- H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Examples All-in-One-R9141-6W100
- 01-Local 802.1X Authentication Configuration Examples
- 02-RADIUS-Based 802.1X Authentication Configuration Examples
- 03-AAA Configuration Examples
- 04-ACL Configuration Examples
- 05-MPLS over ADVPN Configuration Examples
- 06-ARP Attack Protection Configuration Examples
- 07-BFD Configuration Examples
- 08-Basic BGP Configuration Examples
- 09-BGP Route Attribute-Based Route Selection Configuration Examples
- 10-CPOS Interface Configuration Examples
- 11-EAA Monitor Policy Configuration Examples
- 12-GRE with OSPF Configuration Examples
- 13-HoVPN Configuration Examples
- 14-IGMP Snooping Configuration Examples
- 15-IGMP Configuration Examples
- 16-IPsec Configuration Examples
- 17-IPsec Digital Certificate Authentication Configuration Examples
- 18-IPv6 IS-IS Configuration Examples
- 19-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 20-IPv6 over IPv4 Manual Tunnel with OSPFv3 Configuration Examples
- 21-IS-IS Configuration Examples
- 22-Combined ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 23-L2TP over IPsec Configuration Examples
- 24-Multi-Instance L2TP Configuration Examples
- 25-L2TP Multidomain Access Configuration Examples
- 26-MPLS L3VPN Configuration Examples
- 27-MPLS OAM Configuration Examples
- 28-MPLS TE Configuration Examples
- 29-Basic MPLS Configuration Examples
- 30-NAT DNS Mapping Configuration Examples
- 31-NetStream Configuration Examples
- 32-NQA Configuration Examples
- 33-NTP Configuration Examples
- 34-OSPFv3 Configuration Examples
- 35-OSPF Configuration Examples
- 36-OSPF Multi-Process Configuration Examples
- 37-OSPF Multi-Instance Configuration Examples
- 38-Portal Configuration Examples
- 39-POS Interace Configuration Examples
- 40-PPP Configuration Examples
- 41-QinQ Configuration Examples
- 42-RBAC Configuration Examples
- 43-RMON Configuration Examples
- 44-IPv4 NetStream Sampling Configuration Examples
- 45-SNMP Configuration Examples
- 46-SRv6 Configuration Examples
- 47-SSH Configuration Examples
- 48-Tcl Commands Configuration Examples
- 49-VLAN Configuration Examples
- 50-VRRP Configuration Examples
- 51-VXLAN over IPsec Configuration Examples
- 52-Cloudnet VPN Configuration Examples
- 53-Ethernet Link Aggregation Configuration Examples
- 54-Ethernet OAM Configuration Examples
- 55-Outbound Bidirectional NAT Configuration Examples
- 56-NAT Hairpin in C-S Mode Configuration Examples
- 57-Load Sharing NAT Server Configuration Examples
- 58-BIDIR-PIM Configuration Examples
- 59-Control Plane-Based QoS Policy Configuration Examples
- 60-Scheduling a Task Configuration Examples
- 61-Client-Initiated L2TP Tunnel Configuration Examples
- 62-LAC-Auto-Initiated L2TP Tunnel Configuration Examples
- 63-Authorized ARP Configuration Examples
- 64-GTS Configuration Examples
- 65-Traffic Policing Configuration Examples
- 66-Traffic Accounting Configuration Examples
- 67-PBR Configuration Examples
- 68-TFTP Client Software Upgrade Configuration Examples
- 69-FTP Client Software Upgrade Configuration Examples
- 70-FTP Server Software Upgrade Configuration Examples
- 71-Routing Policy Configuration Examples
- 72-Software Upgrade from the BootWare Menu Configuration Examples
- 73-Mirroring Configuration Examples
| 58-BIDIR-PIM Configuration Examples | 132.61 KB |
H3C Routers |
Introduction
This document introduces BIDIR-PIM configuration examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of BIDIR-PIM.
Example: Configuring BIDIR-PIM
As shown in Figure 1:
· Router A, Router B, and Router C run OSPF.
· Source 1 and Source 2 send multicast data to multicast group 225.1.1.1.
· Host A and Host B are member hosts of multicast group 225.1.1.1.
Configure BIDIR-PIM on the routers to implement multicast forwarding.
