04-Comware 7 CLI-based configuration examples (AC+fit AP deployment)
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10204-Comware 7 CLI-based configuration examples (AC+fit AP deployment)
Table of Contents
Related Documents
040-Local 802.1X Authentication Configuration Examples
H3C Access Controllers
Introduction
The following information provides an example for configuring local 802.1X authentication on a wireless network.
The following information applies to Comware-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of WLAN access, WLAN user access authentication, and 802.1X authentication.
Example: Configuring local 802.1X authentication for wireless clients
As shown in Figure 1, the switch acts as a DHCP server to assign IP addresses to the AP and the client.
Configure the AC to meet the following requirements:
·     Perform local 802.1X authentication to control the network access of the client.
·     Use open system authentication to authenticate the client at the data link layer. This is the default authentication method.
Figure 1 Network diagram
When you configure local 802.1X authentication for wireless clients, follow these restrictions and guidelines:
·     Use the serial ID labeled on the AP's rear panel to specify an AP.
·     Local 802.1X authentication does not support EAP relay.
Procedures
Configuring the AC
1.     Configure interfaces on the AC:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The AC will use this IP address to establish CAPWAP control and data tunnels with the AP.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 2.2.2.1 24
[AC-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. VLAN 200 will be used for client access.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 2.2.1.1 24
[AC-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 (the port connected to the switch) as a trunk port, and assign the port to VLAN 100 and VLAN 200.
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
2.     Configure a local user:
# Create a network access user named localuser and set the password to localpass in plaintext form.
[AC] local-user localuser class network
[AC-luser-network-localuser] password simple localpass
# Set the service type to lan-access.
[AC-luser-network-localuser] service-type lan-access
[AC-luser-network-localuser] quit
3.     Configure a local authentication domain:
# Create ISP domain bbb and enter its view.
[AC] domain bbb
# Configure the ISP domain to use local authentication, authorization, and accounting for LAN access wireless clients.
[AC-isp-bbb] authentication lan-access local
[AC-isp-bbb] authorization lan-access local
[AC-isp-bbb] accounting lan-access local
[AC-isp-bbb] quit
4.     Set the 802.1X authentication method to CHAP.
[AC] dot1x authentication-method chap
5.     Configure a service template:
# Create service template service and enter its view.
[AC] wlan service-template service
# Set the SSID of the service template to service.
[AC-wlan-st-service] ssid service
# Assign VLAN 200 to the matching clients.
[AC-wlan-st-service] vlan 200
# Set the user access authentication mode to 802.1X authentication.
[AC-wlan-st-service] client-security authentication-mode dot1x
# Specify ISP domain bbb for 802.1X authentication clients in the service template.
[AC-wlan-st-service] dot1x domain bbb
# Enable the AC to forward client data traffic. If the AC forwards client data traffic by default, skip this step.
[AC-wlan-st-service] client forwarding-location ac
# Enable the service template.
[AC-wlan-st-service] service-template enable
[AC-wlan-st-service] quit
6.     Configure AP settings:
IMPORTANT
IMPORTANT:
In a large-scale network, configure AP groups as a best practice.
# Create manual AP office, and specify the AP model and serial ID.
[AC] wlan ap office model WA6320
[AC-wlan-ap-office] serial-id 219801A28N819CE0003T
[AC-wlan-ap-office] quit
# Create AP group group1 and create an AP grouping rule by AP names to add AP office to AP group group1.
[AC] wlan ap-group group1
[AC-wlan-ap-group-group1] ap office
# Bind service template service to radio 1 in AP group group1.
[AC-wlan-ap-group-group1] ap-model WA6320
[AC-wlan-ap-group-group1-ap-model-WA6320] radio 1
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] service-template service
# Enable radio 1.
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] quit
[AC-wlan-ap-group-group1-ap-model-WA6320] quit
[AC-wlan-ap-group-group1] quit
Configuring the switch
# Enable the DHCP server.
<Switch> system-view
[Switch] dhcp enable
# Create VLAN 100. The switch will use this VLAN to forward the traffic on the CAPWAP tunnels between the AC and AP.
[Switch] vlan 100
[Switch-vlan100] quit
# Create VLAN 200. The switch will use this VLAN to forward packets for wireless clients.
[Switch] vlan 200
[Switch-vlan200] quit
# Configure GigabitEthernet 1/0/1 (the port connected to the AC) as a trunk port, and assign the trunk port to VLAN 100 and VLAN 200.
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
# Configure GigabitEthernet 1/0/2 (the port connected to the AP) as a trunk port, assign the port to VLAN 100 and VLAN 200, and set the PVID of the port to 100.
[Switch-GigabitEthernet1/0/2] port link-type trunk
[Switch-GigabitEthernet1/0/2] port trunk permit vlan 100 200
[Switch-GigabitEthernet1/0/2] port trunk pvid vlan 100
# Enable PoE on GigabitEthernet 1/0/2.
# Assign IP address 2.2.2.100/24 to VLAN-interface 100.
[Switch-Vlan-interface100] ip address 2.2.2.100 255.255.255.0
# Assign IP address 2.2.1.2/24 to VLAN-interface 200.
[Switch] interface vlan-interface 200
[Switch-Vlan-interface200] ip address 2.2.1.2 255.255.255.0
[Switch-Vlan-interface200] quit
# Create a DHCP address pool named 100, and specify subnet 2.2.2.0/24 and gateway IP address 2.2.2.1 in the DHCP address pool.
