H3C S6805 & S6825 & S6850 & S9850 & S9820 Config Examples-Release 66xx-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C S6805 & S6825 & S6850 & S9850 & S9820 Config Examples-Release 66xx-6W100
Table of Contents
Related Documents
37-AAA Configuration Examples
37-AAA Configuration Examples 1.29 MB
H3C S6805 & S6825& S6850 & S9850 & S9820
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides AAA configuration examples for Telnet and SSH users.
This document assumes that you have basic knowledge of AAA.
Example: Configuring HWTACACS authentication and authorization in ACS for Telnet users
As shown in Figure 1, configure the device to meet the following requirements:
·     The HWTACACS server is used to provide authentication and authorization services for Telnet users.
·     The authenticated users are permitted to execute the display commands of all system features and resources.
Add a user account with username user@bbb and password aabbcc on the HWTACACS server.
Figure 1 Network diagram
Analysis
To meet the network requirements, you must perform the following tasks:
·     Configure the Telnet username and password on the HWTACACS server to identify valid users.
·     For Telnet users to perform AAA, set the authentication mode to scheme on VTY user lines.
·     Configure the same shared key on the device and the HWTACACS server to secure HWTACACS communication. When the shared key is configured, the device and the HWTACACS server transfer passwords safely and the device can verify the integrity of each HWTACACS response.
·     Configure HWTACACS authentication and authorization by performing the following tasks on the device:
¡     Create an HWTACACS scheme.
¡     Specify the authentication and authorization servers.
¡     Apply the HWTACACS scheme to the ISP domain to which the Telnet users belong on the device.
·     Configure the HWTACACS server to assign the network-operator user role to the users, so the users can use all display commands.
Hardware
Software version
S6805 series
Release 6607, Release 6616, Release 6616P01, Release 6635, and later versions
S6825 series
S6850 series
S9850 series
Release 6555P01, Release 6607, Release 6616, Release 6616P01, Release 6635, and later versions
S9820-64H
S9820-8C
Procedures
Configuring the HWTACACS server
In this example, the server runs ACS 4.0.
Adding a user
1.     In the navigation tree, click User Setup.
2.     Enter user@bbb in the User field and click Add/Edit, as shown in Figure 2.
Figure 2 Adding a user
Configuring the user
1.     On the User Setup page, configure the following parameters, as shown in Figure 3:
¡     Enter aabbcc in the Password and Confirm Password fields.
¡     Assign the user to user group Group 1.
Figure 3 Configuring the user password
2.     Click Submit.
Configuring the network settings
1.     In the navigation tree, click Network Configuration.
2.     On the Add AAA Client page, configure the following parameters, as shown in Figure 4:
¡     Enter an AAA client hostname in the AAA Client Hostname field. This example uses Device.
¡     Enter 10.1.1.2 in the AAA Client IP Address field.
The IP address is the source IP address for outgoing HWTACACS packets on the device.
¡     Enter expert in the Key field.
The key configured here is the same as the authentication, authorization, and accounting keys configured on the device for secure HWTACACS communication.
¡     Select TACACS+ (Cisco IOS) from the Authenticate Using list.
Figure 4 Configuring the network settings
3.     Click Submit + Apply.
Configuring the user group
1.     In the navigation tree, click Group Setup.
2.     Select 1: Group 1 (29 users) from the Group list and click Edit Settings, as shown in Figure 5.
Figure 5 Selecting a user group
3.     On the TACACS+ Settings page, configure the following parameters, as shown in Figure 6:
¡     Select Shell(exec), which enables command execution for all users in the group.
¡     Select Custom attributes, and enter roles=\"network-operator\" in the Custom attributes field.
¡     Configure other settings as needed.
