H3C Fixed Port Campus Switches Configuration Examples-6W105
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-6W105
Table of Contents
Related Documents
80-Layer 3 Multicast on Multicast Source-Side DR System Configuration Examples
Introduction
This document provides examples for configuring Layer 3 multicast on a DR system attached to multicast sources.
Distributed Resilient Network Interconnect (DRNI) virtualizes two physical devices into one system through multichassis link aggregation. You can configure PIM on a DR system attached to multicast receivers or multicast sources to prevent single points of failure from interrupting multicast forwarding.
This document assumes that you have basic knowledge of DRNI and Layer 3 multicast.
Example: Configuring Layer 3 IPv4 multicast on a DR system attached to multicast sources
As shown in Figure 1:
·     OSPF runs on the network.
·     VOD streams are sent to receiver hosts in multicast. The receivers of different subnets form stub networks, and a minimum of one receiver host exist on each stub network.
·     The entire PIM-SM domain contains only one BSR.
·     Device C is a Layer 2 device attached to the multicast source. Switch A and Switch B are virtualized into a DR system, which is connected to Switch C through a multichassis aggregate link. VLAN-interface 20 interfaces on the DR system are the gateway for the multicast source.
·     Host A is a multicast data receiver attached to Device D.
·     The GigabitEthernet 1/0/3 interfaces on Device A and Device B are excluded from the shutdown action by DRNI MAD to set up the keepalive link.
·     A VRRP group is configured on VLAN-interface 20 interfaces. In the VRRP group, Device A is the master.
·     DR interfaces on Switch A and Switch B permit packets from VLAN 20 to pass through. PIM is enabled on VLAN-interface 20 of Switch A and Switch B.
·     IP multicast routing is enabled on Switch A and Switch B.
Figure 1 Network diagram
Device
IP address
Device
IP address
Device A
Vlan-int20
20.0.0.1/24
Device D
Vlan-int10
100.0.0.2/24
GE1/0/3
200.0.0.1/24
Vlan-int30
30.0.0.2/24
Vlan-int10
100.0.0.1/24
Vlan-int40
40.0.0.2/24
Loop0
1.1.1.1
Device B
Vlan-int20
20.0.0.2/24
GE1/0/3
200.0.0.2/24
Vlan-int30
30.0.0.1/24
Loop0
2.2.2.2
Hardware
Software version
S6812 switch series
S6813 switch series
Release 6615Pxx, Release 6628Pxx
S6550XE-HI switch series
Release 6008 or later, Release 8106Pxx
S6525XE-HI switch series
S5850 switch series
Not supported
S5570S-EI switch series
Not supported
S5560X-EI switch series
S5560X-HI switch series
S5500V2-EI switch series
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S switch
MS4520V2-24TP switch
Not supported
S6520X-HI switch series
S6520X-EI switch series
S6520X-SI switch series
S6520-SI switch series
S5000-EI switch series
MS4600 switch series
ES5500 switch series
S5560S-EI switch series
S5560S-SI switch series
Not supported
S5500V3-24P-SI switch
S5500V3-48P-SI switch
Not supported
S5500V3-SI switch series (except S5500V3-24P-SI and S5500V3-48P-SI)
Not supported
S5170-EI switch series
Not supported
S5130S-HI switch series
S5130S-EI switch series
S5130S-SI switch series
S5130S-LI switch series
Not supported
S5120V2-SI switch series
S5120V2-LI switch series
Not supported
S5120V3-EI switch series
Not supported
S5120V3-36F-SI switch
S5120V3-28P-HPWR-SI switch
S5120V3-54P-PWR-SI switch
Not supported
S5120V3-SI switch series (except S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI)
Not supported
S5120V3-LI switch series
Not supported
S3600V3-EI switch series
Not supported
S3600V3-SI switch series
Not supported
S3100V3-EI switch series
S3100V3-SI switch series
Not supported
S5110V2 switch series
Not supported
S5110V2-SI switch series
Not supported
S5000V3-EI switch series
S5000V5-EI switch series
Not supported
S5000E-X switch series
S5000X-EI switch series
Not supported
E128C switch
E152C switch
E500C switch series
E500D switch series
Not supported
MS4320V2 switch series
MS4320V3 switch series
MS4300V2 switch series
MS4320 switch series
MS4200 switch series
Not supported
WS5850-WiNet switch series
Not supported
WS5820-WiNet switch series
WS5810-WiNet switch series
Not supported
WAS6000 switch series
Not supported
IE4300-12P-AC switch
IE4300-12P-PWR switch
IE4300-M switch series
IE4320 switch series
Not supported
S5135S-EI switch series
Not supported
Procedures
Assigning IP addresses and configuring unicast routing
Assign an IP address and subnet mask to each interface as shown in Figure 1, and configure OSPF on the switches in the PIM-SM domain. (Details not shown.)
