H3C Fixed Port Campus Switches Configuration Examples-6W105
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-6W105
Table of Contents
Related Documents
06-Ethernet Link Aggregation Configuration Examples
Introduction
This document provides Ethernet link aggregation configuration examples.
This document assumes that you have basic knowledge of Ethernet link aggregation.
Example: Configuring Layer 2 link aggregation
As shown in Figure 1, both Device A and Device B forward traffic from VLAN 10 and VLAN 20.
Configure link aggregation on Device A and Device B to meet the following requirements:
·     VLAN 10 on Device A can communicate with VLAN 10 on Device B.
·     VLAN 20 on Device A can communicate with VLAN 20 on Device B.
Figure 1 Network diagram
Analysis
To enable traffic from VLAN 10 and VLAN 20 to pass through Layer 2 aggregate interface Bridge-aggregation 1, perform the following tasks:
·     Configure Layer 2 aggregate interface Bridge-aggregation 1 as a trunk port.
·     Assign the aggregate interface to VLAN 10 and VLAN 20.
Hardware
Software version
S6812 switch series
S6813 switch series
Release 6615Pxx, Release 6628Pxx
S6550XE-HI switch series
Release 6008 and later, Release 8106Pxx
S6525XE-HI switch series
S5850 switch series
Release 8005 and later, Release 8106Pxx
S5570S-EI switch series
Release 11xx
S5560X-EI switch series
Release 63xx, Release 65xx, Release 6615Pxx, Release 6628Pxx
S5560X-HI switch series
S5500V2-EI switch series
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S switch
MS4520V2-24TP switch
Release 63xx
S6520X-HI switch series
S6520X-EI switch series
S6520X-SI switch series
S6520-SI switch series
S5000-EI switch series
MS4600 switch series
ES5500 switch series
S5560S-EI switch series
S5560S-SI switch series
Release 63xx
S5500V3-24P-SI switch
S5500V3-48P-SI switch
Release 63xx
S5500V3-SI switch series (except S5500V3-24P-SI and S5500V3-48P-SI)
Release 11xx
S5170-EI switch series
Release 11xx
S5130S-HI switch series
S5130S-EI switch series
S5130S-SI switch series
S5130S-LI switch series
Release 63xx
S5120V2-SI switch series
S5120V2-LI switch series
Release 63xx
S5120V3-EI switch series
Release 11xx
S5120V3-36F-SI switch
S5120V3-28P-HPWR-SI switch
S5120V3-54P-PWR-SI switch
Release 11xx
S5120V3-SI switch series (except S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI)
Release 63xx
S5120V3-LI switch series
Release 63xx
S3600V3-EI switch series
Release 11xx
S3600V3-SI switch series
Release 11xx
S3100V3-EI switch series
S3100V3-SI switch series
Release 63xx
S5110V2 switch series
Release 63xx
S5110V2-SI switch series
Release 63xx
S5000V3-EI switch series
S5000V5-EI switch series
Release 63xx
S5000E-X switch series
S5000X-EI switch series
Release 63xx
E128C switch
E152C switch
E500C switch series
E500D switch series
Release 63xx
MS4320V2 switch series
MS4320V3 switch series
MS4300V2 switch series
MS4320 switch series
MS4200 switch series
Release 63xx
WS5850-WiNet switch series
Release 63xx
WS5820-WiNet switch series
WS5810-WiNet switch series
Release 63xx
WAS6000 switch series
Release 63xx
IE4300-12P-AC switch
IE4300-12P-PWR switch
IE4300-M switch series
IE4320 switch series
Release 63xx
IE4520 switch series
Release 66xx
S5135S-EI switch series
Release 6658P01 and later
When you configure Layer 2 link aggregation, follow these restrictions and guidelines:
·     When you assign a port to an aggregation group, the recommended configuration procedure is as follows:
a.     Use the display this command in interface view to check the following attribute configurations of the port:
-     Port isolation.
-     QinQ.
-     VLAN.
