04-Comware 7 CLI-based configuration examples (AC+fit AP deployment)
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10204-Comware 7 CLI-based configuration examples (AC+fit AP deployment)
Table of Contents
Related Documents
065-File Filtering Configuration Examples
065-File Filtering Configuration Examples 104.77 KB
H3C Access Controllers
Introduction
The following information provides examples for configuring file filtering.
The following information applies to Comware-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of file filtering.
Example: Configuring file filtering
As shown in Figure 1, the AC connects to the Internet.
Configure file filtering on the AC so the AC performs the following operations:
·     Blocks files with the pptx or dotx extension.
·     Logs the blocked files.
Figure 1 Network diagram
Use the actual serial ID of an AP to uniquely identify that AP.
Procedures
Configuring the AC
1.     Configure interfaces on the AC:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The AP will obtain this IP address to establish CAPWAP tunnels with the AC.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 192.1.1.1 24
[AC-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. The client will access the wireless network in this VLAN.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 192.2.1.1 24
[AC-Vlan-interface200] quit
# Set the link type of GigabitEthernet 1/0/1 (the port connected to the switch) to trunk, and allow traffic from VLAN 100 and VLAN 200 to pass through the port.
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
2.     Configure a wireless service:
# Create service template 1 and enter service template view.
[AC] wlan service-template 1
# Set the SSID to service.
[AC-wlan-st-1] ssid service
# Set the AKM mode to PSK and configure simple character string 12345678 as the PSK.
[AC-wlan-st-1] akm mode psk
[AC-wlan-st-1] preshared-key pass-phrase simple 12345678
# Set the AES-CCMP cipher suite for frame encryption, and enable the RSN IE in beacon and probe responses.
[AC-wlan-st-1] cipher-suite ccmp
[AC-wlan-st-1] security-ie rsn
# Configure the AC to forward client traffic. If the default client traffic forwarding location is the same as the configuration in this step, you can skip this step.
[AC-wlan-st-1] client forwarding-location ac
# Assign the client to VLAN 200 after it comes online.
[AC-wlan-st-1] vlan 200
# Enable the service template.
[AC-wlan-st-1] quit
3.     Configure the AP:
IMPORTANT
IMPORTANT:
In a large-scale network, configure AP groups as a best practice.
# Create a manual AP named ap1, and specify the AP model.
[AC] wlan ap ap1 model WA6320
# Set the serial ID to 219801A28N819CE0002T.
[AC-wlan-ap-ap1] serial-id 219801A28N819CE0002T
[AC-wlan-ap-ap1] quit
# Create AP group group1 and create an AP grouping rule by AP names to add AP ap1 to AP group group1.
[AC] wlan ap-group group1
[AC-wlan-ap-group-group1] ap ap1
# Bind service template 1 to radio 1 in AP group group1.
[AC-wlan-ap-group-group1] ap-model WA6320
[AC-wlan-ap-group-group1-ap-model-WA6320] radio 1
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] service-template 1
# Enable radio 1.
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] quit
# Bind service template 1 to radio 2 in AP group group1.
[AC-wlan-ap-group-group1-ap-model-WA6320] radio 2
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] service-template 1
# Enable radio 2.
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] return
4.     Configure an IP address object group named filefilter and specify subnet 192.2.1.0/24 for the object group.
<AC> system-view
[AC] object-group ip address filefilter
[AC-obj-grp-ip-filefilter] network subnet 192.2.1.0 24
[AC-obj-grp-ip-filefilter] quit
5.     Configure file filtering:
a.     Create a file type group named fg1 and create two file type match patterns to match files with the pptx and dotx extensions, respectively.
[AC] file-filter filetype-group fg1
[AC-file-filter-fgroup-fg1] pattern 1 text pptx
[AC-file-filter-fgroup-fg1] pattern 2 text dotx
[AC-file-filter-fgroup-fg1] quit
b.     Create a file filtering policy named p1 and enter file filtering policy view. Create a file filtering rule named r1 and configure it to drop and log both upload and download HTTP packets that match file type group fg1.
[AC] file-filter policy p1
[AC-file-filter-policy-p1] rule r1
[AC-file-filter-policy-p1-rule-r1] filetype-group fg1
[AC-file-filter-policy-p1-rule-r1] application type http
[AC-file-filter-policy-p1-rule-r1] direction both
[AC-file-filter-policy-p1-rule-r1] action drop logging
[AC-file-filter-policy-p1-rule-r1] quit
[AC-file-filter-policy-p1] quit
6.     Configure a DPI application profile and activate the file filtering policy and rule settings:
# Create a DPI application profile named profile1 and apply file filtering policy p1 to the DPI application profile.
[AC] app-profile profile1
[AC-app-profile-profile1] file-filter apply policy p1
[AC-app-profile-profile1] quit
# Activate the file filtering policy and rule settings.
[AC] inspect activate
7.     Configure a security policy:
# Enter IPv4 security policy view.
[AC] security-policy ip
# Create a security policy rule named inspect1. Configure the rule to permit packets from IP addresses in IP address object group filefilter and apply DPI application profile profile1 to the security policy.
