- 04-Comware 7 CLI-based configuration examples (AC+fit AP deployment)
- 001-HTTPS Login Configuration Examples
- 002-SSH Configuration Examples
- 003-License Management Configuration Examples
- 004-AP Association with the AC at Layer 2 Configuration Examples
- 005-AP Association with the AC at Layer 2 (IPv6) Configuration Examples
- 006-Auto AP Configuration Examples
- 007-AP Association with the AC at Layer 3 Configuration Examples
- 008-AP Association with the AC at Layer 3 (IPv6) Configuration Examples
- 009-WEP Encryption Configuration Examples
- 010-PSK Encryption Configuration Examples
- 011-WPA3-SAE PSK Encryption Configuration Examples
- 012-WLAN Access (IPv6) Configuration Examples
- 013-Policy-Based Forwarding with Dual Gateways Configuration Examples
- 014-Scheduled Configuration Deployment by AP Group Configuration Examples
- 015-Inter-AC Roaming with Static Client VLAN Allocation Configuration Examples
- 016-Service Template and Radio Binding Configuration Examples
- 017-Scheduled WLAN Access Services Configuration Examples
- 018-HTTPS-Based Local Portal Authentication Configuration Examples
- 019-Remote Portal Authentication Configuration Examples
- 020-Local Portal Authentication through LDAP Server Configuration Examples
- 021-Local Portal Auth and SSID-based Auth Page Pushing Configuration Examples
- 022-Local Portal MAC-Trigger Authentication Configuration Examples
- 023-Portal MAC-Trigger Authentication Configuration Examples
- 024-Local Forwarding Mode and Local Portal MAC-Trigger Auth Configuration Examples
- 025-Local Portal Authentication (IPv6) Configuration Examples
- 026-Local Portal Authentication through LDAP Server (IPv6) Configuration Examples
- 027-Remote Portal Authentication (IPv6) Configuration Examples
- 028-Portal MAC-Trigger Authentication (IPv6) Configuration Example
- 029-Remote Portal Authentication with User Profile Authorization Configuration Examples
- 030-WiFiDog Portal Authentication Configuration Examples
- 031-Portal Fail-Permit Configuration Examples
- 032-Local MAC Authentication Configuration Examples
- 033-Remote MAC Authentication Configuration Examples
- 034-Local Portal Authentication Configuration Examples
- 035-Transparent Auth Through Remote MAC and Portal Auth Configuration Examples
- 036-Remote AP, Remote Portal, and MAC-Trigger Authentication Configuration Examples
- 037-MAC Authentication with Guest VLAN Assignment Configuration Examples
- 038-MAC Authentication with Guest VLAN Assignment (IPv6) Configuration Examples
- 039-Local MAC-And-802.1X Authentication Configuration Examples
- 040-Local 802.1X Authentication Configuration Examples
- 041-Local RADIUS-Based 802.1X Authentication in EAP Relay Mode Configuration Examples
- 042-Remote 802.1X Authentication Configuration Examples
- 043-Remote 802.1X Authentication (IPv6) Configuration Examples
- 044-Remote 802.1X Authentication in WPA3-Enterprise Mode Configuration Examples
- 045-802.1X Auth with ACL Assignment Through IMC Server Configuration Examples
- 046-802.1X Auth with User Profile Assignment Through IMC Server Configuration Examples
- 047-EAD Authentication Configuration Examples
- 048-EAD Authentication (IPv6) Configuration Examples
- 049-Local Forwarding Mode and Local Portal Authentication Configuration Examples
- 050-Local Forwarding Mode Direct Portal Authentication Configuration Examples
- 051-Local Forwarding Mode Direct Portal Authentication (IPv6) Configuration Examples
- 052-Local Forwarding Configuration Examples
- 053-Wired Port Local Forwarding through Wireless Terminator Configuration Examples
- 054-Remote AP Configuration Examples
- 055-Downlink VLAN Management for Fit-Mode APs Configuration Examples
- 056-Downlink VLAN Management for Fit APs and Cloud APs Configuration Examples
- 057-WIPS Configuration Examples
- 058-WIPS Countermeasures Against All SSIDs Configuration Examples
- 059-IP Source Guard (IPv4) Configuration Examples
- 060-IP Source Guard (IPv6) Configuration Examples
- 061-IPS Configuration Examples