Figure 6 Configuring the user group
4.     Click Submit.
Configuring the device
# Create VLAN 2 and assign HundredGigE 1/0/2 to the VLAN.
[Device] vlan 2
[Device-vlan2] port hundredgige 1/0/2
[Device-vlan2] quit
# Assign an IP address to VLAN-interface 2.
[Device] interface vlan-interface 2
[Device-Vlan-interface2] ip address 192.168.57.12 255.255.255.0
[Device-Vlan-interface2] quit
# Create VLAN 3 and assign HundredGigE 1/0/1 to the VLAN.
[Device] vlan 3
[Device-vlan3] port hundredgige 1/0/1
[Device-vlan3] quit
# Assign an IP address to VLAN-interface 3.
[Device] interface vlan-interface 3
[Device-Vlan-interface3] ip address 10.1.1.2 255.255.255.0
[Device-Vlan-interface3] quit
# Enable the Telnet server feature.
[Device] telnet server enable
# Enable scheme authentication on VTY user lines 0 through 63.
[Device] line vty 0 63
[Device-line-vty0-63] authentication-mode scheme
[Device-line-vty0-63] quit
# Create an HWTACACS scheme named hwtac.
[Device] hwtacacs scheme hwtac
# Specify the primary HWTACACS server with the IP address 10.1.1.1 and port number 49.
[Device-hwtacacs-hwtac] primary authentication 10.1.1.1 49
[Device-hwtacacs-hwtac] primary authorization 10.1.1.1 49
[Device-hwtacacs-hwtac] primary accounting 10.1.1.1 49
# Specify the shared key as expert for secure HWTACACS communication between the device and HWTACACS server.
[Device-hwtacacs-hwtac] key authentication simple expert
[Device-hwtacacs-hwtac] key authorization simple expert
[Device-hwtacacs-hwtac] key accounting simple expert
[Device-hwtacacs-hwtac] quit
# Create an ISP domain named bbb, and specify the domain to use HWTACACS scheme hwtac as the AAA methods of login users.
[Device] domain bbb
[Device-isp-bbb] authentication login hwtacacs-scheme hwtac
[Device-isp-bbb] authorization login hwtacacs-scheme hwtac
[Device-isp-bbb] accounting login hwtacacs-scheme hwtac
[Device-isp-bbb] quit
# Telnet to the device, and enter username user@bbb and password aabbcc. The user logs into the device. (Details not shown.)
# Verify that the user can use the display commands of all system features and resources. (Details not shown.)
Configuration files
vlan 2 to 3
interface Vlan-interface2
interface Vlan-interface3
interface HundredGigE1/0/2
 port link-mode bridge
 port access vlan 2
interface HundredGigE1/0/1
 port access vlan 3
line vty 0 63
 user-role network-operator
 key authentication cipher $c$3$X3oR/wjLFjDqIyjdAmvjwAhiuqewGABglQ==
 key authorization cipher $c$3$5pmuq0RJ9UWMWDkRNNERX6HFM0aRv5txFg==
 key accounting cipher $c$3$FSdSiBY1u+ZNkAYYlPw9YkGxJA4iR8MDjw==
 domain bbb
Example: Configuring RADIUS authentication and authorization in IMC for SSH users
As shown in Figure 7, configure the device to meet the following requirements:
·     The RADIUS servers are used to provide authentication and authorization services for SSH users. One server acts as the primary server and the other acts as the secondary server.
·     Domain names are included in the usernames sent to the RADIUS servers.
·     The authenticated users are permitted to use the display commands of all system features and resources.
The RADIUS servers run IMC. Add a user account with username hello@bbb and password aabbcc on each RADIUS server.
Figure 7 Network diagram
Analysis
·     Configure the SSH username and password on the primary and secondary RADIUS servers to identify valid users.
·     For SSH users to perform AAA, set the authentication mode to scheme on VTY user lines.
·     Configure the same shared key on the device and the RADIUS servers to secure RADIUS communication. When the shared key is configured, the device and the RADIUS servers transfer passwords safely and the device can verify the integrity of each RADIUS response.
·     Configure RADIUS authentication and authorization by performing the following tasks on the device:
¡     Create a RADIUS scheme.
¡     Specify the primary and secondary servers for authentication and authorization.
¡     Apply the RADIUS scheme to the ISP domain to which the SSH users belong.
