H3C Fixed Port Campus Switches Configuration Examples-6W105
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-6W105
Table of Contents
Related Documents
71-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
Introduction
This document provides examples for configuring EVPN-DCI over an MPLS L3VPN network.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of MPLS L3VPN and EVPN.
General restrictions and guidelines
Before you configure EVPN on a device, you must perform the following tasks:
1.     Set the system operating mode to VXLAN mode by using the switch-mode command in system view.
2.     Save the running configuration.
3.     Reboot the device.
Example: Configuring IPv4 EVPN-DCI over an MPLS L3VPN network
As shown in Figure 1:
·     Data center 1 and data center 2 are interconnected through an MPLS L3VPN network. The two data centers can communicate with each other through the MPLS L3VPN network.
·     Switch A and Switch D are distributed EVPN gateways in the data centers.
·     Switch B and Switch C act as both EVPN EDs and MPLS L3VPN PEs.
Figure 1 Network diagram
Analysis
For the switches within a data center to reach each other, configure a routing protocol on the switches to advertise routes for interfaces (including the loopback interfaces). In this example, OSPF is used.
To enable communication between the data centers, you must perform the following tasks on Switch B and Switch C:
·     Configure both MPLS L3VPN and EVPN.
·     Configure the BGP EVPN address family and the BGP VPNv4 address family to exchange routes.
Hardware
Software version
S6812 switch series
S6813 switch series
Release 6615Pxx, Release 6628Pxx
S6550XE-HI switch series
Not supported
S6525XE-HI switch series
Not supported
S5850 switch series
Not supported
S5570S-EI switch series
Not supported
S5560X-EI switch series
Release 65xx, Release 6615Pxx, Release 6628Pxx
S5560X-HI switch series
S5500V2-EI switch series
MS4520V2-30F switch
Release 65xx, Release 6628Pxx
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S switch
MS4520V2-24TP switch
Release 63xx
S6520X-HI switch series
S6520X-EI switch series
S6520X-SI switch series
S6520-SI switch series
S5000-EI switch series
MS4600 switch series
ES5500 switch series
S5560S-EI switch series
S5560S-SI switch series
Not supported
S5500V3-24P-SI switch
S5500V3-48P-SI switch
Not supported
S5500V3-SI switch series (except S5500V3-24P-SI and S5500V3-48P-SI)
Not supported
S5170-EI switch series
Not supported
S5130S-HI switch series
S5130S-EI switch series
S5130S-SI switch series
S5130S-LI switch series
Not supported
S5120V2-SI switch series
S5120V2-LI switch series
Not supported
S5120V3-EI switch series
Not supported
S5120V3-36F-SI switch
S5120V3-28P-HPWR-SI switch
S5120V3-54P-PWR-SI switch
Not supported
S5120V3-SI switch series (except S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI)
Not supported
S5120V3-LI switch series
Not supported
S3600V3-EI switch series
Not supported
S3600V3-SI switch series
Not supported
S3100V3-EI switch series
S3100V3-SI switch series
Not supported
S5110V2 switch series
Not supported
S5110V2-SI switch series
Not supported
S5000V3-EI switch series
S5000V5-EI switch series
Not supported
S5000E-X switch series
S5000X-EI switch series
Not supported
E128C switch
E152C switch
E500C switch series
E500D switch series
Not supported
MS4320V2 switch series
MS4320V3 switch series
MS4300V2 switch series
MS4320 switch series
MS4200 switch series
Not supported
WS5850-WiNet switch series
Not supported
WS5820-WiNet switch series
WS5810-WiNet switch series
Not supported
WAS6000 switch series
Not supported
IE4300-12P-AC switch
IE4300-12P-PWR switch
IE4300-M switch series
IE4320 switch series
Not supported
IE4520 switch series
Release 66xx
S5135S-EI switch
Not supported
As a best practice to ensure correct traffic forwarding, configure the same MAC address for all VSI interfaces on an EVPN gateway.
When you configure L3 VXLAN IDs for VSI interfaces, make sure the same route targets are configured for the VPN instances associated with these VSI interfaces.
