H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Examples All-in-One-R9141-6W100
HomeSupportRoutersSR6602-I[IE] SeriesConfigure & DeployConfiguration ExamplesH3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
66-Traffic Accounting Configuration Examples
66-Traffic Accounting Configuration Examples 198.68 KB
H3C Routers
Copyright © 2024 New H3C Technologies Co., Ltd. All rights reserved
Introduction
The following information provides examples for configuring traffic accounting.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of traffic accounting.
Example: Configuring traffic accounting
As shown in Figure 1, configure the routers as follows:
·     Configure LDP to establish LSPs between Router A and Router C, so subnets 11.1.1.0/24 and 21.1.1.0/24 can reach each other over MPLS.
·     Configure LDP to establish LSPs only for destinations 1.1.1.9/32, 2.2.2.9/32, 3.3.3.9/32, 11.1.1.0/24, and 21.1.1.0/24 on Router A, Router B, and Router C. Configure the penultimate hop not to pop the label on Router B.
·     On Router A, Router B, and Router C, configure traffic accounting for traffic from subnet 11.1.1.0/24 to subnet 21.1.1.0/24 to identify links that have packet loss.
Figure 1 Network diagram
Device
IP address
Device
IP address
Router A
Loop0
1.1.1.9/32
Router B
Loop0
2.2.2.9/32
XGE0/0/6
10.1.1.1/24
XGE0/0/6
10.1.1.2/24
XGE0/0/7
11.1.1.1/24
XGE0/0/7
20.1.1.1/24
Router C
Loop0
3.3.3.9/32
XGE0/0/6
20.1.1.2/24
XGE0/0/7
21.1.1.1/24
Software versions used
This configuration example was created and verified on Release 9141P16 of the SR6602-I router.
Procedures
Configuring Router A
1.     Assign IP addresses to interfaces.
Configure IP addresses and masks for interfaces as shown in Figure 1. (Details not shown.)
2.     Configure OSPF to ensure IP connectivity between the routers.
[RouterA] ospf
[RouterA-ospf-1] area 0
[RouterA-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[RouterA-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[RouterA-ospf-1-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[RouterA-ospf-1] quit
3.     Enable MPLS and LDP.
[RouterA] mpls lsr-id 1.1.1.9
[RouterA] mpls ldp
[RouterA-ldp] quit
[RouterA] interface ten-gigabitethernet 0/0/6
[RouterA-Ten-GigabitEthernet0/0/6] mpls enable
[RouterA-Ten-GigabitEthernet0/0/6] mpls ldp enable
[RouterA-Ten-GigabitEthernet0/0/6] quit
4.     Configure IP prefix list routera, and configure LDP to use only the routes permitted by the prefix list to establish LSPs.
[RouterA] ip prefix-list routera index 10 permit 1.1.1.9 32
[RouterA] ip prefix-list routera index 20 permit 2.2.2.9 32
[RouterA] ip prefix-list routera index 30 permit 3.3.3.9 32
[RouterA] ip prefix-list routera index 40 permit 11.1.1.0 24
[RouterA] ip prefix-list routera index 50 permit 21.1.1.0 24
[RouterA] mpls ldp
[RouterA-ldp] lsp-trigger prefix-list routera
[RouterA-ldp] quit
5.     Configure traffic classes to match IPv4 traffic from subnet 11.1.1.0/24 to subnet 21.1.1.0/24.
[RouterA] acl advanced 3000
[RouterA-acl-ipv4-adv-3000] rule permit ip destination 21.1.1.0 0.0.0.255 source 11.1.1.0 0.0.0.255
[RouterA-acl-ipv4-adv-3000] quit
[RouterA] traffic classifier FEC
[RouterA-classifier-classifier_FEC] if-match acl 3000
[RouterA-classifier-classifier_FEC] quit
[RouterA] traffic classifier Other
[RouterA-classifier-classifier_Other] if-match any
[RouterA-classifier-classifier_Other] quit
6.     Configure traffic behavior IP_statistic to count IPv4 traffic from subnet 11.1.1.0/24 to subnet 21.1.1.0/24. You do not need to configure any traffic accounting action in the traffic behavior.
