H3C S6805 & S6825 & S6850 & S9850 & S9820 Config Examples-Release 66xx-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C S6805 & S6825 & S6850 & S9850 & S9820 Config Examples-Release 66xx-6W100
Table of Contents
Related Documents
79-MOD and Elephant and Mice Flow Configuration Examples
H3C S6805 & S6825 &S6850 & S9850 & S9820
Copyright © 2020-2023 New H3C Technologies Co., Ltd. All rights reserved.
Introduction· 1
Prerequisites· 1
General restrictions and guidelines· 1
Example: Configuring MOD·· 1
Network configuration· 1
Analysis· 2
Applicable hardware and software versions· 2
Prerequisites· 2
Procedures· 3
Configuring Device A· 3
Configuring Device B, Device C, Device D, and Device E· 4
Verifying the configuration· 4
Verifying the configuration on Device A· 4
Verifying the configuration on Device B, Device C, Device D, and Device E· 5
Analyzing MOD packets received by the collector 5
Configuration files· 6
Example: Configuring simple MOD·· 7
Network configuration· 7
Analysis· 8
Applicable hardware and software versions· 8
Procedures· 9
Configuring Device A· 9
Configuring Device B, Device C, Device D, and Device E· 10
Verifying the configuration· 10
Verifying the configuration on Device A· 10
Verifying the configuration on Device B, Device C, Device D, and Device E· 11
Analyzing MOD packets received by the collector 11
Configuration files· 12
Example: Distinguishing elephant and mice flows· 13
Network configuration· 13
Analysis· 13
Applicable hardware and software versions· 14
Prerequisites· 14
Procedures· 14
Configuring Device A· 14
Configuring Device B, Device C, Device D, and Device E· 15
Verifying the configuration· 16
Verifying the configuration on Device A· 16
Verifying the configuration on Device B, Device C, Device D, and Device E· 16
Observing traffic sending during congestion· 16
Configuration files· 16
Related documentation· 17
Introduction
Mirror On Drop (MOD) can detect packet drops during the forwarding process on the device. When a packet is dropped, MOD can send the packet drop reason and the characteristics of the dropped packet to the collector.
Distinguishing elephant and mice flows can identify elephant flows and assign a high drop precedence, local precedence, or 802.1p priority value to these flows, thus improving application performance for mice flows.
This document provides examples for configuring MOD and for configuring elephant/mice flow distinguishing.
This document assumes that you have basic knowledge of MOD and elephant and mice flow distinguishing.
When you configure MOD follow these restrictions and guidelines:
·     A flow group can reference only one ACL. An ACL referenced by a flow group supports only the 5-tuple (source IP address, destination IP address, source port number, destination port number, and protocol) and DSCP priority match items.
·     Because a flow can belong to only one flow group, make sure the same flow is not assigned to more than one flow group when specifying ACLs.
·     MOD takes effect only on packets matching ACLs referenced by flow groups.
·     To delete an applied flow group, first remove the application and then delete the flow group.
·     Only one flow group can be applied.
·     You cannot modify the name or mode of an existing flow group.
As shown in Figure 1, the network uses a spine-leaf architecture. Configure MOD on the spine device and leaf devices to identify whether packets are dropped during the forwarding process on the devices.
Figure 1 Network diagram
Analysis
To generate flow entries based on the flow group, configure the flow group mode to MOD.
Configure MOD to monitor packet drops based on the reason list.
Configure MOD sampling to send sampled packets to the collector through UDP.
Hardware
Software version
S6805 switch series
Release 6616, Release 6616P01, Release 6635 and later
S6825 switch series
S6850 switch series
S9850 switch series
S9820-64H switch
S9820-8C switch
Not supported
# Set the hardware resource operating mode to EM, save the configuration, and reboot the device.
[DeviceA] hardware-resource switch-mode EM
Do you want to change the specified hardware resource working mode? [Y/N]:y
The hardware resource working mode is changed, please save the configuration and reboot the system to make it effective.
You can use the display hardware-resource switch-mode command to view the hardware resource operating mode.
# Configure the hardware resource operating mode on Device B, Device C, Device D, and Device E in the same way it is configured on Device A.
Procedures
Configuring IP addresses for interfaces
# Configure interfaces HundredGigE 1/0/1 through HundredGigE 1/0/3 to operate in Layer 3 mode, and configure an IP address for each interface.