-     VLAN mapping.
b.     If any of the above configurations exist, use the undo forms of the corresponding commands to remove these configurations. This enables the port to use the default attribute configurations.
c.     Assign the port to the aggregation group.
·     In a static aggregation group, the Selected state of a port is not affected by whether the peer port is added to an aggregation group and is Selected. As a result, the Selected state of a port might be different from the Selected state of the peer port. When both ends support static aggregation and dynamic aggregation, use dynamic aggregation.
·     You cannot assign a port to a Layer 2 aggregation group when MAC authentication, port security mode, or 802.1X is configured or enabled on the port.
Procedures
1.     Configure Device A:
# Create VLAN 10, and assign port GigabitEthernet 1/0/4 to VLAN 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port gigabitethernet 1/0/4
[DeviceA-vlan10] quit
# Create VLAN 20, and assign port GigabitEthernet 1/0/5 to VLAN 20.
[DeviceA] vlan 20
[DeviceA-vlan20] port gigabitethernet 1/0/5
[DeviceA-vlan20] quit
# Create Layer 2 aggregate interface Bridge-aggregation 1. Use one of the following methods as needed.
¡     Use the static aggregation mode to create Layer 2 aggregate interface Bridge-aggregation 1.
[DeviceA] interface bridge-aggregation 1
[DeviceA-Bridge-Aggregation1] quit
¡     Use the dynamic aggregation mode to create Layer 2 aggregate interface Bridge-aggregation 1.
[DeviceA-Bridge-Aggregation1] link-aggregation mode dynamic
# Assign ports GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3 to aggregation group 1.
[DeviceA] interface range gigabitethernet 1/0/1 to gigabitethernet 1/0/3
[DeviceA-if-range] port link-aggregation group 1
[DeviceA-if-range] quit
# Configure Layer 2 aggregate interface Bridge-aggregation 1 as a trunk port.
[DeviceA-Bridge-Aggregation1] port link-type trunk
 Configuring GigabitEthernet1/0/1 done.
 Configuring GigabitEthernet1/0/2 done.
 Configuring GigabitEthernet1/0/3 done.
# Assign the aggregate interface to VLANs 10 and 20.
[DeviceA-Bridge-Aggregation1] port trunk permit vlan 10 20
2.     Configure Device B in the same way Device A is configured. (Details not shown.)
# Display detailed information about the link aggregation groups on Device A.
·     Link aggregation configuration information when the static aggregation mode is used:
[DeviceA] display link-aggregation verbose
Port: A -- Auto port, M -- Management port, R -- Reference port
Flags:  A -- LACP_Activity, B -- LACP_Timeout, C -- Aggregation,
        G -- Defaulted, H -- Expired
Aggregation Interface: Bridge-Aggregation1
Aggregation Mode: Static
Management VLANs: None
  Port             Status  Priority  Oper-Key
  GE1/0/1(R)       S       32768     1
  GE1/0/2          S       32768     1
  GE1/0/3          S       32768     1
The output shows that all member ports in the local aggregation group are in the Selected state. The Selected states of the local member ports are not affected by the Selected states of the peer member ports.
·     Link aggregation configuration information when the dynamic aggregation mode is used:
Creation Mode: Manual
Aggregation Mode: Dynamic
System ID: 0x8000, 000f-e234-5678
Local:
  Port                Status   Priority Index    Oper-Key               Flag
  GE1/0/1             S        32768    2        1                      {ACDEF}
  GE1/0/2             S        32768    3        1                      {ACDEF}
  GE1/0/3             S        32768    4        1                      {ACDEF}
Remote:
  Actor               Priority Index    Oper-Key SystemID               Flag
  GE1/0/1(R)          32768    2        1        0x8000, a4e5-c316-0100 {ACDEF}
  GE1/0/2             32768    3        1        0x8000, a4e5-c316-0100 {ACDEF}
  GE1/0/3             32768    4        1        0x8000, a4e5-c316-0100 {ACDEF}
The output shows that the local member ports and the corresponding peer member ports are all Selected. In the dynamic link aggregation mode, each local member port and its peer member port have the same Selected state through exchanging LACPDUs. The user data traffic can be forwarded correctly.
