H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Examples All-in-One-R9141-6W100
HomeSupportRoutersSR6602-I[IE] SeriesConfigure & DeployConfiguration ExamplesH3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
60-Scheduling a Task Configuration Examples
60-Scheduling a Task Configuration Examples 84.80 KB
H3C Routers
Scheduling a Task
Introduction
The following information provides examples for scheduling a task.
This document applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the router.
This document assumes that you have basic knowledge of task scheduling.
Example: Scheduling a task
As shown in Figure 1, Ten-GigabitEthernet 0/0/6 and Ten-GigabitEthernet 0/0/7 on the router are each connected to a host.
Configure the router to perform the following operations:
·     Enable Ten-GigabitEthernet 0/0/6 and Ten-GigabitEthernet 0/0/7 at 8:00 a.m. every Monday through Friday.
·     Disable Ten-GigabitEthernet 0/0/6 and Ten-GigabitEthernet 0/0/7 at 18:00 every Monday through Friday.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on R9141P16 of the SR6602-I device.
·     The command line specified by the command command must be a successfully executable command line on the device.
·     The command line specified by the command command cannot be telnet, ftp, ssh2, or monitor process.
·     Before configuring a schedule task, check if the system time is correct. If the system time is incorrect, configure NTP or execute the clock command to ensure that the device gets the accurate time.
Procedures
1.     Configure a job to disable Ten-GigabitEthernet 0/0/6.
# Create a job named shutdown-Ten-GigabitEthernet 0/0/6 and enter job view.
[Router] scheduler job shutdown-Ten-GigabitEthernet0/0/6
# Assign a command to the job to enter system view.
[Router-job-shutdown-Ten-GigabitEthernet0/0/6] command 1 system-view
# Assign a command to the job to enter Ten-GigabitEthernet 0/0/6 interface view.
[Router-job-shutdown-Ten-GigabitEthernet0/0/6] command 2 interface gigabitethernet 1/0/1
# Assign a command to the job to disable Ten-GigabitEthernet 0/0/6.
[Router-job-shutdown-Ten-GigabitEthernet0/0/6] command 3 shutdown
[Router-job-shutdown-Ten-GigabitEthernet0/0/6] quit
2.     Configure a job to disable Ten-GigabitEthernet 0/0/7.
# Create a job named shutdown-Ten-GigabitEthernet 0/0/7 and enter job view.
[Router] scheduler job shutdown-GigabitEthernet1/0/2
[Router-job-shutdown-GigabitEthernet1/0/2] command 1 system-view
# Assign a command to the job to enter Ten-GigabitEthernet 0/0/7 interface view.
[Router-job-shutdown-GigabitEthernet1/0/2] command 2 interface gigabitethernet 1/0/2
# Assign a command to the job to disable Ten-GigabitEthernet 0/0/7 .
[Router-job-shutdown-GigabitEthernet1/0/2] command 3 shutdown
[Router-job-shutdown-GigabitEthernet1/0/2] quit
3.     Configure a job to enable Ten-GigabitEthernet 0/0/6.
# Create a job named start-Ten-GigabitEthernet 0/0/6 and enter job view.
[Router] scheduler job start-Ten-GigabitEthernet0/0/6
[Router-job-start-Ten-GigabitEthernet0/0/6] command 1 system-view
[Router-job-start-Ten-GigabitEthernet0/0/6] command 2 interface gigabitethernet 1/0/1
# Assign a command to the job to enable Ten-GigabitEthernet 0/0/6.
[Router-job-start-Ten-GigabitEthernet0/0/6] command 3 undo shutdown
[Router-job-start-Ten-GigabitEthernet0/0/6] quit
4.     Configure a job to enable Ten-GigabitEthernet 0/0/7.
# Create a job named start-Ten-GigabitEthernet 0/0/7 and enter job view.
[Router] scheduler job start-GigabitEthernet1/0/2
[Router-job-start-GigabitEthernet1/0/2] command 1 system-view
[Router-job-start-GigabitEthernet1/0/2] command 2 interface gigabitethernet 1/0/2
# Assign a command to the job to enable Ten-GigabitEthernet 0/0/7 .
[Router-job-start-GigabitEthernet1/0/2] command 3 undo shutdown
[Router-job-start-GigabitEthernet1/0/2] quit
5.     Configure a schedule to enable Ten-GigabitEthernet 0/0/6 and Ten-GigabitEthernet 0/0/7 at 8:00 a.m. every Monday through Friday.
