H3C Fixed Port Campus Switches Configuration Examples-6W105
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-6W105
Table of Contents
Related Documents
81-EVPN Multicast Configuration Examples
Example: Configuring Layer 2 EVPN multicast
As shown in Figure 1, configure Layer 2 EVPN multicast as follows:
·     Configure Leaf 1 and Leaf 2 as distributed EVPN gateways. Assign the multicast receivers attached to Leaf 1 and the multicast source attached to Leaf 2 to VXLAN 10.
·     Configure Leaf 1, Leaf 2, and the RR to set up BGP EVPN peer relationships in AS 65000 of the overlay network. Configure the RR to reflect BGP EVPN routes between Leaf 1 and Leaf 2.
·     Configure OSPF on Leaf 1, Leaf 2, and the RR for them to have Layer 3 connectivity on the underlay network.
Figure 1 Network diagram
Analysis
To enable Layer 2 multicast forwarding in the EVPN network, perform the following tasks:
·     Enable IGMP snooping on the leaf devices for them to snoop the IGMP membership reports sent by the multicast receivers.
·     For the leaf devices to create Layer 2 multicast forwarding entries, configure the leaf devices to advertise multicast group join requests through selective multicast Ethernet tag (SMET) routes.
Hardware
Software version
S6812 switch series
S6813 switch series
Release 6615Pxx, Release 6628Pxx
S6550XE-HI switch series
Not supported
S6525XE-HI switch series
Not supported
S5850 switch series
Not supported
S5570S-EI switch series
Not supported
S5560X-EI switch series
Release 65xx, Release 6615Pxx, Release 6628Pxx
S5560X-HI switch series
S5500V2-EI switch series
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S switch
MS4520V2-24TP switch
Not supported
S6520X-HI switch series
S6520X-EI switch series
S6520X-SI switch series
S6520-SI switch series
S5000-EI switch series
MS4600 switch series
ES5500 switch series
S5560S-EI switch series
S5560S-SI switch series
Not supported
S5500V3-24P-SI switch
S5500V3-48P-SI switch
Not supported
S5500V3-SI switch series (except S5500V3-24P-SI and S5500V3-48P-SI)
Not supported
S5170-EI switch series
Not supported
S5130S-HI switch series
S5130S-EI switch series
S5130S-SI switch series
S5130S-LI switch series
Not supported
S5120V2-SI switch series
S5120V2-LI switch series
Not supported
S5120V3-EI switch series
Not supported
S5120V3-36F-SI switch
S5120V3-28P-HPWR-SI switch
S5120V3-54P-PWR-SI switch
Not supported
S5120V3-SI switch series (except S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI)
Not supported
S5120V3-LI switch series
Not supported
S3600V3-EI switch series
Not supported
S3600V3-SI switch series
Not supported
S3100V3-EI switch series
S3100V3-SI switch series
Not supported
S5110V2 switch series
Not supported
S5110V2-SI switch series
Not supported
S5000V3-EI switch series
S5000V5-EI switch series
Not supported
S5000E-X switch series
S5000X-EI switch series
Not supported
E128C switch
E152C switch
E500C switch series
E500D switch series
Not supported
MS4320V2 switch series
MS4320V3 switch series
MS4300V2 switch series
MS4320 switch series
MS4200 switch series
Not supported
WS5850-WiNet switch series
Not supported
WS5820-WiNet switch series
WS5810-WiNet switch series
Not supported
WAS6000 switch series
Not supported
IE4300-12P-AC switch
IE4300-12P-PWR switch
IE4300-M switch series
IE4320 switch series
Not supported
IE4520 switch series
Release 66xx
S5135S-EI switch
Not supported
IGMP snooping restrictions and guideline
IGMP snooping configuration in a VSI takes effect only on the member ports in the VSI.
In an EVPN VXLAN network, the IGMP snooping querier in a VSI does not include VLAN tags in IGMP general queries. As a best practice, do not enable the IGMP snooping querier in a VSI if the VSI uses the Ethernet access mode.
Distributed EVPN gateway restrictions and guideline
When you configure VSI interfaces on distributed EVPN gateways, follow these restrictions and guidelines:
·     Do not assign reserved MAC addresses to VSI interfaces.
