04-Comware 7 CLI-based configuration examples (AC+fit AP deployment)
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10204-Comware 7 CLI-based configuration examples (AC+fit AP deployment)
Table of Contents
Related Documents
058-WIPS Countermeasures Against All SSIDs Configuration Examples
Introduction
The following information provides examples for configuring WIPS countermeasures against all SSIDs.
The following information applies to Comware-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of WIPS.
Example: Configuring WIPS countermeasures against all SSIDs
As shown in Figure 1, AP 1 and AP 2 provide wireless services for clients through SSID service.
Enable WIPS on the sensor to take countermeasures against the rogue AP that uses SSID service and SSID free.
Figure 1 Network diagram
Procedures
Configuring the AC
1.     Configure interfaces on the AC:
# Configure VLAN-interface 100 and assign it an IP address. The AC will use this IP address to establish CAPWAP tunnels with APs.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 112.12.1.25 16
[AC-Vlan-interface100] quit
# Configure VLAN-interface 200 and assign it an IP address. The AC will use VLAN 200 for client access.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 112.13.1.25 16
[AC-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 that connects the AC to the switch as a trunk port.
[AC] interface gigabitethernet1/0/1
# Remove the trunk port from VLAN 1, and assign the port to VLANs 100 and 200.
[AC-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
2.     Configure DHCP:
# Enable DHCP on the AC.
[AC] dhcp enable
# Create DHCP address pool vlan100 to assign IP addresses for APs, and specify the IP address range for the DHCP address pool.
[AC] dhcp server ip-pool vlan100
[AC-dhcp-pool-vlan100] network 112.12.0.0 mask 255.255.0.0
# Specify gateway IP address 112.12.1.25 in the DHCP address pool.
[AC-dhcp-pool-vlan100] gateway-list 112.12.1.25
[AC-dhcp-pool-vlan100] quit
# Create DHCP address pool vlan200 to assign IP addresses for clients, and specify the IP address range for the DHCP address pool.
[AC] dhcp server ip-pool vlan200
[AC-dhcp-pool-vlan200] network 112.13.0.0 mask 255.255.0.0
# Specify gateway IP address 112.13.1.25 in the DHCP address pool.
[AC-dhcp-pool-vlan200] gateway-list 112.13.1.25
# Configure the DNS server according to the actual network plan. In this example, the gateway is specified as the DNS server.
[AC-dhcp-pool-vlan200] dns-list 112.13.1.25
[AC-dhcp-pool-vlan200] quit
3.     Configure WIPS:
# Enter WIPS view.
[AC] wips
# Create AP classification rule 1 and configure the rule to match APs that use SSID service.
[AC-wips] ap-classification rule 1
[AC-wips-cls-rule-1] ssid equal service
[AC-wips-cls-rule-1] quit
# Create AP classification rule 2 and configure the rule to match APs that do not use SSID service.
[AC-wips] ap-classification rule 2
[AC-wips-cls-rule-2] ssid not equal service
[AC-wips-cls-rule-2] quit
# Create classification policy class1.
[AC-wips] classification policy class1
# Bind AP classification rule 1 to classification policy class1, specify APs that match AP classification rule 1 as rogue APs, and set the severity level to 100.
[AC-wips-cls-class1] apply ap-classification rule 1 rogue-ap severity-level 100
# Bind AP classification rule 2 to classification policy class1, specify APs that match AP classification rule 2 as rogue APs, and set the severity level to 100.