Configuration files
IMPORTANT
IMPORTANT:
Support for the port link-mode bridge command depends on the device model.
·     Device A:
vlan 10
interface GigabitEthernet1/0/4
 port access vlan 10
vlan 20
interface GigabitEthernet1/0/5
 port access vlan 20
¡     In the static aggregation mode:
interface Bridge-Aggregation1
¡     In the dynamic aggregation mode:
·     Device B:
The configuration file on Device B is the same as the configuration file on Device A.
Example: Configuring Layer 2 aggregation load sharing
As shown in Figure 2, both Device A and Device B forward traffic for VLAN 10 and VLAN 20.
·     Configure Layer 2 static aggregation groups 1 and 2 on both Device A and Device B.
·     Configure link aggregation group 1 to forward traffic for VLAN 10.
·     Configure link aggregation group 2 to forward traffic for VLAN 20.
·     Configure link aggregation groups 1 and 2 to load share traffic across aggregation group member ports.
¡     Configure link aggregation group 1 to load share packets based on source MAC addresses.
¡     Configure link aggregation group 2 to load share packets based on destination MAC addresses.
Figure 2 Network diagram
Analysis
To enable the aggregate interfaces to forward traffic for VLAN 10 and VLAN 20, perform the following tasks:
·     Assign Layer 2 aggregate interface Bridge-aggregation 1 to VLAN 10.
·     Assign Layer 2 aggregate interface Bridge-aggregation 2 to VLAN 20.
For Bridge-aggregation 1 and Bridge-aggregation 2 to load share traffic across their Selected ports, set the load sharing mode in aggregate interface view.
Hardware
Software version
S6812 switch series
S6813 switch series
Not supported
S5850 switch series
Not supported
Not supported
Not supported
Not supported
MS4520V2-30F switch
Not supported
MS4520V2-30C switch
MS4520V2-54C switch
Not supported
MS4520V2-28S switch
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
E128C switch
E152C switch
E500C switch series
E500D switch series
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
1.     Use the display this command in interface view to check the following attribute configurations of the port:
¡     Port isolation.
¡     QinQ.
¡     VLAN.
¡     VLAN mapping.
2.     If any of the above configurations exist, use the undo forms of the corresponding commands to remove these configurations. This enables the port to use the default attribute configurations.
3.     Assign the port to the aggregation group.
Procedures
Configuring Device A
# Create VLAN 10, and assign GigabitEthernet 1/0/5 to VLAN 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port gigabitethernet 1/0/5
# Create VLAN 20, and assign GigabitEthernet 1/0/6 to VLAN 20.
[DeviceA] vlan 20
[DeviceA-vlan20] port gigabitethernet 1/0/6
# Create Layer 2 aggregate interface Bridge-Aggregation 1. Configure Layer 2 aggregation group 1 to load share packets based on source MAC addresses.
[DeviceA-Bridge-Aggregation1] link-aggregation load-sharing mode source-mac
# Assign GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to link aggregation group 1.
[DeviceA-GigabitEthernet1/0/1] port link-aggregation group 1
[DeviceA-GigabitEthernet1/0/2] port link-aggregation group 1
# Configure Layer 2 aggregate interface Bridge-Aggregation 1 as an access port and assign it to VLAN 10.
[DeviceA-Bridge-Aggregation1] port access vlan 10
# Create Layer 2 aggregate interface Bridge-Aggregation 2. Configure Layer 2 aggregation group 2 to load share packets based on destination MAC addresses.