[RouterA] traffic behavior IP_statistic
[RouterA-behavior-behavior_IP_statistic] quit
7.     Associate traffic class FEC with traffic behavior IP_statistic in QoS policy IP_statistic.
[RouterA] qos policy IP_statistic
[RouterA-qospolicy-IP_statistic] classifier FEC behavior IP_statistic
[RouterA-qospolicy-IP_statistic] quit
8.     Apply QoS policy IP_statistic to the incoming traffic on Ten-GigabitEthernet 0/0/7.
[RouterA] interface ten-gigabitethernet 0/0/7
[RouterA-Ten-GigabitEthernet0/0/7] qos apply policy IP_statistic inbound
[RouterA-Ten-GigabitEthernet0/0/7] quit
9.     Configure traffic behaviors to set the EXP value in the first label to 7 and 1 for MPLS packets from subnet 11.1.1.0/24 to subnet 21.1.1.0/24 and other MPLS packets, respectively.
[RouterA] traffic behavior MPLS_statistic
[RouterA-behavior-behavior_MPLS_statistic] remark mpls-exp 7
[RouterA-behavior-behavior_MPLS_statistic] quit
[RouterA] traffic behavior Other
[RouterA-behavior-behavior_Other] remark mpls-exp 1
[RouterA-behavior-behavior_Other] quit
10.     Associate traffic class FEC with traffic behavior MPLS_statistic in QoS policy MPLS_statistic.
[RouterA] qos policy MPLS_statistic
[RouterA-qospolicy-MPLS_statistic] classifier FEC behavior MPLS_statistic
[RouterA-qospolicy-MPLS_statistic] classifier Other behavior Other
[RouterA-qospolicy-MPLS_statistic] quit
11.     Apply QoS policy MPLS_statistic to the outgoing traffic on Ten-GigabitEthernet 0/0/6.
[RouterA-Ten-GigabitEthernet0/0/6] qos apply policy MPLS_statistic outbound
Configuring Router B
<RouterB> system-view
[RouterB] ospf
[RouterB-ospf-1] area 0
[RouterB-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[RouterB-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[RouterB-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[RouterB-ospf-1] quit
[RouterB] mpls lsr-id 2.2.2.9
[RouterB] mpls ldp
[RouterB-ldp] quit
[RouterB] interface ten-gigabitethernet 0/0/6
[RouterB-Ten-GigabitEthernet0/0/6] mpls enable
[RouterB-Ten-GigabitEthernet0/0/6] mpls ldp enable
[RouterB-Ten-GigabitEthernet0/0/6] quit
[RouterB] interface ten-gigabitethernet 0/0/7
[RouterB-Ten-GigabitEthernet0/0/7] mpls enable
[RouterB-Ten-GigabitEthernet0/0/7] mpls ldp enable
[RouterB-Ten-GigabitEthernet0/0/7] quit
4.     Configure IP prefix list routerb, and configure LDP to use only the routes permitted by the prefix list to establish LSPs.
[RouterB] ip prefix-list routerb index 10 permit 1.1.1.9 32
[RouterB] ip prefix-list routerb index 20 permit 2.2.2.9 32
[RouterB] ip prefix-list routerb index 30 permit 3.3.3.9 32
[RouterB] ip prefix-list routerb index 40 permit 11.1.1.0 24
[RouterB] ip prefix-list routerb index 50 permit 21.1.1.0 24
[RouterB] mpls ldp
[RouterB-ldp] lsp-trigger prefix-list routerb
[RouterB-ldp] quit
5.     Configure Router B to advertise an explicit null label to the penultimate hop.
[RouterB] mpls label advertise explicit-null
6.     Configure traffic class MPLS_statistic on Router B to match MPLS packets with EXP value 7 in the first MPLS label.
[RouterB] traffic classifier MPLS_statistic
[RouterB-classifier-classifier_MPLS_statistic] if-match mpls-exp 7
[RouterB-classifier-classifier_MPLS_statistic] quit
7.     Configure traffic behavior MPLS_statistic_in to count MPLS packets with EXP value 7 in the first MPLS label. You do not need to configure any traffic accounting action in the traffic behavior.