Procedures
Configuring the system operating mode
# Set the system operating mode to VXLAN on Switch A, and reboot the switch for the mode change to take effect.
[SwitchA] switch-mode 1
[SwitchA] quit
<SwitchA> reboot
# Set the system operating mode of Switch B, Switch C, and Switch D to VXLAN. The method is the same as Switch A. (Details not shown.)
Configuring IP addresses for interfaces
# Configure IP addresses for interfaces on Switch A.
[SwitchA] vlan 11
[SwitchA-vlan11] quit
[SwitchA] interface gigabitethernet 1/0/2
[SwitchA-GigabitEthernet1/0/2] port link-type trunk
[SwitchA-GigabitEthernet1/0/2] port trunk permit vlan 11
[SwitchA-GigabitEthernet1/0/2] undo shutdown
[SwitchA-GigabitEthernet1/0/2] quit
[SwitchA-Vlan-interface11] ip address 11.1.1.1 24
[SwitchA-Vlan-interface11] undo shutdown
[SwitchA-LoopBack0] ip address 1.1.1.1 32
[SwitchA-LoopBack0] undo shutdown
[SwitchA-LoopBack0] quit
# Configure IP addresses for interfaces on Switch B, Switch C, and Switch D. The method is the same as Switch A. (Details not shown.)
Configuring OSPF on the switches
# On Switch A, specify interfaces attached to the specified network to run OSPF.
[SwitchA] ospf 1
[SwitchA-ospf-1] area 0
[SwitchA-ospf-1-area-0.0.0.0] network 1.1.1.1 0.0.0.0
[SwitchA-ospf-1-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[SwitchA-ospf-1] quit
# On Switch B, specify interfaces attached to the specified network to run OSPF.
[SwitchB] ospf 1
[SwitchB-ospf-1] area 0
[SwitchB-ospf-1-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[SwitchB-ospf-1] quit
# On Switch C, specify interfaces attached to the specified network to run OSPF.
[SwitchC] ospf 1
[SwitchC-ospf-1] import-route bgp
[SwitchC-ospf-1] area 0
[SwitchC-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[SwitchC-ospf-1] quit
# On Switch D, specify interfaces attached to the specified network to run OSPF.
<SwitchD> system-view
[SwitchD] ospf 1
[SwitchD-ospf-1] area 0
[SwitchD-ospf-1-area-0.0.0.0] network 4.4.4.4 0.0.0.0
[SwitchD-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[SwitchD-ospf-1] quit
Creating the VXLANs and EVPN instances
Configuring Switch A
# Enable L2VPN.
[SwitchA] l2vpn enable
# Create VSI vpn1 and VXLAN 10.
[SwitchA] vsi vpn1
[SwitchA-vsi-vpn1] vxlan 10
[SwitchA-vsi-vpn1-vxlan-10] quit
# Create an EVPN instance on VSI vpn1. Configure the switch to automatically generate an RD and a route target for the EVPN instance.
