04-Comware 7 CLI-based configuration examples (AC+fit AP deployment)
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10204-Comware 7 CLI-based configuration examples (AC+fit AP deployment)
Table of Contents
Related Documents
073-Dual-Link Backup Configuration Examples
073-Dual-Link Backup Configuration Examples 99.33 KB
H3C Access Controllers
Dual-Link Backup and AP License Synchronization
Introduction
The following information provides a dual-link backup and AP license synchronization configuration example.
This document applies to Comware-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
This document assumes that you have basic knowledge of AP management, WLAN high availability, and AP license synchronization features.
Example: Configuring dual-link backup and AP license synchronization
Network requirements
As shown in Figure 1, configure AC 1 as the master AC and AC 2 as the backup AC. When AC 1 fails and AC 2 takes over, the AP can communicate through AC 2. Configure the master CAPWAP tunnel preemption feature on the two ACs so that the AP reconnects to AC 1 when AC 1 recovers.
Enable AP license synchronization on AC 1 and AC 2 for the two ACs to back up licenses for each other.
Figure 1 Network diagram
When you configure dual-link backup and AP license synchronization, follow these restrictions and guidelines:
·     Make sure the device model is compatible with the software version.
·     Use the actual serial ID of an AP to uniquely identify that AP.
·     If you use a manual AP to establish CAPWAP tunnels with the ACs, make sure the name of the AP is the same on the two ACs and either a serial ID or MAC address is configured for the AP on the two ACs.
·     As a best practice, install a license on the master AC before enabling AP license synchronization.
·     Before enabling AP license synchronization, you must specify IP addresses and roles for the AC and its member ACs in the AP license synchronization group.
·     Configure both AC 1 and AC 2 as the master in the AP license synchronization group.
·     When the master AC fails, the backup AC takes over and becomes the new master AC. The licenses synchronized to the new master AC will be valid for a 30-day grace period.
·     Dual-link backup is applicable to both centralized forwarding and local forwarding. This example uses centralized forwarding.
Procedures
Configuring AC 1
Installing a license
# Install a license on AC 1. (Details not shown.)
Configuring interfaces on AC 1
# Configure VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. AC 1 will use this IP address to establish CAPWAP tunnels with APs.
<AC1> system-view
[AC1] vlan 100
[AC1-vlan100] quit
[AC1] interface vlan-interface 100
[AC1-Vlan-interface100] ip address 10.1.1.1 16
[AC1-Vlan-interface100] quit
# Configure GigabitEthernet 1/0/1 that connects AC 1 to the switch as a trunk port, and assign it to all VLANs.
[AC1] interface gigabitethernet 1/0/1
[AC1-GigabitEthernet1/0/1] port link-type trunk
[AC1-GigabitEthernet1/0/1] port trunk permit vlan all
[AC1-GigabitEthernet1/0/1] quit
# Create AP group group1, and set the connection priority to 7.
[AC1] wlan ap-group group1
[AC1-wlan-ap-group-group1] priority 7
# Specify a backup AC.
[AC1-wlan-ap-group-group1] backup-ac ip 10.1.1.2
# Enable master CAPWAP tunnel preemption.
[AC1-wlan-ap-group-group1] wlan tunnel-preempt enable
# Create an AP grouping rule by AP names.
[AC1-wlan-ap-group-group1] ap ap1
[AC1-wlan-ap-group-group1] quit
Configuring AP license synchronization
# Enable AP license synchronization on AC 1 and configure AC 1 as the master AC.
[AC1] wlan ap-license-group
[AC1-wlan-als-group] local ip 10.1.1.1
[AC1-wlan-als-group] member ip 10.1.1.2
[AC1-wlan-als-group] ap-license-synchronization enable
[AC1-wlan-als-group] quit
Configuring a manual AP
# Create an AP named ap1, and specify the AP model and serial ID.
[AC1] wlan ap ap1 model WA6320
[AC1-wlan-ap-ap1] serial-id 219801A28N819CE0002T
Configuring AC 2
(Optional.) Installing a license
# Install a license on AC 2. (Details not shown.)
Configuring interfaces on AC 2
# Configure VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. AC 2 will use this IP address to establish CAPWAP tunnels with APs.
