- H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Examples All-in-One-R9141-6W100
- 01-Local 802.1X Authentication Configuration Examples
- 02-RADIUS-Based 802.1X Authentication Configuration Examples
- 03-AAA Configuration Examples
- 04-ACL Configuration Examples
- 05-MPLS over ADVPN Configuration Examples
- 06-ARP Attack Protection Configuration Examples
- 07-BFD Configuration Examples
- 08-Basic BGP Configuration Examples
- 09-BGP Route Attribute-Based Route Selection Configuration Examples
- 10-CPOS Interface Configuration Examples
- 11-EAA Monitor Policy Configuration Examples
- 12-GRE with OSPF Configuration Examples
- 13-HoVPN Configuration Examples
- 14-IGMP Snooping Configuration Examples
- 15-IGMP Configuration Examples
- 16-IPsec Configuration Examples
- 17-IPsec Digital Certificate Authentication Configuration Examples
- 18-IPv6 IS-IS Configuration Examples
- 19-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 20-IPv6 over IPv4 Manual Tunnel with OSPFv3 Configuration Examples
- 21-IS-IS Configuration Examples
- 22-Combined ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 23-L2TP over IPsec Configuration Examples
- 24-Multi-Instance L2TP Configuration Examples
- 25-L2TP Multidomain Access Configuration Examples
- 26-MPLS L3VPN Configuration Examples
- 27-MPLS OAM Configuration Examples
- 28-MPLS TE Configuration Examples
- 29-Basic MPLS Configuration Examples
- 30-NAT DNS Mapping Configuration Examples
- 31-NetStream Configuration Examples
- 32-NQA Configuration Examples
- 33-NTP Configuration Examples
- 34-OSPFv3 Configuration Examples
- 35-OSPF Configuration Examples
- 36-OSPF Multi-Process Configuration Examples
- 37-OSPF Multi-Instance Configuration Examples
- 38-Portal Configuration Examples
- 39-POS Interace Configuration Examples
- 40-PPP Configuration Examples
- 41-QinQ Configuration Examples
- 42-RBAC Configuration Examples
- 43-RMON Configuration Examples
- 44-IPv4 NetStream Sampling Configuration Examples
- 45-SNMP Configuration Examples
- 46-SRv6 Configuration Examples
- 47-SSH Configuration Examples
- 48-Tcl Commands Configuration Examples
- 49-VLAN Configuration Examples
- 50-VRRP Configuration Examples
- 51-VXLAN over IPsec Configuration Examples
- 52-Cloudnet VPN Configuration Examples
- 53-Ethernet Link Aggregation Configuration Examples
- 54-Ethernet OAM Configuration Examples
- 55-Outbound Bidirectional NAT Configuration Examples
- 56-NAT Hairpin in C-S Mode Configuration Examples
- 57-Load Sharing NAT Server Configuration Examples
- 58-BIDIR-PIM Configuration Examples
- 59-Control Plane-Based QoS Policy Configuration Examples
- 60-Scheduling a Task Configuration Examples
- 61-Client-Initiated L2TP Tunnel Configuration Examples
- 62-LAC-Auto-Initiated L2TP Tunnel Configuration Examples
- 63-Authorized ARP Configuration Examples
- 64-GTS Configuration Examples
- 65-Traffic Policing Configuration Examples
- 66-Traffic Accounting Configuration Examples
- 67-PBR Configuration Examples
- 68-TFTP Client Software Upgrade Configuration Examples
- 69-FTP Client Software Upgrade Configuration Examples
- 70-FTP Server Software Upgrade Configuration Examples
- 71-Routing Policy Configuration Examples
- 72-Software Upgrade from the BootWare Menu Configuration Examples
- 73-Mirroring Configuration Examples
| 30-NAT DNS Mapping Configuration Examples | 69.85 KB |
H3C Routers |
NAT DNS Mapping |
Introduction
The following information provides examples for configuring NAT DNS mapping on routers.
This document applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the router.
This document assumes that you have basic knowledge of NAT.
