04-Comware 7 CLI-based configuration examples (AC+fit AP deployment)
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10204-Comware 7 CLI-based configuration examples (AC+fit AP deployment)
Table of Contents
Related Documents
041-Local RADIUS-Based 802.1X Authentication in EAP Relay Mode Configuration Examples
H3C Access Controllers
Introduction
The following information provides an example of configuring 802.1X authentication in EAP relay mode when the AC acts as both the access device and RADIUS server.
The following information applies to Comware-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of WLAN access, WLAN security, WLAN access authentication, and 802.1X features.
Example: Configuring local RADIUS-based 802.1X authentication in EAP relay mode
As shown in Figure 1:
·     The switch acts as a DHCP server to assign IP addresses to the AP and the client.
·     The AC acts as both the access device and RADIUS server for the client.
·     When the client accesses a wireless service, it must pass 802.1X EAP-PEAP authentication and obtain the required authorization information.
Configure the AC to meet the following requirements:
·     Use the local RADIUS server to perform authentication and authorization for wireless 802.1X users.
·     Use open system authentication to authenticate the client at the data link layer. This is the default authentication method.
·     Use the 802.1X AKM mode to secure data transmission between the client and the AP.
·     Use CCMP as the cipher suite.
Figure 1 Network diagram
Use the serial ID labeled on the AP's rear panel to specify an AP.
Procedures
Configuring the AC
1.     Install the freeradius image file.
<AC> install activate feature cfa0:/freeradius.bin slot 1
Verifying the file cfa0:/freeradius.bin on slot 1...Done.
Identifying the upgrade methods....Done.
  Running Version             New Version
  None                        Feature 5531
  Slot                        Upgrade Way
  1                           Service Upgrade
Upgrading software images to compatible versions. Continue? [Y/N]:
y
This operation might take several minutes, please wait......Done.
<AC> install activate feature cfa0:/freeradius.bin slot 2
Copying file cfa0:/freeradius.bin to slot2#cfa0:/freeradius.bin...Done.
Verifying the file cfa0:/freeradius.bin on slot 2...Done.
  None                        Feature 5531
  Slot                        Upgrade Way
  2                           Service Upgrade
<AC> install commit
2.     Use FTP or TFTP to transfer the required certificate files to the storage media of the AC and verify that the file transfer has succeeded.
<AC> dir *.pem
Directory of cfa0:
   0 -rw-        3428 Feb 06 2018 13:46:34   ca.pem
   1 -rw-        3345 Feb 06 2018 16:42:10   client.pem
   2 -rw-        3345 Feb 06 2018 13:46:50   server.pem
3.      Configure interfaces on the AC:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The AC will use this IP address to establish CAPWAP tunnels with the AP.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 10.1.1.46 24
[AC-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface.  VLAN 200 will be used for client access.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 10.1.2.1 24
[AC-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 (the port connected to the switch) as a trunk port, and assign the port to VLAN 100 and VLAN 200.
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
4.     Configure EAP relay as the method for the 802.1X module to exchange packets with the local RADIUS server.
[AC] dot1x authentication-method eap
5.     Configure a RADIUS scheme:
# Create a RADIUS scheme named 1x-local and enter its view.
[AC] radius scheme 1x-local
# Specify the server at 10.1.2.1 as the primary authentication server and set the shared key of authentication packets to 12345678 in plaintext form.
[AC-radius-1x-local] primary authentication 10.1.2.1
[AC-radius-1x-local] key authentication simple 12345678
# Exclude the domain name from the usernames sent to the RADIUS server.
[AC-radius-1x-local] user-name-format without-domain
[AC-radius-1x-local] quit
6.     Configure an authentication domain:
# Create an ISP domain named 1x-local and enter its view.
[AC] domain 1x-local
# Configure the ISP domain to use RADIUS scheme 1x-local for LAN user authentication and authorization and to not perform accounting for LAN users.
