- H3C Fixed Port Campus Switches Configuration Examples-6W105
- 00-Applicable hardware and software versions
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-DHCP Snooping Configuration Examples
- 12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 13-IPv6 over IPv4 Tunneling with OSPFv3 Configuration Examples
- 14-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 15-GRE with OSPF Configuration Examples
- 16-OSPF Configuration Examples
- 17-IS-IS Configuration Examples
- 18-BGP Configuration Examples
- 19-Policy-Based Routing Configuration Examples
- 20-OSPFv3 Configuration Examples
- 21-IPv6 IS-IS Configuration Examples
- 22-Routing Policy Configuration Examples
- 23-IGMP Snooping Configuration Examples
- 24-IGMP Configuration Examples
- 25-MLD Snooping Configuration Examples
- 26-IPv6 Multicast VLAN Configuration Examples
- 27-ACL Configuration Examples
- 28-Traffic Policing Configuration Examples
- 29-GTS and Rate Limiting Configuration Examples
- 30-Traffic Filtering Configuration Examples
- 31-AAA Configuration Examples
- 32-Port Security Configuration Examples
- 33-Portal Configuration Examples
- 34-SSH Configuration Examples
- 35-IP Source Guard Configuration Examples
- 36-Ethernet OAM Configuration Examples
- 37-CFD Configuration Examples
- 38-DLDP Configuration Examples
- 39-VRRP Configuration Examples
- 40-BFD Configuration Examples
- 41-NTP Configuration Examples
- 42-SNMP Configuration Examples
- 43-NQA Configuration Examples
- 44-Mirroring Configuration Examples
- 45-sFlow Configuration Examples
- 46-OpenFlow Configuration Examples
- 47-MAC Address Table Configuration Examples
- 48-Static Multicast MAC Address Entry Configuration Examples
- 49-IP Unnumbered Configuration Examples
- 50-MVRP Configuration Examples
- 51-MCE Configuration Examples
- 52-Attack Protection Configuration Examples
- 53-Smart Link Configuration Examples
- 54-RRPP Configuration Examples
- 55-BGP Route Selection Configuration Examples
- 56-IS-IS Route Summarization Configuration Examples
- 57-VXLAN Configuration Examples
- 58-DRNI Configuration Examples
- 59-IRF 3.1 Configuration Examples
- 60-PTP Configuration Examples
- 61-S-MLAG Configuration Examples
- 62-Puppet Configuration Examples
- 63-802.1X Configuration Examples
- 64-MAC Authentication Configuration Examples
- 65-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 66-BIDIR-PIM Configuration Examples
- 67-Congestion Avoidance and Queue Scheduling Configuration Examples
- 68-Basic MPLS Configuration Examples
- 69-MPLS L3VPN Configuration Examples
- 70-MPLS OAM Configuration Examples
- 71-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 72-DRNI and EVPN Configuration Examples
- 73-Multicast VPN Configuration Examples
- 74-MPLS TE Configuration Examples
- 75-Control Plane-Based QoS Policy Configuration Examples
- 76-Priority Mapping and Queue Scheduling Configuration Examples
- 77-ARP Attack Protection Configuration Examples
- 78-IRF Software Upgrade Configuration Examples
- 79-IRF Member Replacement Configuration Examples
- 80-Layer 3 Multicast on Multicast Source-Side DR System Configuration Examples
- 81-EVPN Multicast Configuration Examples
- 82-Priority Marking and Queue Scheduling Configuration Examples
- 83-EAA Configuration Examples
- 84-GRE Tunnel Access to MPLS L3VPN Configuration Examples
- 85-MC-NAT Configuration Examples
- 86-M-LAG Configuration Examples (Applicable to M-LAG Versions)
- 87-MOD Configuration Examples
- 88-MPLS L2VPN Configuration Examples
- 89-VPLS Configuration Examples
- 90-SR-MPLS Configuration Examples
- 91-VCF Fabric Configuration Examples
- 92-NetStream Configuration Examples
- 93-Configuration Example for Software Upgrade with Zero Packet Loss by Using GIR in VXLAN M-LAG Network
- 94-Configuration Example for Software Upgrade with Zero Packet Loss by Using GIR in VXLAN DRNI Network
General restrictions and guidelines
Example: Configuring OpenFlow to deploy flow entries
Introduction
This document provides examples for configuring OpenFlow.
