H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Examples All-in-One-R9141-6W100
HomeSupportRoutersSR6602-I[IE] SeriesConfigure & DeployConfiguration ExamplesH3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
01-Local 802.1X Authentication Configuration Examples
H3C Routers
Introduction
The following information provides an example for configuring local 802.1X authentication on routers.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of AAA and 802.1X.
Example: Configuring local 802.1X authentication
As shown in Figure 1, configure the router to perform local 802.1X authentication for users connected to Ten-GigabitEthernet 0/0/6. Implement port-based access control on the port.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on R9141P16 of the SR6602-I router.
This example can be implemented on only devices installed with Layer 2 switching cards and having fixed Layer 2 interfaces.
Procedures
# Enable 802.1X globally.
<Router> system-view
[Router] dot1x
# Create VLAN-interface 1, and assign an IP address to it. The VLAN interface acts as the gateway for the host.
[Router] interface vlan-interface 1
[Router-Vlan-interface1] ip address 192.168.100.1 255.255.255.0
[Router-Vlan-interface1] quit
# Create a network access user named localuser and set the password to localpass in plaintext form.
[Router] local-user localuser class network
[Router-luser-network-localuser] password simple localpass
# Set the service type to lan-access.
[Router-luser-network-localuser] service-type lan-access
[Router-luser-network-localuser] quit
# Enable 802.1X on Ten-GigabitEthernet 0/0/6.
[Router] interface ten-gigabitethernet 0/0/6
[Router-Ten-GigabitEthernet0/0/6] dot1x
# Enable port-based access control on the port. By default, the port uses MAC-based access control.
[Router-Ten-GigabitEthernet0/0/6] dot1x port-method portbased
[Router-Ten-GigabitEthernet0/0/6] quit
# Use the display dot1x interface command to view 802.1X information on Ten-GigabitEthernet 0/0/6.
[Router] display dot1x interface ten-gigabitethernet 0/0/6
Global 802.1X parameters:
   802.1X authentication      : Enabled
   CHAP authentication        : Enabled
   Max-tx period              : 30 s
   Handshake period           : 15 s
   Quiet timer                : Disabled
       Quiet period           : 60 s
   Supp timeout               : 30 s
   Server timeout             : 100 s
   Reauth period              : 3600 s
   Max auth requests          : 2
   SmartOn supp timeout       : 30 s
   SmartOn retry counts       : 3
   EAD assistant function     : Disabled
       EAD timeout            : 30 min
   Domain delimiter           : @
 Online 802.1X wired users    : 0
 Online 802.1X wireless users : 0
 Ten-GigabitEthernet0/0/6  is link-up
   Handshake                  : Enabled
   Handshake reply            : Disabled
   Handshake security         : Disabled
   Unicast trigger            : Disabled
   Periodic reauth            : Disabled
   Port role                  : Authenticator
   Authorization mode         : Auto
   Port access control        : Port-based
   Multicast trigger          : Enabled
   Mandatory auth domain      : Not configured
   Guest VLAN                 : Not configured
   Auth-Fail VLAN             : Not configured
   Critical VLAN              : Not configured
  Critical voice VLAN         : Disabled
   Max online users           : 4294967295
   SmartOn                    : Disabled
   EAPOL packets: Tx 3, Rx 0
   Sent EAP Request/Identity packets : 3
        EAP Request/Challenge packets: 0
        EAP Success packets: 0
        EAP Failure packets: 0
        EAP Notification packets: 0
   Received EAPOL Start packets : 0
            EAPOL LogOff packets: 0
            EAP Response/Identity packets : 0
            EAP Response/Challenge packets: 0
            Error packets: 0
   Online 802.1X users: 0
# Execute the display dot1x sessions command to verify that you can come online after entering the correct username and password.
Configuration files
 dot1x
interface Vlan-interface1
interface Ten-GigabitEthernet0/0/6
 port link-mode bridge
 dot1x
 password cipher $c$3$YPkufRcxFR3KdpUCHFiNkns/YFPmbJkG/pQxBg==
Related documentation
·     User Access and Authentication Configuration Guide in H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Guides(V9)
·     User Access and Authentication Command Reference in H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Command References(V9)