·     You must assign the same MAC address to the VSI interfaces with L3 VXLAN IDs associated
·     If you use the mac-address command to modify the MAC address of a L3 VXLAN ID associated VSI interface on a DR system, also modify the MAC address of the other L3 VXLAN ID associated VSI interfaces. These VSI interfaces must use the same MAC address.
·     If a distributed EVPN gateway is connected to an IPv6 site, make sure the VSI interfaces with L3 VXLAN IDs associated use the same link-local address.
·     On different distributed EVPN gateways, the VSI interface of a VXLAN must use the same IP address and MAC address to provide services.
·     The L3 VXLAN ID of a VSI interface cannot be the same as the VXLAN ID specified by using the mapping vni command.
·     As a best practice, do not use ARP flood suppression and local proxy ARP or ND flood suppression and local ND proxy together on distributed EVPN gateways. If both ARP flood suppression and local proxy ARP are enabled on a distributed EVPN gateway, only local proxy ARP takes effect. If both ND flood suppression and local ND proxy are enabled on a distributed EVPN gateway, only local ND proxy takes effect.
Procedures
Configuring Leaf 1
Setting the system operating mode to VXLAN
# Set system operating mode to VXLAN, save the running configuration, and reboot the device.
[Sysname] switch-mode 1
Reboot device to make the configuration take effect.
[Sysname] quit
<Sysname> reboot
Start to check configuration with next startup configuration file, please wait..
.......DONE!
Current configuration may be lost after the reboot, save current configuration?
