- H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Examples All-in-One-R9141-6W100
- 01-Local 802.1X Authentication Configuration Examples
- 02-RADIUS-Based 802.1X Authentication Configuration Examples
- 03-AAA Configuration Examples
- 04-ACL Configuration Examples
- 05-MPLS over ADVPN Configuration Examples
- 06-ARP Attack Protection Configuration Examples
- 07-BFD Configuration Examples
- 08-Basic BGP Configuration Examples
- 09-BGP Route Attribute-Based Route Selection Configuration Examples
- 10-CPOS Interface Configuration Examples
- 11-EAA Monitor Policy Configuration Examples
- 12-GRE with OSPF Configuration Examples
- 13-HoVPN Configuration Examples
- 14-IGMP Snooping Configuration Examples
- 15-IGMP Configuration Examples
- 16-IPsec Configuration Examples
- 17-IPsec Digital Certificate Authentication Configuration Examples
- 18-IPv6 IS-IS Configuration Examples
- 19-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 20-IPv6 over IPv4 Manual Tunnel with OSPFv3 Configuration Examples
- 21-IS-IS Configuration Examples
- 22-Combined ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 23-L2TP over IPsec Configuration Examples
- 24-Multi-Instance L2TP Configuration Examples
- 25-L2TP Multidomain Access Configuration Examples
- 26-MPLS L3VPN Configuration Examples
- 27-MPLS OAM Configuration Examples
- 28-MPLS TE Configuration Examples
- 29-Basic MPLS Configuration Examples
- 30-NAT DNS Mapping Configuration Examples
- 31-NetStream Configuration Examples
- 32-NQA Configuration Examples
- 33-NTP Configuration Examples
- 34-OSPFv3 Configuration Examples
- 35-OSPF Configuration Examples
- 36-OSPF Multi-Process Configuration Examples
- 37-OSPF Multi-Instance Configuration Examples
- 38-Portal Configuration Examples
- 39-POS Interace Configuration Examples
- 40-PPP Configuration Examples
- 41-QinQ Configuration Examples
- 42-RBAC Configuration Examples
- 43-RMON Configuration Examples
- 44-IPv4 NetStream Sampling Configuration Examples
- 45-SNMP Configuration Examples
- 46-SRv6 Configuration Examples
- 47-SSH Configuration Examples
- 48-Tcl Commands Configuration Examples
- 49-VLAN Configuration Examples
- 50-VRRP Configuration Examples
- 51-VXLAN over IPsec Configuration Examples
- 52-Cloudnet VPN Configuration Examples
- 53-Ethernet Link Aggregation Configuration Examples
- 54-Ethernet OAM Configuration Examples
- 55-Outbound Bidirectional NAT Configuration Examples
- 56-NAT Hairpin in C-S Mode Configuration Examples
- 57-Load Sharing NAT Server Configuration Examples
- 58-BIDIR-PIM Configuration Examples
- 59-Control Plane-Based QoS Policy Configuration Examples
- 60-Scheduling a Task Configuration Examples
- 61-Client-Initiated L2TP Tunnel Configuration Examples
- 62-LAC-Auto-Initiated L2TP Tunnel Configuration Examples
- 63-Authorized ARP Configuration Examples
- 64-GTS Configuration Examples
- 65-Traffic Policing Configuration Examples
- 66-Traffic Accounting Configuration Examples
- 67-PBR Configuration Examples
- 68-TFTP Client Software Upgrade Configuration Examples
- 69-FTP Client Software Upgrade Configuration Examples
- 70-FTP Server Software Upgrade Configuration Examples
- 71-Routing Policy Configuration Examples
- 72-Software Upgrade from the BootWare Menu Configuration Examples
- 73-Mirroring Configuration Examples
| 10-CPOS Interface Configuration Examples | 83.58 KB |
Copyright © 2024 H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides configuration examples for aggregating E1 links by using a channelized POS (CPOS) interface.
The following information is provided based on the assumption that you have basic knowledge of CPOS, E1, and multilink PPP (MP).
Example: Aggregating E1 links by using a CPOS interface
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on R9141P16 of the SR6602-I device.
