H3C Fixed Port Campus Switches Configuration Examples-6W105
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-6W105
Table of Contents
Related Documents
92-NetStream Configuration Examples
Introduction
This document provides NetStream configuration examples.
This document assumes that you have basic knowledge of NetStream.
This feature is only supported on a device installed with an H3C LSWM2FPGA or LSWM2FPGAB NetStream interface module.
Example: Configuring NetStream
As shown in Figure 1, configure NetStream on the device to collect and export traffic statistics as follows:
·     Export the collected traffic statistics to the IMC server with IP address 12.110.2.2/16 and UDP port 6343.
·     Randomly capture one packet out of every 256 packets (both inbound and outbound) for NetStream traffic statistics collection on GigabitEthernet 3/0/1.
Figure 1 Network diagram
Analysis
To ensure that the device and the IMC server can communicate with each other, add the device to IMC NTA with the correct SNMP community string and port number.
To collect bidirectional traffic statistics on GigabitEthernet 3/0/1 of the device, enable NetStream for both the inbound and outbound traffic on GigabitEthernet 3/0/1. Specify a sampler to implement sampled-NetStream as required.
For the IMC server to analyze the NetStream statistics and generate reports based on the statistics, configure a traffic analysis task in IMC NTA.
Hardware
Software version
S6812 switch series
S6813 switch series
Not supported
S6550XE-HI switch series
Not supported
S6525XE-HI switch series
Not supported
S5850 switch series
Not supported
S5570S-EI switch series
Not supported
S5560X-EI switch series
Release 6628Pxx
S5560X-HI switch series
Not supported
S5500V2-EI switch series
Release 6628Pxx
MS4520V2-30F switch
Release 6628Pxx
MS4520V2-30C switch
MS4520V2-54C switch
Release 6628Pxx
MS4520V2-28S switch
MS4520V2-24TP switch
Not supported
S6520X-HI switch series
S6520X-EI switch series
Not supported
S6520X-SI switch series
S6520-SI switch series
Not supported
S5000-EI switch series
Not supported
MS4600 switch series
Not supported
ES5500 switch series
Release 6628Pxx
S5560S-EI switch series
S5560S-SI switch series
Not supported
S5500V3-24P-SI switch
S5500V3-48P-SI switch
Not supported
S5500V3-SI switch series (except S5500V3-24P-SI and S5500V3-48P-SI)
Not supported
S5170-EI switch series
Not supported
S5130S-HI switch series
S5130S-EI switch series
S5130S-SI switch series
S5130S-LI switch series
Not supported
S5120V2-SI switch series
S5120V2-LI switch series
Not supported
S5120V3-EI switch series
Not supported
S5120V3-36F-SI switch
S5120V3-28P-HPWR-SI switch
S5120V3-54P-PWR-SI switch
Not supported
S5120V3-SI switch series (except S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI)
Not supported
S5120V3-LI switch series
Not supported
S3600V3-EI switch series
Not supported
S3600V3-SI switch series
Not supported
S3100V3-EI switch series
S3100V3-SI switch series
Not supported
S5110V2 switch series
Not supported
S5110V2-SI switch series
Not supported
S5000V3-EI switch series
S5000V5-EI switch series
Not supported
S5000E-X switch series
S5000X-EI switch series
Not supported
E128C switch
E152C switch
E500C switch series
E500D switch series
Not supported
MS4320V2 switch series
MS4320V3 switch series
MS4300V2 switch series
MS4320 switch series
MS4200 switch series
Not supported
WS5850-WiNet switch series
Not supported
WS5820-WiNet switch series
WS5810-WiNet switch series
Not supported
WAS6000 switch series
Not supported
IE4300-12P-AC switch
IE4300-12P-PWR switch
IE4300-M switch series
IE4320 switch series
Not supported
S5135S-EI switch series
Not supported
For the device to send NetStream statistics to the IMC server, specify the IMC server with IP address 12.110.2.2/16 and UDP port 6343 as the destination host for NetStream data export.
Procedures
Configuring a NetStream interface module to work in NetStream mode
You can install a NetStream interface module on the device to provide the NetStream feature. After the device mirrors traffic to the NetStream interface module, the field programmable gate array (FPGA) chip in the module collects and analyzes traffic statistics and creates NetStream entries. This saves ACL resources and improves NetStream entry creation performance.
A NetStream interface module supports the following working modes:
·     0—Normal mode. In this mode, NetStream is not supported.
·     1—NetStream mode. The NetStream interface module works in the unidirectional NetStream mode.
·     2—Session-based NetStream mode. The NetStream interface module works in the session-based bidirectional NetStream mode.
To make the configuration take effect, save the configuration and reboot the device. Before you reboot the device, make sure you understand the potential impact on the network.
2.     Configuring a NetStream interface module to work in NetStream mode.
fpga-working-mode slot slot-number 1
By default, a NetStream interface module works in mode 0 and the device does not support NetStream.
Configuring the device
1.     Configure SNMP:
# Enable the SNMP agent.
[Device] snmp-agent
# Set the read-only community name to public.
[Device] snmp-agent community read public
# Specify the UDP port number for receiving SNMP packets as 161.
[Device] snmp-agent port 161
2.     Create sampler 256 in random sampling mode. Set the sampling rate to 8, which indicates that one packet will be randomly selected out of every 256 packets.
