- H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Examples All-in-One-R9141-6W100
- 01-Local 802.1X Authentication Configuration Examples
- 02-RADIUS-Based 802.1X Authentication Configuration Examples
- 03-AAA Configuration Examples
- 04-ACL Configuration Examples
- 05-MPLS over ADVPN Configuration Examples
- 06-ARP Attack Protection Configuration Examples
- 07-BFD Configuration Examples
- 08-Basic BGP Configuration Examples
- 09-BGP Route Attribute-Based Route Selection Configuration Examples
- 10-CPOS Interface Configuration Examples
- 11-EAA Monitor Policy Configuration Examples
- 12-GRE with OSPF Configuration Examples
- 13-HoVPN Configuration Examples
- 14-IGMP Snooping Configuration Examples
- 15-IGMP Configuration Examples
- 16-IPsec Configuration Examples
- 17-IPsec Digital Certificate Authentication Configuration Examples
- 18-IPv6 IS-IS Configuration Examples
- 19-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 20-IPv6 over IPv4 Manual Tunnel with OSPFv3 Configuration Examples
- 21-IS-IS Configuration Examples
- 22-Combined ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 23-L2TP over IPsec Configuration Examples
- 24-Multi-Instance L2TP Configuration Examples
- 25-L2TP Multidomain Access Configuration Examples
- 26-MPLS L3VPN Configuration Examples
- 27-MPLS OAM Configuration Examples
- 28-MPLS TE Configuration Examples
- 29-Basic MPLS Configuration Examples
- 30-NAT DNS Mapping Configuration Examples
- 31-NetStream Configuration Examples
- 32-NQA Configuration Examples
- 33-NTP Configuration Examples
- 34-OSPFv3 Configuration Examples
- 35-OSPF Configuration Examples
- 36-OSPF Multi-Process Configuration Examples
- 37-OSPF Multi-Instance Configuration Examples
- 38-Portal Configuration Examples
- 39-POS Interace Configuration Examples
- 40-PPP Configuration Examples
- 41-QinQ Configuration Examples
- 42-RBAC Configuration Examples
- 43-RMON Configuration Examples
- 44-IPv4 NetStream Sampling Configuration Examples
- 45-SNMP Configuration Examples
- 46-SRv6 Configuration Examples
- 47-SSH Configuration Examples
- 48-Tcl Commands Configuration Examples
- 49-VLAN Configuration Examples
- 50-VRRP Configuration Examples
- 51-VXLAN over IPsec Configuration Examples
- 52-Cloudnet VPN Configuration Examples
- 53-Ethernet Link Aggregation Configuration Examples
- 54-Ethernet OAM Configuration Examples
- 55-Outbound Bidirectional NAT Configuration Examples
- 56-NAT Hairpin in C-S Mode Configuration Examples
- 57-Load Sharing NAT Server Configuration Examples
- 58-BIDIR-PIM Configuration Examples
- 59-Control Plane-Based QoS Policy Configuration Examples
- 60-Scheduling a Task Configuration Examples
- 61-Client-Initiated L2TP Tunnel Configuration Examples
- 62-LAC-Auto-Initiated L2TP Tunnel Configuration Examples
- 63-Authorized ARP Configuration Examples
- 64-GTS Configuration Examples
- 65-Traffic Policing Configuration Examples
- 66-Traffic Accounting Configuration Examples
- 67-PBR Configuration Examples
- 68-TFTP Client Software Upgrade Configuration Examples
- 69-FTP Client Software Upgrade Configuration Examples
- 70-FTP Server Software Upgrade Configuration Examples
- 71-Routing Policy Configuration Examples
- 72-Software Upgrade from the BootWare Menu Configuration Examples
- 73-Mirroring Configuration Examples
| 23-L2TP over IPsec Configuration Examples | 100.56 KB |
Introduction
The following information provides L2TP over IPsec configuration examples.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of L2TP and IPsec.
Example: Configuring L2TP over IPsec
As shown in Figure 1, Host accesses the LNS-side network through an L2TP tunnel. Configure the network to meet the following requirements:
· The LAC and LNS automatically set up an L2TP tunnel.
· The LAC and LNS use IKE to set up an IPsec security tunnel to encrypt the L2TP traffic.
Software versions used
This configuration example was created and verified on R9141P16 of the SR6602-I device.