[AC-wips-cls-class1] apply ap-classification rule 2 rogue-ap severity-level 100
# Add MAC addresses 000f-1111-0111 and 000f-1111-0112 to the permitted device list.
[AC-wips-cls-class1] trust mac-address 000f-1111-0111
[AC-wips-cls-class1] trust mac-address 000f-1111-0112
[AC-wips-cls-class1] quit
# Create virtual security domain (VSD) vsd1, and apply classification policy class1 to the VSD.
[AC-wips] virtual-security-domain vsd1
[AC-wips-vsd-1] apply classification policy class1
[AC-wips-vsd-1] quit
# Create countermeasure policy 1 and enable WIPS to take countermeasures against rogue APs.
[AC-wips] countermeasure policy 1
[AC-wips-cms-1] countermeasure rogue-ap
[AC-wips-cms-1] quit
# Apply countermeasure policy 1 to VSD vsd1.
[AC-wips-vsd-vsd1] apply countermeasure policy 1
[AC-wips-vsd-vsd1] quit
[AC-wips] quit
4.     Configure the APs:
In large-scale networks, configure AP groups instead of single APs as a best practice.
# Create service template service and set its SSID to service.
[AC] wlan service-template service
[AC-wlan-st-service] ssid service
# Assign clients that come online through service template service to VLAN 200.
[AC-wlan-st-service] vlan 200
# Specify the AKM mode as PSK, and specify plaintext string 12345678 as the preshared key.
[AC-wlan-st-service] akm mode psk
[AC-wlan-st-service] preshared-key pass-phrase simple 12345678
# Specify the cipher suite as CCMP and the security IE as RSN.
[AC-wlan-st-service] cipher-suite ccmp
[AC-wlan-st-service] security-ie rsn
# Configure the AC to forward client data traffic. You can skip this step if the AC is the client traffic forwarder by default.
[AC-wlan-st-service] client forwarding-location ac
# Enable service template service.
[AC-wlan-st-service] service-template enable
[AC-wlan-st-service] quit
# Create AP ap1 and specify its model and serial ID.
[AC] wlan ap ap1 model WA6320
[AC-wlan-ap-ap1] serial-id 219801A28N819CE0002T
[AC-wlan-ap-ap1] quit
# Create AP ap2 and specify its model and serial ID.
[AC] wlan ap ap2 model WA6320
[AC-wlan-ap-ap2] serial-id 219801A28N819CE0003T
[AC-wlan-ap-ap2] quit
# Create AP group group1, and add the AP to the AP group.
[AC] wlan ap-group group1
[AC-wlan-ap-group-group1] ap ap1 ap2
# Bind service template service to radio 1 in group1.
[AC-wlan-ap-group-group1] ap-model WA6320
[AC-wlan-ap-group-group1-ap-model-WA6320] radio 1
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] service-template service
# Enable radio 1.
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] quit
[AC-wlan-ap-group-group1-ap-model-WA6320] quit
[AC-wlan-ap-group-group1] quit
# Create AP sensor and specify its model and serial ID.
[AC] wlan ap sensor model WA6320
[AC-wlan-ap-sensor] serial-id 219801A28N819CE0004T
[AC-wlan-ap-sensor] quit
# Create AP group group2 and add the AP to the AP group.
[AC] wlan ap-group group2
[AC-wlan-ap-group-group2] ap sensor
# Enable radio 1.
[AC-wlan-ap-group-group2] ap-model WA6320
[AC-wlan-ap-group-group2-ap-model-WA6320] radio 1
[AC-wlan-ap-group-group2-ap-model-WA6320-radio-1] radio enable
# Enable WIPS for the radio and add AP sensor to VSD vsd1..
[AC-wlan-ap-group-group2-ap-model-WA6320-radio-1] wips enable
[AC-wlan-ap-group-group2-ap-model-WA6320-radio-1] quit
[AC-wlan-ap-group-group2-ap-model-WA6320] quit
[AC-wlan-ap-group-group2] wips virtual-security-domain vsd1
[AC-wlan-ap-group-group2] return
Configuring the switch
# Create VLANs 100 and 200. The switch will use VLAN 100 to forward the traffic on CAPWAP tunnels between the AC and APs, and use VLAN 200 to forward client traffic.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
[Switch] vlan 200
[Switch-vlan200] quit
# Configure GigabitEthernet 1/0/1 that connects the switch to the AC as a trunk port.
[Switch] interface gigabitethernet1/0/1
# Remove the trunk port from VLAN 1, and assign the port to VLAN 100 and VLAN 200.
[Switch-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
# Configure GigabitEthernet 1/0/2 that connects the switch to AP sensor as an access port, and assign the port to VLAN 100.