[SwitchA-vsi-vpn1] evpn encapsulation vxlan
[SwitchA-vsi-vpn1-evpn-vxlan] route-distinguisher auto
[SwitchA-vsi-vpn1-evpn-vxlan] vpn-target auto
[SwitchA-vsi-vpn1-evpn-vxlan] quit
[SwitchA-vsi-vpn1] quit
Configuring Switch D
# Enable L2VPN.
[SwitchD] l2vpn enable
# Create VSI vpn1 and VXLAN 20.
[SwitchD] vsi vpn1
[SwitchD-vsi-vpn1] vxlan 20
[SwitchD-vsi-vpn1-vxlan-20] quit
[SwitchD-vsi-vpn1] evpn encapsulation vxlan
[SwitchD-vsi-vpn1-evpn-vxlan] route-distinguisher auto
[SwitchD-vsi-vpn1-evpn-vxlan] vpn-target auto
[SwitchD-vsi-vpn1-evpn-vxlan] quit
[SwitchD-vsi-vpn1] quit
Configuring L3 VXLAN IDs and VSI interfaces
# Configure RD and route target settings for VPN instance vpna.
[SwitchA] ip vpn-instance vpna
[SwitchA-vpn-instance-vpna] route-distinguisher 1:1
[SwitchA-vpn-instance-vpna] address-family ipv4
[SwitchA-vpn-ipv4-vpna] vpn-target 2:2
[SwitchA-vpn-ipv4-vpna] quit
[SwitchA-vpn-instance-vpna] address-family evpn
[SwitchA-vpn-evpn-vpna] vpn-target 1:1
[SwitchA-vpn-evpn-vpna] quit
[SwitchA-vpn-instance-vpna] quit
# Enable Layer 3 forwarding for VXLANs.
[SwitchA] vxlan ip-forwarding
# Configure VSI-interface 1 as a distributed gateway.
[SwitchA] interface vsi-interface 1
[SwitchA-Vsi-interface1] ip binding vpn-instance vpna
[SwitchA-Vsi-interface1] ip address 10.1.1.1 24
[SwitchA-Vsi-interface1] mac-address 1-1-1
[SwitchA-Vsi-interface1] distributed-gateway local
[SwitchA-Vsi-interface1] local-proxy-arp enable
[SwitchA-Vsi-interface1] quit
# Create VSI-interface 2. Associate VSI-interface 2 with VPN instance vpna, and configure the L3 VXLAN ID as 1000 for the VPN instance.
[SwitchA] interface vsi-interface 2
[SwitchA-Vsi-interface2] ip binding vpn-instance vpna
[SwitchA-Vsi-interface2] l3-vni 1000
[SwitchA-Vsi-interface2] quit
# Specify VSI-interface 1 as the gateway interface for VSI vpn1.
[SwitchA] vsi vpn1
[SwitchA-vsi-vpn1] gateway vsi-interface 1
Configuring Switch B
# Enable L2VPN.
[SwitchB] l2vpn enable
[SwitchB] ip vpn-instance vpna
[SwitchB-vpn-instance-vpna] route-distinguisher 1:2
[SwitchB-vpn-instance-vpna] address-family ipv4
[SwitchB-vpn-ipv4-vpna] vpn-target 2:2
[SwitchB-vpn-ipv4-vpna] quit
[SwitchB-vpn-instance-vpna] address-family evpn
[SwitchB-vpn-evpn-vpna] vpn-target 1:1
[SwitchB-vpn-evpn-vpna] quit
[SwitchB-vpn-instance-vpna] quit
[SwitchB] vxlan ip-forwarding
# Create VSI-interface 1. Associate VSI-interface 1 with VPN instance vpna, and configure the L3 VXLAN ID as 1000 for the VPN instance.