[Switch] dhcp server ip-pool 100
[Switch-dhcp-pool-100] network 2.2.2.0 mask 255.255.255.0
[Switch-dhcp-pool-100] gateway-list 2.2.2.1
[Switch-dhcp-pool-100] option 138 ip-address 2.2.2.1
[Switch-dhcp-pool-100] quit
# Create a DHCP address pool named 200, and specify subnet 2.2.1.0/24 and gateway IP address 2.2.1.1 in the DHCP address pool.
[Switch] dhcp server ip-pool 200
[Switch-dhcp-pool-200] network 2.2.1.0 mask 255.255.255.0
[Switch-dhcp-pool-200] gateway-list 2.2.1.1
[Switch-dhcp-pool-200] quit
Configuring the iNode client
In this example, the client version is iNode PC 7.1.
Connecting to the wireless network
1.     Run the iNode client, and then click Wireless Connection, as shown in Figure 2.
Figure 2 iNode Client
2.     Click triangle icon in the wireless connection title bar, as shown in Figure 3.
Figure 3 Wireless connection
3.     Double-click the wireless service with SSID service, as shown in Figure 4.
Figure 4 Selecting a wireless service
4.     Click Connect, as shown in Figure 5.
Figure 5 Connecting to the wireless network
Configuring 802.1X authentication
1.     Click 802.1X Connection, as shown in Figure 6.
Figure 6 802.1X connection
2.     Enter username localuser and password localpass, as shown in Figure 7.
Figure 7 Entering the username and password
3.     Click the inverted triangle icon next to Connect and select Properties.
4.     In the dialog box that opens, select a wireless NIC and clear the option for uploading the client version.
5.     Return to the iNode 802.1X connection screen.
6.     Click Connect.
The iNode client displays the connection state as shown in Figure 8.
Figure 8 Successful 802.1X authentication
# Display online 802.1X user information.
[AC] display dot1x connection
User MAC address           : 0015-00bf-e84d
AP name                    : office
Radio ID                   : 1
SSID                       : service
BSSID                      : 741f-4ad4-1fe0
Username                   : localuser
Authentication domain      : bbb
IPv4 address               : 2.2.1.3
Authentication method      : CHAP
Initial VLAN               : 200
Authorization VLAN         : 200
Authorization ACL number   : N/A
Authorization user profile : N/A
Termination action         : N/A
Session timeout period     : N/A
Online from                : 2019/12/04 17:37:55
Online duration            : 0h 4m 20s
# Display service template information.
[AC] display wlan service-template service
Service template name        : service
SSID                         : service
SSID-hide                    : Disabled
User-isolation               : Disabled
Service template status      : Enabled
Maximum clients per BSS      : Not configured
Frame format                 : Dot3
Seamless roam status         : Disabled
Seamless roam RSSI threshold : 50
Seamless roam RSSI gap       : 20
VLAN ID                      : 200
AKM mode                     : Not configured
Security IE                  : Not configured
Cipher suite                 : Not configured
TKIP countermeasure time     : 0 sec
PTK lifetime                 : 43200 sec
GTK rekey                    : Enabled
GTK rekey method             : Time-based
GTK rekey time               : 86400 sec
GTK rekey client-offline     : Disabled
User authentication mode     : 802.1X
Intrusion protection         : Disabled
Intrusion protection mode    : Temporary-block
Temporary block time         : 180 sec
Temporary service stop time  : 20 sec
Fail VLAN ID                 : Not configured
802.1X handshake             : Disabled
802.1X handshake secure      : Disabled
802.1X domain                : bbb
MAC-auth domain              : Not configured
Max 802.1X users             : 4096
Max MAC-auth users           : 4096
802.1X re-authenticate       : Disabled
Authorization fail mode      : Online
Accounting fail mode         : Online
Authorization                : Permitted
Key derivation               : SHA1
PMF status                   : Disabled
Hotspot policy number        : Not configured
Forwarding policy status     : Disabled
Forwarding policy name       : Not configured
FT status                    : Disabled
QoS trust                    : Port
QoS priority                 : 0
Configuration files
·     AC:
vlan 100
vlan 200
 ssid service
 vlan 200
 dot1x domain bbb
interface Vlan-interface100
 ip address 2.2.2.1 255.255.255.0
interface Vlan-interface200
 ip address 2.2.1.1 255.255.255.0
 port link-mode bridge
 port trunk permit vlan 1 100 200
domain bbb
 password cipher $c$3$+5Yra0KsaLci/RxEa4lyYKxxiw6jwMCcOg==
 ap office
 ap-model WA6320
  radio 1
   radio enable
  radio 2
·     Switch:
dhcp enable
vlan 100
vlan 200
 port access permit vlan 100 200
 poe enable
Related documentation
·     AP and WT Management Configuration Guide in H3C Access Controllers Configuration Guides
·     AP and WT Management Command Reference in H3C Access Controllers Command References
·     Network Connectivity Configuration Guide in H3C Access Controllers Configuration Guides
·     Network Connectivity Command Reference in H3C Access Controllers Command References
·     User Access and Authentication Configuration Guide in H3C Access Controllers Configuration Guides
·     User Access and Authentication Command Reference in H3C Access Controllers Command References
·     WLAN Access Configuration Guide in H3C Access Controllers Configuration Guides
·     WLAN Access Command Reference in H3C Access Controllers Command References