Procedures
Configuring the LNS
# Configure local user 1 with the password as 1234.
<LNS> system-view
[LNS] local-user 1 class network
[LNS-luser-network-1] password simple 1234
[LNS-luser-network-1] service-type ppp
[LNS-luser-network-1] quit
# Configure ISP domain system to perform local authentication for PPP users.
[LNS] domain system
[LNS-isp-system] authentication ppp local
[LNS-isp-system] quit
# Enable L2TP.
[LNS] l2tp enable
# Create VT interface 1, and assign IP address 192.168.0.1/24 to the VT interface. Configure the PPP authentication method as PAP on the VT interface, and specify the VT interface to allocate IP address 192.168.0.2 to the PPP client.
[LNS] interface virtual-template 1
[LNS-Virtual-Template1] ip address 192.168.0.1 24
[LNS-Virtual-Template1] ppp authentication-mode pap domain system
[LNS-Virtual-Template1] remote address 192.168.0.2
[LNS-Virtual-Template1] quit
# Create L2TP group 1 in LNS mode, configure the local tunnel name as lns, and specify VT interface 1 for receiving calls from the peer named lac.
[LNS] l2tp-group 1 mode lns
[LNS-l2tp1] tunnel name lns
[LNS-l2tp1] undo tunnel authentication
[LNS-l2tp1] allow l2tp virtual-template 1 remote lac
[LNS-l2tp1] quit
# Configure an ACL.
[LNS] acl number 3000
[LNS-acl-adv-3000] rule permit ip source 10.0.0.2 0 destination 10.0.0.1 0
[LNS-acl-adv-3000] quit
# Configure an IKE keychain.
[LNS] ike keychain l2tp
# Set the pre-shared key to be used for IKE negotiation with peer 10.0.0.1 to abcd.
[LNS-ike-keychain-l2tp] pre-shared-key address 10.0.0.1 key simple abcd
[LNS-ike-keychain-l2tp] quit
# Specify IKE keychain l2tp for IKE profile l2tp.
[LNS] ike profile l2tp
[LNS-ike-profile-l2tp] keychain l2tp
# Set the local ID to IP address 10.0.0.2.
[LNS-ike-profile-l2tp] local-identity address 10.0.0.2
# Configure a peer ID with the identity type of IP address and the value of 10.0.0.1.
[LNS-ike-profile-l2tp] match remote identity address 10.0.0.1
[LNS-ike-profile-l2tp] quit
# Configure an IPsec transform set named l2tp.
[LNS] ipsec transform-set l2tp
# Configure the IPsec transform set to use the 3DES algorithm in CBC mode as the ESP encryption algorithm.
[LNS-ipsec-transform-set-l2tp] esp encryption-algorithm 3des-cbc
# Configure the IPsec transform set to use the MD5 algorithm as the ESP authentication algorithm.
[LNS-ipsec-transform-set-l2tp] esp authentication-algorithm md5
[LNS-ipsec-transform-set-l2tp] quit
# Configure an IPsec policy to use ACL 3000 and IPsec transform set l2tp. Configure the remote IP address for the IPsec tunnel as 10.0.0.1.
[LNS] ipsec policy l2tp 1 isakmp
[LNS-ipsec-policy-isakmp-l2tp-1] security acl 3000
[LNS-ipsec-policy-isakmp-l2tp-1] transform-set l2tp
[LNS-ipsec-policy-isakmp-l2tp-1] ike-profile l2tp
[LNS-ipsec-policy-isakmp-l2tp-1] remote-address 10.0.0.1
[LNS-ipsec-policy-isakmp-l2tp-1] quit
# Assign an IP address to interface GigabitEthernet 1/0/1, which connects to the LAC, and apply an IPsec policy to the interface.
[LNS] interface gigabitethernet 1/0/1
[LNS-GigabitEthernet1/0/1] ip address 10.0.0.2 24
[LNS-GigabitEthernet1/0/1] ipsec apply policy l2tp
[LNS-GigabitEthernet1/0/1] quit
# Assign an IP address to interface GigabitEthernet 1/0/2.
[LNS] interface gigabitethernet 1/0/2
[LNS-GigabitEthernet1/0/2] ip address 15.0.0.1 24
[LNS-GigabitEthernet1/0/2] quit
Configuring the LAC
# Enable L2TP.
<LAC> system-view
[LAC] l2tp enable
# Create L2TP group 1 in LAC mode.
[LAC] l2tp-group 1 mode lac
# Configure the local tunnel name as LAC, and specify LNS IP address 10.0.0.2.
[LAC-l2tp1] tunnel name lac
[LAC-l2tp1] lns-ip 10.0.0.2
[LAC-l2tp1] undo tunnel authentication
[LAC-l2tp1] quit
# Configure an ACL.
[LAC] acl number 3000
# Configure an ACL rule.
[LAC-acl-adv-3000] rule permit ip source 10.0.0.1 0 destination 10.0.0.2 0
[LAC-acl-adv-3000] quit
# Configure a virtual-PPP interface. On the interface, configure the PPP username as 1 and password as 1234, and configure the PPP authentication mode as PAP.