[SwitchB] interface vsi-interface 1
[SwitchB-Vsi-interface1] ip binding vpn-instance vpna
[SwitchB-Vsi-interface1] l3-vni 1000
[SwitchB-Vsi-interface1] quit
Configuring Switch C
# Enable L2VPN.
[SwitchC] l2vpn enable
[SwitchC] ip vpn-instance vpna
[SwitchC-vpn-instance-vpna] route-distinguisher 1:3
[SwitchC-vpn-instance-vpna] address-family ipv4
[SwitchC-vpn-ipv4-vpna] vpn-target 2:2
[SwitchC-vpn-ipv4-vpna] quit
[SwitchC-vpn-instance-vpna] address-family evpn
[SwitchC-vpn-evpn-vpna] vpn-target 1:1
[SwitchC-vpn-evpn-vpna] quit
[SwitchC-vpn-instance-vpna] quit
[SwitchC] vxlan ip-forwarding
[SwitchC] interface vsi-interface 1
[SwitchC-Vsi-interface1] ip binding vpn-instance vpna
[SwitchC-Vsi-interface1] l3-vni 1000
[SwitchC-Vsi-interface1] quit
[SwitchD] ip vpn-instance vpna
[SwitchD-vpn-instance-vpna] route-distinguisher 1:4
[SwitchD-vpn-instance-vpna] address-family ipv4
[SwitchD-vpn-ipv4-vpna] vpn-target 2:2
[SwitchD-vpn-ipv4-vpna] quit
[SwitchD-vpn-instance-vpna] address-family evpn
[SwitchD-vpn-evpn-vpna] vpn-target 1:1
[SwitchD-vpn-evpn-vpna] quit
[SwitchD-vpn-instance-vpna] quit
[SwitchD] vxlan ip-forwarding
[SwitchD] interface vsi-interface 1
[SwitchD-Vsi-interface1] ip binding vpn-instance vpna
[SwitchD-Vsi-interface1] ip address 10.1.2.1 24
[SwitchD-Vsi-interface1] mac-address 1-2-1
[SwitchD-Vsi-interface1] distributed-gateway local
[SwitchD-Vsi-interface1] local-proxy-arp enable
[SwitchD-Vsi-interface1] quit
[SwitchD] interface vsi-interface 2
[SwitchD-Vsi-interface2] ip binding vpn-instance vpna
[SwitchD-Vsi-interface2] l3-vni 1000
[SwitchD-Vsi-interface2] quit
[SwitchD] vsi vpn1
[SwitchD-vsi-vpn1] gateway vsi-interface 1
Disabling remote MAC address learning and remote ARP learning
# On Switch A, disable remote MAC address learning and remote ARP learning.
[SwitchA] vxlan tunnel mac-learning disable
[SwitchA] vxlan tunnel arp-learning disable
# Disable remote MAC address learning and remote ARP learning on Switch B, Switch C, and Switch D. The method is the same as Switch A. (Details not shown.)
Mapping Ethernet service instances to VSIs
# On Switch A, create Ethernet service instance 1000 on GigabitEthernet 1/0/1 to match VLAN 100 and map the Ethernet service instance to VSI vpn1.
[SwitchA-GigabitEthernet1/0/1] service-instance 1000
[SwitchA-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 100
[SwitchA-GigabitEthernet1/0/1-srv1000] xconnect vsi vpn1
[SwitchA-GigabitEthernet1/0/1-srv1000] quit
[SwitchA-GigabitEthernet1/0/1] quit
# On Switch D, create Ethernet service instance 1000 on GigabitEthernet 1/0/1 to match VLAN 100 and map the Ethernet service instance to VSI vpn1.
[SwitchD] interface gigabitethernet 1/0/1
[SwitchD-GigabitEthernet1/0/1] service-instance 1000
[SwitchD-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 100
[SwitchD-GigabitEthernet1/0/1-srv1000] xconnect vsi vpn1
[SwitchD-GigabitEthernet1/0/1-srv1000] quit
[SwitchD-GigabitEthernet1/0/1] quit
Establishing BGP EVPN peer relationship within a data center
Data center 1
# Configure Switch A to advertise BGP EVPN routes.
[SwitchA] bgp 100
[SwitchA-bgp-default] peer 2.2.2.2 as-number 100
[SwitchA-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[SwitchA-bgp-default] address-family l2vpn evpn
[SwitchA-bgp-default-evpn] peer 2.2.2.2 enable
[SwitchA-bgp-default-evpn] quit
[SwitchA-bgp-default] quit
# Configure Switch B to advertise BGP EVPN routes.
[SwitchB] bgp 100
[SwitchB-bgp-default] peer 1.1.1.1 as-number 100
[SwitchB-bgp-default] peer 1.1.1.1 connect-interface loopback 0
[SwitchB-bgp-default] address-family l2vpn evpn
[SwitchB-bgp-default-evpn] peer 1.1.1.1 enable
[SwitchB-bgp-default-evpn] quit
[SwitchB-bgp-default] quit
Data center 2
# Configure Switch C to advertise BGP EVPN routes.
[SwitchC] bgp 200
[SwitchC-bgp-default] peer 4.4.4.4 as-number 200
[SwitchC-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[SwitchC-bgp-default] address-family l2vpn evpn
[SwitchC-bgp-default-evpn] peer 4.4.4.4 enable
[SwitchC-bgp-default-evpn] quit
[SwitchC-bgp-default] quit
# Configure Switch D to advertise BGP EVPN routes.
[SwitchD] bgp 200
[SwitchD-bgp-default] peer 3.3.3.3 as-number 200
[SwitchD-bgp-default] peer 3.3.3.3 connect-interface loopback 0
[SwitchD-bgp-default] address-family l2vpn evpn
[SwitchD-bgp-default-evpn] peer 3.3.3.3 enable
[SwitchD-bgp-default-evpn] quit
[SwitchD-bgp-default] quit
Establishing MPLS L3VPN connections between ASs
# Configure the LSR ID as 2.2.2.2 for the local node, enable LDP globally, and enable MPLS and IPv4 LDP on VLAN-interface 12.
