H3C Fixed Port Campus Switches Configuration Examples-6W105
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-6W105
Table of Contents
Related Documents
45-sFlow Configuration Examples
Introduction
This document provides sFlow configuration examples.
This document assumes that you have basic knowledge of sFlow.
When you configure sFlow, follow these restrictions and guidelines:
·     You can specify only the random sampling mode (the default).
·     For the remote sFlow collector to receive sFlow packets, the IP address of the sFlow collector specified on the sFlow agent must be the same with that of the remote sFlow collector.
·     If the number of packets sampled by an interface is too much in a heavy traffic network, increase the flow sampling interval. If an interface samples insufficient packets in a light traffic network, decrease the flow sampling interval.
·     If an interface collects data too frequently in a heavy traffic network, increase the counter sampling interval. If the sampling statistics is not accurate in a light traffic network, decrease the counter sampling interval.
Example: Configuring sFlow
As shown in Figure 1, perform the following tasks:
·     Configure flow sampling to sample packets on Device A and Device B.
·     Configure counter sampling to periodically collect the counter information on Device A and Device B.
Figure 1 Network diagram
Analysis
To obtain interface counter information and packet information, you must configure both flow sampling and counter sampling.
Hardware
Software version
S6812 switch series
S6813 switch series
Release 6615Pxx, Release 6628Pxx
S6550XE-HI switch series
Release 6008 and later, Release 8106Pxx
S6525XE-HI switch series
S5850 switch series
Release 8005 and later, Release 8106Pxx
S5570S-EI switch series
Release 11xx
S5560X-EI switch series
Release 63xx, Release 65xx, Release 6615Pxx, Release 6628Pxx
S5560X-HI switch series
S5500V2-EI switch series
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S switch
MS4520V2-24TP switch
Release 63xx
S6520X-HI switch series
S6520X-EI switch series
Release 63xx, Release 65xx, Release 6628Pxx
S6520X-SI switch series
S6520-SI switch series
S5000-EI switch series
MS4600 switch series
ES5500 switch series
S5560S-EI switch series
S5560S-SI switch series
Release 63xx
S5500V3-24P-SI switch
S5500V3-48P-SI switch
Release 63xx
S5500V3-SI switch series (except S5500V3-24P-SI and S5500V3-48P-SI)
Release 11xx
S5170-EI switch series
Release 11xx
S5130S-HI switch series
S5130S-EI switch series
S5130S-SI switch series
S5130S-LI switch series
Release 63xx
S5120V2-SI switch series
S5120V2-LI switch series
Release 63xx
S5120V3-EI switch series
Release 11xx
S5120V3-36F-SI switch
S5120V3-28P-HPWR-SI switch
S5120V3-54P-PWR-SI switch
Release 11xx
S5120V3-SI switch series (except S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI)
Release 63xx
S5120V3-LI switch series
Release 63xx
S3600V3-EI switch series
Release 11xx
S3600V3-SI switch series
Release 11xx
S3100V3-EI switch series
S3100V3-SI switch series
Release 63xx
S5110V2 switch series
Release 63xx
S5110V2-SI switch series
Release 63xx
S5000V3-EI switch series
S5000V5-EI switch series
Release 63xx
S5000E-X switch series
S5000X-EI switch series
Release 63xx
E128C switch
E152C switch
E500C switch series
E500D switch series
Release 63xx
MS4320V2 switch series
MS4320V3 switch series
MS4300V2 switch series
MS4320 switch series
MS4200 switch series
Release 63xx
WS5850-WiNet switch series
Release 63xx
WS5820-WiNet switch series
WS5810-WiNet switch series
Release 63xx
WAS6000 switch series
Release 63xx
IE4300-12P-AC switch
IE4300-12P-PWR switch
IE4300-M switch series
IE4320 switch series
Release 63xx
IE4520 switch series
Release 66xx
S5135S-EI switch series
Release 6658P01 and later
Procedures
Configuring Device A
# Create VLAN 10. Assign GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3 to VLAN 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port gigabitethernet 1/0/1 to gigabitethernet 1/0/3
