H3C Fixed Port Campus Switches Configuration Examples-6W105
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-6W105
Table of Contents
Related Documents
61-S-MLAG Configuration Examples
Introduction
This document provides configuration examples for using simple multichassis link aggregation (S-MLAG).
S-MLAG enhances dynamic link aggregation to establish an aggregation that spans multiple standalone devices to a remote device.
The following information is provided based on the assumption that you have basic knowledge of S-MLAG.
Example: Configuring S-MLAG
Device B, Device C, and Device D are standalone devices. As shown in Figure 1, configure Device B, Device C, and Device D as S-MLAG devices to establish a multidevice aggregate link with Device A.
Figure 1 Network diagram
Analysis
To establish a multidevice aggregate link with Device A, you must perform the following tasks on Device B, Device C, and Device D:
1.     Create a Layer 2 dynamic aggregate interface and assign GigabitEthernet 1/0/1 to its aggregation group.
2.     Assign the aggregate interfaces to the same DR group.
Hardware
Software version
S6812 switch series
S6813 switch series
Release 6615Pxx, Release 6628Pxx
S6550XE-HI switch series
Release 6008 and later, Release 8106Pxx
S6525XE-HI switch series
S5850 switch series
Release 8005 and later, Release 8106Pxx
S5570S-EI switch series
Release 11xx
S5560X-EI switch series
Release 63xx, Release 65xx, Release 6615Pxx, Release 6628Pxx
S5560X-HI switch series
S5500V2-EI switch series
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S switch
MS4520V2-24TP switch
Release 63xx
S6520X-HI switch series
S6520X-EI switch series
S6520X-SI switch series
S6520-SI switch series
S5000-EI switch series
MS4600 switch series
ES5500 switch series
S5560S-EI switch series
S5560S-SI switch series
Release 63xx
S5500V3-24P-SI switch
S5500V3-48P-SI switch
Release 63xx
S5500V3-SI switch series (except S5500V3-24P-SI and S5500V3-48P-SI)
Release 11xx
S5170-EI switch series
Release 11xx
S5130S-HI switch series
S5130S-EI switch series
S5130S-SI switch series
S5130S-LI switch series
Release 63xx
S5120V2-SI switch series
S5120V2-LI switch series
Release 63xx
S5120V3-EI switch series
Release 11xx
S5120V3-36F-SI switch
S5120V3-28P-HPWR-SI switch
S5120V3-54P-PWR-SI switch
Release 11xx
S5120V3-SI switch series (except S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI)
Release 63xx
S5120V3-LI switch series
Release 63xx
S3600V3-EI switch series
Release 11xx
S3600V3-SI switch series
Release 11xx
S3100V3-EI switch series
S3100V3-SI switch series
Release 63xx
S5110V2 switch series
Release 63xx
S5110V2-SI switch series
Release 63xx
S5000V3-EI switch series
S5000V5-EI switch series
Release 63xx
S5000E-X switch series
S5000X-EI switch series
Release 63xx
E128C switch
E152C switch
E500C switch series
E500D switch series
Release 63xx
MS4320V2 switch series
MS4320V3 switch series
MS4300V2 switch series
MS4320 switch series
MS4200 switch series
Release 63xx
WS5850-WiNet switch series
Release 63xx
WS5820-WiNet switch series
WS5810-WiNet switch series
Release 63xx
WAS6000 switch series
Release 63xx
IE4300-12P-AC switch
IE4300-12P-PWR switch
IE4300-M switch series
IE4320 switch series
Release 63xx
IE4520 switch series
Release 66xx
S5135S-EI switch series
Release 6658P01 and later
Before you assign an interface to an aggregation group, use the display this command in interface view to identify whether attribute settings exist, including port isolation, QinQ, VLAN, and VLAN mapping settings. If attribute settings exist, use the corresponding undo commands to remove them.
Configure the link aggregation settings other than S-MLAG settings on each S-MLAG device. Make sure the settings are consistent across the S-MLAG devices.
As a best practice, maintain consistency across S-MLAG devices in service feature configuration.
