04-Comware 7 CLI-based configuration examples (AC+fit AP deployment)
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10204-Comware 7 CLI-based configuration examples (AC+fit AP deployment)
Table of Contents
Related Documents
064-Data Filtering Configuration Examples
064-Data Filtering Configuration Examples 106.94 KB
H3C Access Controllers
Introduction
The following information provides an example of configuring data filtering.
The following information applies to Comware-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of data filtering and security policy.
Example: Configuring data filtering
As shown in Figure 1, the AC connects to the external network.
Configure data filtering on the AC so the AC performs the following operations:
·     Blocks HTTP packets that contain the uri or abc.*abc string in the URI field or message body.
·     Blocks download FTP traffic that contains the www.abcd.com/ string.
·     Logs the blocked packets.
Figure 1 Network diagram
·     Use the actual serial ID of an AP to uniquely identify that AP.
·     Configure the AC to forward client traffic.
Procedures
Configuring the AC
Configuring the basic AC features
1.     Configure interfaces on the AC:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The AP will obtain this IP address to establish CAPWAP tunnels with the AC.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 192.1.1.1 24
[AC-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. The client will access the wireless network in this VLAN.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 192.2.1.1 24
[AC-Vlan-interface200] quit
# Set the link type of GigabitEthernet 1/0/1 (the interface connected to the switch) to trunk, and allow traffic from VLAN 100 and VLAN 200 to pass through the interface.
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
2.     Configure a wireless service:
# Create service template 1 and enter service template view.
[AC] wlan service-template 1
# Set the SSID to service.
[AC-wlan-st-1] ssid service
# Set the AKM mode to PSK and configure simple character string 12345678 as the PSK.
[AC-wlan-st-1] akm mode psk
[AC-wlan-st-1] preshared-key pass-phrase simple 12345678
# Set the AES-CCMP cipher suite for frame encryption, and enable the RSN IE in beacon and probe responses.
[AC-wlan-st-1] cipher-suite ccmp
[AC-wlan-st-1] security-ie rsn
# Configure the AC to forward client traffic. If the default client traffic forwarding location is the same as the configuration in this step, you can skip this step.
[AC-wlan-st-1] client forwarding-location ac
# Assign the client to VLAN 200 after it comes online.
[AC-wlan-st-1] vlan 200
# Enable the service template.
[AC-wlan-st-1] quit
3.     Configure the AP:
IMPORTANT
IMPORTANT:
In a large-scale network, configure AP groups as a best practice.
# Create a manual AP named ap1, and specify the AP model.
[AC] wlan ap ap1 model WA6320
# Set the serial ID to 219801A28N819CE0002T.
[AC-wlan-ap-ap1] serial-id 219801A28N819CE0002T
[AC-wlan-ap-ap1] quit
# Create AP group group1 and create an AP grouping rule by AP names to add AP ap1 to AP group group1.
[AC] wlan ap-group group1
[AC-wlan-ap-group-group1] ap ap1
# Bind service template 1 to radio 1 in AP group group1.
[AC-wlan-ap-group-group1] ap-model WA6320
[AC-wlan-ap-group-group1-ap-model-WA6320] radio 1
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] service-template 1
# Enable radio 1.
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] quit
# Bind service template 1 to radio 2 in AP group group1.
[AC-wlan-ap-group-group1-ap-model-WA6320] radio 2
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] service-template 1
# Enable radio 2.
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] return
Configuring an object group
# Configure an IP address object group named datafilter and specify subnet 192.2.1.0/24 for the object group.
<AC> system-view
[AC] object-group ip address datafilter
[AC-obj-grp-ip-datafilter] network subnet 192.2.1.0 24
[AC-obj-grp-ip-datafilter] quit
1.     Configure keyword groups:
# Create a keyword group named kg1 and enter its view.
[AC] data-filter keyword-group kg1
# Create two keyword match patterns that match the uri text string and the abc.*abc regular expression string, respectively.
