- H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Examples All-in-One-R9141-6W100
- 01-Local 802.1X Authentication Configuration Examples
- 02-RADIUS-Based 802.1X Authentication Configuration Examples
- 03-AAA Configuration Examples
- 04-ACL Configuration Examples
- 05-MPLS over ADVPN Configuration Examples
- 06-ARP Attack Protection Configuration Examples
- 07-BFD Configuration Examples
- 08-Basic BGP Configuration Examples
- 09-BGP Route Attribute-Based Route Selection Configuration Examples
- 10-CPOS Interface Configuration Examples
- 11-EAA Monitor Policy Configuration Examples
- 12-GRE with OSPF Configuration Examples
- 13-HoVPN Configuration Examples
- 14-IGMP Snooping Configuration Examples
- 15-IGMP Configuration Examples
- 16-IPsec Configuration Examples
- 17-IPsec Digital Certificate Authentication Configuration Examples
- 18-IPv6 IS-IS Configuration Examples
- 19-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 20-IPv6 over IPv4 Manual Tunnel with OSPFv3 Configuration Examples
- 21-IS-IS Configuration Examples
- 22-Combined ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 23-L2TP over IPsec Configuration Examples
- 24-Multi-Instance L2TP Configuration Examples
- 25-L2TP Multidomain Access Configuration Examples
- 26-MPLS L3VPN Configuration Examples
- 27-MPLS OAM Configuration Examples
- 28-MPLS TE Configuration Examples
- 29-Basic MPLS Configuration Examples
- 30-NAT DNS Mapping Configuration Examples
- 31-NetStream Configuration Examples
- 32-NQA Configuration Examples
- 33-NTP Configuration Examples
- 34-OSPFv3 Configuration Examples
- 35-OSPF Configuration Examples
- 36-OSPF Multi-Process Configuration Examples
- 37-OSPF Multi-Instance Configuration Examples
- 38-Portal Configuration Examples
- 39-POS Interace Configuration Examples
- 40-PPP Configuration Examples
- 41-QinQ Configuration Examples
- 42-RBAC Configuration Examples
- 43-RMON Configuration Examples
- 44-IPv4 NetStream Sampling Configuration Examples
- 45-SNMP Configuration Examples
- 46-SRv6 Configuration Examples
- 47-SSH Configuration Examples
- 48-Tcl Commands Configuration Examples
- 49-VLAN Configuration Examples
- 50-VRRP Configuration Examples
- 51-VXLAN over IPsec Configuration Examples
- 52-Cloudnet VPN Configuration Examples
- 53-Ethernet Link Aggregation Configuration Examples
- 54-Ethernet OAM Configuration Examples
- 55-Outbound Bidirectional NAT Configuration Examples
- 56-NAT Hairpin in C-S Mode Configuration Examples
- 57-Load Sharing NAT Server Configuration Examples
- 58-BIDIR-PIM Configuration Examples
- 59-Control Plane-Based QoS Policy Configuration Examples
- 60-Scheduling a Task Configuration Examples
- 61-Client-Initiated L2TP Tunnel Configuration Examples
- 62-LAC-Auto-Initiated L2TP Tunnel Configuration Examples
- 63-Authorized ARP Configuration Examples
- 64-GTS Configuration Examples
- 65-Traffic Policing Configuration Examples
- 66-Traffic Accounting Configuration Examples
- 67-PBR Configuration Examples
- 68-TFTP Client Software Upgrade Configuration Examples
- 69-FTP Client Software Upgrade Configuration Examples
- 70-FTP Server Software Upgrade Configuration Examples
- 71-Routing Policy Configuration Examples
- 72-Software Upgrade from the BootWare Menu Configuration Examples
- 73-Mirroring Configuration Examples
| 55-Outbound Bidirectional NAT Configuration Examples | 76.35 KB |
H3C Routers |
Outbound Bidirectional NAT |
Introduction
The following information provides examples for configuring outbound bidirectional NAT on routers.
This document applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the router.
This document assumes that you have basic knowledge of NAT.
Example: Configuring outbound bidirectional NAT
As shown in Figure 1, the router acts as the gateway through which the company accesses the public network. The private network where the Web server resides overlaps with the company private network 192.168.1.0/24. The company has two public IP addresses 202.38.1.2 and 202.38.1.3. Configure NAT to allow the host to access the external Web server by using the server's domain name.
Analysis
· Configure inbound dynamic NAT ALG to make sure the internal host can reach the Web server. NAT ALG can translate the Web server's IP address in the DNS reply payload to a dynamically assigned public address.
· Configure outbound dynamic NAT to translate the source IP address of packets from the internal host to a dynamically assigned public address.
· Add a static route to the public IP address of the external Web server.
Software versions used
This configuration example was created and verified on R9141P16 of the SR6602-I device.