Procedures
1. Configure Router A:
# Configure the E1 channels of the CPOS interface to operate in unframed mode.
[RouterA] controller cpos 2/2/1
[RouterA-Cpos2/2/1] e1 1 unframed
[RouterA-Cpos2/2/1] e1 2 unframed
[RouterA-Cpos2/2/1] quit
# Create an MP-group interface and assign an IP address to it.
[RouterA] interface mp-group 2/2/1
[RouterA-Mp-group2/2/1] ip address 10.1.1.1 24
[RouterA-Mp-group2/2/1] quit
[RouterA] interface serial2/2/1/1:0
[RouterA-Serial2/2/1/1:0] ppp mp mp-group 2/2/1
[RouterA-Serial2/2/1/1:0] quit
[RouterA] interface serial2/2/1/2:0
[RouterA-Serial2/2/1/2:0] ppp mp mp-group 2/2/1
[RouterA-Serial2/2/1/2:0] quit
2. Configure Router B:
# Configure CE1 interface E1 2/2/1 to operate in E1 mode.
[RouterB] controller e1 2/2/1
[RouterB-E1 2/2/1] using e1
[RouterB-E1 2/2/1] quit
# Configure CE1 interface E1 2/1/2 to operate in E1 mode.
[RouterB] controller e1 2/1/2
[RouterB-E1 2/1/2] using e1
[RouterB-E1 2/1/2] quit
# Create an MP-group interface.
[RouterB] interface mp-group 2/2/1
[RouterB-Mp-group2/2/1] ip address 10.1.1.2 24
[RouterB-Mp-group2/2/1] quit
# Configure logical serial interfaces Serial 2/2/1:0 and Serial 2/1/2:0 for two E1 links.
[RouterB] interface serial2/2/1:0
[RouterB-Serial2/2/1:0] ppp mp mp-group 2/2/1
[RouterB-Serial2/2/1:0] quit
[RouterB] interface serial2/1/2:0
[RouterB-Serial2/1/2:0] ppp mp mp-group 2/2/1
[RouterB-Serial2/1/2:0] quit
1. Identify whether the MP-group interfaces of Router A and Router B can communicate with each other.
# Check the MP-group interface on Router A.
[RouterA] ping 10.1.1.2
Ping 10.1.1.2 (10.1.1.2): 56 data bytes, press CTRL_C to break
56 bytes from 10.1.1.2: icmp_seq=0 ttl=255 time=32.998 ms
56 bytes from 10.1.1.2: icmp_seq=1 ttl=255 time=27.632 ms
56 bytes from 10.1.1.2: icmp_seq=2 ttl=255 time=34.517 ms
56 bytes from 10.1.1.2: icmp_seq=3 ttl=255 time=45.058 ms
56 bytes from 10.1.1.2: icmp_seq=4 ttl=255 time=35.121 ms
--- Ping statistics for 10.1.1.2 ---
round-trip min/avg/max/std-dev = 27.632/35.065/45.058/5.651 ms
# Check the MP-group interface on Router B.
[RouterB] ping 10.1.1.1
Ping 10.1.1.1 (10.1.1.1): 56 data bytes, press CTRL_C to break
56 bytes from 10.1.1.1: icmp_seq=0 ttl=255 time=27.877 ms
56 bytes from 10.1.1.1: icmp_seq=1 ttl=255 time=27.616 ms
56 bytes from 10.1.1.1: icmp_seq=2 ttl=255 time=42.308 ms
56 bytes from 10.1.1.1: icmp_seq=3 ttl=255 time=36.238 ms
56 bytes from 10.1.1.1: icmp_seq=4 ttl=255 time=71.639 ms
--- Ping statistics for 10.1.1.1 ---
round-trip min/avg/max/std-dev = 27.616/41.136/71.639/16.214 ms
# Display the details for the MP-group interface on Router A.
[RouterA] display interface mp-group 2/2/1
MP-group2/2/1
Current state: UP
Line protocol state: UP
Description: MP-group2/2/1 Interface
Bandwidth: 1024kbps
Maximum Transmit Unit: 1500
Hold timer: 10 seconds, retry times: 5
Internet Address is 10.1.1.1/24 (primary)
Link layer protocol: PPP
LCP: opened, MP: opened, IPCP: opened, OSICP: opened, MPLSCP: opened, IPv6CP: op
ened
Physical: MP, baudrate: 1024000 bps
Last link flapping: Never
Last 300 seconds input rate: 0 bytes/sec, 0 packets/sec
Last 300 seconds output rate: 0 bytes/sec, 0 packets/sec
# Display the details for the MP-group interface on Router B.
[RouterB] display interface mp-group 2/2/1
MP-group2/2/1
Current state: UP
Bandwidth: 1024kbps
Internet Address is 10.1.1.2/24 (primary)
LCP: opened, MP: opened, IPCP: opened, OSICP: opened, MPLSCP: opened, IPv6CP: opened
The information above indicates that the MP-group interfaces of Router A and Router B are both UP and can communicate normally.
3. Check the details of MP on Router A and Router B, and verify that the MP configuration for MP-group 1 is correct.
# Display MP details on Router A.
[RouterA] display ppp mp interface mp-group 2/2/1
Template: MP-group2/2/1
max-bind: 16, fragment: enabled, min-fragment: 128
Master link: MP-group2/2/1, Active members: 2, Bundle Multilink
Peer's endPoint descriptor: MP-group2/2/1
Sequence format: long (rcv)/long (sent)
Bundle Up Time: 2017/07/25 09:16:07:745
0 lost fragments, 0 reordered, 0 unassigned, 0 interleaved
Sequence: 0 (rcv)/0 (sent)
Active member channels: 16 members
Serial2/2/1/1:0 Up-Time:2017/07/25 09:16:07:747
Serial2/2/1/2:0 Up-Time:2017/07/25 09:16:07:746
# Display MP details on Router B.
[RouterB] display ppp mp interface mp-group 2/2/1
Serial2/2/1:0 Up-Time:2017/07/25 09:16:07:747
Serial2/1/2:0 Up-Time:2017/07/25 09:16:07:746
The information above indicates that the MP-group configuration of Router A and Router B is correct and Router A and Rotuer B can communicate normally.
Configuration files
· Router A:
e1 1 unframed
e1 2 unframed
· Router B:
controller e1 2/2/1
using e1
controller e1 2/1/2
using e1
Related documentation
· H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Guides(V9)
· H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Command References(V9)