[DeviceA] interface bridge-aggregation 2
[DeviceA-Bridge-Aggregation2] link-aggregation load-sharing mode destination-mac
[DeviceA-Bridge-Aggregation2] quit
# Assign GigabitEthernet 1/0/3 and GigabitEthernet 1/0/4 to link aggregation group 2.
[DeviceA-GigabitEthernet1/0/3] port link-aggregation group 2
[DeviceA] interface gigabitethernet 1/0/4
[DeviceA-GigabitEthernet1/0/4] port link-aggregation group 2
[DeviceA-GigabitEthernet1/0/4] quit
# Configure Layer 2 aggregate interface Bridge-Aggregation 2 as an access port and assign it to VLAN 20.
[DeviceA-Bridge-Aggregation2] port access vlan 20
Configuring GigabitEthernet1/0/4 done.
Configuring Device B
# Display detailed information about all aggregation groups on Device A.
Port Status: S -- Selected, U -- Unselected , I -- Individual
  GE1/0/2          S       32768     1
Aggregation Interface: Bridge-Aggregation2
  GE1/0/3(R)       S       32768     2
  GE1/0/4          S       32768     2
The output shows that:
·     Both link aggregation groups 1 and 2 load share traffic.
·     Each aggregation group contains two Selected ports.
# Display all the group-specific load sharing modes on Device A.
[DeviceA]display link-aggregation load-sharing mode interface Bridge-Aggregation 1
Bridge-Aggregation1 load-sharing mode:
source-mac address
[DeviceA]display link-aggregation load-sharing mode interface Bridge-Aggregation 2
Bridge-Aggregation2 load-sharing mode:
destination-mac address
·     Link aggregation group 1 distributes packets based on source MAC addresses.
·     Link aggregation group 2 distributes packets based on destination MAC addresses.
Configuration files
IMPORTANT
IMPORTANT:
·     Device A:
vlan 10
 port access vlan 10
vlan 20
interface GigabitEthernet1/0/6
 port access vlan 10
 port access vlan 10
 port access vlan 10
 port access vlan 10
interface Bridge-Aggregation2
 port access vlan 20
 port access vlan 20
 port access vlan 20
·     Device B:
Example: Configuring Layer 2 link aggregation in an IRF fabric
On the network as shown in Figure 3, perform the following tasks:
·     Set up a two-chassis IRF fabric at the access layer and a two-chassis IRF fabric at the distribution layer of the enterprise network.
·     Configure link aggregation to improve the reliability of the links between the access-layer and distribution-layer IRF fabrics and implement load sharing.
·     Run LACP MAD on the two IRF fabrics to detect IRF split.
Figure 3 Network diagram
Hardware
Software version
S6812 switch series
S6813 switch series
S5850 switch series
Release 11xx
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S switch
Release 63xx
Release 63xx
Release 63xx
Release 11xx
Release 11xx
Release 63xx
Release 63xx
Release 11xx
Release 11xx
Release 63xx
Release 63xx
Release 11xx
Release 11xx
Release 63xx
Release 63xx
Release 63xx
Release 63xx
Release 63xx
E128C switch
E152C switch
E500C switch series
E500D switch series
Release 63xx
Release 63xx
Release 63xx
Release 63xx
Release 63xx
Release 63xx
Release 66xx
When you configure Layer 2 link aggregation in an IRF fabric, follow these restrictions and guidelines:
·     IRF physical ports must be set to the bridge mode.
·     When you bind physical ports to an IRF port, you must set all the physical ports to operate in either normal or enhanced mode.
·     The physical ports of two connected IRF ports must operate in the same mode: normal or enhanced. For more information about the binding mode of the IRF physical ports, see IRF Configuration Guide.
-     Port isolation.
-     QinQ.
-     VLAN.
-     VLAN mapping.
Procedures
1.     Configure IRF on Device A:
# Shut down GigabitEthernet 1/0/1.
[DeviceA-GigabitEthernet1/0/1] shutdown
# Bind GigabitEthernet 1/0/1 to IRF port 1/1.
[DeviceA] irf-port 1/1
[DeviceA-irf-port1/1] port group interface gigabitethernet 1/0/1
You must perform the following tasks for a successful IRF setup:
Save the configuration after completing IRF configuration.