·     Configure the RADIUS servers to assign the network-operator user role to the users, so the users can use all display commands.
Hardware
Software version
S6805 series
S6825 series
S6850 series
S9850 series
S9820-64H
S9820-8C
When you configure RADIUS authentication and authorization for SSH users, follow these restrictions and guidelines:
·     The Stelnet server supports only 256-bit and 384-bit ECDSA key pairs.
·     Local DSA, ECDSA, and RSA key pairs for SSH use default names. You cannot assign names to the key pairs.
Procedures
Configuring RADIUS servers
In this example, RADIUS servers run IMC PLAT 7.0 (E0102) and IMC UAM 7.0 (E0201). This example describes the configuration of the primary RADIUS server. Configure the secondary RADIUS server in the same way the primary RADIUS server is configured.
Adding the device to IMC as an access device
1.     Click the User tab.
2.     From the navigation tree, select User Access Policy > Access Device Management > Access Device.
The access device list appears.
3.     Click Add.
4.     On the Add Access Device page, configure the following parameters, as shown in Figure 8:
¡     Enter 1812 and 1813 in the Authentication Port and Accounting Port fields, respectively.
¡     Enter expert in the Shared Key and Confirm Shared Key fields.
¡     Select Device Management Service from the Service Type list.
¡     Select H3C(General) from the Access Device Type list.
¡     Use the default values for other parameters in the Access Configuration area.
¡     In the Device List area, click Select or Add Manually to add the device (10.1.1.2) to IMC as an access device.
Figure 8 Adding an access device
5.     Click OK.
Adding a device management user
2.     From the navigation tree, select Access User > Device User.
The device management user list appears.
3.     Click Add.
4.     On the Add Device User page, configure the following parameters, as shown in Figure 9:
¡     Enter hello@bbb in the Account Name field.
¡     Enter aabbcc in the User Password and Confirm Password fields.
¡     Select SSH from the Service Type list.
¡     Enter network-operator in the Role Name field.
The network-operator user role has access to the display commands of all system features and resources.
¡     In the IP Address List of Managed Devices area, click Add to specify an IP segment (from 10.1.1.0 to 10.1.1.255) for management. The IP segment must contain the IP address of the access device.
Figure 9 Adding a device management user
5.     Click OK.
[Device] vlan 2
[Device-vlan2] quit
[Device-Vlan-interface2] ip address 192.168.1.70 255.255.255.0
[Device] vlan 3
[Device-vlan3] quit
# Create a local RSA key pair.
[Device] public-key local create rsa
The range of public key modulus is (512 ~ 4096).
If the key modulus is greater than 512, it will take a few minutes.
Press CTRL+C to abort.
Generating Keys...
# Create a local DSA key pair.
[Device] public-key local create dsa
The range of public key modulus is (512 ~ 2048).
Generating Keys...
# Create a 256-bit ECDSA key pair.
[Device] public-key local create ecdsa secp256r1
Generating Keys...
# Create a 384-bit ECDSA key pair.
[Device] public-key local create ecdsa secp384r1
Generating Keys...
# Enable the Stelnet server.
[Device] ssh server enable
# Create a RADIUS scheme named rad.
[Device] radius scheme rad
# Specify the primary authentication RADIUS server with the IP address 10.1.1.1 and port number 1812.
[Device-radius-rad] primary authentication 10.1.1.1 1812
# Specify the secondary authentication RADIUS server with the IP address 10.1.1.11 and port number 1812.
[Device-radius-rad] secondary authentication 10.1.1.11 1812
# Specify the primary accounting RADIUS server with the IP address 10.1.1.1 and port number 1813.
[Device-radius-rad] primary accounting 10.1.1.1 1813
# Specify the secondary accounting RADIUS server with the IP address 10.1.1.11 and port number 1813.
[Device-radius-rad] secondary accounting 10.1.1.11 1813
# Set the authentication and accounting shared keys to expert in plain text for secure communication between the device and the RADIUS server.