[Y/N]:y
Assigning IP addresses and configuring unicast routing
# Assign IP addresses to loopback interfaces and GigabitEthernet 1/0/3.
[Sysname] sysname Leaf1
[Leaf1] interface loopback 0
[Leaf1-LoopBack0] ip address 172.16.0.1 255.255.255.255
[Leaf1-LoopBack0] quit
[Leaf1] interface gigabitethernet 1/0/3
[Leaf1-GigabitEthernet1/0/3] port link-mode route
[Leaf1-GigabitEthernet1/0/3] ip address 12.1.1.1 24
[Leaf1-GigabitEthernet1/0/3] quit
# Configure OSPF for the devices to communicate at Layer 3 over the underlay network.
[Leaf1] router id 172.16.0.1
[Leaf1] ospf
[Leaf1-ospf-1] area 0
[Leaf1-ospf-1-area-0.0.0.0] network 172.16.0.1 0.0.0.0
[Leaf1-ospf-1-area-0.0.0.0] network 12.1.1.1 0.0.0.255
[Leaf1-ospf-1-area-0.0.0.0] quit
[Leaf1-ospf-1] quit
Configuring a VPN instance
# Create VPN instance vpn1 and configure an RD and route targets for it.
[Leaf1] ip vpn-instance vpn1
[Leaf1-vpn-instance-vpn1] route-distinguisher 1:1
[Leaf1-vpn-instance-vpn1] address-family ipv4
[Leaf1-vpn-ipv4-vpn1] vpn-target 2:2 import-extcommunity
[Leaf1-vpn-ipv4-vpn1] vpn-target 2:2 export-extcommunity
[Leaf1-vpn-ipv4-vpn1] quit
[Leaf1-vpn-instance-vpn1] address-family evpn
[Leaf1-vpn-evpn-vpn1] vpn-target 1:1 import-extcommunity
[Leaf1-vpn-evpn-vpn1] vpn-target 1:1 export-extcommunity
[Leaf1-vpn-evpn-vpn1] quit
[Leaf1-vpn-instance-vpn1] quit
Configuring a VSI interface
# Enable L2VPN.
[Leaf1] l2vpn enable
# Configure VSI interface 1.
[Leaf1] interface vsi-interface 1
[Leaf1-Vsi-interface1] ip binding vpn-instance vpn1
[Leaf1-Vsi-interface1] ip address 10.255.255.254 255.0.0.0
[Leaf1-Vsi-interface1] mac-address 0000-0001-0001
[Leaf1-Vsi-interface1] distributed-gateway local
[Leaf1-Vsi-interface1] quit
Configuring an EVPN instance
# Disable remote MAC address learning and remote ARP learning.
[Leaf1] vxlan tunnel mac-learning disable
[Leaf1] vxlan tunnel arp-learning disable
# Create VXLAN 10 on VSI vsi1, and specify VSI interface 1 as the gateway for the VXLAN.
[Leaf1] vsi vsi1
[Leaf1-vsi-vsi1] gateway vsi-interface 1
[Leaf1-vsi-vsi1] statistics enable
[Leaf1-vsi-vsi1] arp suppression enable
[Leaf1-vsi-vsi1] vxlan 10
[Leaf1-vsi-vsi1-vxlan-10] quit
# Configure an EVPN instance using VXLAN encapsulation, and configure an RD and route targets for it.
[Leaf1-vsi-vsi1] evpn encapsulation vxlan
[Leaf1-vsi-vsi1-evpn-vxlan] route-distinguisher auto
[Leaf1-vsi-vsi1-evpn-vxlan] vpn-target auto export-extcommunity
[Leaf1-vsi-vsi1-evpn-vxlan] vpn-target auto import-extcommunity
[Leaf1-vsi-vsi1-evpn-vxlan] quit
[Leaf1-vsi-vsi1] quit
Assigning L3 VXLAN IDs
# Assign a L3 VXLAN ID to VSI interface 2.
[Leaf1] interface vsi-interface 2
[Leaf1-Vsi-interface2] ip binding vpn-instance vpn1
[Leaf1-Vsi-interface2] l3-vni 10000
[Leaf1-Vsi-interface2] quit
Configuring BGP EVPN route advertisement
# Configure Leaf 1 to establish a BGP EVPN peer relationship with the RR.
[Leaf1] bgp 65000
[Leaf1-bgp-default] peer 172.16.10.1 as-number 65000
[Leaf1-bgp-default] peer 172.16.10.1 connect-interface loopback 0
[Leaf1-bgp-default] peer 172.16.10.1 password simple overlay
[Leaf1-bgp-default] address-family l2vpn evpn
[Leaf1-bgp-default-evpn] peer 172.16.10.1 enable
[Leaf1-bgp-default-evpn] quit
[Leaf1-bgp-default] quit
Mapping ACs to the VSI
# On GigabitEthernet 1/0/1, create Ethernet service instance 1 and map it to VSI vsi1.
[Leaf1] interface gigabitethernet 1/0/1
[Leaf1-GigabitEthernet1/0/1] port link-mode bridge
[Leaf1-GigabitEthernet1/0/1] port link-type trunk
[Leaf1-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[Leaf1-GigabitEthernet1/0/1] port trunk permit vlan 1000
[Leaf1-GigabitEthernet1/0/1] service-instance 1
[Leaf1-GigabitEthernet1/0/1-srv1] encapsulation s-vid 1000
[Leaf1-GigabitEthernet1/0/1-srv1] statistics enable
[Leaf1-GigabitEthernet1/0/1-srv1] xconnect vsi vsi1
[Leaf1-GigabitEthernet1/0/1-srv1] quit
[Leaf1-GigabitEthernet1/0/1] quit
# On GigabitEthernet 1/0/2, create Ethernet service instance 1 and map it to VSI vsi1.
[Leaf1] interface gigabitethernet 1/0/2
[Leaf1-GigabitEthernet1/0/2] port link-mode bridge
[Leaf1-GigabitEthernet1/0/2] port link-type trunk
[Leaf1-GigabitEthernet1/0/2] undo port trunk permit vlan 1
[Leaf1-GigabitEthernet1/0/2] port trunk permit vlan 1001
[Leaf1-GigabitEthernet1/0/2] service-instance 1
[Leaf1-GigabitEthernet1/0/2-srv1] encapsulation s-vid 1001
[Leaf1-GigabitEthernet1/0/2-srv1] statistics enable
[Leaf1-GigabitEthernet1/0/2-srv1] xconnect vsi vsi1
[Leaf1-GigabitEthernet1/0/2-srv1] quit
[Leaf1-GigabitEthernet1/0/2] quit
Configuring IGMP snooping
# Enable IGMP snooping globally.
[Leaf1] igmp-snooping
[Leaf1-igmp-snooping] global-enable
[Leaf1-igmp-snooping] quit
# Configure IGMP snooping for VSI vsi1.
[Leaf1] vsi vsi1
[Leaf1-vsi-vsi1] igmp-snooping enable
[Leaf1-vsi-vsi1] igmp-snooping drop-unknown
[Leaf1-vsi-vsi1] igmp-snooping proxy enable
# Configure Leaf 2 as an IGMP querier.
[Leaf1-vsi-vsi1] igmp-snooping querier
Configuring Leaf 2
[Sysname] quit
<Sysname> reboot
.......DONE!