Execute the "irf-port-configuration active" command to activate the IRF ports.
[DeviceA-irf-port1/1] quit
# Bring up GigabitEthernet1/0/1, and save the configuration.
[DeviceA-GigabitEthernet1/0/1] undo shutdown
[DeviceA] save
# Activate the IRF port configuration.
[DeviceA] irf-port-configuration active
2.     Configure IRF on Device B:
# Change the member ID of Device B to 2, and reboot the device to validate the change.
[DeviceB] irf member 1 renumber 2
Renumbering the member ID may result in configuration change or loss. Continue? [Y/N]:y
[DeviceB] quit
<DeviceB> reboot
# Shut down Gigabitethernet 2/0/1.
[DeviceB] interface gigabitethernet 2/0/1
[DeviceB-GigabitEthernet2/0/1] shutdown
[DeviceB-GigabitEthernet2/0/1] quit
# Bind GigabitEthernet 2/0/1 to IRF port 2/2.
[DeviceB] irf-port 2/2
[DeviceB-irf-port2/2] port group interface gigabitethernet 2/0/1
[DeviceB-irf-port2/2] quit
# Bring up GigabitEthernet 2/0/1, and save the configuration.
[DeviceB-GigabitEthernet2/0/1] undo shutdown
[DeviceB] save
[DeviceB] irf-port-configuration active
Device A and Device B perform master election, and the one that has lost the election reboots to form an IRF fabric with the master. In this example, Device B reboots.
# Use the display irf command to verify that Device A has become the Master device.
[DeviceA] display irf
MemberID    Role    Priority  CPU-Mac         Description
 *+1        Master   1        00a0-fc00-5801  ---
   2        Standby  1        00e0-fc58-1235  ---
 The bridge MAC of the IRF is: 00a0-fc00-5800
 Auto upgrade                : yes
 Mac persistent              : 6 min
 Domain ID                   : 0
 Auto merge                  : yes
3.     Configure a Layer 2 aggregation group on Device A:
# Create Layer 2 aggregate interface Bridge-Aggregation 1, and configure the link aggregation mode as dynamic.
# Assign ports GigabitEthernet 1/0/9, GigabitEthernet1/0/10, GigabitEthernet 2/0/9, and GigabitEthernet 2/0/10 to link aggregation group 1.
[DeviceA] interface range gigabitethernet 1/0/9 to gigabitethernet 1/0/10
gigabitethernet 2/0/9 to gigabitethernet 2/0/10
[DeviceA]
Configure LACP MAD on the IRF fabric:
# Set the domain ID of the IRF fabric to 1.
[DeviceA] irf domain 1
# Enable LACP MAD on Bridge-Aggregation 1.
[DeviceA] interface Bridge-Aggregation 1
[DeviceA-Bridge-Aggregation1] mad enable
[Current domain is: 1]:
The assigned domain ID is: 1
MAD LACP only enable on dynamic aggregation interface.
4.     Configure IRF on Device C in the same way IRF is configured on Device A. (Details not shown.)
5.     Configure IRF on Device D in the same way IRF is configured on Device B. (Details not shown.)
Device C and Device D perform master election, and the one that has lost the election reboots to form an IRF fabric with the master. In this example, Device C reboots.
6.     Configure a Layer 2 dynamic aggregation group Bridge-Aggregation 1 on Device C in the same way Bridge-Aggregation 1 is configured on Device A. (Details not shown.)