[Device-radius-rad] key authentication simple expert
[Device-radius-rad] key accounting simple expert
# Include domain names in the usernames sent to the RADIUS server.
[Device-radius-rad] user-name-format with-domain
[Device-radius-rad] quit
# Create an ISP domain named bbb, and configure the ISP domain to use the RADIUS scheme rad as the AAA methods of login users.
[Device] domain bbb
[Device-isp-bbb] authentication login radius-scheme rad
[Device-isp-bbb] authorization login radius-scheme rad
[Device-isp-bbb] accounting login radius-scheme rad
# Initiate an SSH connection to the device, and enter username hello@bbb and password aabbcc. The user logs into the device. (Details not shown.)
# Display RADIUS scheme configuration.
<Sysname> display radius scheme
Total 1 RADIUS schemes
RADIUS scheme name: rad
  Index: 0
  Primary authentication server:
    Host name: Not Configured
    IP   : 10.1.1.1                                 Port: 1812
    VPN  : Not configured
    State: Active
    Test profile: Not configured
    Weight: 0
  Primary accounting server:
    IP   : 10.1.1.1                                 Port: 1813
    State: Active
    Weight: 0
  Second authentication server:
    IP   : 10.1.1.11                                Port: 1812
    State: Active
    Weight: 0
  Second accounting server:
    IP   : 10.1.1.11                                Port: 1813
    State: Active
    Weight: 0
  Accounting-On function                     : Disabled
    extended function                        : Disabled
    retransmission times                     : 50
    retransmission interval(seconds)         : 3
  Timeout Interval(seconds)                  : 3
  Retransmission Times                       : 3
  Retransmission Times for Accounting Update : 5
  Server Quiet Period(minutes)               : 5
  Realtime Accounting Interval(seconds)      : 720
  Stop-accounting packets buffering          : Enabled
    Retransmission times                     : 500
  NAS IP Address                             : Not configured
  User Name Format                           : with-domain
  Data flow unit                             : Byte
  Packet unit                                : One
  Attribute 15 check-mode                    : Strict
  Attribute 25                               : Standard
  Attribute Remanent-Volume unit             : Kilo
  server-load-sharing                        : Disabled
  Attribute 31 MAC format                    : HH-HH-HH-HH-HH-HH
  Stop-accounting packets send-force         : Disabled
  Reauthentication server selection          : Inherit
The output shows that the primary RADIUS server is in Active state.
# Disconnect the device from the primary RADIUS server. (Details not shown.)
# Verify that the primary RADIUS server has changed to the Block state in the RADIUS scheme. (Details not shown.)
Configuration files
vlan 2 to 3
 port access vlan 2
 port access vlan 3
line vty 0 63
 ssh server enable
radius scheme rad
 key authentication cipher $c$3$GBZ1jhslcGwSOpSejsESMnOr8Gb8SIT5ew==
 key accounting cipher $c$3$nGb/DWK8pxbHaLXQVc+xsmbUr1etIZVd7Q==
domain bbb
Example: Configuring RADIUS authentication and authorization in ACS for SSH users
As shown in Figure 10, configure the device to meet the following requirements:
·     Act as the Stelnet server to provide RADIUS-based authentication and authorization services for the SSH user.
·     Assign the highest level of privilege to the SSH user after the user passes authentication.
The RADIUS server runs Cisco ACS. Add a user account with username manager@bbb and password 1234ab## on the RADIUS server.
The host runs Stelnet client software.
Figure 10 Network diagram
Analysis
·     Configure the SSH username and password on the RADIUS server to identify valid users.
·     To support Stelnet clients that use different types of key pairs, generate DSA, ECDSA, and RSA key pairs on the Stelnet server.
¡     Apply the RADIUS scheme to the ISP domain to which the SSH users belong on the device.
·     Enable the default user role feature and specify network-admin as the default user role, so the authenticated users can obtain the highest level of privilege.