[RouterB] traffic behavior MPLS_statistic_in
[RouterB-behavior-behavior_MPLS_statistic_in] quit
8.     Associate traffic class MPLS_statistic with traffic behavior MPLS_statistic_in in QoS policy MPLS_statistic_in.
[RouterB] qos policy MPLS_statistic_in
[RouterB-qospolicy-MPLS_statistic_in] classifier MPLS_statistic behavior MPLS_statistic_in
[RouterB-qospolicy-MPLS_statistic_in] quit
9.     Apply QoS policy MPLS_statistic_in to the incoming traffic on Ten-GigabitEthernet 0/0/6.
[RouterB-Ten-GigabitEthernet0/0/6] qos apply policy MPLS_statistic_in inbound
10.     Configure traffic behavior MPLS_statistic_out to count packets with EXP value 7 in the first MPLS label. You do not need to configure any traffic accounting action in the traffic behavior.
[RouterB] traffic behavior MPLS_statistic_out
[RouterB-behavior-behavior_MPLS_statistic_out] quit
11.     Associate traffic class MPLS_statistic with traffic behavior MPLS_statistic_out in QoS policy MPLS_statistic_out.
[RouterB] qos policy MPLS_statistic_out
[RouterB-qospolicy-MPLS_statistic] classifier MPLS_statistic behavior MPLS_statistic_out
[RouterB-qospolicy-MPLS_statistic] quit
12.     Apply QoS policy MPLS_statistic_out to the outgoing traffic on Ten-GigabitEthernet 0/0/7.
[RouterB-Ten-GigabitEthernet0/0/7] qos apply policy MPLS_statistic_out outbound
Configuring Router C
<RouterC> system-view
[RouterC] ospf
[RouterC-ospf-1] area 0
[RouterC-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[RouterC-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[RouterC-ospf-1-area-0.0.0.0] network 21.1.1.0 0.0.0.255
[RouterC-ospf-1] quit
[RouterC] mpls lsr-id 3.3.3.9
[RouterC] mpls ldp
[RouterC-ldp] quit
[RouterC] interface ten-gigabitethernet 0/0/6
[RouterC-Ten-GigabitEthernet0/0/6] mpls enable
[RouterC-Ten-GigabitEthernet0/0/6] mpls ldp enable
[RouterC-Ten-GigabitEthernet0/0/6] quit
4.     Configure IP prefix list routerc, and configure LDP to use only the routes permitted by the prefix list to establish LSPs.
[RouterC] ip prefix-list routerc index 10 permit 1.1.1.9 32
[RouterC] ip prefix-list routerc index 20 permit 2.2.2.9 32
[RouterC] ip prefix-list routerc index 30 permit 3.3.3.9 32
[RouterC] ip prefix-list routerc index 40 permit 11.1.1.0 24
[RouterC] ip prefix-list routerc index 50 permit 21.1.1.0 24
[RouterC] mpls ldp
[RouterC-ldp] lsp-trigger prefix-list routerc
[RouterC-ldp] quit
5.     Configure traffic class MPLS_statistic to match MPLS packets with EXP value 7 in the first MPLS label.
6.     Configure traffic behavior MPLS_statistic to count packets with EXP value 7 in the first MPLS label. You do not need to configure any traffic accounting action in the traffic behavior.
[RouterC] traffic behavior MPLS_statistic
[RouterC-behavior-behavior_MPLS_statistic] quit
7.     Associate traffic class MPLS_statistic with traffic behavior MPLS_statistic in QoS policy MPLS_statistic.
[RouterC] qos policy MPLS_statistic
[RouterC-qospolicy-MPLS_statistic] classifier MPLS_statistic behavior MPLS_statistic
[RouterC-qospolicy-MPLS_statistic] quit
8.     Apply QoS policy MPLS_statistic to the incoming traffic on Ten-GigabitEthernet 0/0/6.
[RouterC-Ten-GigabitEthernet0/0/6] qos apply policy MPLS_statistic inbound
9.     Configure a traffic class to match IPv4 traffic from subnet 11.1.1.0/24 to subnet 21.1.1.0/24.
[RouterC] acl advanced 3000
[RouterC-acl-ipv4-adv-3000] rule permit ip destination 21.1.1.0 0.0.0.255 source 11.1.1.0 0.0.0.255
[RouterC-acl-ipv4-adv-3000] quit
[RouterC] traffic classifier FEC operator and
[RouterC-classifier-classifier_FEC] if-match acl 3000
[RouterC-classifier-classifier_FEC] quit
10.     Configure traffic behavior IP_statistic to count IPv4 traffic from subnet 11.1.1.0/24 to subnet 21.1.1.0/24. You do not need to configure any traffic accounting action in the traffic behavior.