[DeviceA] interface hundredgige 1/0/1
[DeviceA-HundredGigE1/0/1] port link-mode route
[DeviceA-HundredGigE1/0/1] ip address 10.1.2.2 24
[DeviceA-HundredGigE1/0/1] quit
[DeviceA] interface hundredgige 1/0/2
[DeviceA-HundredGigE1/0/2] port link-mode route
[DeviceA-HundredGigE1/0/2] ip address 20.1.2.2 24
[DeviceA-HundredGigE1/0/2] quit
[DeviceA] interface hundredgige 1/0/3
[DeviceA-HundredGigE1/0/3] port link-mode route
[DeviceA-HundredGigE1/0/3] ip address 30.1.2.2 24
[DeviceA-HundredGigE1/0/3] quit
Configuring a routing protocol
# Configure OSPF.
[DeviceA] ospf 1 router-id 1.1.1.1
[DeviceA-ospf-1] area 0
[DeviceA-ospf-1-area-0.0.0.0] network 10.1.2.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] network 20.1.2.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] network 30.1.2.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] quit
[DeviceA-ospf-1] quit
Configuring a flow group
# Create advanced IPv4 ACL 3000, and configure a rule to match packets with destination IP address 10.0.0.10 for the ACL.
[DeviceA] acl advanced 3000
[DeviceA-acl-ipv4-adv-3000] rule permit ip destination 30.1.1.2 0
[DeviceA-acl-ipv4-adv-3000] quit
# Create flow group 1 in MOD mode and configure it to reference ACL 3000.
[DeviceA] telemetry flow-group 1
[DeviceA-telemetry-flow-group-1] if-match acl 3000
# Configure the flow group to generate flow entries based on the destination IP address.
[DeviceA-telemetry-flow-group-1] template destination-ip
[DeviceA-telemetry-flow-group-1] quit
# Set the flow entry aging time to 10 minutes.
[DeviceA] telemetry flow-group aging-time 10
# Apply flow group 1.
[DeviceA] telemetry apply flow-group 1
Configuring MOD
# Configure the device ID for MOD as 10.1.2.2.
[DeviceA] telemetry mod
[DeviceA-telemetry-mod] device-id 10.1.2.2
[DeviceA-telemetry-mod] quit
# Create sampler samp, set the sampling mode to random, and set the sampling rate to 2 to the 8th power.
[DeviceA] sampler samp mode random packet-interval n-power 8
# Enable sampling for MOD, and reference sampler samp.
[DeviceA-telemetry-mod] sampler samp
# Specify UDP for MOD to use to send packets to the collector.
[DeviceA-telemetry-mod] transport-protocol udp
# Encapsulate the packets sent to the collector by MOD with the following information: source IP address 10.1.2.2, destination IP address 40.1.1.1, source port number 1000, and destination port number 2333.
[DeviceA-telemetry-mod] collector source-ip 10.1.2.2 destination-ip 40.1.1.1 source-port 1000 destination-port 2333
# Configure MOD to monitor all packet drop reasons.
[DeviceA-telemetry-mod] reason-list all
[DeviceA] quit
# Configure Device B, Device C, Device D, and Device E in the same way Device A is configured except for the following items:
·     Interface IP addresses.
·     OSPF router ID and network segments.
·     Device ID for MOD.
·     Source IP address encapsulated in the packets sent to the collector.
# Display the ACL configuration.
<DeviceA> display acl 3000
Advanced IPv4 ACL 3000, 1 rule,
ACL's step is 5, start ID is 0
 rule 0 permit ip destination 30.1.1.2 0
# Display the flow group configuration.
<DeviceA> display telemetry flow-group 1
Flow group 1 (Successful)
  ACL       : 3000
  Template  : destination-ip
  Mode      : MOD
Aging time: 10 minutes
Rate limit -
Max-entry -
# Display the MOD configuration.
<DeviceA> display telemetry mod
Status          : Successful
Drop reason list:
  ipv4-dip-miss
  ip-multicast-error
  unknown-vlan
  ipv4-l3-header-error
  tunnel-header-error
  parity-error
  higig-header-error
  invalid-tpid
Sampler            : samp
Device ID          : 10.1.2.2
Transport protocol : UDP
Collector
  Source IP        : 10.1.2.2
  Destination IP   : 40.1.1.1
  Source port      : 1000
  Destination port : 2333
The configurations on Device B, Device C, Device D, and Device E are the same as the configuration on Device A except for interface IP addresses, OSPF router ID and network segments, the device ID for MOD, and the source IP address encapsulated in the packets sent to the collector. (Details not shown.)