[AC-isp-1x-local] authentication lan-access radius-scheme 1x-local
[AC-isp-1x-local] authorization lan-access radius-scheme 1x-local
[AC-isp-1x-local] accounting lan-access none
[AC-isp-1x-local] quit
7.     Configure a RADIUS user:
# Create a network access user named dot1x and enter its view.
[AC] local-user dot1x class network
# Set the user password to 123456 in plaintext form.
[AC-luser-network-dot1x] password simple 123456
# Allow the user to use the LAN access service.
[AC-luser-network-dot1x] service-type lan-access
# Assign the network-operator user role to the user.
[AC-luser-network-dot1x] authorization-attribute user-role network-operator
[AC-luser-network-dot1x] quit
8.     Configure EAP authentication on the RADIUS server:
# Set the EAP authentication method to peap-mschapv2.
[AC] eap-profile dot1x
[AC-eap-profile-dot1x] method peap-mschapv2
# Specify a CA certificate for EAP authentication.
[AC-eap-profile-dot1x] ca-file ca.pem
# Specify a local certificate for EAP authentication.
[AC-eap-profile-dot1x] certificate-file server.pem
# Specify the private key file of the local certificate for EAP authentication.
[AC-eap-profile-dot1x] private-key-file server.pem
# Configure the private key password of the local certificate.
[AC-eap-profile-dot1x] private-key-password simple whatever
[AC-eap-profile-dot1x] quit
# Specify an EAP profile for the local RADIUS server.
[AC] radius-server eap-profile dot1x
9.     Specify the RADIUS client at 10.1.2.1 and set the shared key to 12345678 in plaintext form for secure communication with the client.
[AC] radius-server client ip 10.1.2.1 key simple 12345678
10.     Restart the RADIUS server and activate the RADIUS server settings.
[AC] radius-server activate
11.     Configure a service template:
# Create a service template named 1x-local and enter its view.
[AC] wlan service-template 1x-local
# Set the SSID of the service template to dot1x-local.
[AC-wlan-st-1x-local] ssid dot1x-local
# Assign clients coming online through the service template to VLAN 200.
[AC-wlan-st-1x-local] vlan 200
# Set the AKM mode to 802.1X.
[AC-wlan-st-1x-local] akm mode dot1x
# Set the cipher suite to CCMP.
[AC-wlan-st-1x-local] cipher-suite ccmp
# Enable the RSN IE in beacon and probe responses.
[AC-wlan-st-1x-local] security-ie rsn
# Set the authentication mode to 802.1X.
[AC-wlan-st-1x-local] client-security authentication-mode dot1x
# Specify ISP domain 1x-local for authenticating 802.1X clients.
[AC-wlan-st-1x-local] dot1x domain 1x-local
# Enable the AC to forward client data traffic. If the AC forwards client data traffic by default, skip this step.
[AC-wlan-st-1x-local] client forwarding-location ac
# Enable the service template.
[AC-wlan-st-1x-local] service-template enable
[AC-wlan-st-1x-local] quit
12.     Configure AP settings:
IMPORTANT
IMPORTANT:
In a large-scale network, configure AP groups as a best practice.
# Create a manual AP named aptest and enter its view.
[AC] wlan ap aptest model WA6320
# Specify the serial ID of the AP.
[AC-wlan-ap-aptest] serial-id 219801A28N819CE0002T
[AC-wlan-ap-aptest] quit
# Create AP group group1 and create an AP grouping rule by AP names to add AP aptest to AP group group1.
[AC] wlan ap-group group1
[AC-wlan-ap-group-group1] ap aptest
# Bind service template 1x-local to radio 1 in AP group group1, and enable radio 1.
[AC-wlan-ap-group-group1] ap-model WA6320
[AC-wlan-ap-group-group1-ap-model-WA6320] radio 1
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] service-template 1x-local
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] quit
# Bind service template 1x-local to radio 2 in AP group group1, and enable radio 2.
[AC-wlan-ap-group-group1-ap-model-WA6320] radio 2
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] service-template 1x-local
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6320] quit
[AC-wlan-ap-group-group1] quit
Configuring the switch
# Create VLAN 100. The switch will use this VLAN to forward the traffic on the CAPWAP tunnels between the AC and AP.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
# Create VLAN 200. The switch will use this VLAN to forward packets for wireless clients.
[Switch] vlan 200
[Switch-vlan200] quit
# Set the link type of GigabitEthernet 1/0/1 (the port connected to the AC) to trunk, and assign the trunk port to VLAN 100 and VLAN 200.
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
# Set the link type of GigabitEthernet 1/0/2 (the port connected to the AP) to access, and assign the access port to VLAN 100.
# Enable PoE on GigabitEthernet 1/0/2.
# Create VLAN-interface 100 and assign an IP address to the VLAN interface.
[Switch-Vlan-interface100] ip address 10.1.1.2 24
# Create VLAN-interface 200 and assign an IP address to the VLAN interface.
[Switch] interface vlan-interface 200
[Switch-Vlan-interface200] ip address 10.1.2.2 24
[Switch-Vlan-interface200] quit
# Create a DHCP address pool named 100, and specify a subnet and a gateway IP address in the DHCP address pool. The IP address of the AP is assigned from this pool.
[Switch] dhcp server ip-pool 100
[Switch-dhcp-pool-100] network 10.1.1.0 mask 255.255.255.0
[Switch-dhcp-pool-100] gateway-list 10.1.1.2
[Switch-dhcp-pool-100] quit
# Create a DHCP address pool named 200, and specify a subnet, a gateway IP address, and a DNS server in the DHCP address pool. In this example, the address of the DNS server is 10.1.2.2. You must replace it with the actual address of the DNS server on your network. The IP address of the client is assigned from this pool.