Hardware
Software version
S6805 series
S6825 series
S6850 series
S9850 series
S9820-64H
S9820-8C
Procedures
Configuring the RADIUS server
In this example, the server runs ACS 4.2. Before you perform the following tasks, make sure the host, the device, and the RADIUS server can reach each other.
1.     Enter the username and password, and click Login, as shown in Figure 11.
Figure 11 Logging into ACS
2.     Add the device to ACS as an AAA client:
a.     In the navigation tree, click Network Configuration.
b.     Click Add Entry, as shown in Figure 12.
Figure 12 Adding an AAA client
c.     On the Add AAA Client page, configure the following parameters, as shown in Figure 13:
-     Enter an AAA client hostname in the AAA Client Hostname field. This example uses Device.
-     Enter 10.1.1.2 in the AAA Client IP Address field.
The IP address is the source IP address for outgoing RADIUS packets on the device.
-     Enter expert in the Shared Secret field.
The shared secret must be the same as the authentication and accounting keys configured on the device for secure RADIUS communication.
-     Select RADIUS (IETF) from the Authenticate Using list.
Figure 13 Configuring the AAA client
d.     Click Submit + Apply.
3.     Add a user:
a.     In the navigation tree, click User Setup.
b.     On the User Setup page, enter manager in the User field and click Add/Edit, as shown in Figure 14.
Figure 14 Adding a user
c.     Configure parameters for the user, including the user password and user group, as shown in Figure 15.
This example uses the default user group.
Figure 15 Configuring the user manager
d.     Click Submit.
[Device] vlan 2
[Device-vlan2] quit
[Device-Vlan-interface2] ip address 192.168.1.65 255.255.255.0
[Device] vlan 3
[Device-vlan3] quit
Generating Keys...
Generating Keys...
# Create a local 256-bit ECDSA key pair.
Generating Keys...
# Create a local 384-bit ECDSA key pair.
Generating Keys...
# Enable the default user role feature and specify network-admin as the default user role.
[Device] role default-role enable network-admin
# Specify the primary RADIUS authentication server with the IP address 10.1.1.1 and port number 1812.
# Specify the shared key as expert for secure RADIUS communication between the device and RADIUS server.
# Remove the domain name from usernames sent to the RADIUS server.
[Device-radius-rad] user-name-format without-domain
# Create an ISP domain named bbb, and specify the domain to use RADIUS scheme rad as the authentication and authorization methods of login users.
[Device] domain bbb
[Device-isp-bbb] accounting login none
Stelnet client software includes PuTTY and OpenSSH. This example uses an Stelnet client that runs PuTTY 0.58.
To verify that you can log into the Stelnet server from the Stelnet client:
1.     Launch PuTTY.
2.     From the navigation tree, click Session.
The PuTTY Configuration page appears.
3.     Configure the following parameters, as shown in Figure 16:
a.     Enter 192.168.1.65 in the Host Name (or IP address) field.
b.     Enter 22 in the Port field.
c.     Select SSH for Protocol.
Figure 16 Specifying basic connection parameters
4.     Click Open.
The system might display a security alert dialog box, as shown in Figure 17.
Figure 17 PuTTY Security Alert dialog box (1)
5.     Click Yes or No to continue the connection.
The system might display another security alert dialog box, as shown in Figure 18.
Figure 18 PuTTY Security Alert dialog box (2)
6.     Click Yes or No to continue the connection.
7.     Enter username manager@bbb and password 1234ab## to log into the Stelnet server.
login as: manager@bbb
manager@[email protected]'s password:
* Copyright (c) 2004-2019 New H3C Technologies Co., Ltd. All rights reserved.*
<Device>
Configuration files
vlan 2 to 3
 port access vlan 2
 port access vlan 3
line vty 0 63
ssh server enable
radius scheme rad
 key authentication cipher $c$3$+zkawxNT2KQ1IhixdPDszSvNAH5b+yFMIQ==
domain bbb
Example: Configuring HWTACACS authentication and authorization in ACS for SSH users
As shown in Figure 19, configure the device to meet the following requirements:
·     Act as the Stelnet server to provide HWTACACS-based authentication and authorization services for the SSH user.