Device |
IP address |
Device |
IP address |
Router A |
XGE0/0/6 |
10.10.1.1/24 |
Router C |
XGE0/0/6 |
10.13.1.3/24 |
Router A |
XGE0/0/7 |
10.12.1.1/24 |
Router C |
XGE0/0/7 |
10.23.1.3/24 |
Router A |
XGE0/0/8 |
10.13.1.1/24 |
Router C |
XGE0/0/8 |
10.102.1.1/24 |
Router B |
XGE0/0/6 |
10.12.1.2/24 |
Router C |
XGE0/0/9 |
Router B |
XGE0/0/7 |
10.23.1.2/24 |
Source 1 |
10.10.1.2/24 |
Router B |
XGE0/0/8 |
10.101.1.1/24 |
Source 2 |
10.33.1.4/24 |
Analysis
To meet the network requirements, perform the following tasks:
· To establish the bidirectional RPT, configure Ten-GigabitEthernet 0/0/7 on Router A as a C-RP.
· To use the BSR mechanism to dynamically elect the RP, configure Ten-GigabitEthernet 0/0/7 on Router A as a C-BSR.
· To avoid multicast forwarding interruption when the RP fails, specify the unused IP address 10.13.1.4/24 as the static RP. In this way, the link on the subnet 10.13.1.0/24 becomes the RPL. Router A and Router C on the link function as the RPs.
Software versions used
This configuration example was created and verified on Release 9141P16 of the SR6602-I router.
When you configure BIDIR-PIM, follow these restrictions and guidelines:
· Enable the same PIM mode on the interfaces that belong to the same VPN instance on each router.
· Configure the same static RP on all the routers in the BIDIR-PIM domain.
· Enable PIM-SM for all interfaces on the routers in the BIDIR-PIM domain.
· Enable IGMP for the interfaces that connect to the stub networks on all the routers in the BIDIR-PIM domain.