Procedures
Configuring Device A
# Create Layer 2 aggregate interface Bridge-Aggregation 10, and set the link aggregation mode to dynamic.
[DeviceA] interface bridge-aggregation 10
[DeviceA-Bridge-Aggregation10] link-aggregation mode dynamic
[DeviceA-Bridge-Aggregation10] quit
# Assign GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3 to aggregation group 10.
[DeviceA-GigabitEthernet1/0/1] port link-aggregation group 10
[DeviceA-GigabitEthernet1/0/2] port link-aggregation group 10
[DeviceA-GigabitEthernet1/0/3] port link-aggregation group 10
Configuring Device B
# Set the LACP system MAC address to 0001-0001-0001.
[DeviceB] lacp system-mac 1-1-1
# Set the LACP system priority to 123.
[DeviceB] lacp system-priority 123
# Set the LACP system number to 1.
[DeviceB] lacp system-number 1
# Create Layer 2 aggregate interface Bridge-Aggregation 2, and set the link aggregation mode to dynamic.
[DeviceB] interface bridge-aggregation 2
[DeviceB-Bridge-Aggregation2] link-aggregation mode dynamic
# Assign Bridge-Aggregation 2 to S-MLAG group 100.
[DeviceB-Bridge-Aggregation2] port s-mlag group 100
[DeviceB-Bridge-Aggregation2] quit
# Assign GigabitEthernet 1/0/1 to aggregation group 2.
[DeviceB-GigabitEthernet1/0/1] port link-aggregation group 2
Configuring Device C
<DeviceC> system-view
[DeviceC] lacp system-mac 1-1-1
[DeviceC] lacp system-priority 123
# Set the LACP system number to 2.
[DeviceC] lacp system-number 2
# Create Layer 2 aggregate interface Bridge-Aggregation 3, and set the link aggregation mode to dynamic.
[DeviceC] interface bridge-aggregation 3
[DeviceC-Bridge-Aggregation3] link-aggregation mode dynamic
# Assign Bridge-Aggregation 3 to S-MLAG group 100.
[DeviceC-Bridge-Aggregation3] port s-mlag group 100
# Assign GigabitEthernet 1/0/1 to aggregation group 3.
[DeviceC-GigabitEthernet1/0/1] port link-aggregation group 3
Configuring Device D
<DeviceD> system-view
[DeviceD] lacp system-mac 1-1-1
[DeviceD] lacp system-priority 123
# Set the LACP system number to 3.
[DeviceD] lacp system-number 3
# Create Layer 2 aggregate interface Bridge-Aggregation 4, and set the link aggregation mode to dynamic.
[DeviceD] interface bridge-aggregation 4
[DeviceD-Bridge-Aggregation4] link-aggregation mode dynamic
# Assign Bridge-Aggregation 4 to S-MLAG group 100.
[DeviceD-Bridge-Aggregation4] port s-mlag group 100
# Assign GigabitEthernet 1/0/1 to aggregation group 4.
[DeviceD] interface gigabitethernet 1/0/1
[DeviceD-GigabitEthernet1/0/1] port link-aggregation group 4
[DeviceD-GigabitEthernet1/0/1] quit
# Verify that GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3 on Device A are Selected ports.
[DeviceA] display link-aggregation verbose
Port: A -- Auto port, M -- Management port, R -- Reference port
Flags:  A -- LACP_Activity, B -- LACP_Timeout, C -- Aggregation,
        G -- Defaulted, H -- Expired
Aggregate Interface: Bridge-Aggregation10
Creation Mode: Manual
Aggregation Mode: Dynamic
Management VLANs: None
System ID: 0x8000, a0c7-9afd-0100
Local:
  Port                Status   Priority Index    Oper-Key               Flag
  GE1/0/1             S        32768    1        1                      {ACDEF}
  GE1/0/2             S        32768    2        1                      {ACDEF}
  GE1/0/3             S        32768    3        1                      {ACDEF}
Remote:
  Actor               Priority Index    Oper-Key SystemID               Flag
  GE1/0/1(R)          32768    16385    50100    0x7b  , 0001-0001-0001 {ACDEF}
  GE1/0/2             32768    32769    50100    0x7b  , 0001-0001-0001 {ACDEF}
  GE1/0/3             32768    49153    50100    0x7b  , 0001-0001-0001 {ACDEF}
Configuration files
IMPORTANT
IMPORTANT:
Support for the port link-mode bridge command depends on the device model.
·     Device A:
interface Bridge-Aggregation10
 combo enable fiber
 combo enable fiber
 combo enable fiber
·     Device B:
 lacp system-mac 0001-0001-0001
interface Bridge-Aggregation2
 combo enable fiber
·     Device C:
interface Bridge-Aggregation3
 combo enable fiber
·     Device D:
interface Bridge-Aggregation4
 combo enable fiber
Example: Aggregating server-side links by using S-MLAG
As shown in Figure 2, configure S-MLAG as follows:
·     Connect GigabitEthernet 1/0/1 interfaces on Device A, Device B, and Device C to the server, and configure S-MLAG to aggregate the links to the server.
·     Configure the server-facing aggregate interfaces on Device A, Device B, and Device C as edge aggregate interfaces for the aggregation member ports to forward traffic correctly before link aggregation is set up on the server.