<AC2> system-view
[AC2] vlan 100
[AC2-vlan100] quit
[AC2] interface Vlan-interface 100
[AC2-Vlan-interface100] ip address 10.1.1.2 16
[AC2-Vlan-interface100] quit
# Configure GigabitEthernet 1/0/1 that connects AC 2 to the switch as a trunk port, and assign it to all VLANs.
[AC2] interface gigabitethernet 1/0/1
[AC2-GigabitEthernet1/0/1] port link-type trunk
[AC2-GigabitEthernet1/0/1] port trunk permit vlan all
[AC2-GigabitEthernet1/0/1] quit
# Create AP group group1, and specify a backup AC. Use the default setting for the connection priority.
[AC2] wlan ap-group group1
[AC2-wlan-ap-group-group1] backup-ac ip 10.1.1.1
[AC2-wlan-ap-group-group1] ap ap1
[AC2-wlan-ap-group-group1] quit
[AC2] wlan ap-license-group
[AC2-wlan-als-group] local ip 10.1.1.2
[AC2-wlan-als-group] member ip 10.1.1.1
[AC2-wlan-als-group] ap-license-synchronization enable
[AC2-wlan-als-group] quit
[AC2] wlan ap ap1 model WA6320
[AC2-wlan-ap-ap1] serial-id 219801A28N819CE0002T
Configuring the switch
Configuring interfaces on the switch
# Create VLAN 100. The switch will use this VLAN to forward the traffic on the CAPWAP tunnels between the AC and AP.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
# Create VLAN interface 100, and assign it an IP address.
[Switch-Vlan-interface100] ip address 10.1.1.3 16
# Configure GigabitEthernet 1/0/1 that connects the switch to AC 1 as a trunk port, and assign the trunk port to all VLANs.
[Switch-GigabitEthernet1/0/1] port trunk permit vlan all
# Configure GigabitEthernet 1/0/2 that connects the switch to AC 2 as a trunk port, and assign the port to all VLANs.
[Switch-GigabitEthernet1/0/2] port link-type trunk
[Switch-GigabitEthernet1/0/2] port trunk permit vlan all
# Configure GigabitEthernet 1/0/3 that connects the switch to the AP as an access port, and assign the port to VLAN 100.
[Switch] interface gigabitethernet 1/0/3
[Switch-GigabitEthernet1/0/3] port link-type access
[Switch-GigabitEthernet1/0/3] port access vlan 100
# Enable the PoE feature.
[Switch-GigabitEthernet1/0/3] poe enable
[Switch-GigabitEthernet1/0/3] quit
Configuring DHCP
# Create DHCP address pool 100. Specify the 10.1.0.0/16 subnet for the pool.
[Switch] dhcp server ip-pool 100
[Switch-dhcp-pool-100] network 10.1.0.0 mask 255.255.0.0
[Switch-dhcp-pool-100] quit
# Enable DHCP.
[Switch] dhcp enable
# Display AP license synchronization group information on AC 1 to verify that the number of licenses in the group is the sum of licenses installed on AC 1 and AC 2.
<AC1> display wlan ap-license-group
 Group total licenses: 256
 Group used licenses: 1
 AP license synchronization: Enabled
 Local IP: 10.1.1.1
 Local role: Master
 Member information: 1
 IP address        Total      Used      Member role      State      Online duration
 10.1.1.2           0          0          Master            UP         00hr 1min 51sec
# Verify that the AP state is R/M on AC 1.
<AC1> display wlan ap all
Total number of APs: 1
Total number of connected APs: 1
Total number of connected manual APs: 1
Total number of connected auto APs: 0
Total number of connected common APs: 1
Total number of connected WTUs: 0
Total number of inside APs: 0
Maximum supported APs: 384
Remaining APs: 383
Total AP licenses: 256
Local AP licenses: 256
Server AP licenses: 0
Remaining local AP licenses: 255
Sync AP licenses: 0
                                  AP information
 State : I = Idle,      J  = Join,       JA = JoinAck,    IL = ImageLoad
         C = Config,    DC = DataCheck,  R  = Run,   M = Master,  B = Backup
AP name                        APID  State Model           Serial ID
ap1                            1     R/M   WA6320          219801A28N819CE0002T
# Verify that the AP state is R/M on AC 1 and R/B on AC 2, and the number of licenses is 256.
<AC2> display wlan ap all
Remaining APs: 383
Remaining local AP licenses: 256
Sync AP licenses: 256
                                  AP information
ap1                            1     R/B   WA6320          219801A28N819CE0002T
# Shut down VLAN-interface 1 on AC 2 and wait for no longer than 30 seconds, during which service interruption occurs. Verify that the AP is in R/M state.
Remaining APs: 383
                                  AP information
# Bring up VLAN-interface 1 on AC 1. Verify that the AP state is R/M on AC 1 and R/B on AC 2. (Details not shown.)
Configuration files
·     AC 1:
vlan 100
interface Vlan-interface100
 ip address 10.1.1.1 255.255.0.0
 priority 7
 ap ap1
 local ip 10.1.1.1
 member ip 10.1.1.2
·     AC 2:
vlan 100
 ip address 10.1.1.2 255.255.0.0
 ap ap1
 local ip 10.1.1.2
 member ip 10.1.1.1
·     Switch
 dhcp enable
vlan 100
 ip address 10.1.1.3 255.255.0.0
 poe enable
Related documentation
·     AP License Synchronization Command Reference in H3C Access Controllers Command References
·     AP License Synchronization Configuration Guide in H3C Access Controllers Configuration Guides
·     AP Management Command Reference in H3C Access Controllers Command References
·     AP Management Configuration Guide in H3C Access Controllers Configuration Guides
·     WLAN High Availability Command Reference in H3C Access Controllers Command References
·     WLAN High Availability Configuration Guide in H3C Access Controllers Configuration Guides