Procedures
# Specify IP addresses for the interfaces on the router.
<Router> system-view
[Router] interface ten-gigabitethernet 0/0/6
[Router-Ten-GigabitEthernet0/0/6] ip address 192.168.1.1 24
[Router-Ten-GigabitEthernet0/0/6] quit
[Router] interface ten-gigabitethernet 0/0/7
[Router-Ten-GigabitEthernet0/0/7] ip address 10.0.1.1 24
[Router-Ten-GigabitEthernet0/0/7] quit
# Enable NAT with ALG and DNS.
# Configure ACL 2000 to identify packets from subnet 192.168.1.0/24.
[Router-acl-ipv4-basic-2000] rule permit source 192.168.1.0 0.0.0.255
[Router-acl-ipv4-basic-2000] quit
# Create address group 1.
# Add address 202.38.1.2 to address group 1.
[Router-nat-address-group-1] address 202.38.1.2 202.38.1.2
[Router-nat-address-group-1] quit
# Create address group 2.
# Add address 202.38.1.3 to address group 2.
[Router-nat-address-group-2] address 202.38.1.3 202.38.1.3
[Router-nat-address-group-2] quit
# Enable inbound NO-PAT on Ten-GigabitEthernet 0/0/7 to translate the source IP address in the DNS reply payload into the address in address group 1, and allow reverse translation.
[Router-Ten-GigabitEthernet0/0/7] nat inbound 2000 address-group 1 no-pat reversible
# Enable outbound PAT on Ten-GigabitEthernet 0/0/7 to translate the source address of outgoing packets into the address in address group 2.
[Router-Ten-GigabitEthernet0/0/7] nat outbound 2000 address-group 2
# Configure a static route to 202.38.1.2 with Ten-GigabitEthernet 0/0/7 as the output interface and 10.0.1.1 as the next hop.
[Router] ip route-static 202.38.1.2 32 ten-gigabitethernet 0/0/7 10.0.1.1
# Verify that the host can access the Web server by using its domain name. (Details not shown.)
# Execute the display nat all command to display all NAT configuration and statistics.
NAT address group information:
Totally 2 NAT address groups.
Address group 1:
Port range: 1-65535
Address information:
Start address End address
Address group 2:
Port range: 1-65535
NAT inbound information:
Totally 1 NAT inbound rules.
Interface: Ten-GigabitEthernet0/0/7
ACL: 2000
Address group ID: 1
Add route: N NO-PAT: Y Reversible: Y
NAT counting: 0
Config status: Active
NAT outbound information:
Totally 1 NAT outbound rules.
ACL: 2000
Address group ID: 2
Port-preserved: N NO-PAT: N Reversible: N
NAT counting: 0
NAT logging:
Log enable : Disabled
Flow-begin : Disabled
Flow-end : Disabled
Flow-active : Disabled
Port-block-assign : Disabled
Port-block-withdraw : Disabled
Alarm : Disabled
NO-PAT IP usage : Disabled
NAT mapping behavior:
Mapping mode: Address and Port-Dependent
ACL : ---
NAT ALG:
DNS : Enabled
FTP : Enabled
H323 : Enabled
ICMP-ERROR : Enabled
ILS : Enabled
MGCP : Enabled
NBT : Enabled
PPTP : Enabled
RTSP : Enabled
RSH : Enabled
SCCP : Enabled
SCTP : Enabled
SIP : Enabled
SQLNET : Enabled
TFTP : Enabled
XDMCP : Enabled
Static NAT load balancing: Disabled
NAT link-switch recreate-session: Disabled
NAT configuration-for-new-connection: Disabled
NAT global-policy compatible-previous-version rule-type ipv4-snat-and-dnat trans
late-before-secp : Disabled
# Execute the display nat session verbose command to display NAT sessions that are generated when the host accesses the Web server.
[Router] display nat session verbose
Slot 1:
Initiator:
Source IP/port: 192.168.1.10/1694
Destination IP/port: 202.38.1.2/8080
DS-Lite tunnel peer: -
VPN instance/VLAN ID/VLL ID: -/-/-
Protocol: TCP(6)
Inbound interface: Ten-GigabitEthernet0/0/6
Responder:
Source IP/port: 192.168.1.10/8080
Destination IP/port: 202.38.1.3/1025
Protocol: TCP(6)
Inbound interface: Ten-GigabitEthernet0/0/7
State: TCP_ESTABLISHED
Application: HTTP
Rule ID: -/-/-
Rule name:
Start time: 2013-08-15 14:53:29 TTL: 3597s
Initiator->Responder: 7 packets 308 bytes
Responder->Initiator: 5 packets 312 bytes
Total sessions found: 1
Configuration files
interface Ten-GigabitEthernet0/0/6
port link-mode route
interface Ten-GigabitEthernet0/0/7
ip address 10.0.1.1 255.255.255.0
ip route-static 202.38.1.2 32 Ten-GigabitEthernet0/0/7 10.0.1.1
acl number 2000
rule 0 permit source 192.168.1.0 0.0.0.255
nat address-group 1
nat address-group 2
Related documentation
· NAT and IPv6 Transition Technologies Configuration Guide in H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Guides(V9)
· NAT and IPv6 Transition Technologies Command Reference in H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Command References(V9)