[Y/N]:y
[Sysname] sysname Leaf2
[Leaf2] interface loopback 0
[Leaf2-LoopBack0] ip address 172.16.0.2 255.255.255.255
[Leaf2-LoopBack0] quit
[Leaf2] interface gigabitethernet 1/0/3
[Leaf2-GigabitEthernet1/0/3] port link-mode route
[Leaf2-GigabitEthernet1/0/3] ip address 13.1.1.2 24
[Leaf2-GigabitEthernet1/0/3] quit
[Leaf2] router id 172.16.0.2
[Leaf2] ospf
[Leaf2-ospf-1] area 0
[Leaf2-ospf-1-area-0.0.0.0] network 172.16.0.2 0.0.0.0
[Leaf2-ospf-1-area-0.0.0.0] network 13.1.1.2 0.0.0.255
[Leaf2-ospf-1-area-0.0.0.0] quit
[Leaf2-ospf-1] quit
[Leaf2] ip vpn-instance vpn1
[Leaf2-vpn-instance-vpn1] route-distinguisher 1:1
[Leaf2-vpn-instance-vpn1] address-family ipv4
[Leaf2-vpn-ipv4-vpn1] vpn-target 2:2 import-extcommunity
[Leaf2-vpn-ipv4-vpn1] vpn-target 2:2 export-extcommunity
[Leaf2-vpn-ipv4-vpn1] quit
[Leaf2-vpn-instance-vpn1] address-family evpn
[Leaf2-vpn-evpn-vpn1] vpn-target 1:1 import-extcommunity
[Leaf2-vpn-evpn-vpn1] vpn-target 1:1 export-extcommunity
[Leaf2-vpn-evpn-vpn1] quit
[Leaf2-vpn-instance-vpn1] quit
# Enable L2VPN.
[Leaf2] l2vpn enable
[Leaf2] interface vsi-interface 1
[Leaf2-Vsi-interface1] ip binding vpn-instance vpn1
[Leaf2-Vsi-interface1] ip address 10.255.255.254 255.0.0.0
[Leaf2-Vsi-interface1] mac-address 0000-0001-0001
[Leaf2-Vsi-interface1] distributed-gateway local
[Leaf2-Vsi-interface1] quit
[Leaf2] vxlan tunnel mac-learning disable
[Leaf2] vxlan tunnel arp-learning disable
[Leaf2] vsi vsi1
[Leaf2-vsi-vsi1] gateway vsi-interface 1
[Leaf2-vsi-vsi1] statistics enable
[Leaf2-vsi-vsi1] arp suppression enable
[Leaf2-vsi-vsi1] vxlan 10
[Leaf2-vsi-vsi1-vxlan-10] quit
[Leaf2-vsi-vsi1] evpn encapsulation vxlan
[Leaf2-vsi-vsi1-evpn-vxlan] route-distinguisher auto
[Leaf2-vsi-vsi1-evpn-vxlan] vpn-target auto export-extcommunity
[Leaf2-vsi-vsi1-evpn-vxlan] vpn-target auto import-extcommunity
[Leaf2-vsi-vsi1-evpn-vxlan] quit
[Leaf2-vsi-vsi1] quit
[Leaf2] interface vsi-interface 10000
[Leaf2-Vsi-interface10000] ip binding vpn-instance vpn1
[Leaf2-Vsi-interface10000] l3-vni 10000
[Leaf2-Vsi-interface10000] quit
# Configure Leaf 2 to establish a BGP EVPN peer relationship with the RR.
[Leaf2] bgp 65000
[Leaf2-bgp-default] peer 172.16.10.1 as-number 65000
[Leaf2-bgp-default] peer 172.16.10.1 connect-interface loopback 0
[Leaf2-bgp-default] peer 172.16.10.1 password simple overlay
[Leaf2-bgp-default] address-family l2vpn evpn
[Leaf2-bgp-default-evpn] peer 172.16.10.1 enable
[Leaf2-bgp-default-evpn] quit
[Leaf2-bgp-default] quit
[Leaf2] interface gigabitethernet 1/0/1