[LAC] interface virtual-PPP 1
[LAC-Virtual-PPP1] ip address ppp-negotiate
[LAC-Virtual-PPP1] ppp pap local-user 1 password simple 1234
[LAC-Virtual-PPP1] quit
# Configure a private network route, so that the packets to the HQ of the company are forwarded through an L2TP tunnel.
[LAC] ip route-static 15.0.0.1 24 Virtual-PPP 1
[LAC] ike keychain l2tp
# Set the pre-shared key to be used for IKE negotiation with peer 10.0.0.2 to abcd.
[LAC-ike-keychain-l2tp] pre-shared-key address 10.0.0.2 key simple abcd
[LAC-ike-keychain-l2tp] quit
[LAC] ike profile l2tp
[LAC-ike-profile-l2tp] keychain l2tp
# Set the local ID to IP address 10.0.0.1.
[LAC-ike-profile-l2tp] local-identity address 10.0.0.1
# Configure a peer ID with the identity type of IP address and the value of 10.0.0.2.
[LAC-ike-profile-l2tp] match remote identity address 10.0.0.2
[LAC-ike-profile-l2tp] quit
[LAC] ipsec transform-set l2tp
[LAC-ipsec-transform-set-l2tp] esp encryption-algorithm 3des-cbc
[LAC-ipsec-transform-set-l2tp] esp authentication-algorithm md5
[LAC-ipsec-transform-set-l2tp] quit
# Configure an IPsec policy to use ACL 3000 and IPsec transform set l2tp. Configure the remote IP address for the IPsec tunnel as 10.0.0.2.
[LAC] ipsec policy l2tp 1 isakmp
[LAC-ipsec-policy-isakmp-l2tp-1] security acl 3000
[LAC-ipsec-policy-isakmp-l2tp-1] transform-set l2tp
[LAC-ipsec-policy-isakmp-l2tp-1] ike-profile l2tp
[LAC-ipsec-policy-isakmp-l2tp-1] remote-address 10.0.0.2
[LAC-ipsec-policy-isakmp-l2tp-1] quit
[LAC] interface gigabitethernet 1/0/2
[LAC-GigabitEthernet1/0/2] ip address 14.0.0.1 24
[LAC-GigabitEthernet1/0/2] quit
# Assign an IP address to interface GigabitEthernet 1/0/1, which connects to the LNS, and apply an IPsec policy to the interface.
[LAC] interface gigabitethernet 1/0/1
[LAC-GigabitEthernet1/0/1] ip address 10.0.0.1 24
[LAC-GigabitEthernet1/0/1] ipsec apply policy l2tp
[LAC-GigabitEthernet1/0/1] quit
# Trigger the LAC to automatically establish an L2TP tunnel.
[LAC-Virtual-PPP1] l2tp-auto-client l2tp-group 1
# Display information about L2TP tunnels and sessions on the LAC.
[LAC] display l2tp tunnel
LocalTID RemoteTID State Sessions RemoteAddress RemotePort RemoteName
23561 63423 Established 1 10.0.0.2 1701 lns
[LAC] display l2tp session
LocalSID RemoteSID LocalTID State
1538 2562 23561 Established
# Display information about L2TP tunnels and sessions on the LNS.
[LNS] display l2tp tunnel
63423 23561 Established 1 10.0.0.1 1701 lac
[LNS] display l2tp session
2562 1538 63423 Established
# Display information about IKE SAs and IPsec SAs on the LAC.
[LAC] display ike sa
Connection-ID Remote Flag DOI
5 10.0.0.2 RD IPSEC
Flags:
RD--READY RL--REPLACED FD-FADING RK-REKEY
[LAC]display ipsec sa
IPsec policy: l2tp
Sequence number: 1
Mode: isakmp
Tunnel id: 0
Encapsulation mode: tunnel
Perfect forward secrecy:
Path MTU: 1443
Tunnel:
local address: 10.0.0.1
remote address: 10.0.0.2
Flow:
sour addr: 10.0.0.1/255.255.255.255 port: 0 protocol: ip
dest addr: 10.0.0.2/255.255.255.255 port: 0 protocol: ip
[Inbound ESP SAs]
SPI: 987342280 (0x3ad9a5c8)
Transform set: ESP-ENCRYPT-3DES-CBC ESP-AUTH-MD5
SA duration (kilobytes/sec): 1843200/3600
SA remaining duration (kilobytes/sec): 1843181/2339
Max received sequence-number: 319
Anti-replay check enable: Y
Anti-replay window size: 64
UDP encapsulation used for nat traversal: N
Status: active
[Outbound ESP SAs]
SPI: 2705574035 (0xa143c893)
