- H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Examples All-in-One-R9141-6W100
- 01-Local 802.1X Authentication Configuration Examples
- 02-RADIUS-Based 802.1X Authentication Configuration Examples
- 03-AAA Configuration Examples
- 04-ACL Configuration Examples
- 05-MPLS over ADVPN Configuration Examples
- 06-ARP Attack Protection Configuration Examples
- 07-BFD Configuration Examples
- 08-Basic BGP Configuration Examples
- 09-BGP Route Attribute-Based Route Selection Configuration Examples
- 10-CPOS Interface Configuration Examples
- 11-EAA Monitor Policy Configuration Examples
- 12-GRE with OSPF Configuration Examples
- 13-HoVPN Configuration Examples
- 14-IGMP Snooping Configuration Examples
- 15-IGMP Configuration Examples
- 16-IPsec Configuration Examples
- 17-IPsec Digital Certificate Authentication Configuration Examples
- 18-IPv6 IS-IS Configuration Examples
- 19-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 20-IPv6 over IPv4 Manual Tunnel with OSPFv3 Configuration Examples
- 21-IS-IS Configuration Examples
- 22-Combined ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 23-L2TP over IPsec Configuration Examples
- 24-Multi-Instance L2TP Configuration Examples
- 25-L2TP Multidomain Access Configuration Examples
- 26-MPLS L3VPN Configuration Examples
- 27-MPLS OAM Configuration Examples
- 28-MPLS TE Configuration Examples
- 29-Basic MPLS Configuration Examples
- 30-NAT DNS Mapping Configuration Examples
- 31-NetStream Configuration Examples
- 32-NQA Configuration Examples
- 33-NTP Configuration Examples
- 34-OSPFv3 Configuration Examples
- 35-OSPF Configuration Examples
- 36-OSPF Multi-Process Configuration Examples
- 37-OSPF Multi-Instance Configuration Examples
- 38-Portal Configuration Examples
- 39-POS Interace Configuration Examples
- 40-PPP Configuration Examples
- 41-QinQ Configuration Examples
- 42-RBAC Configuration Examples
- 43-RMON Configuration Examples
- 44-IPv4 NetStream Sampling Configuration Examples
- 45-SNMP Configuration Examples
- 46-SRv6 Configuration Examples
- 47-SSH Configuration Examples
- 48-Tcl Commands Configuration Examples
- 49-VLAN Configuration Examples
- 50-VRRP Configuration Examples
- 51-VXLAN over IPsec Configuration Examples
- 52-Cloudnet VPN Configuration Examples
- 53-Ethernet Link Aggregation Configuration Examples
- 54-Ethernet OAM Configuration Examples
- 55-Outbound Bidirectional NAT Configuration Examples
- 56-NAT Hairpin in C-S Mode Configuration Examples
- 57-Load Sharing NAT Server Configuration Examples
- 58-BIDIR-PIM Configuration Examples
- 59-Control Plane-Based QoS Policy Configuration Examples
- 60-Scheduling a Task Configuration Examples
- 61-Client-Initiated L2TP Tunnel Configuration Examples
- 62-LAC-Auto-Initiated L2TP Tunnel Configuration Examples
- 63-Authorized ARP Configuration Examples
- 64-GTS Configuration Examples
- 65-Traffic Policing Configuration Examples
- 66-Traffic Accounting Configuration Examples
- 67-PBR Configuration Examples
- 68-TFTP Client Software Upgrade Configuration Examples
- 69-FTP Client Software Upgrade Configuration Examples
- 70-FTP Server Software Upgrade Configuration Examples
- 71-Routing Policy Configuration Examples
- 72-Software Upgrade from the BootWare Menu Configuration Examples
- 73-Mirroring Configuration Examples
| 49-VLAN Configuration Examples | 77.26 KB |
H3C Routers |
Introduction
The following information provides examples for VLAN.
This document applies to Comware 9-based router. Procedures and information in the examples might be slightly different depending on the software or hardware version of the router.
This document assumes that you have basic knowledge of VLAN.
Restrictions and guidelines: VLAN compatibility
This feature is supported only by Layer 2 interfaces.
Example: Configuring port-based VLANs
As shown in Figure 1:
· Host A and Host C belong to Department A. VLAN 100 is assigned to Department A.
· Host B and Host D belong to Department B. VLAN 200 is assigned to Department B.
Configure port-based VLANs so that only hosts in the same department can communicate with each other.
Software versions used
This configuration example was created and verified on R9141P16 of the SR6602-I device.
Procedures
1. Configure Device A
# Batch set the link mode to bridge for GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3.
[DeviceA] interface range gigabitethernet 1/0/1 to gigabitethernet 1/0/3
[DeviceA-if-range] port link-mode bridge
[DeviceA-if-range] quit
# Create VLAN 100, and assign GigabitEthernet 1/0/1 to VLAN 100.
[DeviceA-vlan100] port gigabitethernet 1/0/1
[DeviceA-vlan100] quit
# Create VLAN 200, and assign GigabitEthernet 1/0/2 to VLAN 200.
[DeviceA-vlan200] port gigabitethernet 1/0/2
[DeviceA-vlan200] quit
# Configure GigabitEthernet 1/0/3 as a trunk port, and assign the port to VLANs 100 and 200.
[DeviceA-GigabitEthernet1/0/3] port link-type trunk
[DeviceA-GigabitEthernet1/0/3] port trunk permit vlan 100 200
2. Configure Device B in the same way Device A is configured. (Details not shown.)
3. Configure hosts:
¡ Configure Host A and Host C to be on the same IP subnet. For example, 192.168.100.0/24.
¡ Configure Host B and Host D to be on the same IP subnet. For example, 192.168.200.0/24.
# Verify that Host A and Host C can ping each other, but they both fail to ping Host B.
# Verify that Host B and Host D can ping each other, but they both fail to ping Host A.
# Verify that VLANs 100 and 200 are correctly configured on Device A.
[DeviceA-GigabitEthernet1/0/3] display vlan 100
VLAN ID: 100
VLAN type: Static
Description: VLAN 0100
Tagged ports:
Untagged ports:
GigabitEthernet1/0/1
[DeviceA-GigabitEthernet1/0/3] display vlan 200
VLAN ID: 200
VLAN type: Static
Description: VLAN 0200
Tagged ports:
Untagged ports:
GigabitEthernet1/0/2
Configuration files
The configuration on Device B is the same as that on Device A. The following is the configuration file for Device A.
vlan 100
vlan 200
port access vlan 100
port access vlan 200
port trunk permit vlan 1 100 200
Related documentation
· H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Guides (V9)
· H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Command References (V9)
