- H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Examples All-in-One-R9141-6W100
- 01-Local 802.1X Authentication Configuration Examples
- 02-RADIUS-Based 802.1X Authentication Configuration Examples
- 03-AAA Configuration Examples
- 04-ACL Configuration Examples
- 05-MPLS over ADVPN Configuration Examples
- 06-ARP Attack Protection Configuration Examples
- 07-BFD Configuration Examples
- 08-Basic BGP Configuration Examples
- 09-BGP Route Attribute-Based Route Selection Configuration Examples
- 10-CPOS Interface Configuration Examples
- 11-EAA Monitor Policy Configuration Examples
- 12-GRE with OSPF Configuration Examples
- 13-HoVPN Configuration Examples
- 14-IGMP Snooping Configuration Examples
- 15-IGMP Configuration Examples
- 16-IPsec Configuration Examples
- 17-IPsec Digital Certificate Authentication Configuration Examples
- 18-IPv6 IS-IS Configuration Examples
- 19-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 20-IPv6 over IPv4 Manual Tunnel with OSPFv3 Configuration Examples
- 21-IS-IS Configuration Examples
- 22-Combined ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 23-L2TP over IPsec Configuration Examples
- 24-Multi-Instance L2TP Configuration Examples
- 25-L2TP Multidomain Access Configuration Examples
- 26-MPLS L3VPN Configuration Examples
- 27-MPLS OAM Configuration Examples
- 28-MPLS TE Configuration Examples
- 29-Basic MPLS Configuration Examples
- 30-NAT DNS Mapping Configuration Examples
- 31-NetStream Configuration Examples
- 32-NQA Configuration Examples
- 33-NTP Configuration Examples
- 34-OSPFv3 Configuration Examples
- 35-OSPF Configuration Examples
- 36-OSPF Multi-Process Configuration Examples
- 37-OSPF Multi-Instance Configuration Examples
- 38-Portal Configuration Examples
- 39-POS Interace Configuration Examples
- 40-PPP Configuration Examples
- 41-QinQ Configuration Examples
- 42-RBAC Configuration Examples
- 43-RMON Configuration Examples
- 44-IPv4 NetStream Sampling Configuration Examples
- 45-SNMP Configuration Examples
- 46-SRv6 Configuration Examples
- 47-SSH Configuration Examples
- 48-Tcl Commands Configuration Examples
- 49-VLAN Configuration Examples
- 50-VRRP Configuration Examples
- 51-VXLAN over IPsec Configuration Examples
- 52-Cloudnet VPN Configuration Examples
- 53-Ethernet Link Aggregation Configuration Examples
- 54-Ethernet OAM Configuration Examples
- 55-Outbound Bidirectional NAT Configuration Examples
- 56-NAT Hairpin in C-S Mode Configuration Examples
- 57-Load Sharing NAT Server Configuration Examples
- 58-BIDIR-PIM Configuration Examples
- 59-Control Plane-Based QoS Policy Configuration Examples
- 60-Scheduling a Task Configuration Examples
- 61-Client-Initiated L2TP Tunnel Configuration Examples
- 62-LAC-Auto-Initiated L2TP Tunnel Configuration Examples
- 63-Authorized ARP Configuration Examples
- 64-GTS Configuration Examples
- 65-Traffic Policing Configuration Examples
- 66-Traffic Accounting Configuration Examples
- 67-PBR Configuration Examples
- 68-TFTP Client Software Upgrade Configuration Examples
- 69-FTP Client Software Upgrade Configuration Examples
- 70-FTP Server Software Upgrade Configuration Examples
- 71-Routing Policy Configuration Examples
- 72-Software Upgrade from the BootWare Menu Configuration Examples
- 73-Mirroring Configuration Examples
| 63-Authorized ARP Configuration Examples | 97.83 KB |
H3C Routers |
Authorized ARP |
Example: Configuring authorized ARP on a DHCP server
Example: Configuring authorized ARP on a DHCP relay agent
Introduction
The following information provides examples for configuring authorized ARP on routers.
This document applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the router.
This document assumes that you have basic knowledge of authorized ARP.
As shown in Figure 1, configure authorized ARP on Ten-GigabitEthernet 0/0/6 of the router (a DHCP server). Then, only hosts with IP addresses assigned by the router can access external networks through the router.
Software versions used
This configuration example was created and verified on R9141P16 of the SR6602-I device.
Procedures
Configuring the router
# Specify an IP address for Ten-GigabitEthernet 0/0/6.
<Router> system-view
[Router] interface ten-gigabitethernet 0/0/6
[Router-Ten-GigabitEthernet0/0/6] ip address 10.1.1.1 24
[Router-Ten-GigabitEthernet0/0/6] quit
# Enable DHCP.
[Router] dhcp enable
# Specify primary subnet 10.1.1.0/24 in DHCP address pool 1.
[Router] dhcp server ip-pool 1
[Router-dhcp-pool-1] network 10.1.1.0 mask 255.255.255.0
[Router-dhcp-pool-1] quit
# Enable authorized ARP.
[Router-Ten-GigabitEthernet0/0/6] arp authorized enable
Configuring the host
Configure the NIC of the host to obtain an IP address automatically.