7.     Configure LACP MAD on the IRF fabric:
# Set the domain ID of the IRF fabric to 2.
<DeviceC> system-view
[DeviceC] irf domain 2
[DeviceC] interface Bridge-Aggregation 1
[DeviceC-Bridge-Aggregation1] mad enable
[Current domain is: 2]:
The assigned domain ID is: 2
# Display the information about the link aggregation groups on Device A.
System ID: 0x8000, 00a0-fc00-5800
Local:
  GE1/0/9(R)          S        32768    10       1                      {ACG}
  GE1/0/10            S        32768    11       1                      {ACG}
  GE2/0/9             S        32768    138      1                      {ACG}
  GE2/0/10            S        32768    139      1                      {ACG}
Remote:
  GE1/0/9             32768    0        0        0x8000, 0000-0000-0000 {EF}
  GE1/0/10            32768    0        0        0x8000, 0000-0000-0000 {EF}
  GE2/0/9             32768    0        0        0x8000, 0000-0000-0000 {EF}
  GE2/0/10            32768    0        0        0x8000, 0000-0000-0000 {EF}
# Shut down physical IRF port GigabitEthernet 2/0/1 on Device B.
A log message appears on Device A.
[DeviceA]%Jul  9 16:52:41:734 2016 DeviceA STM/3/STM_LINK_DOWN: IRF port 1 went down.
%Jul  9 16:52:41:800 2016 DeviceA IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/1 changed to down.
%Jul  9 16:52:41:854 2016 DeviceA IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/1 changed to down.
%Jul  9 16:52:41:867 2016 DeviceA DEV/3/BOARD_REMOVED: Board was removed from slot 2, type is Simware.
The output shows that IRF split occurs on the distribution layer because GigabitEthernet 2/0/1 that is bound to IRF port 2/2 is physically down.
Configuration files
IMPORTANT
IMPORTANT:
·     Device A:
 irf domain 1
 irf mac-address persistent timer
 irf auto-update enable
 irf auto-merge enable
 undo irf link-delay
 irf member 1 priority 1
 irf member 2 priority 1
irf-port 1/1
 port group interface GigabitEthernet1/0/1
irf-port 2/2
 port group interface GigabitEthernet2/0/1
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet2/0/9
interface GigabitEthernet2/0/10
·     Device C:
The configuration file on Device C is similar as the configuration file on Device A.
Example: Configuring Layer 3 link aggregation
On the network as shown in Figure 4, perform the following tasks:
·     Configure a Layer 3 dynamic aggregation group on both Device A and Device B.
·     Configure IP addresses and subnet masks for the corresponding Layer 3 aggregate interfaces.
Figure 4 Network diagram
Hardware
Software version
S6812 switch series
S6813 switch series
S5850 switch series
Release 11xx
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S
MS4520V2-24TP
Release 63xx
Release 63xx
Release 63xx
Release 11xx
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Release 11xx
Release 11xx
Not supported
Not supported
Not supported
Not supported
Not supported
E128C switch
E152C switch
E500C switch series
E500D switch series
Not supported
Not supported
Release 63xx
Not supported
Not supported
Not supported
Release 66xx
Not supported
If you use the S5570S-EI, S5500V3-SI, S3600V3-EI, or S3600V3-SI switch series, reserve local VLAN interface resources by using the reserve-vlan-interface command before you switch Layer 2 Ethernet interfaces to Layer 3 Ethernet interfaces or create Layer 3 aggregate interfaces. For more information about VLAN interface resource reservation, see the VLAN configuration and commands for the products.
Procedures
# Create Layer 3 aggregate interface Route-Aggregation 1. Use one of the following methods as needed.
¡     Use the static aggregation mode to create Layer 3 aggregate interface Route-Aggregation 1.
[DeviceA] interface route-aggregation 1
¡     Use the dynamic aggregation mode to create Layer 3 aggregate interface Route-Aggregation 1.
[DeviceA-Route-Aggregation1] link-aggregation mode dynamic
# Configure an IP address and subnet mask for Layer 3 aggregate interface Route-Aggregation 1.
[DeviceA-Route-Aggregation1] ip address 192.168.1.1 24
[DeviceA-Route-Aggregation1] undo shutdown
[DeviceA-Route-Aggregation1] quit
[DeviceA-if-range] port link-mode route
[DeviceA-if-range] undo shutdown
  GE1/0/1          S       32768    1
  GE1/0/2          S       32768    1
  GE1/0/3          S       32768    1
The output shows that all member ports in the local aggregation group are in Selected state. The Selected states of the local member ports are not affected by the Selected states of the peer member ports.