Configuring Device A
# Configure the DR system settings.
[DeviceA] drni system-mac 1-1-1
[DeviceA] drni system-number 1
[DeviceA] drni system-priority 123
# Configure DR keepalive packet parameters.
[DeviceA] drni keepalive ip destination 200.0.0.2 source 200.0.0.1
# Exclude the interface used for DR keepalive detection (GigabitEthernet 1/0/3) from the shutdown action by DRNI MAD.
[DeviceA] drni mad exclude interface gigabitethernet 1/0/3
# Create Layer 2 dynamic aggregate interface Bridge-Aggregation 1.
[DeviceA] interface bridge-aggregation 1
[DeviceA-Bridge-Aggregation1] link-aggregation mode dynamic
[DeviceA-Bridge-Aggregation1] quit
# Assign GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to aggregation group 1.
[DeviceA-GigabitEthernet1/0/1] port link-aggregation group 1
[DeviceA-GigabitEthernet1/0/2] port link-aggregation group 1
# Create Layer 2 dynamic aggregate interface Bridge-Aggregation 2.
[DeviceA] interface bridge-aggregation 2
[DeviceA-Bridge-Aggregation2] link-aggregation mode dynamic
[DeviceA-Bridge-Aggregation2] quit
# Assign GigabitEthernet 1/0/5 and GigabitEthernet 1/0/6 to aggregation group 1.
[DeviceA] interface gigabitethernet 1/0/5
[DeviceA-GigabitEthernet1/0/5] port link-aggregation group 2
[DeviceA-GigabitEthernet1/0/5] quit
[DeviceA] interface gigabitethernet 1/0/6
[DeviceA-GigabitEthernet1/0/6] port link-aggregation group 2
[DeviceA-GigabitEthernet1/0/6] quit
# Configure Bridge-Aggregation 1 as a trunk port, assign it to all VLANs, and specify it as the IPP.
[DeviceA-Bridge-Aggregation1] port link-type trunk
[DeviceA-Bridge-Aggregation1] port trunk permit vlan all
[DeviceA-Bridge-Aggregation1] port drni intra-portal-port 1
# Configure Bridge-Aggregation 2 as a trunk port, and assign it to VLAN 20 and a DR group.
[DeviceA-Bridge-Aggregation2] port link-type trunk
[DeviceA-Bridge-Aggregation2] port trunk permit vlan 20
[DeviceA-Bridge-Aggregation2] port drni group 1
# Configure VRRP group 1 on VLAN-interface 20, and set the priority of Device A to 200 for it to be the master in the VRRP group.
[DeviceA] vlan 20
[DeviceA-vlan20] quit
[DeviceA] interface vlan-interface 20
[DeviceA-Vlan-interface20] vrrp vrid 1 virtual-ip 20.0.0.10
[DeviceA-Vlan-interface20] vrrp vrid 1 priority 200
[DeviceA-Vlan-interface20] quit
# Enable IP multicast routing, enable IGMP and PIM on VLAN-interface 10, and enable PIM-SM on other interfaces as required.
[DeviceA] multicast routing
[DeviceA-mrib] quit
[DeviceA-Vlan-interface10] igmp enable
[DeviceA-Vlan-interface10] pim sm
[DeviceA-Vlan-interface20] pim sm
[DeviceA] interface loopback 0
[DeviceA-LoopBack0] pim sm
[DeviceA-LoopBack0] quit
# Specify the IP address of Loopback 0 as a C-RP and a C-BSR.
[DeviceA] pim
[DeviceA-pim] c-rp 1.1.1.1
[DeviceA-pim] c-bsr 1.1.1.1
[DeviceA-pim] quit
Configuring Device B
Configure Device B in the same way you configure Device A. (Details not shown.)