- 062-URL Filtering Configuration Examples
- 063-Anti-Virus Configuration Examples
- 064-Data Filtering Configuration Examples
- 065-File Filtering Configuration Examples
- 066-Application Audit and Management Configuration Examples
- 067-Application Rate Limiting Configuration Examples
- 068-IRF Setup with LACP MAD Configuration Examples
- 069-IRF Setup with ARP MAD Configuration Examples
- 070-IRF Setup with Members Not Directly Connected Configuration Examples
- 071-IRF Setup with Members in One Chassis Configuration Examples
- 072-IRF Setup with Members in Different Chassis Configuration Examples
- 073-Dual-Link Backup Configuration Examples
- 074-Remote 802.1X Auth on an AC Hierarchy Network with Dual-Link Backup Configuration Examples
- 075-Remote Portal Auth on an AC Hierarchy Network with Dual-Link Backup Configuration Examples
- 076-OAuth-Based Portal MAC-Trigger Auth on a Local-Forwarding Dual-Link Backup Configuration Examples
- 077-Dual-Link Backup OAuth-Based Portal Authentication in Local Forwarding Configuration Examples
- 078-Dual-Link Backup Remote Portal MAC-Trigger Authentication in Local Forwarding Configuration Examples
- 079-Dual-Link Backup Remote Portal and Transparent MAC Auth in Local Forwarding Configuration Examples
- 080-Dual-Link Backup Remote Portal Authentication in Local Forwarding Configuration Examples
- 081-Dual-Link Backup Remote Portal and Transparent MAC Auth in Centralized Forwarding Configuration Examples
- 082-Dual-Link Backup Remote Portal Authentication in Centralized Forwarding Configuration Examples
- 083-Dual-Link Backup Lightweight Portal Authentication in Centralized Forwarding Configuration Examples
- 084-Dual-Link Backup OAuth-Based Portal Authentication in Centralized Forwarding Configuration Examples
- 085-Dual-Link Backup Remote Portal MAC-Trigger Auth in Centralized Forwarding Configuration Examples
- 086-Remote 802.1X Authentication on a Dual-Link AC Backup Network Configuration Examples
- 087-Remote MAC Authentication on a Dual-Link AC Backup Network Configuration Examples
- 088-AC Hierarchy Configuration Examples
- 089-Remote 802.1X Auth (Local AC Auth+AC Forwardering) Configuration Examples
- 090-Remote 802.1X Auth (Central AC Auth+AP Forwarding) Configuration Examples
- 091-AC Hierarchy (IPv6) Configuration Examples
- 092-WLAN Probe Configuration Examples
- 093-Multicast Optimization Configuration Examples
- 094-Client Rate Limiting Configuration Examples
- 095-Inter-AC Roaming Configuration Examples
- 096-Inter-AC Roaming (IPv6) Configuration Examples
- 097-Inter-AC Roaming in Local Forwarding Mode Configuration Examples
- 098-H3C Access Controllers Cooperative Roaming for 802.11v Clients Configuration Examples
- 099-WLAN Load Balancing Configuration Examples
- 100-Static Blacklist Configuration Examples
- 101-Client Quantity Control Configuration Examples
- 102-AP License Synchronization Configuration Examples
- 103-BLE Module iBeacon Transmission Configuration Examples
- 104-Medical RFID Tag Management Configuration Examples
- 105-iBeacon Management Configuration Examples
- 106-Mesh Link Establishment Between Fit APs Configuration Examples
- 107-Mesh Link Establishment Between a Fit AP and a Fat AP Configuration Examples
- 108-Auto-DFS and Auto-TPC Configuration Examples
- 109-AP Image Downloading Configuration Examples
- 110-Dual-Uplink Interfaces Configuration Guide
- 111-H3C Comware AC Cloud-Managed AP Centralized Management Configuration Examples
- 112-Internal-to-External Access Through NAT Configuration Examples
- 113-Layer 2 Static Aggregation Configuration Examples
- 114-Layer 2 Multicast Configuration Examples
- 115-Static VLAN Allocation Configuration Examples
- 116-URL Redirection Configuration Examples
- 117-IPv6 URL Redirection Configuration Examples
066-Application Audit and Management Configuration Examples | 98.24 KB |
H3C Access Controllers |
Introduction
The following information provides examples for configuring application audit and management.