OpenFlow separates the control plane and the data forwarding plane. An OpenFlow switch matches packets against one or more flow tables. A flow table contains one or more flow entries that are deployed by the controller and packets are matched based on the matching precedence of flow entries.
These examples use VLAN-interface 1.
This document assumes that you have basic knowledge of OpenFlow.
When you configure OpenFlow, follow these restrictions and guidelines:
· Enable LLDP globally on OpenFlow switches so that the controller can learn the OpenFlow topology through LLDP.
· Configure each OpenFlow switch with an interface for communicating with the controller so that OpenFlow instances can establish connections with the controller.
· Configure the Loosen mode when you associate VLAN 4092 and VLAN 4094 with an OpenFlow instance so that the access ports of switches can belong to the OpenFlow instance.
As shown in Figure 1, configure OpenFlow to meet the following requirements:
· The controller can deploy dynamic flow entries.
· Host A and Host C can communicate with each other based on the flow entries deployed by the controller.
· Host B and Host D can communicate with each other based on the flow entries deployed by the controller.
Hardware |
Software version |
S6812 switch series S6813 switch series |
Release 6615Pxx, Release 6628Pxx |
S6550XE-HI switch series |
Release 6008 and later, Release 8106Pxx |
S6525XE-HI switch series |
S5850 switch series |
Release 8005 and later, Release 8106Pxx |
S5570S-EI switch series |
Not supported |
S5560X-EI switch series |
Release 63xx, Release 65xx, Release 6615Pxx, Release 6628Pxx |
S5560X-HI switch series |
S5500V2-EI switch series |
MS4520V2-30F switch |
MS4520V2-30C switch MS4520V2-54C switch |
MS4520V2-28S switch MS4520V2-24TP switch |
Release 63xx |
S6520X-HI switch series S6520X-EI switch series |
S6520X-SI switch series S6520-SI switch series |
S5000-EI switch series |
MS4600 switch series |
ES5500 switch series |
S5560S-EI switch series S5560S-SI switch series |
Release 63xx |
S5500V3-24P-SI switch S5500V3-48P-SI switch |
Release 63xx |
S5500V3-SI switch series (except S5500V3-24P-SI and S5500V3-48P-SI) |
Not supported |
S5170-EI switch series |
Not supported |
S5130S-HI switch series S5130S-EI switch series S5130S-SI switch series S5130S-LI switch series |
Release 63xx |
S5120V2-SI switch series S5120V2-LI switch series |
Release 63xx |
S5120V3-EI switch series |
Not supported |
S5120V3-36F-SI switch S5120V3-28P-HPWR-SI switch S5120V3-54P-PWR-SI switch |
Not supported |
S5120V3-SI switch series (except S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI) |
Release 63xx |
S5120V3-LI switch series |
Release 63xx |
S3600V3-EI switch series |
Not supported |
S3100V3-EI switch series S3100V3-SI switch series |
Release 63xx |
S5110V2 switch series |
Release 63xx |
S5110V2-SI switch series |
Release 63xx |
S5000V3-EI switch series S5000V5-EI switch series |
Release 63xx |
S5000E-X switch series S5000X-EI switch series |
Release 63xx |
E128C switch E152C switch E500C switch series E500D switch series |
Release 63xx |
MS4320V2 switch series MS4320V3 switch series MS4300V2 switch series MS4320 switch series MS4200 switch series |
Release 63xx |
WS5850-WiNet switch series |
Release 63xx |
WS5820-WiNet switch series WS5810-WiNet switch series |
Release 63xx |
WAS6000 switch series |
Release 63xx |
IE4300-12P-AC switch IE4300-12P-PWR switch IE4300-M switch series IE4320 switch series |