[DeviceA-vlan10] quit
# Assign an IP address to VLAN-interface 10.
[DeviceA-Vlan-interface10] ip address 10.1.1.1 255.255.255.0
# Assign IP addresses to other interfaces. (Details not shown.)
# Assign an IP address to the sFlow agent.
[DeviceA] sflow agent ip 10.1.1.1
# Specify the sFlow collector ID as 1, IP address as 30.1.1.2, and port number as 5000.
[DeviceA] sflow collector 1 ip 30.1.1.2 port 5000
# Enable counter sampling and set the counter sampling interval to 120 seconds on GigabitEthernet 1/0/1.
[DeviceA-GigabitEthernet1/0/1] sflow counter interval 120
# Specify sFlow collector 1 for counter sampling on GigabitEthernet 1/0/1.
[DeviceA-GigabitEthernet1/0/1] sflow counter collector 1
# Enable counter sampling and set the counter sampling interval to 120 seconds on GigabitEthernet 1/0/2.
[DeviceA-GigabitEthernet1/0/2] sflow counter interval 120
# Specify sFlow collector 1 for counter sampling on GigabitEthernet 1/0/2.
[DeviceA-GigabitEthernet1/0/2] sflow counter collector 1
# Enable flow sampling and set the sampling interval to 10000 on GigabitEthernet 1/0/1.
[DeviceA-GigabitEthernet1/0/1] sflow sampling-rate 10000
# Specify sFlow collector 1 for flow sampling on GigabitEthernet 1/0/1.
[DeviceA-GigabitEthernet1/0/1] sflow flow collector 1
# Enable flow sampling and set the sampling interval to 10000 on GigabitEthernet 1/0/2.
[DeviceA-GigabitEthernet1/0/2] sflow sampling-rate 10000
# Specify sFlow collector 1 for flow sampling on GigabitEthernet 1/0/2.
[DeviceA-GigabitEthernet1/0/2] sflow flow collector 1
Configuring Device B
# Create VLAN 20. Assign GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to VLAN 20.
[DeviceB] vlan 20
[DeviceB-vlan20] port gigabitethernet 1/0/1 to gigabitethernet 1/0/2
[DeviceB-vlan20] quit
# Assign an IP address to VLAN-interface 20.
[DeviceB] interface vlan-interface 20
[DeviceB-Vlan-interface20] ip address 20.1.1.1 255.255.255.0
[DeviceB-Vlan-interface20] quit
[DeviceB] sflow agent ip 20.1.1.1
[DeviceB] sflow collector 1 ip 30.1.1.2 port 5000
# Enable counter sampling and set the counter sampling interval to 30 seconds on GigabitEthernet 1/0/1.
[DeviceB-GigabitEthernet1/0/1] sflow counter interval 30
[DeviceB-GigabitEthernet1/0/1] sflow counter collector 1
# Enable flow sampling and set the sampling interval to 20000 on GigabitEthernet 1/0/1.
[DeviceB-GigabitEthernet1/0/1] sflow sampling-rate 20000
[DeviceB-GigabitEthernet1/0/1] sflow flow collector 1
# Verify the following items on Device A:
·     GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 enabled with sFlow are active.
·     The counter sampling interval is 120 seconds.
·     The flow sampling interval is 10000.
[DeviceA] display sflow
sFlow datagram version: 5
Global information:
Agent IP: 10.1.1.1(CLI)
Source address:
Collector information:
ID    IP              Port  Aging      Size VPN-instance Description
1     30.1.1.2        5000  N/A        1400              CLI Collector
Port counter sampling information:
Interface   Instance   CID   Interval(s)
GE1/0/1     1          1     120
GE1/0/2     1          1     120
Port flow sampling information:
Interface   Instance   FID   MaxHLen Rate       Mode      Status
GE1/0/1     1          1     128     10000      Random    Active
GE1/0/2     1          1     128     10000      Random    Active
Configuration files
IMPORTANT
IMPORTANT:
Support for the port link-mode bridge command depends on the device model.
·     Device A:
vlan 10
interface Vlan-interface10
 sflow collector 1 ip 30.1.1.2 port 5000 description "CLI Collector"
 port access vlan 10
 port access vlan 10
 port access vlan 10
·     Device B:
vlan 20
interface Vlan-interface20
 port access vlan 20
 port access vlan 20
不同款型规格的资料略有差异, 详细信息请向具体销售和400咨询。 H3C保留在没有任何通知或提示的情况下对资料内容进行修改的权利!