The following information applies to Comware-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of application audit and management.
Example: Configuring application audit and management
As shown in Figure 1, the switch assigns IP addresses to the AP and the client. The AP and the AC establish a CAPWAP tunnel through VLAN 100, and the client accesses the wireless network through VLAN 200. The working hours of the company are 8:00:00 through 18:00:00 from Monday to Friday.
Configure an application audit and management policy on the AC to meet the following requirements:
· Permit login from all QQ accounts during working hours.
· Generate audit logs.
Use the actual serial ID of an AP to uniquely identify that AP.
Procedures
Configuring the AC
1. Configure interfaces on the AC:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to VLAN-interface 100.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 192.1.1.1 24
[AC-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to VLAN-interface 200.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 192.2.1.1 24
[AC-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 as a trunk port, remove it from VLAN 1, assign it to VLAN 100 and VLAN 200, and set its PVID to VLAN 100.
[AC-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
[AC-GigabitEthernet1/0/1] port trunk pvid vlan 100
2. Configure wireless services:
# Create service template 1 and enter service template view.
[AC] wlan service-template 1
# Set the SSID to service.
[AC-wlan-st-1] ssid service
# Configure the PSK AKM mode and the 12345678 plaintext key.
[AC-wlan-st-1] akm mode psk
[AC-wlan-st-1] preshared-key pass-phrase simple 12345678
# Configure CCMP as the cipher suite and RSN as the security IE.
[AC-wlan-st-1] cipher-suite ccmp
[AC-wlan-st-1] security-ie rsn
# Configure the AC to forward client data traffic. If the AC forwards client data traffic by default, skip this step.
[AC-wlan-st-1] client forwarding-location ac
# Assign clients coming online through the service template to VLAN 200.
[AC-wlan-st-1] vlan 200
# Enable the service template..
[AC-wlan-st-1] quit
3. Configure the AP:
NOTE: In a large network, use AP groups to configure APs as a best practice. |
# Create an AP named ap1, with model WA6320.
[AC] wlan ap ap1 model WA6320
# Set the serial ID to 219801A28N819CE0002T.
[AC-wlan-ap-ap1] serial-id 219801A28N819CE0002T
# Create an AP group named group1, and create an AP grouping rule by AP names to add AP ap1 to the AP group.
[AC-wlan-ap-group-group1] ap ap1
# Enter radio view of radio 1, and bind service template 1 to the radio.
[AC-wlan-ap-group-group1] ap-model WA6320
[AC-wlan-ap-group-group1-ap-model-WA6320] radio 1
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] service-template 1
# Enable radio 1.
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] quit
# Enter radio view of radio 2, and bind service template 1 to the radio.
[AC-wlan-ap-group-group1-ap-model-WA6320] radio 2
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] service-template 1
# Enable radio 2.
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] quit
4. Configure a time range named work to cover 8:00:00 through 18:00:00 from Monday to Friday.
<AC> system-view
[AC] time-range work 08:00 to 18:00 working-day
5. Create an IPv4 address object group named audit, and configure an IPv4 address object with the IPv4 address of 192.2.1.0 and mask length of 24..
[AC] object-group ip address audit
[AC-obj-grp-ip-audit] network subnet 192.2.1.0 24
[AC-obj-grp-ip-audit] quit
6. Configure an application audit and management policy:
# Enter application audit and management view.
[AC] uapp-control
# Create an audit policy named audit-qq and enter its view.
[AC-uapp-control] policy name audit-qq audit
# Specify IPv4 address object group audit as a match criterion for audit policy audit-qq.
[AC-uapp-control-policy-audit-qq] source-address ipv4 audit
# Specify time range work for audit policy audit-qq.
[Device-uapp-control-policy-audit-qq] time-range work
# Configure an audit rule to permit login from all QQ accounts and generate audit logs.
[AC-uapp-control-policy-audit-qq] rule 1 app QQ behavior Login bhcontent any keyword equal any action permit audit-logging
