 255.255.255.0
[Device-Ten-GigabitEthernet0/0/7] quit
Configuring internal users to access the external network
# Configure address group 0, and add public IP addresses 61.16.0.2 and 61.16.0.3 to the group.
[Device] nat address-group 0
[Device-nat-address-group-0] address 61.16.0.2 61.16.0.3
[Device-nat-address-group-0] quit
# Configure ACL 2000 to identify packets from subnets 10.110.0.0 to 10.110.2.255.
[Device] acl number 2000
[Device-acl-ipv4-basic-2000] rule permit source 10.110.0.0 0.0.1.255
[Device-acl-ipv4-basic-2000] rule permit source 10.110.2.0 0.0.0.255
# Enable outbound dynamic PAT on Ten-GigabitEthernet 0/0/7 to translate the source IP addresses of the packets permitted by the ACL into the IP addresses in address group 0.
[Device-Ten-GigabitEthernet0/0/7] nat outbound 2000 address-group 0
Configuring FTP servers to provide FTP services
# Create NAT server group 0, and add members 10.110.3.1, 10.110.3.2, and 10.110.3.3 to the group.
[Device] nat server-group 0
[Device-server-group-0] inside ip 10.110.3.1 port 21
[Device-server-group-0] inside ip 10.110.3.2 port 21
[Device-server-group-0] inside ip 10.110.3.3 port 21
[Device-server-group-0] quit
# Associate NAT server group 0 with Ten-GigabitEthernet 0/0/7 so that servers in the server group can provide FTP services.
[Device-Ten-GigabitEthernet0/0/7] nat server protocol tcp global 61.16.0.1 ftp inside server-group 0
# Enable NAT hairpin on Ten-GigabitEthernet 0/0/6.
[Device-Ten-GigabitEthernet0/0/6] nat hairpin enable
# Display NAT sessions that are generated when PC 1 accesses the WWW server.
[Device] display nat session verbose
Slot 1:
Initiator:
  Source      IP/port: 10.110.1.10/1024
  Destination IP/port: 200.1.1.10/80
  DS-Lite tunnel peer: -
  VPN instance/VLAN ID/VLL ID: -/-/-
  Protocol: UDP(17)
  Inbound interface: Ten-GigabitEthernet0/0/6
Responder:
  Source      IP/port: 200.1.1.10/80
  Destination IP/port: 61.16.0.2/1025
  Protocol: UDP(17)
  Inbound interface: Ten-GigabitEthernet0/0/7
State: UDP_READY
Application: HTTP
Rule ID: -/-/-
Rule name:
Start time: 2014-07-08 13:30:47  TTL: 60s
Initiator->Responder:     21946552 packets 2414120720 bytes
Responder->Initiator:       650389 packets   71542790 bytes
Total sessions found: 1
# Display NAT sessions that are generated when two external users (61.16.0.10 and 61.16.0.11) access the FTP servers at the same time. The output shows that two NAT sessions are generated, and FTP server 1 and FTP server 2 provide FTP services for the two users respectively.
Slot 1:
Initiator:
  Source      IP/port: 61.16.0.11/1024
  Destination IP/port: 61.16.0.1/21
  Protocol: TCP(6)
Responder:
  Source      IP/port: 10.110.3.1/21
  Destination IP/port: 61.16.0.11/1024
  Protocol: TCP(6)
State: TCP_ESTABLISHED
Application: FTP
Rule ID: -/-/-
Rule name:
Start time: 2014-07-08 14:11:41  TTL: 3600s
Initiator->Responder:       598098 packets   65790780 bytes
Responder->Initiator:            0 packets          0 bytes
Initiator:
  Source      IP/port: 61.16.0.10/1024
  Protocol: TCP(6)
Responder:
  Source      IP/port: 10.110.3.2/21
  Destination IP/port: 61.16.0.10/1024
  Protocol: TCP(6)
Application: FTP
Rule ID: -/-/-
Rule name:
Start time: 2014-07-08 14:12:00  TTL: 3600s
Initiator->Responder:        74783 packets    8226130 bytes
Total sessions found: 2
# Display NAT sessions that are generated when PC 1 accesses the FTP servers by using IP address 61.16.0.1.
Slot 1:
Initiator:
  Protocol: TCP(6)
Responder:
  Protocol: TCP(6)
Application: FTP
Rule ID: -/-/-
Rule name:
Start time: 2014-07-08 14:24:15  TTL: 3600s
Initiator->Responder:       209716 packets   23068760 bytes
Configuration files
interface Ten-GigabitEthernet0/0/6
 port link-mode route
 nat hairpin enable
interface Ten-GigabitEthernet0/0/7
 nat server protocol tcp global 61.16.0.1 21 inside server-group 0
acl number 2000
 rule 0 permit source 10.110.0.0 0.0.1.255
 rule 5 permit source 10.110.2.0 0.0.0.255
nat address-group 0
nat server-group 0
Related documentation
·     NAT and IPv6 Transition Technologies Configuration Guide in H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Guides(V9)
·     NAT and IPv6 Transition Technologies Command Reference in H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Command References(V9)