Procedures
Configure Router A
1. Enable IP multicast routing.
[RouterA] multicast routing
[RouterA-mrib] quit
2. Configure each interface and enable PIM-SM.
# Assign an IP address to Ten-GigabitEthernet 0/0/6, and enable PIM-SM on the interface.
[RouterA] interface ten-gigabitethernet 0/0/6
[RouterA-Ten-GigabitEthernet0/0/6] ip address 10.10.1.1 24
[RouterA-Ten-GigabitEthernet0/0/6] pim sm
[RouterA-Ten-GigabitEthernet0/0/6] quit
# Assign an IP address to Ten-GigabitEthernet 0/0/7, enable PIM-SM on the interface.
[RouterA-vlan12] interface ten-gigabitethernet 0/0/7
[RouterA-Ten-GigabitEthernet0/0/7] ip address 10.12.1.1 24
[RouterA-Ten-GigabitEthernet0/0/7] pim sm
[RouterA-Ten-GigabitEthernet0/0/7] quit
# Assign an IP address to GigabitEthernet 1/0/3, enable PIM-SM on the interface.
[RouterA] interface gigabitethernet 1/0/3
[RouterA-GigabitEthernet1/0/3] ip address 10.13.1.1 24
[RouterA-GigabitEthernet1/0/3] pim sm
[RouterA-GigabitEthernet1/0/3] quit
3. Configure a C-RP, a C-BSR, and the static RP.
# Configure Ten-GigabitEthernet 0/0/7 as a C-BSR and a C-RP.
[RouterA] pim
[RouterA-pim] c-bsr 10.12.1.1
[RouterA-pim] c-rp 10.12.1.1 bidir
# Specify the unused IP address 10.13.1.4 as a static RP.
[RouterA-pim] static-rp 10.13.1.4 bidir
4. Enable BIDIR-PIM.
[RouterA-pim] bidir-pim enable
[RouterA-pim] quit
5. Configure OSPF.
[RouterA] ospf 1
[RouterA-ospf-1] import-route direct
[RouterA-ospf-1] area 0
[RouterA-ospf-1-area-0.0.0.0] network 10.0.0.0 0.255.255.255
[RouterA-ospf-1] quit
Configure Router B
<RouterB> system-view
[RouterB] multicast routing
[RouterB-mrib] quit
# Assign an IP address to Ten-GigabitEthernet 0/0/6, enable PIM-SM on the interface.
[RouterB] interface ten-gigabitethernet 0/0/6
[RouterB-Ten-GigabitEthernet0/0/6] ip address 10.12.1.2 24
[RouterB-Ten-GigabitEthernet0/0/6] pim sm
[RouterB-Ten-GigabitEthernet0/0/6] quit
[RouterB] interface ten-gigabitethernet 0/0/7
[RouterB-Ten-GigabitEthernet0/0/7] ip address 10.23.1.2 24
[RouterB-Ten-GigabitEthernet0/0/7] pim sm
[RouterB-Ten-GigabitEthernet0/0/7] quit
# Assign an IP address to GigabitEthernet 1/0/3, enable PIM-SM and IGMP on the interface.
[RouterB] interface gigabitethernet 1/0/3
[RouterB-GigabitEthernet1/0/3] ip address 10.101.1.1 24
[RouterB-GigabitEthernet1/0/3] pim sm
[RouterB-GigabitEthernet1/0/3] igmp enable
[RouterB-GigabitEthernet1/0/3] quit
3. Specify the unused IP address 10.13.1.4 as a static RP.
[RouterB] pim
[RouterB-pim] static-rp 10.13.1.4 bidir
[RouterB-pim] bidir-pim enable
[RouterB-pim] quit
5. Configure OSPF.
[RouterB] ospf 1
[RouterB-ospf-1] import-route direct
[RouterB-ospf-1] area 0
[RouterB-ospf-1-area-0.0.0.0] network 10.0.0.0 0.255.255.255
[RouterB-ospf-1] quit
Configure Router C
<RouterC> system-view
[RouterC] multicast routing
[RouterC-mrib] quit
# Assign an IP address to GigabitEthernet 1/0/4, enable PIM-SM on the interface.
[RouterC] interface gigabitethernet 1/0/4
[RouterC-GigabitEthernet1/0/4] ip address 10.33.1.3 24
[RouterC-GigabitEthernet1/0/4] pim sm
[RouterC-GigabitEthernet1/0/4] quit
[RouterC] interface ten-gigabitethernet 0/0/6
[RouterC-Ten-GigabitEthernet0/0/6] ip address 10.13.1.3 24
[RouterC-Ten-GigabitEthernet0/0/6] pim sm
[RouterC-Ten-GigabitEthernet0/0/6] quit
[RouterC] interface ten-gigabitethernet 0/0/7
[RouterC-Ten-GigabitEthernet0/0/7] ip address 10.23.1.3 24
[RouterC-Ten-GigabitEthernet0/0/7] pim sm
[RouterC-Ten-GigabitEthernet0/0/7] quit
[RouterC] interface gigabitethernet 1/0/3
[RouterC-GigabitEthernet1/0/3] ip address 10.102.1.1 24
[RouterC-GigabitEthernet1/0/3] pim sm
[RouterC-GigabitEthernet1/0/3] igmp enable
