04-Comware 7 CLI-based configuration examples (AC+fit AP deployment)
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10204-Comware 7 CLI-based configuration examples (AC+fit AP deployment)
Table of Contents
Related Documents
059-IP Source Guard (IPv4) Configuration Examples
H3C Access Controllers
Introduction
The following information provides an example for configuring IPv4 source guard (IPv4SG).
The following information applies to Comware-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
This document assumes that you have basic knowledge of IPv4SG and WLAN.
Example: Configuring IPv4SG
As shown in Figure 1, the DHCP server assigns IP addresses to Client 1 and the AP. Client 2 is assigned a static IPv4 address.
Configure network settings to meet the following requirements:
·     Both of the clients access the same wireless network.
·     Enable IPv4SG to generate IPv4SG bindings based on DHCP so that the AP forwards the packets only from Client 1.
Figure 1 Network diagram
When you configure a serial ID for the AP, use the serial ID labeled on the AP's rear panel.
Procedures
Configuring the AC
1.     Configure interfaces on the AC:
# Create VLAN 100 and VLAN-interface 100, and assign IP address 192.168.1.1 to the VLAN interface. The AC will establish a CAPWAP tunnel with the AP in this VLAN.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 192.168.1.1 24
[AC-Vlan-interface100] quit
# Create VLAN 200. The AC will use this VLAN for client access.
[AC] vlan 200
[AC-vlan200] quit
# Configure GigabitEthernet 1/0/1 (port that connects the AC and the switch) as a trunk port. Remove the port from VLAN 1, and assign the port to VLAN 100 and VLAN 200.
[AC-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
2.     Configure a wireless service:
# Create service template 1 and enter its view.
[AC] wlan service-template 1
# Set the SSID to service.
[AC-wlan-st-1] ssid service
# Enable snooping DHCP packets on the service template.
[AC-wlan-st-1] client ipv4-snooping dhcp-learning enable
# Enable IPv4SG on the service template.
[AC-wlan-st-1] ip verify source
# Specify PSK as the AKM mode and specify 12345678 as the plaintext key.
[AC-wlan-st-1] akm mode psk
[AC-wlan-st-1] preshared-key pass-phrase simple 12345678
# Specify CCMP as the cipher suite and specify RSN as the security IE.
[AC-wlan-st-1] cipher-suite ccmp
[AC-wlan-st-1] security-ie rsn
# Configure the AC to forward client data traffic. If the default client data traffic forwarder is AC, skip this step.
[AC-wlan-st-1] client forwarding-location ac
# Enable service template 1.
[AC-wlan-st-1] quit
3.     Configure AP settings:
To simply AP configuration on a large-scale network, configure AP settings on a per AP group basis as a best practice.
# Create AP officeap, and specify the AP model and serial ID.
[AC] wlan ap officeap model WA6320
[AC-wlan-ap-officeap] serial-id 209801A28N819CE0002T
[AC-wlan-ap-officeap] quit
# Create AP group group1 and configure officeap as the AP grouping rule.
[AC] wlan ap-group group1
[AC-wlan-ap-group-group1] ap officeap
# Bind service template 1 and VLAN 200 to radio 1 for AP group group1.
[AC-wlan-ap-group-group1] ap-model WA6320
[AC-wlan-ap-group-group1-ap-model-WA6320] radio 1
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] service-template 1 vlan 200
# Enable radio 1.
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] quit
[AC-wlan-ap-group-group1-ap-model-WA6320] quit
[AC-wlan-ap-group-group1] quit
Configuring the switch
1.     Configure switch interfaces:
# Create VLAN 100. The switch will use this VLAN to forward the traffic on the CAPWAP tunnel between the AC and the AP.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
# Create VLAN 200. The switch will use this VLAN to forward packets for wireless clients.
[Switch] vlan 200
[Switch-vlan200] quit
# Create VLAN-interface 100 that acts as a gateway and assign IP address 192.168.1.254 to the interface.
[AC-Vlan-interface100] ip address 192.168.1.254 24
# Create VLAN-interface 200 that acts as a gateway and assign IP address 192.168.2.254 to the interface.
[AC-Vlan-interface200] ip address 192.168.2.254 24
[AC-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 (port that connects the switch and the AC) as a trunk port, and assign the port to VLAN 100 and VLAN 200.