Configuring Device C
<DeviceC> system-view
[DeviceC] interface bridge-aggregation 1
[DeviceC-Bridge-Aggregation1] link-aggregation mode dynamic
[DeviceC-Bridge-Aggregation1] quit
# Assign GigabitEthernet 1/0/1 through GigabitEthernet 1/0/4 to aggregation group 1.
[DeviceC] interface range gigabitethernet 1/0/1 to gigabitethernet 1/0/4
[DeviceC-if-range] port link-aggregation group 1
[DeviceC-if-range] quit
# Configure Bridge-Aggregation 2 as a trunk port, and assign it to VLAN 20.
[DeviceC-Bridge-Aggregation1] port link-type trunk
[DeviceC-Bridge-Aggregation1] port trunk permit vlan 20
# Assign GigabitEthernet 1/0/5 to VLAN 20.
[DeviceC] interface gigabitethernet 1/0/5
[DeviceC-GigabitEthernet1/0/5] port access vlan 20
[DeviceC-GigabitEthernet1/0/5] quit
Configuring Device D
# Assign GigabitEthernet 1/0/1, GigabitEthernet 1/0/2, and GigabitEthernet 1/0/3 to VLAN 10, VLAN 30, and VLAN 40, respectively.
<DeviceD> system-view
[DeviceD] vlan 10
[DeviceD-vlan10] quit
[DeviceD] interface gigabitethernet1/0/1
[DeviceD-GigabitEthernet1/0/1] port access vlan 10
[DeviceD-GigabitEthernet1/0/1] quit
[DeviceD] vlan 40
[DeviceD-vlan40] quit
[DeviceD] interface gigabitethernet1/0/3
[DeviceD-GigabitEthernet1/0/3] port access vlan 40
[DeviceD] vlan 30
[DeviceD-vlan30] quit
[DeviceD] interface gigabitethernet1/0/2
[DeviceD-GigabitEthernet1/0/2] port access vlan 30
# Enable IP multicast routing, and enable PIM-SM on VLAN-interface 10 and VLAN-interface 30.
[DeviceD] multicast routing
[DeviceD-mrib] quit
[DeviceD] interface vlan-interface 10
[DeviceD-Vlan-interface10] pim sm
[DeviceD-Vlan-interface10] quit
[DeviceD] vlan 30
[DeviceD] interface vlan-interface 30
# Enable IGMPv2 on VLAN-interface 40.
[DeviceD] interface vlan-interface 40
[DeviceD-Vlan-interface40] igmp enable
[DeviceD-Vlan-interface40] igmp version 2
[DeviceD-Vlan-interface40] quit
# Verify that Device B sends and receives keepalive packets correctly.
<DeviceB> display drni keepalive
Neighbor keepalive link status (cause): Up
Neighbor is alive for: 176 s 237 ms
Keepalive packet transmission status:
  Sent: Successful
  Received: Successful
Last received keepalive packet information:
  Source IP address: 200.0.0.1
  Time: 2021/12/21 15:12:43
  Action: Accept
Distributed relay keepalive parameters:
Destination IP address: 200.0.0.1
Source IP address: 200.0.0.2
Keepalive UDP port : 6400
Keepalive VPN name : N/A
Keepalive interval : 1000 ms
Keepalive timeout  : 5 sec
Keepalive hold time: 3 sec
# Verify that interfaces used by DRNI operate correctly on Device B.
<DeviceB> display drni summary
Flags: A -- Aggregate interface down, B -- No peer DR interface configured
       C -- Configuration consistency check failed
IPP: BAGG1
IPP state (cause): UP
Keepalive link state (cause): UP
                     DR interface information
DR interface  DR group  Local state (cause)  Peer state  Remaining down time(s)