Figure 2 Network diagram
Analysis
To create a multichassis aggregate link on Device A, Device B, and Device C, perform the following tasks:
·     Create server-facing Layer 2 dynamic aggregate interfaces.
·     Assign the aggregate interfaces to an S-MLAG group.
Hardware
Software version
S6812 switch series
S6813 switch series
S5850 switch series
Release 11xx
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S switch
Release 63xx
Release 63xx
Release 63xx
Release 11xx
Release 11xx
Release 63xx
Release 63xx
Release 11xx
Release 11xx
Release 63xx
Release 63xx
Release 11xx
Release 11xx
Release 63xx
Release 63xx
Release 63xx
Release 63xx
S5000E-X switch
Release 63xx
E128C switch
E152C switch
E500C switch series
E500D switch series
Release 63xx
Release 63xx
Release 63xx
Release 63xx
Release 63xx
Release 63xx
Release 66xx
When you configure S-MLAG, follow these restrictions and guidelines:
·     When you assign a port to an aggregation group, the recommended configuration procedure is as follows:
a.     Use the display this command in interface view to check the following attribute configurations of the port:
-     Port isolation.
-     QinQ.
-     VLAN.
-     VLAN mapping.
b.     If any of the above configurations exist, use the undo forms of the corresponding commands to remove these configurations. This enables the port to use the default attribute configurations.
c.     Assign the port to the aggregation group.
·     Make sure the S-MLAG member devices have consistent link aggregation configuration.
·     To ensure correct service traffic forwarding, configure the same service settings on the S-MLAG member devices.
Procedures
[DeviceA] lacp system-mac 1-1-1
[DeviceA] lacp system-priority 123
[DeviceA] lacp system-number 1
# Create Layer 2 aggregate interface Bridge-Aggregation 1, and set the link aggregation mode to dynamic.
[DeviceA-Bridge-Aggregation1] link-aggregation mode dynamic
# Configure Bridge-Aggregation 1 as an edge aggregate interface.
[DeviceA-Bridge-Aggregation1] lacp edge-port
# Assign Bridge-Aggregation 1 to S-MLAG group 100.
[DeviceA-Bridge-Aggregation1] port s-mlag group 100
[DeviceA-Bridge-Aggregation1] quit
# Assign GigabitEthernet 1/0/1 to aggregation group 1.
[DeviceB] lacp system-number 2
[DeviceC-Bridge-Aggregation2] link-aggregation mode dynamic
# Configure Bridge-Aggregation 2 as an edge aggregate interface.
[DeviceB-Bridge-Aggregation2] lacp edge-port
[DeviceC] lacp system-number 3
# Configure Bridge-Aggregation 3 as an edge aggregate interface.
[DeviceC-Bridge-Aggregation3] lacp edge-port
# Before you configure dynamic link aggregation on the server, verify that the aggregation member ports are in individual state on Device A, Device B, and Device C to forward traffic independently.
System ID: 0x7b, 0001-0001-0001
Local:
  GE1/0/1             I        32768    16385    50100                  {AG}
Remote:
  GE1/0/1             32768    0        0        0x8000, 0000-0000-0000 {DEF}
[DeviceB] display link-aggregation verbose
Aggregate Interface: Bridge-Aggregation2
Local:
  GE1/0/1             I        32768    32769    50100                  {AG}
Remote:
[DeviceC] display link-aggregation verbose
Aggregate Interface: Bridge-Aggregation3
Local:
  GE1/0/1             I        32768    49153    50100                  {AG}
Remote:
# After you configure dynamic link aggregation on the server, verify that the aggregation member ports are selected on Device A, Device B, and Device C, which indicates that the multichassis link aggregation has been set up.
Local:
  GE1/0/1(R)          S        32768    16385    50100                  {ACDEF}
Remote:
  GE1/0/1             32768    1        1        0x8000, 5022-e533-0400 {ACDEF}
Local:
  GE1/0/1(R)          S        32768    32769    50100                  {ACDEF}
Remote:
  GE1/0/1             32768    2        1        0x8000, 5022-e533-0400 {ACDEF}
Local:
  GE1/0/1(R)          S        32768    49153    50100                  {ACDEF}
Remote:
  GE1/0/1             32768    3        1        0x8000, 5022-e533-0400 {ACDEF}
Configuration files
IMPORTANT
IMPORTANT:
·     Device A:
 lacp edge-port
·     Device B:
 lacp edge-port
·     Device C:
 lacp edge-port
不同款型规格的资料略有差异, 详细信息请向具体销售和400咨询。 H3C保留在没有任何通知或提示的情况下对资料内容进行修改的权利!