[Leaf2-GigabitEthernet1/0/1] port link-mode bridge
[Leaf2-GigabitEthernet1/0/1] port link-type trunk
[Leaf2-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[Leaf2-GigabitEthernet1/0/1] port trunk permit vlan 1002
[Leaf2-GigabitEthernet1/0/1] storm-constrain control shutdown
[Leaf2-GigabitEthernet1/0/1] service-instance 1
[Leaf2-GigabitEthernet1/0/1-srv1] encapsulation s-vid 1002
[Leaf2-GigabitEthernet1/0/1-srv1] statistics enable
[Leaf2-GigabitEthernet1/0/1-srv1] xconnect vsi vsi1
[Leaf2-GigabitEthernet1/0/1-srv1] quit
[Leaf2-GigabitEthernet1/0/1] quit
[Leaf2] vsi vsi1
[Leaf2-vsi-vsi1] igmp-snooping enable
[Leaf2-vsi-vsi1] igmp-snooping drop-unknown
[Leaf2-vsi-vsi1] igmp-snooping proxy enable
[Leaf2-vsi-vsi1] igmp-snooping querier
Configuring the RR
[Sysname] quit
<Sysname> reboot
.......DONE!
[Y/N]:y
# Assign IP addresses to loopback interfaces, GigabitEthernet 1/0/1, and GigabitEthernet 1/0/2.
[Sysname] sysname RR
[RR] interface loopback 0
[RR-LoopBack0] ip address 172.16.10.1 255.255.255.255
[RR-LoopBack0] quit
[RR] interface gigabitethernet 1/0/1
[RR-GigabitEthernet1/0/1] port link-mode route
[RR-GigabitEthernet1/0/1] ip address 12.1.1.3 24
[RR-GigabitEthernet1/0/1] quit
[RR] interface gigabitethernet 1/0/2
[RR-GigabitEthernet1/0/2] port link-mode route
[RR-GigabitEthernet1/0/2] ip address 13.1.1.3 24
[RR-GigabitEthernet1/0/2] quit
[RR] router id 172.16.10.1
[RR] ospf
[RR-ospf-1] area 0
[RR-ospf-1-area-0.0.0.0] network 172.16.10.1 0.0.0.0
[RR-ospf-1-area-0.0.0.0] network 12.1.1.3 0.0.0.255
[RR-ospf-1-area-0.0.0.0] network 13.1.1.3 0.0.0.255
[RR-ospf-1-area-0.0.0.0] quit
[RR-ospf-1] quit
# Assign Leaf 1 and Leaf 2 to IBGP peer group leaf.
[RR] bgp 65000
[RR-bgp-default] group leaf internal
[RR-bgp-default] peer leaf connect-interface loopback 0
[RR-bgp-default] peer leaf password simple overlay
[RR-bgp-default] peer 172.16.0.1 group leaf
[RR-bgp-default] peer 172.16.0.2 group leaf
# Configure the device as an RR, configure it to establish BGP EVPN peer relationships with IBGP peer group leaf, and disable route target filtering of received BGP EVPN routes.
[RR-bgp-default] address-family l2vpn evpn
[RR-bgp-default-evpn] undo policy vpn-target
[RR-bgp-default-evpn] peer leaf enable
[RR-bgp-default-evpn] peer leaf reflect-client
[RR-bgp-default-evpn] quit
[RR-bgp-default] quit
Verifying routing information
# Verify that the leaf devices and the RR have learned one another's OSPF routes and can communicate at Layer 3 over the underlay network.