Example: Configuring NAT DNS mapping
As shown in Figure 1, the internal Web server at 10.0.0.2/24 provides Web services for external users. The private network has three public addresses 172.31.123.201 to 172.31.123.203. The DNS server at 172.31.123.181 is on the public network.
Configure NAT so that both internal and external hosts can access the internal server by using their domain names.
Analysis
· Configure a NAT server mapping to map the private IP address and port of the internal server to a public address and port so that external users can access the internal server.
· Configure NAT DNS mapping and ALG so that the public IP address of the internal server in the payload of the DNS response packet can be translated to the private IP address.
Software versions used
This configuration example was created and verified on R9141P16 of the SR6602-I device.
Procedures
# Specify IP addresses for Ten-GigabitEthernet 0/0/6 and Ten-GigabitEthernet 0/0/7.
<Router> system-view
[Router] interface ten-gigabitethernet 0/0/7
[Router-Ten-GigabitEthernet0/0/7] ip address 172.31.123.201 24
[Router-Ten-GigabitEthernet0/0/7] quit
[Router] interface ten-gigabitethernet 0/0/6
[Router-Ten-GigabitEthernet0/0/6] ip address 10.0.0.1 24
[Router-Ten-GigabitEthernet0/0/6] quit
# Enable NAT ALG for DNS.
[Router] nat alg dns
# Configure NAT Server to allow external hosts to access the internal Web server by using address 172.31.123.202.
[Router-Ten-GigabitEthernet0/0/7] nat server protocol tcp global 172.31.123.202 inside 10.0.0.2 http
[Router-Ten-GigabitEthernet0/0/7] nat outbound
# Configure a NAT DNS mapping entry by mapping domain name www.server.com of the Web server to 172.31.123.202.
[Router] nat dns-map domain www.server.com protocol tcp ip 172.31.123.202 port http
[Router] quit
# Display all NAT configuration and statistics.
<Router> display nat all
NAT internal server information:
Totally 1 internal servers.
Interface: Ten-GigabitEthernet0/0/7
Protocol: 6(TCP)
Global IP/port: 172.31.123.202/80
Local IP/port: 10.0.0.2/80
NAT counting : 0
Config status : Active
NAT DNS mapping information:
Totally 1 NAT DNS mappings.
Domain name: www.server.com
Global IP : 172.31.123.202
Global port: 80
Protocol : TCP(6)
Config status: Active
NAT logging:
Log enable : Disabled
Flow-begin : Disabled
Flow-end : Disabled
Flow-active : Disabled
Port-block-assign : Disabled
Port-block-withdraw : Disabled
Alarm : Disabled
NO-PAT IP usage : Disabled
NAT mapping behavior:
Mapping mode: Address and Port-Dependent
ACL : ---
NAT ALG:
DNS : Enabled
FTP : Enabled
H323 : Enabled
ICMP-ERROR : Enabled
ILS : Enabled
MGCP : Enabled
NBT : Enabled
PPTP : Enabled
RTSP : Enabled
RSH : Enabled
SCCP : Enabled
SCTP : Enabled
SIP : Enabled
SQLNET : Enabled
TFTP : Enabled
XDMCP : Enabled
Static NAT load balancing: Disabled
NAT link-switch recreate-session: Disabled
NAT configuration-for-new-connection: Disabled
NAT global-policy compatible-previous-version rule-type ipv4-snat-and-dnat trans
late-before-secp : Disabled
Configuration files
interface Ten-GigabitEthernet0/0/6
port link-mode route
ip address 10.0.0.1 255.255.255.0
interface Ten-GigabitEthernet0/0/7
ip address 172.31.123.201 255.255.255.0
nat outbound
nat server protocol tcp global 172.31.123.202 80 inside 10.0.0.2 80
nat alg dns
nat dns-map domain www.server.com protocol tcp ip 172.31.123.202 port 80
Related documentation
· NAT and IPv6 Transition Technologies Configuration Guide in H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Guides(V9)
· NAT and IPv6 Transition Technologies Command Reference in H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Command References(V9)
