- H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Examples All-in-One-R9141-6W100
- 01-Local 802.1X Authentication Configuration Examples
- 02-RADIUS-Based 802.1X Authentication Configuration Examples
- 03-AAA Configuration Examples
- 04-ACL Configuration Examples
- 05-MPLS over ADVPN Configuration Examples
- 06-ARP Attack Protection Configuration Examples
- 07-BFD Configuration Examples
- 08-Basic BGP Configuration Examples
- 09-BGP Route Attribute-Based Route Selection Configuration Examples
- 10-CPOS Interface Configuration Examples
- 11-EAA Monitor Policy Configuration Examples
- 12-GRE with OSPF Configuration Examples
- 13-HoVPN Configuration Examples
- 14-IGMP Snooping Configuration Examples
- 15-IGMP Configuration Examples
- 16-IPsec Configuration Examples
- 17-IPsec Digital Certificate Authentication Configuration Examples
- 18-IPv6 IS-IS Configuration Examples
- 19-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 20-IPv6 over IPv4 Manual Tunnel with OSPFv3 Configuration Examples
- 21-IS-IS Configuration Examples
- 22-Combined ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 23-L2TP over IPsec Configuration Examples
- 24-Multi-Instance L2TP Configuration Examples
- 25-L2TP Multidomain Access Configuration Examples
- 26-MPLS L3VPN Configuration Examples
- 27-MPLS OAM Configuration Examples
- 28-MPLS TE Configuration Examples
- 29-Basic MPLS Configuration Examples
- 30-NAT DNS Mapping Configuration Examples
- 31-NetStream Configuration Examples
- 32-NQA Configuration Examples
- 33-NTP Configuration Examples
- 34-OSPFv3 Configuration Examples
- 35-OSPF Configuration Examples
- 36-OSPF Multi-Process Configuration Examples
- 37-OSPF Multi-Instance Configuration Examples
- 38-Portal Configuration Examples
- 39-POS Interace Configuration Examples
- 40-PPP Configuration Examples
- 41-QinQ Configuration Examples
- 42-RBAC Configuration Examples
- 43-RMON Configuration Examples
- 44-IPv4 NetStream Sampling Configuration Examples
- 45-SNMP Configuration Examples
- 46-SRv6 Configuration Examples
- 47-SSH Configuration Examples
- 48-Tcl Commands Configuration Examples
- 49-VLAN Configuration Examples
- 50-VRRP Configuration Examples
- 51-VXLAN over IPsec Configuration Examples
- 52-Cloudnet VPN Configuration Examples
- 53-Ethernet Link Aggregation Configuration Examples
- 54-Ethernet OAM Configuration Examples
- 55-Outbound Bidirectional NAT Configuration Examples
- 56-NAT Hairpin in C-S Mode Configuration Examples
- 57-Load Sharing NAT Server Configuration Examples
- 58-BIDIR-PIM Configuration Examples
- 59-Control Plane-Based QoS Policy Configuration Examples
- 60-Scheduling a Task Configuration Examples
- 61-Client-Initiated L2TP Tunnel Configuration Examples
- 62-LAC-Auto-Initiated L2TP Tunnel Configuration Examples
- 63-Authorized ARP Configuration Examples
- 64-GTS Configuration Examples
- 65-Traffic Policing Configuration Examples
- 66-Traffic Accounting Configuration Examples
- 67-PBR Configuration Examples
- 68-TFTP Client Software Upgrade Configuration Examples
- 69-FTP Client Software Upgrade Configuration Examples
- 70-FTP Server Software Upgrade Configuration Examples
- 71-Routing Policy Configuration Examples
- 72-Software Upgrade from the BootWare Menu Configuration Examples
- 73-Mirroring Configuration Examples
| 40-PPP Configuration Examples | 97.25 KB |
Introduction
The following information provides PPP protocol-related configuration examples.
The following information applies to Comware 9-based router. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
This document assumes that you have basic knowledge of PPP, MP, PPPoE, and DHCP.