[Switch] interface GigabitEthernet1/0/1
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
# Configure GigabitEthernet 1/0/2 (port that connects the switch and the AP) as an access port, and assign the port to VLAN 100.
[Switch] interface GigabitEthernet1/0/2
# Enable PoE on GigabitEthernet 1/0/2.
# Configure GigabitEthernet 1/0/3 (port that connects the switch and the host) as an access port, and assign the port to VLAN 200.
[Switch] interface GigabitEthernet1/0/3
[Switch-GigabitEthernet1/0/3] port link-type access
[Switch-GigabitEthernet1/0/3] port access vlan 200
[Switch-GigabitEthernet1/0/3] quit
2.     Configure the DHCP server:
# Enable DHCP server.
[Switch] dhcp enable
# Create DHCP address pool 1 for dynamic IP allocation to the AP. Specify 192.168.1.0/24 as the subnet and 192.168.1.254 as the gateway address in the address pool.
[Switch] dhcp server ip-pool 1
[Switch-dhcp-pool-1] network 192.168.1.0 mask 255.255.255.0
[Switch-dhcp-pool-1] gateway-list 192.168.1.254
# Exclude the IP address of VLAN-interface 100 on the AC from dynamic IP allocation in DHCP address pool 1.
[Switch-dhcp-pool-1] forbidden-ip 192.168.1.1
[Switch-dhcp-pool-1] quit
# Create DHCP address pool 2 for dynamic IP allocation to Client 1 and the host. Specify 192.168.2.0/24 as the subnet and 192.168.2.254 as the gateway address in the address pool, and then specify the address of the DNS server. In this example, the gateway also acts as the DNS server.
[Switch] dhcp server ip-pool 2
[Switch-dhcp-pool-2] network 192.168.2.0 mask 255.255.255.0
[Switch-dhcp-pool-2] gateway-list 192.168.2.254
[Switch-dhcp-pool-2] dns-list 192.168.2.254
[Switch-dhcp-pool-2] quit
# Client 1 at MAC address 0024-d774-e6f4 comes online and obtains IP address 192.168.2.2/24 through DHCP. (Details not shown.)
# Client 2 at MAC address 0024-0130-696b comes online and obtains statically configured IP address 192.168.2.3/24. (Details not shown.)
# Verify that Client 1 can ping the host on the same subnet.
C:\Users\>ping -S 192.168.2.2 192.168.2.1
Pinging 192.168.2.1 from 192.168.2.2 with 32 bytes of data:
Reply from 192.168.2.1 : time=22ms
Reply from 192.168.2.1 : time=61ms
Reply from 192.168.2.1 : time=32ms
Reply from 192.168.2.1 : time=16ms
Ping statistics for 192.168.2.1 :
    Packets: Sent = 4,Received = 4,Lost = 0 (0% loss),
    Minimum = 16msMaximum = 61msAverage = 32ms
# Verify that Client 2 cannot ping the host.
C:\Users\>ping -S 192.168.2.3 192.168.2.1
Pinging 192.168.2.1 from 192.168.2.3 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
    Packets: Sent = 4,Received = 0,Lost = 4 (100% loss),
Configuration files
·     AC
vlan 100
vlan 200
 ssid service
 akm mode psk
 preshared-key pass-phrase cipher $c$3$X2Rlxl49vpJ158WfBfCMdjt0NpHVdUHApNcS
 cipher-suite ccmp
 security-ie rsn
 ip verify source
interface Vlan-interface100
 ap officeap
 ap-model WA6320
  radio 1
   radio enable
  radio 2
·     Switch:
vlan 100
vlan 200
 ip address 192.168.1.254 255.255.255.0
interface Vlan-interface200
 ip address 192.168.2.254 255.255.255.0
 port link-mode bridge
 poe enable
Related documentation
·     Network Connectivity Command Reference in H3C Access Controllers Command References
·     Network Connectivity Configuration Guide in H3C Access Controllers Configuration Guides
·     Security Command Reference in H3C Access Controllers Command References
·     Security Configuration Guide in H3C Access Controllers Configuration Guides
·     AP and WT Management Command Reference in H3C Access Controllers Command References
·     AP and WT Management Configuration Guide in H3C Access Controllers Configuration Guides