Release 63xx |
IE4520 switch series |
Release 66xx |
S5135S-EI switch series |
Release 6658P01 and later |
Procedures
Configuring Switch A
# Create VLAN 4092 and VLAN 4094.
[SwitchA] vlan 4092
[SwitchA-vlan4092] quit
[SwitchA] vlan 4094
[SwitchA-vlan4094] quit
# Configure GigabitEthernet 1/0/1, GigabitEthernet 1/0/2, and GigabitEthernet 1/0/3.
[SwitchA-GigabitEthernet1/0/1] port access vlan 4092
[SwitchA-GigabitEthernet1/0/1] quit
[SwitchA] interface gigabitethernet 1/0/2
[SwitchA-GigabitEthernet1/0/2] port access vlan 4094
[SwitchA-GigabitEthernet1/0/2] quit
[SwitchA] interface gigabitethernet 1/0/3
[SwitchA-GigabitEthernet1/0/3] port link-type trunk
[SwitchA-GigabitEthernet1/0/3] port trunk permit vlan 4092 4094
[SwitchA-GigabitEthernet1/0/3] quit
# Enable LLDP globally.
[SwitchA] lldp global enable
# Configure VLAN-interface 1 on Switch A for communicating with the controller.
[SwitchA] interface Vlan-interface 1
[SwitchA-Vlan-interface1] ip address 192.168.2.125 255.255.255.0
# Create OpenFlow instance 1. Associate VLAN 4092 and VLAN 4094 with it in loosen mode.
[SwitchA] openflow instance 1
[SwitchA-of-inst-1] classification vlan 4092 mask 4093 loosen
# Specify 192.168.2.225 as the IP address of controller 0 for OpenFlow instance 1 and activate the instance..
[SwitchA-of-inst-1] controller 0 address ip 192.168.2.225
[SwitchA-of-inst-1] active instance
[SwitchA-of-inst-1] quit
Configuring Switch B
[SwitchB] vlan 4092
[SwitchB-vlan4092] quit
[SwitchB] vlan 4094
[SwitchB-vlan4094] quit
[SwitchB-GigabitEthernet1/0/1] port access vlan 4092
[SwitchB] interface gigabitethernet 1/0/2
[SwitchB-GigabitEthernet1/0/2] port access vlan 4094
[SwitchB] interface gigabitethernet 1/0/3
[SwitchB-GigabitEthernet1/0/3] port link-type trunk
[SwitchB-GigabitEthernet1/0/3] port trunk permit vlan 4092 4094
[SwitchB-GigabitEthernet1/0/3] quit
[SwitchB] lldp global enable
# Configure VLAN-interface 1 on Switch B for communicating with the controller.
[SwitchB] interface Vlan-interface 1
[SwitchB-Vlan-interface1] ip address 192.168.2.125 255.255.255.0
[SwitchB-Vlan-interface1] quit
[SwitchB] openflow instance 1
[SwitchB-of-inst-1] classification vlan 4092 mask 4093 loosen
[SwitchB-of-inst-1] controller 0 address ip 192.168.2.225
[SwitchB-of-inst-1] active instance
[SwitchB-of-inst-1] quit
# Display details for OpenFlow instance 1 on devices, for example, Switch A.
[SwitchA] display openflow instance 1
Instance 1 information:
Configuration information:
Description : --
Active status : Active
Inactive configuration:
None
Active configuration:
Classification VLAN, loosen mode, total VLANs(2)
4092, 4094
In-band management VLAN, total VLANs(0)
Empty VLAN
Connect mode: Multiple
MAC address learning: Enabled
Flow table:
Table ID(type): 0(Extensibility), count: 1
Flow-entry max-limit: 65535
Datapath ID: 0x000174258a024c00
Port information:
Active channel information:
Controller 0 IP address: 192.168.2.225 port: 6633
The output shows that GigabitEthernet 1/0/1, GigabitEthernet 1/0/2, and GigabitEthernet 1/0/3 belong to OpenFlow instance 1 and can be used to forward packets in the OpenFlow forwarding process.
# Display controller information for OpenFlow instance 1 on devices, for example, Switch A.
[SwitchA] display openflow instance 1 controller
Instance 1 controller information:
Reconnect interval: 60 (s)
Echo interval : 5 (s)
Controller ID : 0
Controller IP address : 192.168.2.225
Controller port : 6633
Controller role : Equal
Connect type : TCP
Connect state : Established
Packets sent : 132
Packets received : 434
SSL policy : --
VRF name : --
The output shows that Switch A has established a connection with the controller.
# Display flow table information for OpenFlow instance 1 on devices, for example, Switch A.
[SwitchA] display openflow instance 1 flow-table
Instance 1 flow table information:
Table 0 information:
Table type: Extensibility, flow entry count: 1, total flow entry count: 1
MissRule flow entry information:
cookie: 0x0, priority: 0, hard time: 0, idle time: 0, flags: flow_send_rem,
byte count: 0, packet count: 0
Match information: any
Instruction information:
Write actions:
Output interface: Controller, send length: 65509 bytes
The output shows that Switch A has only one table-miss flow entry with the priority of 0 and the action of outputting packets to the controller. The action in the table-miss flow entry varies by device model. For more information about the action in the table-miss flow entry, see the related documentation of the controller.