Example: Configuring MP+CHAP
As shown in Figure 1, Serial 1/2/0/1:0 and Serial 1/2/1/1:0 of Device A are connected to Serial 1/2/0/1:0 and Serial 1/2/1/1:0 of Device B, respectively. Set up an MP link in MP-group mode. Each PPP link uses CHAP for authentication.
Software versions used
This configuration example was created and verified on R9141P16 of the SR6602-I device.
· Make sure the username and password for CHAP authentication are the same on both ends.
· After a serial interface is configured, you must use the undo shutdown command to bring up the interface.
· When creating a PPP user, you must specify the network option after the class keyword in the local-user command.
Procedures
Configuring Device A
1. Create a local user for Device B, and set the service type to PPP for the local user.
[DeviceA] local-user userb class network
[DeviceA-luser-network-userb] password simple hello
[DeviceA-luser-network-userb] service-type ppp
[DeviceA-luser-network-userb] quit
2. Configure serial interface Serial 1/2/0/1:0, and use the default ISP domain system to perform CHAP authentication for Device B.
[DeviceA] interface serial 1/2/0/1:0
[DeviceA-Serial1/2/0/1:0] link-protocol ppp
[DeviceA-Serial1/2/0/1:0] ppp authentication-mode chap domain system
[DeviceA-Serial1/2/0/1:0] quit
3. Configure serial interface Serial 1/2/1/1:0, and use the default ISP domain system to perform CHAP authentication for Device B.
[DeviceA] interface serial 1/2/1/1:0
[DeviceA-Serial1/2/1/1:0] link-protocol ppp
[DeviceA-Serial1/2/1/1:0] ppp authentication-mode chap domain system
[DeviceA-Serial1/2/1/1:0] quit
4. In the default ISP domain system, configure PPP users to use local authentication.
[DeviceA] domain system
[DeviceA-isp-system] authentication ppp local
5. Create an MP-group interface, and assign an IP address to it.
[DeviceA] interface mp-group 1/2/1
[DeviceA-MP-group1/2/1] ip address 1.1.1.1 24
[DeviceA-MP-group1/2/1] quit
6. Assign serial interface Serial 1/2/0/1:0 to MP-group 1, and bring up the interface.
[DeviceA-Serial1/2/0/1:0] ppp mp mp-group 1/2/1
[DeviceA-Serial1/2/0/1:0] shutdown
[DeviceA-Serial1/2/0/1:0] undo shutdown
7. Assign serial interface Serial 1/2/1/1:0 to MP-group 1, and bring up the interface.
[DeviceA] interface Serial 1/2/1/1:0
[DeviceA-Serial1/2/1/1:0] ppp mp mp-group 1/2/1
[DeviceA-Serial1/2/1/1:0] shutdown
[DeviceA-Serial1/2/1/1:0] undo shutdown
Configuring Device B
1. Configure serial interface Serial 1/2/0/1:0, and enable PPP encapsulation on the interface. Configure the username and password for CHAP authentication on the interface.
[DeviceB] interface serial 1/2/0/1:0
[DeviceB-Serial1/2/0/1:0] link-protocol ppp
[DeviceB-Serial1/2/0/1:0] ppp chap user userb
[DeviceB-Serial1/2/0/1:0] ppp chap password simple hello
[DeviceB-Serial1/2/0/1:0] quit
2. Configure serial interface Serial 1/2/1/1:0, and enable PPP encapsulation on the interface. Configure the username and password for CHAP authentication on the interface.