[AC-uapp-control-policy-audit-qq] quit
[AC-uapp-control] quit
# Activate the configuration.
[AC] inspect activate
Configuring the switch
1. Configure interfaces on the switch:
# Create VLANs 100 and 200, create VLAN-interface 100 and VLAN-interface 200, and assign IP addresses to VLAN-interface 100 and VLAN-interface 200. The switch will use VLAN 100 to forward the traffic on CAPWAP tunnels between the AC and APs, and use VLAN 200 to forward client traffic.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
[Switch-Vlan-interface100] ip address 192.1.1.2 24
[Switch] vlan 200
[Switch-vlan200] quit
[Switch] interface vlan-interface 200
[Switch-Vlan-interface200] ip address 192.2.1.2 24
[Switch-Vlan-interface200] quit
[Switch-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
[Switch-GigabitEthernet1/0/1] port trunk pvid vlan 100
# Configure GigabitEthernet 1/0/2 as a trunk port, remove it from VLAN 1, assign it to VLAN 100, and set its PVID to VLAN 100.
[Switch-GigabitEthernet1/0/2] port link-type trunk
[Switch-GigabitEthernet1/0/2] undo port trunk permit vlan 1
[Switch-GigabitEthernet1/0/2] port trunk permit vlan 100
[Switch-GigabitEthernet1/0/2] port trunk pvid vlan 100
# Enable PoE on GigabitEthernet 1/0/2.
2. Configure DHCP:
# Enable DHCP.
[Switch] dhcp enable
# Create a DHCP address pool named vlan100 to assign IP addresses and other configuration parameters to clients on subnet 192.1.1.0/24.
[Switch] dhcp server ip-pool vlan100
[Switch-dhcp-pool-vlan100] network 192.1.1.0 mask 255.255.255.0
# Exclude IP addresses 192.1.1.1 and 192.1.1.2 from dynamic allocation.
[Switch-dhcp-pool-vlan100] forbidden-ip 192.1.1.1 192.1.1.2
# Specify a gateway.
[Switch-dhcp-pool-vlan100] gateway-list 192.1.1.1
[Switch-dhcp-pool-vlan100] quit
# Create a DHCP address pool named vlan200 to assign IP addresses and other configuration parameters to clients on subnet 192.2.1.0/24.
[Switch] dhcp server ip-pool vlan200
[Switch-dhcp-pool-vlan200] network 192.2.1.0 mask 255.255.255.0
# Exclude IP addresses 192.2.1.1 and 192.2.1.2 from dynamic allocation.
[Switch-dhcp-pool-vlan200] forbidden-ip 192.2.1.1 192.2.1.2
# Specify a gateway and a DNS server.
[Switch-dhcp-pool-vlan200] dns-list 192.2.1.2
[Switch-dhcp-pool-vlan200] gateway-list 192.2.1.2
[Switch-dhcp-pool-vlan200] quit
# Verify that the device permits the login requests and generates audit log messages when QQ accounts attempt to access the Internet. (Details not shown.)
Configuration files
· AC:
vlan 100
vlan 200
0 network subnet 192.2.1.0 255.255.255.0
ssid service
vlan 200
akm mode psk
preshared-key pass-phrase cipher $c$3$29gn1DalRVhkcyZ1CKwevH+xb6Lxopy3eq/H
cipher-suite ccmp
security-ie rsn
interface Vlan-interface100
ip address 192.1.1.1 255.255.255.0
interface Vlan-interface200
ip address 192.2.1.1 255.255.255.0
wlan ap-group group1
vlan 1
ap ap1
ap-model WA6320
radio 1
radio enable
service-template 1
radio 2
radio enable
service-template 1
gigabitethernet 1
wlan ap ap1 model WAP722S-HI
serial-id 219801A2F98205P00031
radio 1
radio enable
service-template 1
radio 2
radio enable
service-template 1
uapp-control
time-range work
· Switch:
dhcp enable
vlan 100
vlan 200
dns-list 192.2.1.2
ip address 192.1.1.2 255.255.255.0
ip address 192.2.1.2 255.255.255.0
poe enable
Related documentation
· Application Audit and Management Command Reference in H3C Access Controllers Command References
· Application Audit and Management Configuration Guide in H3C Access Controllers Configuration Guides
· Security Policy Command Reference in H3C Access Controllers Command References
· Security Policy Configuration Guide in H3C Access Controllers Configuration Guides