SA remaining duration (kilobytes/sec): 1843182/2339
Max sent sequence-number: 301
Status: active
# Display information about IKE SAs and IPsec SAs on the LNS.
[LNS] display ike sa
1 10.0.0.1 RD IPSEC
Flags:
[LNS] display ipsec sa
IPsec policy: l2tp
Sequence number: 1
Mode: isakmp
Tunnel id: 0
Path MTU: 1443
Tunnel:
local address: 10.0.0.2
remote address: 10.0.0.1
Flow:
sour addr: 10.0.0.2/255.255.255.255 port: 0 protocol: ip
dest addr: 10.0.0.1/255.255.255.255 port: 0 protocol: ip
[Inbound ESP SAs]
SA remaining duration (kilobytes/sec): 1843181/2300
Max received sequence-number: 310
Status: active
[Outbound ESP SAs]
SA remaining duration (kilobytes/sec): 1843180/2300
Max sent sequence-number: 329
Status: active
# Verify that the subnet to which Host A belongs can access the external network through the L2TP tunnel.
[LAC] ping -a 14.0.0.1 15.0.0.1
Ping 15.0.0.1 (15.0.0.1) from 14.0.0.1: 56 data bytes, press escape sequence to break
56 bytes from 15.0.0.1: icmp_seq=0 ttl=255 time=0.462 ms
56 bytes from 15.0.0.1: icmp_seq=1 ttl=255 time=0.280 ms
56 bytes from 15.0.0.1: icmp_seq=2 ttl=255 time=0.276 ms
56 bytes from 15.0.0.1: icmp_seq=3 ttl=255 time=0.280 ms
56 bytes from 15.0.0.1: icmp_seq=4 ttl=255 time=0.280 ms
--- Ping statistics for 15.0.0.1 ---
round-trip min/avg/max/std-dev = 0.276/0.316/0.462/0.073 ms
[LAC]%Jul 3 14:01:16:689 2013 LAC PING/6/PING_STATIS_INFO: Ping statistics for 15.0.0.1: 5 packet(s) transmitted, 5 packet(
s) received, 0.0% packet loss, round-trip min/avg/max/std-dev = 0.276/0.316/0.462/0.073 ms.
Configuration files
· LNS:
interface Virtual-Template1
ip address 192.168.0.1 255.255.255.0
port link-mode route
combo enable copper
ip address 10.0.0.2 255.255.255.0
ip address 15.0.0.1 255.255.255.0
ip route-static 14.0.0.0 24 192.168.0.2
acl number 3000
rule 0 permit ip source 10.0.0.2 0 destination 10.0.0.1 0
domain system
password cipher $c$3$1dZEFYrvdICeeFOnqOoFpzXF8G0dZ+4=
service-type ppp
transform-set l2tp
security acl 3000
ike-profile l2tp
tunnel name lns
l2tp enable
ike profile l2tp
keychain l2tp
match remote identity address 10.0.0.1 255.255.255.255
ike keychain l2tp
pre-shared-key address 10.0.0.1 255.255.255.255 key cipher $c$3$7tvgEkFh6On3KIybUaywz5NDiHtwJqU=
· LAC:
interface Virtual-PPP1
ppp pap local-user 1 password cipher $c$3$i132FpC8DcHeIet4NXtmz6ot44xY8ts=
ip address 10.0.0.1 255.255.255.0
ip address 14.0.0.1 255.255.255.0
acl number 3000
rule 0 permit ip source 10.0.0.1 0 destination 10.0.0.2 0
domain system
transform-set l2tp
security acl 3000
ike-profile l2tp
lns-ip 10.0.0.2
tunnel name lac
l2tp enable
ike profile l2tp
keychain l2tp
match remote identity address 10.0.0.2 255.255.255.255
ike keychain l2tp
pre-shared-key address 10.0.0.2 255.255.255.255 key cipher $c$3$3ErJJ2M1lhES32CdsR3ofs5CdLvPJGk=
Related documentation
· Layer 2—WAN Access Configuration Guide in H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Guides (V9)
· Layer 2—WAN Access Command Reference in H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Command References (V9)
· Security Configuration Guide in H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Guides (V9)
· Security Command Reference in H3C SR6602-I[IE] AI-Powered ICT Converged Gateways Command References (V9)