Local:
  GE1/0/1(R)          S        32768    2        1                      {ACDEF}
Remote:
  GE1/0/1             32768    2        1        0x8000, 68fa-34f2-0200 {ACDEF}
  GE1/0/2             32768    3        1        0x8000, 68fa-34f2-0200 {ACDEF}
  GE1/0/3             32768    4        1        0x8000, 68fa-34f2-0200 {ACDEF}
Configuration files
IMPORTANT
IMPORTANT:
·     Device A:
interface route-aggregation1
 Device B:
The configuration file on Device B is similar as the configuration file on Device A.
Example: Configuring Layer 3 aggregation load sharing
As shown in Figure 5, configure link aggregation on Device A and Device B to meet the following requirements:
·     Configure Layer 3 static aggregation groups 1 and 2 on both Device A and Device B.
·     Assign IP addresses and subnet masks to the Layer 3 aggregate interfaces of the aggregation groups.
¡     Configure link aggregation group 1 to load share packets based on source IP addresses.
¡     Configure link aggregation group 2 to load share packets based on destination IP addresses.
Figure 5 Network diagram
Hardware
Software version
S6812 switch series
S6813 switch series
Not supported
S5850 switch series
Not supported
Not supported
Not supported
Not supported
MS4520V2-30F switch
Not supported
MS4520V2-30C switch
MS4520V2-54C switch
Not supported
MS4520V2-28S switch
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
E128C switch
E152C switch
E500C switch series
E500D switch series
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
You can set the global or group-specific load sharing mode. A link aggregation group preferentially uses the group-specific load sharing mode. If the group-specific load sharing mode is not available, the group uses the global load sharing mode. This example uses group-specific load sharing mode configuration.
Procedures
# Configure Layer 3 aggregation group 1 to load share packets based on source IP addresses.
[DeviceA-Route-Aggregation1] link-aggregation load-sharing mode source-ip
# Create Layer 3 aggregate interface Route-Aggregation 2.
[DeviceA] interface route-aggregation 2
# Configure Layer 3 aggregation group 2 to load share packets based on destination IP addresses.
[DeviceA-Route-Aggregation2] link-aggregation load-sharing mode destination-ip
# Configure an IP address and subnet mask for Layer 3 aggregate interface Route-Aggregation 2.
[DeviceA-Route-Aggregation2] ip address 192.168.2.1 24
[DeviceA-Route-Aggregation2] quit
# Assign Layer 3 Ethernet interfaces GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to aggregation group 1.
[DeviceA] interface range gigabitethernet 1/0/1 gigabitethernet 1/0/2
# Assign Layer 3 Ethernet interfaces GigabitEthernet 1/0/3 and GigabitEthernet 1/0/4 to aggregation group 2.
[DeviceA] interface range gigabitethernet 1/0/3 gigabitethernet 1/0/4
[DeviceA-if-range] port link-aggregation group 2
  GE1/0/2          S       32768    1
Aggregate Interface: Route-Aggregation2
  GE1/0/4          S       32768    2
[DeviceA] display link-aggregation load-sharing mode interface
Route-Aggregation1 load-sharing mode:
source-ip address
Route-Aggregation2 load-sharing mode:
destination-ip address
·     Link aggregation group 1 distributes packets based on source IP addresses.
·     Link aggregation group 2 distributes packets based on destination IP addresses.
Configuration files
IMPORTANT
IMPORTANT:
·     Device A:
interface Route-Aggregation1
interface Route-Aggregation2
 ip address 192.168.2.1 255.255.255.0
·     Device B:
The configuration file on Device B is similar to the configuration file on Device A.
不同款型规格的资料略有差异, 详细信息请向具体销售和400咨询。 H3C保留在没有任何通知或提示的情况下对资料内容进行修改的权利!