# Ping Host C from Host A.
Ping 10.1.1.2 (10.1.1.2): 56 data bytes, press CTRL_C to break
56 bytes from 10.1.1.2: icmp_seq=0 ttl=255 time=4.582 ms
56 bytes from 10.1.1.2: icmp_seq=1 ttl=255 time=1.299 ms
56 bytes from 10.1.1.2: icmp_seq=2 ttl=255 time=1.389 ms
56 bytes from 10.1.1.2: icmp_seq=3 ttl=255 time=6.688 ms
56 bytes from 10.1.1.2: icmp_seq=4 ttl=255 time=1.294 ms
--- Ping statistics for 10.1.1.2 ---
round-trip min/avg/max/std-dev = 1.294/3.050/6.688/2.213 ms
The output shows that Host A and Host C can reach each other.
# Display flow table information for OpenFlow instance 1 again on devices, for example, Switch A.
Table type: Extensibility, flow entry count: 4, total flow entry count: 4
Write actions:
Flow entry 1 information:
cookie: 0x2328, priority: 29999, hard time: 0, idle time: 300, flags:
flow_send_rem, byte count: 1, packet count: 1
Match information:
Input interface: GE1/0/3
Ethernet destination MAC address: 0cda-41b1-d1c5
Ethernet destination MAC address mask: ffff-ffff-ffff
Ethernet source MAC address: 7425-8a0f-8034
Ethernet source MAC address mask: ffff-ffff-ffff
Ethernet type: 0x0806
Write actions:
Output interface: GE1/0/1
Flow entry 2 information:
flow_send_rem, byte count: 1, packet count: 4
Match information:
Input interface: GE1/0/1
Ethernet destination MAC address: 7425-8a0f-8034
Ethernet source MAC address: 0cda-41b1-d1c5
Ethernet type: 0x0800
Write actions:
Output interface: GE1/0/3
Flow entry 3 information:
Match information:
Write actions:
· The ARP request/reply packets and ICMP request/replay packets between Host A and Host C successfully trigger the controller to deploy flow entries.
· Switch A forwards packets based on the flow entries that are deployed by the controller.
# Ping Host D from Host B.
Ping 20.1.1.2 (20.1.1.2): 56 data bytes, press CTRL_C to break
56 bytes from 20.1.1.2: icmp_seq=0 ttl=255 time=1.620 ms
56 bytes from 20.1.1.2: icmp_seq=1 ttl=255 time=6.625 ms
56 bytes from 20.1.1.2: icmp_seq=2 ttl=255 time=1.454 ms
56 bytes from 20.1.1.2: icmp_seq=3 ttl=255 time=1.134 ms
56 bytes from 20.1.1.2: icmp_seq=4 ttl=255 time=1.260 ms
--- Ping statistics for 20.1.1.2 ---
round-trip min/avg/max/std-dev = 1.134/2.419/6.625/2.110 ms
The output shows that Host B and Host D can reach each other.
Table type: Extensibility, flow entry count: 7, total flow entry count: 7
Write actions:
Match information:
Write actions:
Match information:
Write actions:
Match information:
Write actions:
Flow entry 4 information:
Match information:
Ethernet destination MAC address: 0cda-41b1-d1c4
Ethernet source MAC address: 7425-8a0f-8035
Write actions:
Output interface: GE1/0/2
Flow entry 5 information:
Match information:
Input interface: GE1/0/2
Ethernet destination MAC address: 7425-8a0f-8035
Ethernet source MAC address: 0cda-41b1-d1c4
Write actions:
Flow entry 6 information:
Match information:
Write actions:
· The ARP request/reply packets and ICMP request/replay packets between Host B and Host D successfully trigger the controller to deploy flow entries.
Configuration files
IMPORTANT: Support for the port link-mode bridge command depends on the device model. |
· Switch A:
lldp global enable
vlan 4092
vlan 4094
openflow instance 1
active instance
interface Vlan-interface1
port trunk permit vlan 1 4092 4094
· Switch B:
lldp global enable
vlan 4092
vlan 4094
openflow instance 1
active instance
ip address 192.168.2.126 255.255.255.0