The HWTACACS server runs Cisco ACS. Add a user account with username manager@bbb and password 1234ab## on the HWTACACS server.
Figure 19 Network diagram
Analysis
·     Configure the SSH username and password on the HWTACACS server to identify valid users.
¡     Apply the HWTACACS scheme to the ISP domain to which the SSH users belong on the device.
·     Enable the default user role feature and specify network-admin as the default user role, so the authenticated users can have the highest level of privilege.
Hardware
Software version
S6805 series
S6825 series
S6850 series
S9850 series
S9820-64H
S9820-8C
When you configure HWTACACS authentication and authorization for SSH users, follow these restrictions and guidelines:
Procedures
In this example, the server runs ACS 4.2. Before you perform the following tasks, make sure the host, the device, and the HWTACACS server can reach each other.
1.     Enter the username and password, and click Login, as shown in Figure 20.
Figure 20 Logging into ACS
b.     Click Add Entry, as shown in Figure 21.
Figure 21 Adding an AAA client
c.     On the Add AAA Client page, configure the following parameters, as shown in Figure 22:
The shared secret must be the same as the authentication, authorization, and accounting keys configured on the device for secure HWTACACS communication.
-     Select TACACS+ (Cisco IOS) from the Authenticate Using list.
Figure 22 Adding an AAA client
3.     Add a user:
b.     On the User Setup page, enter manager in the User field and click Add/Edit, as shown in Figure 23.
Figure 23 Adding a user
c.     Configure parameters for the user, including the user password and user group, as shown in Figure 24.
Figure 24 Configuring the user manager
d.     Click Submit.
[Device] vlan 2
[Device-vlan2] quit
[Device] vlan 3
[Device-vlan3] quit
Generating Keys...
Generating Keys...
Generating Keys...
Generating Keys...
# Create an HWTACACS scheme named tac.
[Device] hwtacacs scheme tac
# Specify the primary HWTACACS authentication server with the IP address 10.1.1.1 and port number 49.
[Device-hwtacacs-tac] primary authentication 10.1.1.1 49
# Specify the shared key as expert for secure HWTACACS communication between the device and HWTACACS authentication server.
[Device-hwtacacs-tac] key authentication simple expert
# Specify the primary HWTACACS authorization server with the IP address 10.1.1.1 and port number 49.
[Device-hwtacacs-tac] primary authorization 10.1.1.1 49
# Specify the shared key as expert for secure HWTACACS communication between the device and HWTACACS authorization server.
[Device-hwtacacs-tac] key authorization simple expert
# Remove the domain name from usernames sent to the HWTACACS server.
[Device-hwtacacs-tac] user-name-format without-domain
[Device-hwtacacs-tac] quit
# Create an ISP domain named bbb, and specify the domain to use HWTACACS scheme tac for authentication and authorization of login users.
[Device] domain bbb
[Device-isp-bbb] authentication login hwtacacs-scheme tac
[Device-isp-bbb] authorization login hwtacacs-scheme tac
1.     Launch PuTTY.
3.     Configure the following parameters, as shown in Figure 25:
Figure 25 Specifying basic connection parameters
4.     Click Open.
The system might display a security alert dialog box, as shown in Figure 26.
Figure 26 PuTTY Security Alert dialog box (1)
The system might display another security alert dialog box, as shown in Figure 27.
Figure 27 PuTTY Security Alert dialog box (2)
<Device>
Configuration files
vlan 2 to 3
 port access vlan 2
 port access vlan 3
line vty 0 63
ssh server enable
hwtacacs scheme tac
 key authentication cipher $c$3$/9bCuPjMxjOtUvBx8NjtN+AnAsuLT2SrNA==
 key authorization cipher $c$3$QF/fFJNv9IyKyFlsNOpeBYnDXArNhOvOdQ==
domain bbb
Related documentation
See the following documents for the corresponding product model and version:
·     Security Configuration Guide
·     Security Command Reference
  • Become a Partner
  • Partner Resources