[SwitchB] mpls lsr-id 2.2.2.2
[SwitchB] mpls ldp
[SwitchB-ldp] quit
[SwitchB] interface vlan-interface 12
[SwitchB–Vlan-interface12] mpls enable
[SwitchB–Vlan-interface12] mpls ldp enable
[SwitchB–Vlan-interface12] quit
# Configure BGP to advertise VPNv4 routes.
[SwitchB] bgp 100
[SwitchB-bgp-default] peer 12.1.1.3 as-number 200
[SwitchB-bgp-default] address-family vpnv4
[SwitchB-bgp-default-vpnv4] peer 12.1.1.3 enable
[SwitchB-bgp-default-vpnv4] quit
# Configure the LSR ID as 3.3.3.3 for the local node, enable LDP globally, and enable MPLS and IPv4 LDP on VLAN-interface 12.
[SwitchC] mpls lsr-id 3.3.3.3
[SwitchC] mpls ldp
[SwitchC -ldp] quit
[SwitchC] interface vlan-interface 12
[SwitchC–Vlan-interface12] mpls enable
[SwitchC–Vlan-interface12] mpls ldp enable
[SwitchC–Vlan-interface12] quit
[SwitchC] bgp 200
[SwitchC-bgp-default] peer 12.1.1.2 as-number 100
[SwitchC-bgp-default] address-family vpnv4
[SwitchC-bgp-default-vpnv4] peer 12.1.1.2 enable
[SwitchC-bgp-default-vpnv4] quit
Configuring the BGP EVPN address family and the BGP VPNv4 address family to exchange routes
# On Switch B, configure the BGP EVPN address family and the BGP VPNv4 address family to exchange routes.
[SwitchB] bgp 100
[SwitchB-bgp-default-evpn] advertise l3vpn route
[SwitchB-bgp-default-vpnv4] advertise evpn route
# On Switch C, configure the BGP EVPN address family and the BGP VPNv4 address family to exchange routes.
[SwitchC] bgp 200
[SwitchC-bgp-default-evpn] advertise l3vpn route
[SwitchC-bgp-default-vpnv4] advertise evpn route
# On Switch B, display the BGP VPNv4 routing table. Verify that BGP EVPN routes are redistributed to the routing table.
[SwitchB] display bgp routing-table vpnv4
 Status codes: * - valid, > - best, d - dampened, h - history
               a - additional-path
 Total number of routes from all PEs: 1
 Route distinguisher: 1:2(vpna)
 Total number of routes: 3
* >i 10.1.1.0/24        1.1.1.1         0          100        0       i
* >i 10.1.1.11/32       1.1.1.1         0          100        0       i
* >e 10.1.2.0/24        12.1.1.3                              0       200i
 Route distinguisher: 1:3
 Total number of routes: 1
# Display BGP VPNv4 route advertisement information. Verify that the BGP EVPN routes are advertised to the BGP VPNv4 neighbor.
[SwitchB] display bgp routing-table vpnv4 10.1.1.0 advertise-info
 BGP local router ID: 2.2.2.2
 Local AS number: 100
 Paths:   1 best
 BGP routing table information of 10.1.1.0/24(TxPathID:0):
    12.1.1.3
 Inlabel              : 1150
# Display BGP EVPN routes. Verify that an IP prefix advertisement route is generated based on the route that is redistributed in to the BGP EVPN address family from the BGP VPNv4 address family.