BAGG2         1         UP                   UP          -
# Verify that the DR interface on Device B operates correctly.
<DeviceB> display link-aggregation verbose bridge-aggregation 2
Port: A -- Auto port, M -- Management port, R -- Reference port
Flags:  A -- LACP_Activity, B -- LACP_Timeout, C -- Aggregation,
        G -- Defaulted, H -- Expired
Aggregate Interface: Bridge-Aggregation2
Creation Mode: Manual
Aggregation Mode: Dynamic
Management VLANs: None
System ID: 0x7b, 0001-0001-0001
Local:
  Port                Status   Priority Index    Oper-Key               Flag
  GE1/0/5(R)          S        32768    32770    40001                  {ACDEF}
  GE1/0/6             S        32768    32770    40001                  {ACDEF}
Remote:
  Actor               Priority Index    Oper-Key SystemID               Flag
  GE1/0/5             32768    2        1        0x8000, 84c4-42e5-0300 {ACDEF}
  GE1/0/6             32768    2        1        0x8000, 84c4-42e5-0300 {ACDEF}
# Verify that the IGMP group information on Device D is correct.
<DeviceD> display igmp group
IGMP groups in total: 1
 Vlan-interface40(40.0.0.2):
  IGMP groups reported in total: 1
   Group address   Last reporter   Uptime      Expires
   225.0.0.1       40.0.0.10       00:02:04    00:01:15
# Verify that PIM routing entries have been created on Device B.
<DeviceB> display pim routing-table
 Total 1 (*, G) entries; 1 (S, G) entries
 (*, 225.0.0.1)
     RP: 2.2.2.2 (local)
     Protocol: pim-sm, Flag: WC
     UpTime: 00:00:20
     Upstream interface: Register-Tunnel0
         Upstream neighbor: NULL
         RPF prime neighbor: NULL
     Downstream interface information:
         1: Vlan-interface30
             Protocol: pim-sm, UpTime: 00:00:20, Expires: -
 (20.0.0.100, 225.0.0.1)
     RP: 2.2.2.2 (local)
     Protocol: pim-sm, Flag: SPT ACT 2MVPN
     UpTime: 00:00:19
     Upstream interface: Vlan-interface20
         1: Vlan-interface30
             Protocol: pim-sm, UpTime: 00:00:19, Expires: -
# Verify that multicast forwarding entries have been created on Device B.
<DeviceB> display multicast forwarding-table
Total 1 entries, 1 matched
00001. (20.0.0.100, 225.0.0.1)
     Flags: 0x0
     Uptime: 00:00:55, Timeout in: 00:03:18
     Incoming interface: Vlan-interface20
     List of 1 outgoing interfaces:
       1: Vlan-interface30
     Matched 1293 packets(36204 bytes), Wrong If 0 packets
     Forwarded 1291 packets(36148 bytes)
# Verify that Device A does not create PIM routing entries or multicast forwarding entries, which indicates that Device B forwards all multicast traffic to the receiver. (Details not shown.)
Configuration files
·     Device A:
 sysname DeviceA
ospf 1
 router-id 2.2.2.2
 area 0.0.0.0
vlan 1
vlan 10
vlan 20
interface Bridge-Aggregation1
interface Bridge-Aggregation2
 port trunk permit vlan 1 20
 port drni group 1
interface LoopBack0
 ospf 1 area 0.0.0.0
 pim sm
 ip address 1.1.1.1 255.255.255.255
interface Vlan-interface10
 ospf 1 area 0.0.0.0
 pim sm
 ip address 100.0.0.1 255.255.255.0
interface Vlan-interface20
 ospf 1 area 0.0.0.0
 pim sm
 ip address 20.0.0.1 255.255.255.0
 ip address 200.0.0.1 255.255.255.0