# Create a schedule named connect-host1/host2 and enter schedule view.
[Router] scheduler schedule connect-host1/host2
# Assign the job named start-Ten-GigabitEthernet 0/0/6 to the schedule.
[Router-schedule-connect-host1/host2] job start-Ten-GigabitEthernet0/0/6
# Assign the job named start-Ten-GigabitEthernet 0/0/7 to the schedule.
[Router-schedule-connect-host1/host2] job start-GigabitEthernet1/0/2
# Configure the device to execute the schedule at 8:00 a.m. every Monday through Friday.
[Router-schedule-connect-host1/host2] time repeating at 08:00 week-day Mon Tue Wed Thu Fri
[Router-schedule-connect-host1/host2] quit
6.     Configure a schedule to disable Ten-GigabitEthernet 0/0/6 and Ten-GigabitEthernet 0/0/7 at 18:00 every Monday through Friday.
# Create a schedule named unconnect-host1/host2 and enter schedule view.
[Router] scheduler schedule unconnect-host1/host2
# Assign the job named shutdown-Ten-GigabitEthernet 0/0/6 to the schedule.
[Router-schedule-unconnect-host1/host2] job shutdown-Ten-GigabitEthernet0/0/6
# Assign the job named shutdown-Ten-GigabitEthernet 0/0/7 to the schedule.
[Router-schedule-unconnect-host1/host2] job shutdown-GigabitEthernet1/0/2
# Configure the device to execute the schedule at 18:00 every Monday through Friday.
[Router-schedule-unconnect-host1/host2] time repeating at 18:00 week-day Mon Tue Wed Thu Fri
[Router-schedule-unconnect-host1/host2] quit
# Use display scheduler job to display the configuration information of all jobs.
<Router> display scheduler job
Job name: shutdown-Ten-GigabitEthernet0/0/6
 interface Ten-GigabitEthernet0/0/6
 shutdown
Job name: shutdown-GigabitEthernet1/0/2
 shutdown
Job name: start-Ten-GigabitEthernet0/0/6
Job name: start-GigabitEthernet1/0/2
# Use display scheduler schedule to display the schedule information.
<Router> display scheduler schedule
Schedule name        : connect-host1/host2
Schedule type        : Run on every Mon Tue Wed Thu Fri at 08:00:00
Start time           : Thu Nov 14 08:00:00 2013
Last execution time  : Yet to be executed
start-Ten-GigabitEthernet0/0/6                        -NA-
start-GigabitEthernet1/0/2                        -NA-
Schedule name        : unconnect-host1/host2
Schedule type        : Run on every Mon Tue Wed Thu Fri at 18:00:00
Start time           : Wed Nov 13 18:00:00 2013
shutdown-Ten-GigabitEthernet0/0/6                     -NA-
shutdown-GigabitEthernet1/0/2                     -NA-
# Use display ip interface brief to view the status of Layer 3 interfaces at 7:59 a.m.
[Router] display ip interface brief
*down: administratively down
(s): spoofing  (l): loopback
Interface                Physical Protocol IP Address      Description
Ana3/0                   down     down     --              --
Aux0                     up       down     --              --
GE0/0/0                  up       up       192.168.100.67  --
GE1/0/1                  *down    down     --              --
GE1/0/2                  *down    down     --              --
# At 8:00 a.m., the following log information is displayed:
%Apr 22 08:00:10:245 2014 Router IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet0/0/6 changed to up.
%Apr 22 08:00:10:245 2014 Router IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet0/0/6 changed to up.
%Apr 22 08:00:10:250 2014 Router IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/2 changed to up.
%Apr 22 08:00:10:250 2014 Router IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/2 changed to up.
# Use display ip interface brief to view the status of Layer 3 interfaces at 8:00 a.m.
Aux0                     up       down     --              --
GE1/0/1                  up       up       --              --
GE1/0/2                  up       up       --              --
# At 18:00 p.m., the following log information is displayed:
%Apr 22 18:00:06:250 2014 Router IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet0/0/6 changed to down.
%Apr 22 18:00:06:250 2014 Router IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet0/0/6 changed to down.
%Apr 22 18:00:06:256 2014 Router IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/2 changed to down.
%Apr 22 18:00:06:256 2014 Router IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/2 changed to down.
# Use display ip interface brief to view the status of Layer 3 interfaces at 18:00 p.m.
Aux0                     up       down     --              --
GE0/0                    up       up       192.168.100.67  --
Configuration files
 command 2 interface gigabitethernet1/0/1
 command 3 shutdown
 command 2 interface gigabitethernet1/0/2
 command 3 shutdown
Related documentation
·     System Management Configuration Guide in H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Guides(V9)
·     System Management Command Reference in H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Command References(V9)