[SwitchB] display bgp l2vpn evpn
               a - additional-path
 Total number of routes from all PEs: 2
 Route distinguisher: 1:1
*>  Network : [5][0][24][10.1.1.0]/80
    NextHop : 1.1.1.1                             LocPrf    :100
    PrefVal : 0                                   OutLabel  : NULL
    MED     : 0
    Path/Ogn: i
 Total number of routes: 2
*>i Network : [2][0][48][0005-0005-0005][32][10.1.1.11]/136
    NextHop : 1.1.1.1                             LocPrf    : 100
    MED     : 0
    Path/Ogn: i
*>e Network : [5][0][24][10.1.2.0]/80
    NextHop : 127.0.0.1                           LocPrf    : 0
    MED     : 0
    Path/Ogn: 200i
 Route distinguisher: 1:10
    MED     : 0
    Path/Ogn: i
# Display detailed advertisement information about the IP prefix advertisement route. Verify that the switch has advertised the route to the EVPN neighbor.
[SwitchB] display bgp l2vpn evpn [5][0][24][10.1.2.0]/80 advertise-info
 Paths:   1 best
 BGP routing table information of [5][0][24][10.1.2.0]/80(TxPathID:0):
    1.1.1.1
Configuration files
·     Switch A:
 sysname SwitchA
 address-family ipv4
  vpn-target 2:2 import-extcommunity
  vpn-target 2:2 export-extcommunity
 address-family evpn
  vpn-target 1:1 import-extcommunity
  vpn-target 1:1 export-extcommunity
ospf 1
 area 0.0.0.0
vlan 11
vlan 100
 l2vpn enable
vsi vpn1
 vxlan 10
  vpn-target auto export-extcommunity
  vpn-target auto import-extcommunity
interface LoopBack0
 ip address 1.1.1.1 255.255.255.255
interface Vlan-interface11
 ip address 11.1.1.1 255.255.255.0
 port link-mode bridge
  xconnect vsi vpn1
 port trunk permit vlan 1 11
interface Vsi-interface1
 mac-address 0001-0001-0001
interface Vsi-interface2
 l3-vni 1000
bgp 100
 peer 2.2.2.2 connect-interface LoopBack0
  peer 2.2.2.2 enable
return
·     Switch B:
 sysname SwitchB
 address-family ipv4
 address-family evpn
ospf 1
 import-route bgp
 area 0.0.0.0
 mpls lsr-id 2.2.2.2
vlan 11 to 12
mpls ldp
 l2vpn enable
interface LoopBack0
 ip address 2.2.2.2 255.255.255.255
 ip address 11.1.1.2 255.255.255.0
interface Vlan-interface12
 ip address 12.1.1.2 255.255.255.0
 mpls enable
 mpls ldp enable
 port trunk permit vlan 1 12
 l3-vni 1000
bgp 100
 peer 1.1.1.1 connect-interface LoopBack0
  peer 1.1.1.1 enable
·     Switch C:
 sysname SwitchC
 address-family ipv4
 address-family evpn
ospf 1
 import-route bgp
 area 0.0.0.0
 mpls lsr-id 3.3.3.3
vlan 12 to 13
mpls ldp
 l2vpn enable
interface LoopBack0
 ip address 3.3.3.3 255.255.255.255
 ip address 12.1.1.3 255.255.255.0
 mpls enable
 mpls ldp enable
interface Vlan-interface13
 ip address 13.1.1.3 255.255.255.0
 port trunk permit vlan 1 13
 l3-vni 1000
bgp 200
 peer 4.4.4.4 connect-interface LoopBack0
  peer 4.4.4.4 enable
·     Switch D:
 sysname SwitchD
 address-family ipv4
 address-family evpn
ospf 1
 area 0.0.0.0
vlan 13
 l2vpn enable
vsi vpn1
 vxlan 20
interface LoopBack0
 ip address 4.4.4.4 255.255.255.255
 ip address 13.1.1.4 255.255.255.0
  xconnect vsi vpn1
 ip address 10.1.2.1 255.255.255.0
 mac-address 0001-0002-0001
 l3-vni 1000
bgp 200
 peer 3.3.3.3 connect-interface LoopBack0
  peer 3.3.3.3 enable
不同款型规格的资料略有差异, 详细信息请向具体销售和400咨询。 H3C保留在没有任何通知或提示的情况下对资料内容进行修改的权利!