[Switch] interface gigabitethernet1/0/2
# Enable PoE on the access port.
# Configure GigabitEthernet 1/0/3 that connects the switch to AP ap1 as an access port, and assign the port to VLAN 100.
[Switch] interface gigabitethernet1/0/3
[Switch-GigabitEthernet1/0/3] port link-type access
[Switch-GigabitEthernet1/0/3] port access vlan 100
[Switch-GigabitEthernet1/0/3] poe enable
[Switch-GigabitEthernet1/0/3] quit
# Configure GigabitEthernet 1/0/4 that connects the switch to AP ap2 as an access port, and assign the port to VLAN 100.
[Switch] interface gigabitethernet1/0/4
[Switch-GigabitEthernet1/0/4] port link-type access
[Switch-GigabitEthernet1/0/4] port access vlan 100
[Switch-GigabitEthernet1/0/4] poe enable
[Switch-GigabitEthernet1/0/4] quit
1.     Verify that WIPS has classified the AP that uses all SSIDs as a rogue AP and the service APs as authorized APs.
<AC> display wips virtual-security-domain vsd1 device
Total 3 detected devices in virtual-security-domain vsd1
Class: Auth - authorization; Ext - external; Mis - mistake;
Unauth - unauthorized; Uncate - uncategorized;
(A) - associate; (C) - config; (P) - potential
MAC address    Type   Class    Duration    Sensors Channel Status
000f-1111-0111 AP   Auth   00h 05m 26s 1       161     Active
000f-1111-0112 AP   Auth   00h 05m 26s 1       161     Active
000f-e200-1202 AP   Rogue  00h 05m 26s 1       161     Active
000f-e200-1222 AP   Rogue  00h 05m 26s 1       161     Active
2.     Verify that WIPS has taken countermeasures against the rogue AP.
<AC> display wips virtual-security-domain vsd1 countermeasure record
Total 2 times countermeasure, current 2 countermeasure record in virtual-security-domain vsd1
Reason: Attack; Ass - associated; Black - blacklist;
        Class - classification; Manu - manual;
MAC address    Type   Reason   Countermeasure AP      Radio ID  Time
000f-e200-1202 AP      Class    sensor                    1          2019-09-20/07:20:38
000f-e200-1222 AP      Class    sensor                    1          2019-09-20/07:20:38
Configuration files
·     AC:
dhcp enable
vlan 100
vlan 200
 ssid service
 vlan 200
 akm mode psk
 preshared-key pass-phrase cipher $c$3$jJ5Vq5IaYJJP9g7gA9h4rbGHLlUK/iEIQlFB
 cipher-suite ccmp
 security-ie rsn
interface Vlan-interface100
 ip address 112.12.1.25 255.255.0.0
interface Vlan-interface200
 ip address 112.13.1.25 255.255.0.0
 vlan 1
 ap ap1
 ap ap2
 ap-model WA6320
  radio 1
   radio enable
  radio 2
  gigabitethernet 1
 vlan 1
 ap sensor
 ap-model WA6320
  radio 1
   radio enable
   wips enable
  radio 2
  gigabitethernet 1
 serial-id 219801A2N819CE0002T
 serial-id 219801A2N819CE0003T
wlan ap sensor model 6320
 serial-id 219801A2N819CE0004T
wips
  ssid equal service
·     Switch:
vlan 100
vlan 200
poe enable
poe enable
interface GigabitEthernet1/0/4
poe enable
Related documentation
·     WLAN Security Command Reference in H3C Access Controllers Command References
·     WLAN Security Configuration Guide in H3C Access Controllers Configuration Guides