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/4
 port access vlan 10
multicast routing
pim
 c-bsr 1.1.1.1
 c-rp 1.1.1.1
 drni system-mac 0001-0001-0001
 drni mad exclude interface GigabitEthernet1/0/3
·     Device B:
 sysname DeviceB
ospf 1
 router-id 3.3.3.3
 area 0.0.0.0
 area 0.0.0.9
vlan 20
vlan 30
 port drni group 1
interface LoopBack0
 ospf 1 area 0.0.0.0
 pim sm
 ip address 2.2.2.2/32
 ospf 1 area 0.0.0.0
 pim sm
 ip address 20.0.0.2 255.255.255.0
 vrrp vrid 1 priority 100
interface Vlan-interface30
 ospf 1 area 0.0.0.0
 pim sm
 ip address 30.0.0.1 255.255.255.0
 ospf 1 area 0.0.0.0
 ip address 200.0.0.2 255.255.255.0
 port access vlan 30
multicast routing
pim
 c-bsr 1.1.1.1
 c-rp 1.1.1.1
 drni system-number 2
 drni keepalive ipv6 destination 200.0.0.1 source 200.0.0.2
·     Device C:
 sysname DeviceC
vlan 1
vlan 20
interface LoopBack1
 ip address 3.3.3.3 255.255.255.255
 port access vlan 20
·     Device D:
 sysname DeviceD
ospf 1
 router-id 4.4.4.4
 area 0.0.0.0
vlan 10
vlan 40
vlan 30
 ospf 1 area 0.0.0.0
 pim sm
 ip address 100.0.0.2 255.255.255.0
interface Vlan-interface40
 ospf 1 area 0.0.0.0
 ip address 40.0.0.2 255.255.255.0
 igmp enable
 igmp version 2
 ospf 1 area 0.0.0.0
 pim sm
 ip address 30.0.0.2 255.255.255.0
 port access vlan 40
 port access vlan 10
 port access vlan 30
multicast routing
Example: Configuring Layer 3 IPv6 multicast on a DR system attached to multicast sources
As shown in Figure 2:
·     OSPFv3 runs on the network.
·     The entire IPv6 PIM-SM domain contains only one BSR.
·     IPv6 multicast routing is enabled on Switch A and Switch B.
Figure 2 Network diagram
Device
IP address
Device
IP address
Device A
Vlan-int20
2000::1/80
Device D
Vlan-int10
2003::2/80
GE1/0/3
2002::1/80
Vlan-int30
2004::2/80
Vlan-int10
2003::1/80
Vlan-int40
20::1/80
Loop0
1111::1111/128
Device B
Vlan-int20
2000::2/80
GE1/0/3
2002::2/80
Vlan-int30
2004::1/80
Loop0
2222::2222/128
Hardware
Software version
S6812 switch series
S6813 switch series
S5850 switch series
Not supported
Not supported
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S switch
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
E128C switch
E152C switch
E500C switch series
E500D switch series
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Procedures
Assigning IPv6 addresses and configuring unicast routing
Assign an IPv6 address and prefix to each interface as shown in Figure 2, and configure OSPFv3 on the switches in the IPv6 PIM-SM domain. (Details not shown.)
[DeviceA] drni keepalive ipv6 destination 2002::2 source 2002::1
# Configure Bridge-Aggregation 2 as a trunk port, assign it to VLAN 20, and assign it to a DR group.
# Configure VRRP group 1 on VLAN-interface 20, and set the priority of Device A to 200 for it to become the master in the VRRP group.
[DeviceA-Vlan-interface20] vrrp ipv6 vrid 1 virtual-ip FE80::10 link-local
[DeviceA-Vlan-interface20] vrrp ipv6 vrid 1 virtual-ip 2000::10
[DeviceA-Vlan-interface20] vrrp ipv6 vrid 1 priority 200
# Enable IPv6 multicast routing, enable MLD and IPv6 PIM on VLAN-interface 10, and enable IPv6 PIM-SM on other interfaces as required.