[AC-data-filter-kgroup-kg1] pattern 1 text uri
[AC-data-filter-kgroup-kg1] pattern 2 regex abc.*abc
[AC-data-filter-kgroup-kg1] quit
# Create a keyword group named kg2 and enter its view.
[AC] data-filter keyword-group kg2
# Create a keyword match pattern that matches the www.abcd.com/ text string.
[AC-data-filter-kgroup-kg2] pattern 1 text www.abcd.com
[AC-data-filter-kgroup-kg2] quit
2.     Configure a data filtering policy:
# Create a data filtering policy named p1 and enter its view.
[AC] data-filter policy p1
# Create a data filtering rule named r1 and enter its view.
[AC-data-filter-policy-p1] rule r1
# Configure the rule to drop and log both upload and download HTTP traffic that matches keyword group kg1.
[AC-data-filter-policy-p1-rule-r1] keyword-group kg1
[AC-data-filter-policy-p1-rule-r1] application type http
[AC-data-filter-policy-p1-rule-r1] direction both
[AC-data-filter-policy-p1-rule-r1] action drop logging
[AC-data-filter-policy-p1-rule-r1] quit
# Create a data filtering rule named r2 and enter its view.
[AC-data-filter-policy-p1] rule r2
# Configure the rule to drop and log download FTP traffic that matches keyword group kg2.
[AC-data-filter-policy-p1-rule-r2] keyword-group kg2
[AC-data-filter-policy-p1-rule-r2] application type ftp
[AC-data-filter-policy-p1-rule-r2] direction download
[AC-data-filter-policy-p1-rule-r2] action drop logging
[AC-data-filter-policy-p1-rule-r2] quit
[AC-data-filter-policy-p1] quit
Applying the data filtering policy to a DPI application profile
# Create a DPI application profile named profile1 and enter its view.
[AC] app-profile profile1
# Apply data filtering policy p1 to the DPI application profile.
[AC-app-profile-profile1] data-filter apply policy p1
[AC-app-profile-profile1] quit
# Activate the data filtering policy and rule settings.
[AC] inspect activate
Applying the DPI application profile to a security policy
# Enter IPv4 security policy view.
[AC] security-policy ip
# Create a security policy rule named inspect1. Configure the rule to permit packets from IP addresses in IP address object group datafilter and apply DPI application profile profile1 to the security policy.
[AC-security-policy-ip] rule name inspect1
[AC-security-policy-ip-14-inspect1] source-ip datafilter
[AC-security-policy-ip-14-inspect1] action pass
[AC-security-policy-ip-14-inspect1] profile profile1
[AC-security-policy-ip-14-inspect1] quit
# Activate rule matching acceleration.
[AC-security-policy-ip] accelerate enhanced enable
[AC-security-policy-ip] quit
Configuring the switch
1.     Configure interfaces on the switch:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The switch will use this VLAN to forward CAPWAP tunnel traffic between the AC and the AP.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
[Switch-Vlan-interface100] ip address 192.1.1.2 24
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. This VLAN will be used to forward wireless client packets.
[Switch] vlan 200
[Switch-vlan200] quit
[Switch] interface vlan-interface 200
[Switch-Vlan-interface200] ip address 192.2.1.2 24
[Switch-Vlan-interface200] quit
# Set the link type of GigabitEthernet 1/0/1 (the interface connected to the AC) to trunk, and allow traffic from VLAN 100 and VLAN 200 to pass through the interface.
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
# Set the link type of GigabitEthernet 1/0/2 (the interface connected to the AP) to access, and allow only traffic from VLAN 100 to pass through the interface.
[Switch] interface gigabitethernet1/0/2
# Enable PoE.
2.     Configure DHCP settings:
# Enable DHCP.
[Switch] dhcp enable
# Create a DHCP address pool named vlan100 to assign IP addresses and other configuration parameters to clients on subnet 192.1.1.0/24.
[Switch] dhcp server ip-pool vlan100
[Switch-dhcp-pool-vlan100] network 192.1.1.0 mask 255.255.255.0
# Exclude IP addresses 192.1.1.1 and 192.1.1.2 from dynamic allocation.
[Switch-dhcp-pool-vlan100] forbidden-ip 192.1.1.1 192.1.1.2
# Specify a gateway.
[Switch-dhcp-pool-vlan100] gateway-list 192.1.1.1
[Switch-dhcp-pool-vlan100] quit
# Create a DHCP address pool named vlan200 to assign IP addresses and other configuration parameters to clients on subnet 192.2.1.0/24.
[Switch] dhcp server ip-pool vlan200
[Switch-dhcp-pool-vlan200] network 192.2.1.0 mask 255.255.255.0
# Exclude IP addresses 192.2.1.1 and 192.2.1.2 from dynamic allocation.
[Switch-dhcp-pool-vlan200] forbidden-ip 192.2.1.1 192.2.1.2
# Specify a gateway and a DNS server.
[Switch-dhcp-pool-vlan200] dns-list 192.2.1.1
[Switch-dhcp-pool-vlan200] gateway-list 192.2.1.1
[Switch-dhcp-pool-vlan200] quit
# Verify that the AC blocks and logs HTTP packets and FTP packets that meet the specified criteria. (Details not shown.)
Configuration files
·     AC:
vlan 100
vlan 200
 ssid service
 vlan 200
 akm mode psk
 preshared-key pass-phrase cipher $c$3$29gn1DalRVhkcyZ1CKwevH+xb6Lxopy3eq/H
 cipher-suite ccmp
 security-ie rsn
interface Vlan-interface100
 ip address 192.1.1.1 255.255.255.0
interface Vlan-interface200
 ip address 192.2.1.1 255.255.255.0
 vlan 1
 ap ap1
 ap-model WA6320
 radio 1
  radio enable
  service-template 1
 radio 2
  radio enable
  service-template 1
 gigabitethernet 1
 0 network subnet 192.2.1.0 255.255.255.0
 pattern 1 text uri
 rule r1
  keyword-group kg1
  direction both
  action drop logging
 rule r2
  keyword-group kg2
  direction download
  action drop logging
security-policy ip
 rule 1 name inspect1
  action pass
  profile profile1
·     Switch:
 dhcp enable
vlan 100
vlan 200
 ip address 192.1.1.2 255.255.255.0
 ip address 192.2.1.2 255.255.255.0
 network 192.1.0.0 mask 255.255.255.0
 dns-list 192.2.1.1
 poe enable
Related documentation
·     Data Filtering Command Reference in H3C Access Controllers Command References
·     Data Filtering Configuration Guide in H3C Access Controllers Configuration Guides
·     Security Policy Command Reference in H3C Access Controllers Command References
·     Security Policy Configuration Guide in H3C Access Controllers Configuration Guides