[DeviceB] interface Serial 1/2/1/1:0
[DeviceB-Serial1/2/1/1:0] link-protocol ppp
[DeviceB-Serial1/2/1/1:0] ppp chap user userb
[DeviceB-Serial1/2/1/1:0] ppp chap password simple hello
[DeviceB-Serial1/2/1/1:0] quit
3. Create an MP-group interface, and assign an IP address to it.
[DeviceB] interface mp-group 1/2/1
[DeviceB-Mp-group1] ip address 1.1.1.2 24
[DeviceB-Mp-group1] quit
4. Assign serial interface Serial 1/2/0/1:0 to MP-group 1, and bring up the interface.
[DeviceB-Serial1/2/0/1:0] ppp mp mp-group 1/2/1
[DeviceB-Serial1/2/0/1:0] shutdown
[DeviceB-Serial1/2/0/1:0] undo shutdown
5. Assign serial interface Serial 1/2/1/1:0 to MP-group 1, and bring up the interface.
[DeviceB-Serial1/2/1/1:0] ppp mp mp-group 1/2/1
[DeviceB-Serial1/2/1/1:0] shutdown
[DeviceB-Serial1/2/1/1:0] undo shutdown
1. Display the MP information of Device A.
Template: Mp-group1/2/1
max-bind: 16, fragment: enabled, min-fragment: 128
Master link: Mp-group1/2/1, Active members: 2, Bundle Multilink
Peer's endPoint descriptor: Mp-group1/2/1
Sequence format: long (rcv)/long (sent)
Bundle Up Time: 2014/07/22 16:51:40:835
0 lost fragments, 5 reordered, 0 unassigned, 0 interleaved
Sequence: 4 (rcv)/5 (sent)
Active member channels: 2 members
Serial1/2/0/1:0 Up-Time:2014/07/22 16:51:40:836
Serial1/2/1/1:0 Up-Time:2014/07/22 16:51:53:542
2. Display information about interface MP-group 1/2/1 on Device A.
[DeviceA] display interface mp-group 1/2/1
MP-group1/2/1
Current state: UP
Line protocol state: UP
Description: MP-group1/2/1 Interface
Bandwidth: 128kbps
Maximum Transmit Unit: 1500
Hold timer: 10 seconds
Internet Address is 1.1.1.1/24 Primary
Link layer protocol: PPP
LCP: opened, MP: opened, IPCP: opened
Physical: MP, baudrate: 128000 bps
Last 300 seconds input rate: 1 bytes/sec, 8 bits/sec, 0 packets/sec
Last 300 seconds output rate: 1 bytes/sec, 8 bits/sec, 0 packets/sec
Input: 8 packets, 466 bytes, 0 drops
Output: 8 packets, 456 bytes, 0 drops
3. Ping the peer IP address from Device A.
Ping 1.1.1.2 (1.1.1.2): 56 data bytes, press CTRL_C to break
56 bytes from 1.1.1.2: icmp_seq=0 ttl=255 time=25.749 ms
56 bytes from 1.1.1.2: icmp_seq=1 ttl=255 time=25.751 ms
56 bytes from 1.1.1.2: icmp_seq=2 ttl=255 time=25.521 ms
56 bytes from 1.1.1.2: icmp_seq=3 ttl=255 time=25.512 ms
56 bytes from 1.1.1.2: icmp_seq=4 ttl=255 time=25.599 ms
--- Ping statistics for 1.1.1.2 ---
round-trip min/avg/max/std-dev = 25.512/25.626/25.751/0.105 ms
<DeviceA>%Jul 22 17:08:22:460 2014 DeviceA PING/6/PING_STATISTICS: Ping statisti
cs for 1.1.1.2: 5 packets transmitted, 5 packets received, 0.0% packet loss, rou
nd-trip min/avg/max/std-dev = 25.512/25.626/25.751/0.105 ms.
Configuration files
· Device A:
interface Serial1/2/0/1:0
ppp mp MP-group1/2/1
interface Serial1/2/1/1:0
interface MP-group1/2/1
ip address 1.1.1.1 255.255.255.0
local-user 123 class network
password cipher $c$3$5ulb/vg58eiBIm5EnilnsZ2cS2Cmwg==
service-type ppp
· Device B:
ppp chap password cipher $c$3$4kD4T3bLZ/lngijhEKIS70/oTbNSkw==
ppp chap user 123
ppp chap password cipher $c$3$mVlcV3W+YQBgmxKePKpZV9tTcaFhXg==
ppp chap user 123
ip address 1.1.1.2 255.255.255.0
Related documentation
· Layer 2—WAN Access Configuration Guide in H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Guides (V9)
· Layer 2—WAN Access Command Reference in H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Command References (V9)