[RouterC] traffic behavior IP_statistic
[RouterC-behavior-behavior_IP_statistic] quit
11.     Associate traffic class FEC with traffic behavior IP_statistic in QoS policy IP_statistic.
[RouterC] qos policy IP_statistic
[RouterC-qospolicy-IP_statistic] classifier FEC behavior IP_statistic
[RouterC-qospolicy-IP_statistic] quit
12.     Apply QoS policy IP_statistic to the outgoing traffic on Ten-GigabitEthernet 0/0/7.
[RouterC] interface ten-gigabitethernet 0/0/7
[RouterC-Ten-GigabitEthernet0/0/7] qos apply policy IP_statistic outbound
[RouterC-Ten-GigabitEthernet0/0/7] quit
# Display the QoS policies applied to all interfaces on each router. Verify that the traffic accounting information of the traffic input and output interfaces on the routers is the same. The following uses Router A as an example.
[RouterA-Ten-GigabitEthernet0/0/6] display qos policy interface
Interface: Ten-GigabitEthernet0/0/6
  Direction: Inbound
  Policy: IP_statistic
   Classifier: default-class
     Matched : 0 (Packets) 0 (Bytes)
     5-minute statistics:
      Forwarded: 0/0 (pps/bps)
      Dropped  : 0/0 (pps/bps)
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: be
      -none-
   Classifier: FEC
      Forwarded: 123/41248 (pps/bps)
     Operator: AND
     Rule(s) :
      If-match acl 3000
     Behavior: IP_statistic
      -none-
Interface: Ten-GigabitEthernet0/0/7
  Direction: Outbound
  Policy: MPLS_statistic
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: be
      -none-
   Classifier: FEC
     Matched : 123 (Packets) 41248 (Bytes)
     Operator: AND
     Rule(s) :
      If-match acl 3000
     Behavior: MPLS_statistic
      Marking:
        Remark mpls-exp 7
Configuration files
·     Router A:
ospf 1
 area 0.0.0.0
 mpls lsr-id 1.1.1.9
 if-match acl 3000
traffic classifier Other operator and
 if-match any
 remark mpls-exp 7
 remark mpls-exp 1
mpls ldp
interface LoopBack0
 ip address 1.1.1.9 255.255.255.255
interface Ten-GigabitEthernet0/0/6
 port link-mode route
 combo enable copper
 mpls enable
 mpls ldp enable
interface Ten-GigabitEthernet0/0/7
 combo enable copper
 ip address 11.1.1.1 255.255.255.0
acl advanced 3000
 rule 5 permit ip source 11.1.1.0 0.0.0.255 destination 21.1.1.0 0.0.0.255
·     Router B:
ospf 1
 area 0.0.0.0
 mpls lsr-id 2.2.2.9
traffic classifier MPLS_statistic operator and
 if-match mpls-exp 7
mpls ldp
interface LoopBack0
 ip address 2.2.2.9 255.255.255.255
 combo enable copper
 mpls enable
 mpls ldp enable
 combo enable copper
 ip address 20.1.1.1 255.255.255.0
·     Router C:
ospf 1
 area 0.0.0.0
 mpls lsr-id 3.3.3.9
 if-match acl 3000
mpls ldp
interface LoopBack0
 ip address 3.3.3.9 255.255.255.255
 combo enable copper
 ip address 20.1.1.2 255.255.255.0
 mpls enable
 mpls ldp enable
 combo enable copper
 ip address 21.1.1.1 255.255.255.0
acl advanced 3000
Related documentation
·     ACL and QoS Configuration Guide in H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Guides(V9)
·     ACL and QoS Command Reference in H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Command References(V9)