[DeviceA] ipv6 multicast routing
[DeviceA-mrib6] quit
[DeviceA-Vlan-interface10] mld enable
[DeviceA-Vlan-interface10] ipv6 pim sm
[DeviceA-Vlan-interface20] ipv6 pim sm
[DeviceA-LoopBack0] ipv6 pim sm
# Specify the IPv6 address of Loopback 0 as a C-RP and a C-BSR.
[DeviceA] ipv6 pim
[DeviceA-pim6] c-rp 1111::1111
[DeviceA-pim6] c-bsr 1111::1111
[DeviceA-pim6] quit
[DeviceD] vlan 10
[DeviceD] vlan 40
[DeviceD] vlan 30
# Enable IPv6 multicast routing, and enable IPv6 PIM-SM on VLAN-interface 10 and VLAN-interface 30.
[DeviceD] ipv6 multicast routing
[DeviceD-mrib6] quit
[DeviceD-Vlan-interface10] ipv6 pim sm
[DeviceD] vlan 30
[DeviceD-Vlan-interface30] ipv6 pim sm
[DeviceD-Vlan-interface30] quit
# Enable MLDv2 on VLAN-interface 40.
[DeviceD-Vlan-interface40] mld enable
[DeviceD-Vlan-interface40] mld version 2
Neighbor is alive for: 2128 s 421 ms
  Sent: Successful
  Source IP address: 2002::1
  Time: 2021/12/21 15:45:15
  Action: Accept
Destination IP address: 2002::1
Source IP address: 2002::2
IPP: BAGG1
BAGG2         1         UP                   UP          -
Local:
Remote:
# Verify that the MLD group information on Device D is correct.
<DeviceD> display mld group
MLD groups in total: 1
 Vlan-interface40(FE80::200:FCFF:FE00:3472):
  MLD groups reported in total: 1
   Group address: FF08::2
    Last reporter: FE80::1
    Uptime: 01:56:46
    Expires: 00:02:43
# Verify that IPv6 PIM routing entries have been created on Device B.
<DeviceB> display ipv6 pim routing-table
 (*, FF08::2)
     RP: 2222::2222(local)
     UpTime: 00:17:51
         1: Vlan-interface30
             Protocol: pim-sm, UpTime: 00:17:51, Expires: 00:02:39
 (2000::111, FF08::2)
     Protocol: pim-sm, Flag: SPT LOC ACT 2MVPN
     UpTime: 00:17:54
         1: Vlan-interface30
             Protocol: pim-sm, UpTime: 00:17:54, Expires: 00:02:36
# Verify that IPv6 multicast forwarding entries have been created on Device B.
<DeviceB> display ipv6 multicast forwarding-table
00001. (2000::111, FF08::2)
     Flags: 0x0
     Uptime: 00:08:27, Timeout in: 00:03:27
       1: Vlan-interface30
     Matched 5 packets(71681 bytes), Wrong If 0 packets
     Forwarded 5 packets(71681 bytes)
# Verify that Device A does not create IPv6 PIM routing entries or multicast forwarding entries, which indicates that Device B forwards all multicast traffic to the receiver. (Details not shown.)
Configuration files
·     Device A:
 sysname DeviceA
ospfv3 1
 router-id 2.2.2.2
 area 0.0.0.0
vlan 10
vlan 20
 port drni group 1
interface LoopBack0
 ospfv3 1 area 0.0.0.0
 ipv6 pim sm
 ipv6 address 1111::1111/128
 ipv6 pim sm
 ipv6 address 2003::1/80
 ipv6 pim sm
 ipv6 address 2000::1/80
 ipv6 address 2002::1/80
 port access vlan 10
ipv6 pim
 c-bsr 1111::1111
 c-rp 1111::1111
·     Device B:
 sysname DeviceB
ospfv3 1
 router-id 3.3.3.3
 area 0.0.0.0
vlan 20
vlan 30
 port drni group 1
interface LoopBack0
 ipv6 pim sm
 ipv6 address 2222::2222/128
 ipv6 pim sm
 ipv6 address 2000::2/80
 vrrp ipv6 vrid 1 priority 100
 ipv6 pim sm
 ipv6 address 2004::1/80
 ipv6 address 2002::2/80
 port access vlan 30
ipv6 pim
 c-bsr 2222::2222
 c-rp 2222::2222
 drni keepalive ipv6 destination 2002::1 source 2002::2
·     Device C:
 sysname DeviceC
vlan 20
interface LoopBack1
 ipv6 address FE80::2 link-local
 port access vlan 20
·     Device D:
 sysname DeviceD
ospfv3 1
 router-id 4.4.4.4
 area 0.0.0.0
vlan 10
vlan 40
vlan 30
 ipv6 pim sm
 ipv6 address 2003::2/80
 ipv6 address 20::1/80
 mld enable
 mld version 2
 ipv6 pim sm
 ipv6 address 2004::2/80
 port access vlan 40
 port access vlan 10
 port access vlan 30
pim
不同款型规格的资料略有差异, 详细信息请向具体销售和400咨询。 H3C保留在没有任何通知或提示的情况下对资料内容进行修改的权利!