[RouterC-GigabitEthernet1/0/3] quit
[RouterC] pim
[RouterC-pim] static-rp 10.13.1.4 bidir
4. Enable BIDIR-PIM
[RouterC-pim] bidir-pim enable
[RouterC-pim] quit
5. Configure OSPF.
[RouterC] ospf 1
[RouterC-ospf-1] import-route direct
[RouterC-ospf-1] area 0
[RouterC-ospf-1-area-0.0.0.0] network 10.0.0.0 0.255.255.255
[RouterC-ospf-1] quit
1. Verify that Router A, Router B, and Router C have established PIM neighbor relationships.
# Display PIM neighbor information on Router A.
[RouterA] display pim neighbor
Total Number of Neighbors = 2
Neighbor Interface Uptime Expires DR-Priority Mode
10.12.1.2 XGE0/0/7 00:02:27 00:01:45 1 B
10.13.1.3 XGE0/0/8 00:02:27 00:01:19 1 B
# Display PIM neighbor information on Router B.
[RouterB] display pim neighbor
10.12.1.1 XGE0/0/6 00:03:05 00:01:44 1 B
10.23.1.3 XGE0/0/8 00:13:49 00:01:29 1 B
# Display PIM neighbor information on Router C.
[RouterC] display pim neighbor
10.13.1.1 XGE0/0/6 00:03:28 00:01:39 1 B
10.23.1.2 XGE0/0/7 00:14:05 00:01:36 1 B
2. Verify that Ten-GigabitEthernet 0/0/7 on Router A has been elected as the BSR on each router.
# Display BSR information on Router A.
[RouterA] display pim bsr-info
Scope: non-scoped
State: Elected
Bootstrap timer: 00:01:18
Elected BSR address: 10.12.1.1
Priority: 64
Hash mask length: 30
Uptime: 00:04:01
Candidate BSR address: 10.12.1.1
Priority: 64
# Display BSR information on Router B.
[RouterB] display pim bsr-info
Scope: non-scoped
State: Accept Preferred
Bootstrap timer: 00:00:26
Priority: 64
Uptime: 00:10:41
# Display BSR information on Router C.
[RouterC] display pim bsr-info
Scope: non-scoped
Bootstrap timer: 00:02:08
Priority: 64
Uptime: 00:15:41
3. Verify that Ten-GigabitEthernet 0/0/7 on Router A has been elected as the RP, and verify that the IP address of the static RP is 10.13.1.4 on each router.
# Display RP information on Router A.
[RouterA] display pim rp-info
BSR RP information:
Scope: non-scoped
Group/MaskLen: 224.0.0.0/4 [B]
RP address Priority HoldTime Uptime Expires
10.12.1.1 (local) 192 150 00:06:01 00:02:58
Static RP information:
RP address ACL Mode Preferred
10.13.1.4 ---- bidir No
# Display RP information on Router B.
[SwatchB] display pim rp-info
BSR RP information:
Scope: non-scoped
10.12.1.1 192 150 00:06:33 00:02:26
# Display RP information on Router C.
[RouterC] display pim rp-info
BSR RP information:
Scope: non-scoped
10.12.1.1 192 150 00:06:51 00:02:05
4. Verify that the DFs have been elected for BIDIR-PIM on each router.
# Display information about DFs for BIDIR-PIM on Router A.
[RouterA] display pim df-info
RP address: 10.12.1.1
Interface State DF-Pref DF-Metric DF-Uptime DF-Address
XGE0/0/6 Win 0 0 00:01:09 10.10.1.1 (local)
XGE0/0/7 - - - - -
XGE0/0/8 Win 0 0 00:01:10 10.13.1.1 (local)
RP address: 10.13.1.4
XGE0/0/6 Win 0 0 00:00:07 10.10.1.1 (local)
XGE0/0/7 Win 0 0 00:00:07 10.12.1.1 (local)
XGE0/0/8 - - - - -
# Display information about DFs for BIDIR-PIM on Router B.
[RouterB] display pim df-info
XGE0/0/6 - - - - -
XGE0/0/7 Win 0 0 00:01:46 10.23.1.2 (local)
XGE0/0/8 Win 0 0 00:01:45 10.101.1.1 (local)
XGE0/0/6 Lose 0 0 00:00:44 10.12.1.1
XGE0/0/7 Lose 0 0 00:00:53 10.23.1.3
XGE0/0/8 Win 10 2 00:00:53 10.101.1.1 (local)
# Display information about DFs for BIDIR-PIM on Router C.
[RouterC] display pim df-info
XGE0/0/8 Win 10 2 00:02:07 10.102.1.1 (local)
XGE0/0/9 Win 10 2 00:02:06 10.33.1.3 (local)
XGE0/0/6 Lose 0 0 00:02:07 10.13.1.1
XGE0/0/7 Lose 0 0 00:02:07 10.23.1.2
XGE0/0/8 Win 0 0 00:01:24 10.102.1.1 (local)
XGE0/0/9 Win 0 0 00:01:23 10.33.1.3 (local)
XGE0/0/6 - - - - -
XGE0/0/7 Win 0 0 00:01:24 10.23.1.3 (local)
