H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Examples All-in-One-R9141-6W100
HomeSupportRoutersSR6602-I[IE] SeriesConfigure & DeployConfiguration ExamplesH3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
53-Ethernet Link Aggregation Configuration Examples
H3C Routers
Introduction
The following information provides examples for Ethernet link aggregation.
This document applies to Comware 9-based router. Procedures and information in the examples might be slightly different depending on the software or hardware version of the router.
This document assumes that you have basic knowledge of Ethernet link aggregation.
Example: Configuring a Layer 3 aggregation group
On the network shown in Figure 1, perform the following tasks:
·     Configure a Layer 3 aggregation group on both Device A and Device B.
·     Configure IP addresses and subnet masks for the corresponding Layer 3 aggregate interfaces.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on R9141P16 of the SR6602-I device.
The Selected state of ports in a static aggregation group is not affected by whether the peer ports are in an aggregation group or in Selected state, Selected ports determined by both ends of the static aggregate link might to be inconsistent. As a best practice, use the dynamic aggregation mode if both ends support static and dynamic link aggregation modes.
Procedures
Configure Device A
# Create a Layer 3 aggregate interface Route-Aggregation 1. (Choose one of the following two methods.)
·     Static aggregation mode.
[DeviceA] interface route-aggregation 1
·     Dynamic aggregation mode.
[DeviceA-Route-Aggregation1] link-aggregation mode dynamic
# Configure an IP address and subnet mask for Route-Aggregation 1.
[DeviceA-Route-Aggregation1] ip address 192.168.1.1 24
[DeviceA-Route-Aggregation1] quit
# Assign Layer 3 Ethernet interfaces GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3 to aggregation group 1.
[DeviceA] interface range gigabitethernet 1/0/1 to gigabitethernet 1/0/3
[DeviceA-if-range] port link-aggregation group 1
[DeviceA-if-range] quit
Configure Device B
Configure Device B in the same way Device A is configured. (Details not shown.)
# Use display link-aggregation verbose to display detailed information about the aggregation groups.
·     Aggregate group information in static aggregation mode
[DeviceA] display link-aggregation verbose
Port: A -- Auto port
Flags:  A -- LACP_Activity, B -- LACP_Timeout, C -- Aggregation,
        G -- Defaulted, H -- Expired
Aggregation Mode: Static
  Port             Status  Priority Oper-Key
  XGE0/0/6         S       32768    1
  XGE0/0/7         S       32768    1
  XGE0/0/8         S       32768    1
The output shows that the member ports added to the static aggregation group at the local end are all in Selected state, regardless of whether the peer ports are in Selected state.
·     Aggregate group information in dynamic aggregation mode
Creation Mode: Manual
Aggregation Mode: Dynamic
Local:
  Port             Status  Priority Oper-Key  Flag
  XGE0/0/6         S       32768    1         {ACDEF}
  XGE0/0/7         S       32768    1         {ACDEF}
  XGE0/0/8         S       32768    1         {ACDEF}
Remote:
  Actor            Partner Priority Oper-Key  SystemID               Flag
  XGE0/0/6         1       32768    1         0x8000, 000f-e267-57ad {ACDEF}
  XGE0/0/7         2       32768    1         0x8000, 000f-e267-57ad {ACDEF}
  XGE0/0/8         3       32768    1         0x8000, 000f-e267-57ad {ACDEF}
The output shows that the aggregation member ports on both the local and the peer devices are in Selected state. To ensure correct user data forwarding, the devices exchange LACP protocol packets over the dynamic aggregate link to maintain consistency of the aggregation state between their aggregation member ports.
Configuration files
·     Device A:
¡     Static aggregation mode.
interface route-aggregation1
¡     Dynamic aggregation mode.
 port link-mode route
·     Device B:
Configuration files on Device B are similar to Device A.
Related documentation
·     H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Guides (V9)
·     H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Command References (V9)