[Switch] dhcp server ip-pool 200
[Switch-dhcp-pool-200] network 10.1.2.0 mask 255.255.255.0
[Switch-dhcp-pool-200] gateway-list 10.1.2.1
[Switch-dhcp-pool-200] dns-list 10.1.2.2
[Switch-dhcp-pool-200] quit
# Enable DHCP.
[Switch] dhcp enable
1.     On the client, verify that the client can pass 802.1X authentication, associate with the AP, and access the wireless network after you enter the correct username and password. (Details not shown.)
2.     On the AC, perform the following tasks to verify that the client has passed authentication and come online:
# Display detailed WLAN client information.
[AC] display wlan client verbose
Total number of clients: 1
 MAC address                       : 1044-0037-2e9f
 IPv4 address                      : 10.1.2.3
 IPv6 address                      : N/A
 Username                          : dot1x
 AID                               : 1
 AP ID                             : 20
 AP name                           : aptest
 Radio ID                          : 1
 SSID                              : 15209_local_1x_eap_peap_5560h
 BSSID                             : d461-fe62-1537
 VLAN ID                           : 200
 Sleep count                       : 0
 Wireless mode                     : 802.11ac
 Channel bandwidth                 : 80MHz
 SM power save                     : Disabled
 Short GI for 20MHz                : Supported
 Short GI for 40MHz                : Supported
 Short GI for 80MHz                : Supported
 Short GI for 160/80+80MHz         : Not supported
 STBC RX capability                : Supported
 STBC TX capability                : Not supported
 LDPC RX capability                : Supported
 Beamformee STS capability         : 1
 Number of Sounding Dimensions     : 0
 SU beamformee capability          : Supported
 MU beamformee capability          : Supported
 Block Ack                         : N/A
 Supported VHT-MCS set             : NSS1 0, 1, 2, 3, 4, 5, 6, 7, 8, 9
 Supported HT MCS set              : 0, 1, 2, 3, 4, 5, 6, 7
 Supported rates                   : 6, 9, 12, 18, 24, 36,
                                     48, 54 Mbps
 QoS mode                          : WMM
 Listen interval                   : 3
 RSSI                              : 0
 Rx/Tx rate                        : 0/0 Mbps
 Speed                             : N/A
 Authentication method             : Open system
 Security mode                     : RSN
 AKM mode                          : 802.1X
 Cipher suite                      : CCMP
 User authentication mode          : 802.1X
 WPA3 status                       : Disabled
 Authorization CAR                 : N/A
 Authorization ACL ID              : N/A
 Authorization user profile        : N/A
 Roam status                       : N/A
 Key derivation                    : SHA1
 PMF status                        : N/A
 Forwarding policy name            : Not configured
 Online time                       : 0days 0hours 0minutes 6seconds
 FT status                         : Inactive
# Display online 802.1X client information.
[AC] display dot1x connection
Total connections: 1
User MAC address                   : 1044-0037-2e9f
AP name                            : aptest
Radio ID                           : 1
SSID                               : dot1x-local
Username                           : dot1x
Authentication domain              : hk-local
Authentication method              : EAP
Initial VLAN                       : 200
Authorization VLAN                 : 200
Authorization ACL number           : N/A
Termination action                 : N/A
Session timeout last from          : N/A
Session timeout period             : N/A
Online from                        : 2020/05/22 11:54:58
Online duration                    : 0h 0m 20s
Configuration files
·     AC:
vlan 100
vlan 200
 ssid dot1x-local
 vlan 200
 akm mode dot1x
 cipher-suite ccmp
 security-ie rsn
interface Vlan-interface100
 ip address 10.1.1.46 255.255.255.0
interface Vlan-interface200
 ip address 10.1.2.1 255.255.255.0
 port link-mode bridge
 port trunk permit vlan 1 100 200
eap-profile dot1x
 ca-file ca.pem
radius-server eap-profile 1x
 password simple 12345678
domain 1x-local
 ap aptest
 ap-model WA6320
  radio 1
   radio enable
  radio 2
   radio enable
  gigabitethernet 1
·     Switch:
dhcp enable
vlan 100
vlan 200
 dns-list 10.1.2.2
 ip address 10.1.2.2 255.255.255.0
 poe enable
Related documentation
·     User Access and Authentication Configuration Guide in H3C Access Controllers Configuration Guides
·     User Access and Authentication Command Reference in H3C Access Controllers Command References
·     WLAN Access Configuration Guide in H3C Access Controllers Configuration Guides
·     WLAN Access Command Reference in H3C Access Controllers Command References