# Verify that the NIC of the host obtains an IP address through DHCP.
C:\Windows\System32>ipconfig
Windows IP Configuration
Ethernet adapter ???? 3:
Connection-specific DNS Suffix :
Link-local IPv6 Address : fe80::d083:44cb:9d9b:71b7%21
IPv4 Address : 10.1.1.2
Subnet Mask : 255.255.255.0
Default Gateway : 10.1.1.1
# Display authorized ARP entry information on the router.
[Router] display arp all
Type: S-Static D-Dynamic M-Multiport I-Invalid
IP address MAC address VLAN Interface Aging Type
10.1.1.2 000f-e123-4568 N/A XGE0/0/6 18 D
The output shows that the router has recorded an authorized ARP entry.
# Disconnect the host from the switch and change the IP address of the host to a static IP address that resides on the same network segment as the router. Verify that the host and the router cannot communicate with each other after you reconnect the host to the switch.
C:\Windows\System32>ping 10.1.1.1
Pinging 10.1.1.1 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 10.1.1.1:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss)
Configuration files
dhcp enable
interface Ten-GigabitEthernet0/0/6
port link-mode route
As shown in Figure 2, configure authorized ARP on Ten-GigabitEthernet 0/0/7 of Router B (a DHCP relay agent) to ensure user validity.
Analysis
Configure recording of relay entries on the relay agent and authorized ARP so that only packets matching a relay entry can be forwarded by the relay agent. In this way, illegal hosts cannot access external networks through the relay agent.
Procedures
Configuring Router A
[RouterA] interface ten-gigabitethernet 0/0/6
[RouterA-Ten-GigabitEthernet0/0/6] ip address 10.1.1.1 24
[RouterA-Ten-GigabitEthernet0/0/6] quit
# Enable DHCP.
[RouterA] dhcp enable
# Specify primary subnet 10.10.1.0/24 in DHCP address pool 1.
[RouterA] dhcp server ip-pool 1
[RouterA-dhcp-pool-1] network 10.10.1.0 mask 255.255.255.0
[RouterA-dhcp-pool-1] gateway-list 10.10.1.1
[RouterA-dhcp-pool-1] quit
#Configure a static route.
[RouterA] ip route-static 10.10.1.0 24 10.1.1.2
Configuring Router B
# Enable DHCP.
<RouterB> system-view
[RouterB] dhcp enable
# Specify IP addresses for Ten-GigabitEthernet 0/0/6 and Ten-GigabitEthernet 0/0/7.
[RouterB] interface ten-gigabitethernet 0/0/6
[RouterB-Ten-GigabitEthernet0/0/6] ip address 10.1.1.2 24
[RouterB-Ten-GigabitEthernet0/0/6] quit
[RouterB] interface Ten-GigabitEthernet 0/0/7
[RouterB-Ten-GigabitEthernet0/0/7] ip address 10.10.1.1 24
# Enable the DHCP relay agent on Ten-GigabitEthernet 0/0/7.
[RouterB-Ten-GigabitEthernet0/0/7] dhcp select relay
# Specify the IP address of the DHCP server on the relay agent.
[RouterB-Ten-GigabitEthernet0/0/7] dhcp relay server-address 10.1.1.1
[RouterB-Ten-GigabitEthernet0/0/7] arp authorized enable
[RouterB-Ten-GigabitEthernet0/0/7] quit
# Enable the recording of relay entries on the relay agent.
[RouterB] dhcp relay client-information record
IPv4 Address : 10.10.1.2
Default Gateway : 10.10.1.1
# Display authorized ARP entry information on Router B.
[RouterB] display arp all
10.1.1.1 0cda-41c7-057e N/A XGE0/0/6 15 D
10.10.1.2 0066-61e2-f7f2 N/A XGE0/0/7 20 D
#Disconnect the host from Router B and change the IP address of the host to a static IP address that resides on the same network segment as Router B. Verify that the host and Router B cannot communicate with each other after you reconnect the host to Router B.
C:\Windows\System32> ping 10.10.1.1
Pinging 10.10.1.1 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 10.10.1.1:
Configuration files
· Router A:
dhcp enable
combo enable copper
· Router B:
dhcp enable
interface Ten-GigabitEthernet0/0/7
ip address 10.10.1.1 255.255.255.0
dhcp select relay
Related documentation
· Layer 3—IP Services Configuration Guide in H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Guides(V9)
· Layer 3—IP Services Command Reference in H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Command References(V9)
· Security Configuration Guide in H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Guides(V9)
· Security Command Reference in H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Command References(V9)