[Device] sampler 256 mode random packet-interval n-power 8
3.     Configure NetStream:
# Enable NetStream sampling for both incoming and outgoing traffic on GigabitEthernet 1/0/1 with sampler 256.
[Device-GigabitEthernet1/0/1] ip netstream inbound
[Device-GigabitEthernet1/0/1] ip netstream outbound
[Device-GigabitEthernet1/0/1] ip netstream inbound sampler 256
[Device-GigabitEthernet1/0/1] ip netstream outbound sampler 256
# Specify the IMC server as the NetStream data export destination.
[Device] ip netstream export host 12.110.2.2 6343
Configuring IMC
The IMC platform version running on the IMC server is PLAT 7.3 (E0504).
Adding the device to IMC NTA
1.     Log in to IMC.
2.     Click the Service tab.
3.     From the left navigation pane, select Traffic Analysis and Audit > Settings.
4.     On the Settings page that opens, click Device Management.
The Device Management page opens.
5.     Click Add.
6.     On the Add Device page shown in Figure 2, perform the following steps:
a.     Enter the device IP address (12.110.2.1) in the Device IP field.
b.     Specify the device name, SNMP community name, SNMP port number, and other parameters as needed.
c.     Click OK.
Figure 2 Adding the device to IMC NTA
Deploying NTA server configuration to the device
1.     On the Settings page, click Server Management.
The Server List page opens.
2.     Click the Modify icon icon_modify_16x16.png for the NTA server.
3.     On the Server Configuration page shown in Figure 3, configure the following parameters:
a.     Set port 6343 as the listening port for the server.
b.     Select the device (12.110.2.1) in the Traffic Analysis area.
c.     Use the default settings for the other parameters.
d.     Click Deploy.
Figure 3 Server Configuration
Adding a traffic analysis task
1.     On the Settings page, click Traffic Analysis Task Management.
The Traffic Analysis Task Management page opens.
2.     Click Add.
The Select Task Type page opens.
3.     Select Interface and click Next.
The Add Traffic Analysis Task page opens.
4.     In the Basic Information area, configure the following settings:
¡     Task Name—Enter a task name. This example uses Interface.
¡     ServerSelect 127.0.0.1 from the list.
¡     Reader—Click Select next to the Reader field, select the operator groups that have access to the analysis and reports provided by the task, and click OK.
¡     Vlan Analysis—Select Enable from the list.
¡     Baseline Analysis—Select Enable from the list.
The Enable Automatic Anomaly Detection Based On The Baseline parameter and the Baseline Threshold Setting area are displayed.
¡     Enable Automatic Anomaly Detection Based On The Baseline—Select Disable from the list.
¡     Threshold Alarm—Select Enable from the list.
The Threshold Alarm Settings area is displayed.
5.     In the Baseline Threshold Settings area, set the In Threshold to 40% and the Out Threshold to 30%.
6.     In the Threshold Alarm Settings area, set the In Threshold to 50 Mbps and the Out Threshold to 30 Mbps.
7.     In the Interface Information area, click Select and select interface GigabitEthernet 1/0/2.
8.     Use the default settings for the other parameters.
9.     Click OK.
Figure 4 Adding an interface traffic analysis task
Verifying the configuration on the device
# Display NetStream data export information.
[Device] display ip netstream export
IP export information:
  Flow source interface                           : GigabitEthernet1/0/2
  Flow destination VPN instance                   : Not specified
  Flow destination IP address (UDP)               : 12.110.2.2 (6343)
  Version 5 exported flow number                  : 0
  Version 5 exported UDP datagram number (failed) : 0 (0)
  Version 9 exported flow number                  : 10
  Version 9 exported UDP datagram number (failed) : 10 (0)
Verifying the configuration on IMC
1.     View the interface traffic analysis task summary reports.
a.     Click the Service tab.
b.     From the left navigation pane, select Traffic Analysis and Audit > Interface Traffic Analysis Task.
The interface traffic analysis task summary reports are displayed, as shown in Figure 5.
Figure 5 Summary reports for interface traffic analysis tasks
2.     View detailed reports for the interface traffic analysis task named Interface:
b.     From the left navigation tree, select Traffic Analysis and Audit > Interface Traffic Analysis Task.
c.     Use either of the following methods to access the report page of interface traffic analysis task Interface:
-     In the Summary List area, click the name of interface traffic analysis task.
-     On the left navigation pane, move your mouse pointer to the shortcut menu icon  next to imc_nta_icon_interface_trafficInterface Traffic Analysis Task, and then select Interface from the menu.
The Traffic tab displays the traffic analysis reports of the task.
Figure 6 Viewing the traffic analysis reports of the task
3.     To view the application usage reports of the task, click the Application tab.
Figure 7 Viewing the application usage reports of the task
4.     To view the source host-based traffic analysis reports of the task, click the Source tab.
Figure 8 Viewing source host-based traffic analysis reports of the task
5.     To view the destination host-based traffic analysis reports of the task, click the Destination tab.
Figure 9 Viewing destination host-based traffic analysis reports of the task
6.     To view the session-based traffic analysis reports of the task, click the Session tab.
Figure 10 Viewing session-based traffic analysis reports of the task
Configuration files
snmp-agent
snmp-agent port 161
interface gigabitethernet 1/0/1
 ip address 11.110.2.1 255.255.0.0
interface gigabitethernet 1/0/2
 ip address 12.110.2.1 255.255.0.0
不同款型规格的资料略有差异, 详细信息请向具体销售和400咨询。 H3C保留在没有任何通知或提示的情况下对资料内容进行修改的权利!
