H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Examples All-in-One-R9141-6W100
HomeSupportRoutersSR6602-I[IE] SeriesConfigure & DeployConfiguration ExamplesH3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
61-Client-Initiated L2TP Tunnel Configuration Examples
H3C Routers
Introduction
The following information provides client-initiated L2TP tunnel configuration examples.
The following information applies to Comware 9-based router. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of L2TP.
Example: Configuring a client-initiated L2TP tunnel
As shown in Figure 1, Host accesses the corporate network through an L2TP tunnel. Configure the LNS to actively accept tunnel setup requests from Host and set up an L2TP tunnel.
Figure 1 Network diagram
Analysis
For a valid user to access normally and establish an L2TP tunnel in client-Initiated mode, perform the following tasks:
1.     Configure L2TP user-side authentication on the LNS.
2.     Create a PPP user and create a domain for the user.
3.     Initiate tunnel setup requests on Host by using the username configured on the device.
Software versions used
This configuration example was created and verified on R9141P16 of the SR6602-I device.
Procedures
Configuring the LNS
# Configure interface GigabitEthernet 1/0/1.
<LNS> system-view
[LNS] interface gigabitethernet 1/0/1
[LNS-GigabitEthernet1/0/1] ip address 1.1.1.1 24
[LNS-GigabitEthernet1/0/1] quit
# Create a PPP user with the username as user and password as hello.
[LNS] local-user user class network
[LNS-luser-network-user] password simple hello
[LNS-luser-network-user] service-type ppp
[LNS-luser-network-user] quit
# Create domain abc, and configure the domain to perform local authentication for users.
[LNS] domain abc
[LNS-isp-abc] authentication ppp local
[LNS-isp-abc] quit
# Enable L2TP.
[LNS] l2tp enable
# Create VT interface 1, and assign IP address 192.168.0.1/24 to the VT interface. Configure the PPP authentication method as CHAP on the VT interface, and specify the VT interface to allocate IP address 192.168.0.2 to the PPP user.
[LNS] interface virtual-template 1
[LNS-Virtual-Template1] ip address 192.168.0.1 24
[LNS-Virtual-Template1] ppp authentication-mode chap domain abc
[LNS-Virtual-Template1] remote address 192.168.0.2
[LNS-Virtual-Template1] quit
# Create L2TP group 1 in LNS mode, configure the local tunnel name as LNS, and specify VT interface 1 for receiving calls.
[LNS] l2tp-group 1 mode lns
[LNS-l2tp1] tunnel name LNS
[LNS-l2tp1] allow l2tp virtual-template 1
[LNS-l2tp1] undo tunnel authentication
[LNS-l2tp1] quit
Configuring Host
# Assign IP address 1.1.1.2 and gateway 1.1.1.1 to Host.
# Use Windows 7 as an example. Access Network and Sharing Center and click Set up a new connection or network.
Figure 2 Creating a network connection
# Select Connect to a workspace and click Next.
Figure 3 Selecting a connection option
# Select Use my Internet connection (VPN).
Figure 4 Selecting a connection method
# Set the Internet address, which is the address of the host-side interface on the LNS. Select the Don't connect now; just set it up so I can connect later option, and click Next.
Figure 5 Setting the LNS address
# In the diaglog box that opens, enter the username and password that have been configured on the device, and click Create.
Figure 6 Entering the username and password
# At this point, the connection is available. Click Close.
Figure 7 Connection established successfully
# Access the network connection page again, and you can see a new network connection named VPN Connection. Double-click it. The login window opens.
Figure 8 Newly generated connection
Figure 9 Login window
# Right-click the connection, and select Properties. The Properties dialog box opens.
Figure 10 VPN connection properties
# Click the Security tab. Select Optional encryption (connect even if no encryption) for data encryption and click OK.
Figure 11 Configuring security properties
# On the login window, enter username [email protected] and password hello configured on the router, and click Connect.
Figure 12 Connecting an L2TP tunnel
# Verify that the connection succeeded.
Figure 13 Connection succeeded
# Verify that an L2TP tunnel has been established on the LNS.
[LNS] display l2tp tunnel
LocalTID RemoteTID State        Sessions RemoteAddress   RemotePort RemoteName
11556    1         Established  1        1.1.1.2         1701       Host
Configuration files
interface Virtual-Template1
 ip address 192.168.0.1 255.255.255.0
 port link-mode route
 ip address 1.1.1.1 255.255.255.0
domain abc
local-user aa class network
 password cipher $c$3$Rprc/RW4jluoNccTiRfV0t1OxEN0MegX
 service-type ppp
 tunnel name LNS
l2tp enable
Related documentation
·     Layer 2—WAN Access Configuration Guide in H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Guides (V9)
·     Layer 2—WAN Access Command Reference in H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Command References (V9)