# Ping Host C from Device A.
<DeviceA> ping 30.1.1.2
Ping 30.1.1.2 (30.1.1.2): 56 data bytes, press CTRL+C to break
56 bytes from 30.1.1.2: icmp_seq=0 ttl=255 time=4.703 ms
56 bytes from 30.1.1.2: icmp_seq=1 ttl=255 time=1.636 ms
56 bytes from 30.1.1.2: icmp_seq=2 ttl=255 time=1.733 ms
56 bytes from 30.1.1.2: icmp_seq=3 ttl=255 time=1.662 ms
56 bytes from 30.1.1.2: icmp_seq=4 ttl=255 time=1.606 ms
--- Ping statistics for 30.1.1.2 ---
round-trip min/avg/max/std-dev = 1.606/2.268/4.703/1.218 ms
# Modify the configuration of Device E.
<DeviceE> system-view
[DeviceE] ospf 1
[DeviceE-ospf-1] area 0
[DeviceE-ospf-1-area-0.0.0.0] undo network 30.1.2.0 0.0.0.255
[DeviceE-ospf-1-area-0.0.0.0] quit
[DeviceE-ospf-1] quit
Request time out
Request time out
Request time out
Request time out
Request time out
5 packet(s) transmitted, 0 packet(s) received, 100.0% packet loss
When a packet destined for Host C is dropped during the forwarding process on the spine device and leaf devices, the collector can receive the packet drop reason and the characteristics of the dropped packet from the devices.
In this example, the packet drop information received by the collector showed that Device A dropped packets and the packet drop reason is ipv4-dip-miss. This indicates that there is no route on Device A to Host C. After you recover the OSPF configuration on Device E, Host C can receive the packets.
Configuration files
·     Device A:
 area 0.0.0.0
interface HundredGigE1/0/1
 ip address 10.1.2.2 255.255.255.0
interface HundredGigE1/0/2
 ip address 20.1.2.2 255.255.255.0
interface HundredGigE1/0/3
 ip address 30.1.2.2 255.255.255.0
acl advanced 3000
telemetry mod
 reason-list all
 device-id 10.1.2.2
 sampler samp
telemetry flow-group 1 mode mod
 if-match acl 3000
·     Device B, Device C, Device D, and Device E:
As shown in Figure 2, the network uses a spine-leaf architecture. Configure simple MOD on the spine device and leaf devices to identify whether packets are dropped during the forwarding process on the devices.
Figure 2 Network diagram
Analysis
To generate flow entries based on the flow group, configure the flow group mode to simple MOD.
Configure simple MOD to monitor packet drops based on the reason list.
Hardware
Software version
S6805 switch series
S6825 switch series
S6850 switch series
S9850 switch series
S9820-64H switch
S9820-8C switch
Procedures
# Configure OSPF.
# Create flow group 2 in simple MOD mode and configure it to reference ACL 3000.
[DeviceA] telemetry flow-group 2 mode simple-mod
[DeviceA-telemetry-flow-group-2] if-match acl 3000
[DeviceA-telemetry-flow-group-2] template destination-ip
[DeviceA-telemetry-flow-group-2] quit
# Apply flow group 2.
[DeviceA] telemetry apply flow-group 2
# Configure the device ID for simple MOD as 10.1.2.2.
# Specify UDP for simple MOD to use to send packets to the collector.
# Encapsulate the packets sent to the collector by simple MOD with the following information: source IP address 10.1.2.2, destination IP address 40.1.1.1, source port number 1000, and destination port number 2333.
# Configure simple MOD to monitor all packet drop reasons.
[DeviceA] quit
Device ID for simple MOD.