5. Verify that DFs for multicast forwarding are correct on each router.
# Display information about DFs for multicast forwarding on Router A.
[RouterA] display multicast forwarding df-info
Total 2 RPs, 2 matched
00001. RP address: 10.12.1.1
Flags: 0x0
Uptime: 00:02:42
RPF interface: Ten-GigabitEthernet0/0/7
List of 2 DF interfaces:
1: Ten-GigabitEthernet0/0/6
2: GigabitEthernet1/0/3
00002. RP address: 10.13.1.4
Flags: 0x0
Uptime: 00:01:41
RPF interface: GigabitEthernet1/0/3
2: Ten-GigabitEthernet0/0/7
# Display information about DFs for multicast forwarding on Router B.
[RouterB] display multicast forwarding df-info
Flags: 0x0
Uptime: 00:03:18
RPF interface: Ten-GigabitEthernet0/0/6
1: Ten-GigabitEthernet0/0/7
Flags: 0x0
Uptime: 00:02:24
List of 1 DF interfaces:
1: GigabitEthernet1/0/3
# Display information about DFs for multicast forwarding on Router C.
[RouterC] display multicast forwarding df-info
Flags: 0x0
Uptime: 00:03:38
2: GigabitEthernet1/0/4
Flags: 0x0
Uptime: 2d:18h
List of 3 DF interfaces:
3: Ten-GigabitEthernet0/0/7
6. Send IGMP reports from Host A and Host B to join multicast group 225.1.1.1, and send multicast data from Source 1 and Source 2 to the group. (Details not shown.)
7. Verify that PIM forwarding entries have been correctly established on each router.
# Display information about PIM routing entries on Router A.
[RouterA] display pim routing-table
Total 1 (*, G) entry; 0 (S, G) entry
(*, 225.1.1.1)
RP: 10.12.1.1 (local)
Protocol: pim-bidir, Flag: WC LOC ACT
UpTime: 00:21:59
Upstream interface: Ten-GigabitEthernet0/0/7
Upstream neighbor: NULL
RPF prime neighbor: NULL
Protocol: pim-bidir, UpTime: 00:21:59, Expires: -
Protocol: pim-bidir, UpTime: 00:03:26, Expires: -
# Display information about PIM routing entries on Router B.
[RouterB] display pim routing-table
(*, 225.1.1.1)
RP: 10.12.1.1
UpTime: 00:23:47
Upstream interface: Ten-GigabitEthernet0/0/6
Total number of downstreams: 3
Protocol: pim-bidir, UpTime: 00:23:47, Expires: -
Protocol: pim-bidir, UpTime: 00:21:56, Expires: -
3: GigabitEthernet1/0/3
Protocol: igmp, UpTime: 00:23:47, Expires: -
# Display information about PIM routing entries on Router C.
[RouterC] display pim routing-table
(*, 225.1.1.1)
RP: 10.12.1.1
Protocol: pim-bidir, Flag: WC ACT
UpTime: 00:01:45
Upstream neighbor: 10.23.1.2
RPF prime neighbor: 10.23.1.2
Total number of downstreams: 2
Protocol: igmp, UpTime: 00:01:05, Expires: -
Protocol: pim-bidir, UpTime: 00:00:53, Expires: -
Configuration files
· Router A:
ospf 1
import-route direct
area 0.0.0.0
interface Ten-GigabitEthernet0/0/6
port link-mode route
ip address 10.10.1.1 255.255.255.0
pim sm
interface Ten-GigabitEthernet0/0/7
ip address 10.12.1.1 255.255.255.0
pim sm
ip address 10.13.1.1 255.255.255.0
pim sm
multicast routing
pim
c-bsr 10.12.1.1
bidir-pim enable
· Router B:
ospf 1
import-route direct
area 0.0.0.0
combo enable copper
ip address 10.12.1.2 255.255.255.0
pim sm
combo enable copper
ip address 10.23.1.2 255.255.255.0
pim sm
combo enable copper
ip address 10.101.1.1 255.255.255.0
pim sm
igmp enable
multicast routing
pim
bidir-pim enable
· Router C:
ospf 1
import-route direct
area 0.0.0.0
ip address 10.13.1.3 255.255.255.0
pim sm
ip address 10.23.1.3 255.255.255.0
pim sm
ip address 10.102.1.1 255.255.255.0
pim sm
igmp enable
interface GigabitEthernet1/0/4
ip address 10.33.1.3 255.255.255.0
pim sm
multicast routing
pim
bidir-pim enable
Related documentation
· IP Multicast Configuration Guide in H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Guides(V9)
· IP Multicast Command Reference in H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Command References(V9)
