H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Examples All-in-One-R9141-6W100
HomeSupportRoutersSR6602-I[IE] SeriesConfigure & DeployConfiguration ExamplesH3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
54-Ethernet OAM Configuration Examples
54-Ethernet OAM Configuration Examples 73.55 KB
H3C Routers
Introduction
The following information provides an example for using Ethernet OAM to monitor link performance.
Ethernet Operation, Administration, and Maintenance (OAM) is a tool that monitors the status of the link between two directly connected devices.
This document assumes that you have basic knowledge of Ethernet OAM.
Example: Configuring Ethernet OAM
As shown in Figure 1, the enterprise network and the ISP network are connected through their respective edge devices, Device A and Device B. Configure Ethernet OAM to monitor the status of the link between Device A and Device B, which helps identify whether the ISP network reliability meets the Service Level Agreement (SLA) with the enterprise customer. The specific requirements are as follows:
·     Enable Ethernet OAM on Device A and Device B to auto-detect link errors between the two devices.
·     Enable the administrator to identify whether a critical link event occurs for the link between Device A and Device B.
·     Enable the administrator to dynamically obtain the link status by observing Ethernet OAM link error event statistics.
Figure 1 Network diagram
Analysis
To set up an OAM connection between Device A and Device B, you must set at least the interface on one end to operate in active mode. You can skip this configuration, because all interfaces on the device operate in active Ethernet OAM mode by default. In this example, configure Ten-GigabitEthernet 0/0/6 on Device A to operate in active Ethernet OAM mode, and configure Ten-GigabitEthernet 0/0/6 on Device B to operate in passive Ethernet OAM mode.
The Ethernet OAM link error events that can be monitored by Ethernet OAM include errored symbol events, errored frame events, errored frame period events, and errored frame seconds events. By default, an interface enabled with Ethernet OAM adopts the global link error detection settings. You can edit the detection settings as needed based on actual network conditions. This example takes the configuration of the errored frame event detection settings for illustration.
Software versions used
This configuration example was created and verified on R9141P16 of the SR6602-I device.
To change the Ethernet OAM mode on an Ethernet OAM-enabled interface, first disable Ethernet OAM on the interface.
Procedures
Configuring Device A
# Configure Ten-GigabitEthernet 0/0/6 to operate in active Ethernet OAM mode (default setting), and enable Ethernet OAM for it.
[DeviceA] interface ten-gigabitethernet 0/0/6
[DeviceA-Ten-GigabitEthernet0/0/6] undo shutdown
[DeviceA-Ten-GigabitEthernet0/0/6] oam mode active
[DeviceA-Ten-GigabitEthernet0/0/6] oam enable
# Set the errored frame event detection window to 20000 milliseconds, and set the errored frame event triggering threshold to 10.
[DeviceA-Ten-GigabitEthernet0/0/6] oam errored-frame window 200
[DeviceA-Ten-GigabitEthernet0/0/6] oam errored-frame threshold 10
[DeviceA-Ten-GigabitEthernet0/0/6] quit
Configuring Device B
# Configure Ten-GigabitEthernet 0/0/6 to operate in passive Ethernet OAM mode, and enable Ethernet OAM for it.
[DeviceB] interface ten-gigabitethernet 0/0/6
[DeviceB-Ten-GigabitEthernet0/0/6] undo shutdown
[DeviceB-Ten-GigabitEthernet0/0/6] oam mode passive
[DeviceB-Ten-GigabitEthernet0/0/6] oam enable
[DeviceB-Ten-GigabitEthernet0/0/6] quit
# Display global Ethernet OAM configuration and  Ethernet OAM configuration on the interfaces that do not use the default settings on Device A.
[DeviceA] display oam configuration
---------------- [Global] ----------------
 OAM timers
   Hello timer        : 1000 milliseconds
   Keepalive timer    : 5000 milliseconds
 Link monitoring
   Errored symbol period
     Window           : 100 x 1000000 symbols
     Threshold        : 1 error symbols
   Errored frame
     Window           : 10 x 100 milliseconds
     Threshold        : 1 error frames
   Errored frame period
     Window           : 1000 x 10000 frames
   Errored frame seconds
     Window           : 600 x 100 milliseconds
     Threshold        : 1 error seconds
----------- [Ten-GigabitEthernet0/0/6] -----------
 OAM timers
 Link monitoring
   Errored frame
     Window           : 200 x 100 milliseconds
     Threshold        : 10 error frames
# Display the statistics of Ethernet OAM critical link events on Device A.
[DeviceA] display oam critical-event
 Local link status   : UP
 Event statistics
   Link fault        : Not occurred
   Dying gasp        : Not occurred
   Critical event    : Not occurred
The output shows that no critical link event occurred on the link between Device A and Device B.
# Display Ethernet OAM link event statistics on the local end of Device A.
[DeviceA] display oam link-event local
 Link status: UP
 OAM local errored frame event
   Event time stamp        : 5789 x 100 milliseconds
   Errored frame window    : 200 x 100 milliseconds
   Errored frame threshold : 10 error frames
   Errored frame           : 13 error frames
   Error running total     : 350 error frames
   Event running total     : 17 events
The output shows that 350 errors occurred after Ethernet OAM is enabled on Device A, among which 17 errors were caused by error frames. The link is unstable.
If the link detection result shows that the link performance is unstable, contact H3C Support for help.
Configuration files
·     Device A
interface Ten-GigabitEthernet0/0/6
 port link-mode bridge
 oam enable
·     Device B
 oam mode passive
 oam enable
Related documentation
·     High Availability Configuration Guide in H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Guides(V9)
·     High Availability Command Reference in H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Command References(V9)