<Device> display telemetry flow-group 2
Flow group 2 (Successful)
  ACL       : 3000
  Mode      : Simple MOD
Rate limit -
Max-entry -
# Display the simple MOD configuration.
Status          : Successful
Drop reason list:
  ipv4-dip-miss
  ip-multicast-error
  unknown-vlan
  tunnel-header-error
  parity-error
  higig-header-error
Collector
  Source port      : 1000
The configurations on Device B, Device C, Device D, and Device E are the same as the configuration on Device A except for interface IP addresses, OSPF configuration, the device ID for simple MOD, and the source IP address encapsulated in the packets sent to the collector. (Details not shown.)
[DeviceE] ospf 1
Request time out
Request time out
Request time out
Request time out
Request time out
Configuration files
·     Device A:
 area 0.0.0.0
acl advanced 3000
telemetry mod
 reason-list all
 device-id 10.1.2.2
telemetry flow-group 21 mode simple-mod
 if-match acl 3000
The configurations on Device B, Device C, Device D, and Device E are the same as the configuration on Device A except for interface IP addresses, OSPF router ID and network segments, the device ID for simple MOD, and the source IP address encapsulated in the packets sent to the collector. (Details not shown.)
As shown in Figure 3, the network uses a spine-leaf architecture. The 10.1.1.0/24 segment is deployed with mission-critical applications and also sends and receives mice flows such as IM messages. Configure elephant and mice flows distinguishing to identify high-bandwidth, delay-insensitive flows so the device preferentially transmits mice flows when congestion occurs.
Figure 3 Network diagram
Analysis
To generate flow entries based on the flow group, configure the flow group mode to elephant/mice flow mode.
For the device to preferentially transmit mice flows when congestion occurs, configure the traffic thresholds to identify elephant flows.
Hardware
Software version
S6805 switch series
S6825 switch series
S6850 switch series
S9850 switch series
S9820-64H switch
S9820-8C switch
Not supported
Procedures
# Configure OSPF.
# Create advanced IPv4 ACL 3000, and configure a rule to match packets with source or destination IP address 10.0.0.10 for the ACL.
[DeviceA-acl-ipv4-adv-3000] rule permit ip destination 10.1.1.0 0.0.0.255
[DeviceA-acl-ipv4-adv-3000] rule permit ip source 10.1.1.0 0.0.0.255
# Create flow group 3 in elephant/mice flow mode and configure it to reference ACL 3000.
[DeviceA] telemetry flow-group 3 mode mice-elephant-flow
[DeviceA-telemetry-flow-group-3] if-match acl 3000
# Configure the flow group to generate flow entries based on the destination and source IP addresses.
[DeviceA-telemetry-flow-group-3] template destination-ip source-ip
[DeviceA-telemetry-flow-group-3] quit
# Apply flow group 3.
[DeviceA] telemetry apply flow-group 3
# Specify the traffic thresholds as 20 kbps and 100 KB for identifying elephant flows.
[DeviceA] qos mice-elephant-flow
[DeviceA-mice-elephant-flow] elephant-flow rate 20 kbps size 100 kbytes
# Specify drop precedence 2 for elephant flows.
[DeviceA-mice-elephant-flow] elephant-flow action drop-precedence 2
[DeviceA-mice-elephant-flow] quit
[DeviceA] quit
Advanced IPv4 ACL 3000, 2 rules,
 rule 0 permit ip destination 10.1.1.0 0.0.0.255
 rule 5 permit ip source 10.1.1.0 0.0.0.255
<DeviceA> display telemetry flow-group 3
Flow group 3 (Successful)
  ACL       : 3000
  Template  :
    destination-ip
    source-ip
  Mode      : Mice elephant flow
Rate limit -
Max-entry -
# Display the elephant/mice flow configuration.
<DeviceA> display current-configuration | include elephant
 elephant-flow rate 20 size 100 kbytes
The configurations on Device B, Device C, Device D, and Device E are the same as the configuration on Device A except for interface IP addresses, OSPF router ID and network segments. (Details not shown.)
The device on the 10.1.1.0/24 segment preferentially sends mice flows to prevent them from being affected by elephant flows.
Configuration files
·     Device A:
 area 0.0.0.0
acl advanced 3000
 if-match acl 3000
 template source-ip destination-ip
Use this document in conjunction with the following documents for the product and software version you are working with:
·     Telemetry Configuration Guide
·     Telemetry Command Reference
  • Become a Partner
  • Partner Resources