[AC-security-policy-ip] rule name inspect1
[AC-security-policy-ip-14-inspect1] source-ip filefilter
[AC-security-policy-ip-14-inspect1] action pass
[AC-security-policy-ip-14-inspect1] profile profile1
[AC-security-policy-ip-14-inspect1] quit
# Activate rule matching acceleration.
[AC-security-policy-ip] accelerate enhanced enable
[AC-security-policy-ip] quit
Configuring the switch
1.     Configure interfaces on the switch:
# Create VLANs 100 and 200, create VLAN-interface 100 and VLAN-interface 200, and assign IP addresses to VLAN-interface 100 and VLAN-interface 200. The switch will use VLAN 100 to forward the traffic on CAPWAP tunnels between the AC and APs, and use VLAN 200 to forward client traffic.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
[Switch-Vlan-interface100] ip address 192.1.1.2 24
[Switch] vlan 200
[Switch-vlan200] quit
[Switch] interface vlan-interface 200
[Switch-Vlan-interface200] ip address 192.2.1.2 24
[Switch-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 that connects the switch to the AC as a trunk port.
# Assign the port to VLAN 100 and VLAN 200.
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
# Configure GigabitEthernet 1/0/2 that connects the switch to the AP as an access port, and assign the port to VLAN 100.
# Enable PoE on the trunk port.
2.     Configure DHCP:
# Enable DHCP.
[Switch] dhcp enable
# Create a DHCP address pool named vlan100 to assign IP addresses and other configuration parameters to clients on subnet 192.1.1.0/24.
[Switch] dhcp server ip-pool vlan100
[Switch-dhcp-pool-vlan100] network 192.1.1.0 mask 255.255.255.0
# Exclude IP addresses 192.1.1.1 and 192.1.1.2 from dynamic allocation.
[Switch-dhcp-pool-vlan100] forbidden-ip 192.1.1.1 192.1.1.2
# Specify a gateway.
[Switch-dhcp-pool-vlan100] gateway-list 192.1.1.1
[Switch-dhcp-pool-vlan100] quit
# Create a DHCP address pool named vlan200 to assign IP addresses and other configuration parameters to clients on subnet 192.2.1.0/24.
[Switch] dhcp server ip-pool vlan200
[Switch-dhcp-pool-vlan200] network 192.2.1.0 mask 255.255.255.0
# Exclude IP addresses 192.2.1.1 and 192.2.1.2 from dynamic allocation.
[Switch-dhcp-pool-vlan200] forbidden-ip 192.2.1.1 192.2.1.2
# Specify a gateway and a DNS server.
[Switch-dhcp-pool-vlan200] dns-list 192.2.1.1
[Switch-dhcp-pool-vlan200] gateway-list 192.2.1.1
[Switch-dhcp-pool-vlan200] quit
# Verify that the AC blocks and logs files that meet the specified criteria. (Details not shown.)
Configuration files
·     AC:
vlan 100
vlan 200
 ssid service
 vlan 200
 akm mode psk
 preshared-key pass-phrase cipher $c$3$29gn1DalRVhkcyZ1CKwevH+xb6Lxopy3eq/H
 cipher-suite ccmp
 security-ie rsn
interface Vlan-interface100
 ip address 192.1.1.1 255.255.255.0
interface Vlan-interface200
 ip address 192.2.1.1 255.255.255.0
 vlan 1
 ap ap1
 ap-model WA6320
 radio 1
  radio enable
  service-template 1
 radio 2
  radio enable
  service-template 1
 gigabitethernet 1
 0 network subnet 192.2.1.0 255.255.2
 rule r1
  filetype-group fg1
  direction both
  action drop logging
 pattern 1 text pptx
 pattern 2 text dotx
security-policy ip
 rule 1 name inspect1
  action pass
  profile profile1
·     Switch:
 dhcp enable
vlan 100
vlan 200
 ip address 192.1.1.2 255.255.255.0
 ip address 192.2.1.2 255.255.255.0
 network 192.1.0.0 mask 255.255.255.0
 forbidden-ip 192.1.1.1 192.2.1.2
dns-list 192.2.1.1
 poe enable
Related documentation
·     File Filtering Command Reference in H3C Access Controllers Command References
·     File Filtering Configuration Guide in H3C Access Controllers Configuration Guides
·     Security Policy Command Reference in H3C Access Controllers Command References
·     Security Policy Configuration Guide in H3C Access Controllers Configuration Guides