[Leaf1] display ip routing-table
Destinations : 16       Routes : 16
12.1.1.0/24        Direct  0   0           12.1.1.1        GE1/0/3
12.1.1.0/32        Direct  0   0           12.1.1.1        GE1/0/3
12.1.1.1/32        Direct  0   0           127.0.0.1       InLoop0
12.1.1.255/32      Direct  0   0           12.1.1.1        GE1/0/3
13.1.1.0/24        O_INTRA 10  2           12.1.1.3        GE1/0/3
127.0.0.0/8        Direct  0   0           127.0.0.1       InLoop0
127.0.0.0/32       Direct  0   0           127.0.0.1       InLoop0
172.16.0.1/32      Direct  0   0           127.0.0.1       InLoop0
172.16.0.2/32      O_INTRA 10  2           12.1.1.3        GE1/0/3
172.16.10.1/32     O_INTRA 10  1           12.1.1.3        GE1/0/3
224.0.0.0/4        Direct  0   0           0.0.0.0         NULL0
224.0.0.0/24       Direct  0   0           0.0.0.0         NULL0
255.255.255.255/32 Direct  0   0           127.0.0.1       InLoop0
# Verify that the leaf devices and the RR have established BGP EVPN peer relationships with one another.
[Leaf1] display bgp peer l2vpn evpn
 BGP local router ID: 172.16.0.1
 Local AS number: 65000
 Total number of peers: 1                 Peers in established state: 1
  * - Dynamically created peer
  ^ - Peer created through link-local address
  172.16.10.1          65000       24       27    0       4 00:14:59 Established
Verifying VSI configuration
# Verify that VXLAN tunnels and ACs are correctly mapped to VSI vsi1.
[Leaf1] display l2vpn vsi verbose
VSI Name: Auto_L3VNI10000_2
  VSI Index               : 1
  VSI State               : Down
  Bandwidth               : -
  Broadcast Restrain      : -
  Multicast Restrain      : -
  Unknown Unicast Restrain: -
  MAC Table Limit         : -
  MAC Learning rate       : -
  Drop Unknown            : -
  Statistics              : Disabled
  Gateway Interface       : VSI-interface 2
  VXLAN ID                : 10000
VSI Name: vsi1
  VSI Index               : 0
  VSI State               : Up
  Bandwidth               : -
  MAC Table Limit         : -
  Drop Unknown            : -
  Statistics              : Enabled
  Input Statistics        :
    Octets   :0
    Packets  :0
    Errors   :0
    Discards :0
  Output Statistics       :
    Octets   :0
    Packets  :0
    Errors   :0
    Discards :0
  Gateway Interface       : VSI-interface 1
  VXLAN ID                : 10
  Tunnels:
    Tunnel Name          Link ID    State    Type        Flood proxy
    Tunnel0              0x5000000  UP       Auto        Disabled
  ACs:
    AC                                 Link ID    State       Type
    GE1/0/1 srv1                       0          Up          Manual
    GE1/0/2 srv1                       1          Up          Manual
Verifying IGMP snooping and SMET routes
# Verify that IGMP snooping is enabled on a per-VSI basis on the leaf devices.
[Leaf1] display igmp-snooping vsi vsi1
IGMP snooping information: VSI vsi1
 IGMP snooping: Enabled
 Drop-unknown: Enabled
 Version: 2
 Host-aging-time: 260s
 Router-aging-time: 260s
 Max-response-time: 10s
 Last-member-query-interval: 1s
 Querier: Enabled (IP:10.255.255.254, Expires: 00:01:39)
 Querier-election: Disabled
 Query-interval: 125s
 General-query source IP: 10.255.255.254
 Special-query source IP: 10.255.255.254
 Report source IP: 10.255.255.254
 Leave source IP: 10.255.255.254
 Proxy: Enabled
 IPP: -(Link ID: 0xffff)
# Verify that Leaf 1 has a dynamic IGMP snooping group entry for multicast group (0.0.0.0, 225.0.0.1).
[Leaf1] display igmp-snooping group
Total 1 entries.
VSI vsi1: Total 1 entries.
    Host ports (1 in total):
      GE1/0/1 (Link ID 0)                        (00:03:42)
# Verify that Leaf 1 has created an SMET route.
[Leaf1] display evpn route smet
VSI name: vsi1
  Source address :
  Group address  : 225.0.0.1
  Local version  : v2
  ACs   :
    AC                               Link ID    Flags
    GE1/0/1 srv1                     0          Local
# Verify that Leaf 2 has received the SMET route created by Leaf 1.
[Leaf2] display evpn route smet
VSI name: vsi1
  Source address :
  Local version  : -
  Peers :
    Nexthop          Tunnel name     Link ID    Remote version
    172.16.0.1       Tunnel0         0x5000000  v2
[Leaf2] display igmp-snooping evpn-group
Total 1 entries.
      Tun0 (VXLAN ID 10)
Configuration files
·     Leaf 1:
 sysname Leaf1
 address-family ipv4
 address-family evpn
ospf 1
 area 0.0.0.0
  network 12.1.1.0 0.0.0.255
igmp-snooping
 global-enable
 l2vpn enable
vsi vsi1
 statistics enable
 vxlan 10
 service-instance 1
  statistics enable
  xconnect vsi vsi1
 service-instance 1
  statistics enable
  xconnect vsi vsi1
interface LoopBack0
 combo enable copper
 ip address 12.1.1.1 255.255.255.0
interface Vsi-interface1
interface Vsi-interface2
 l3-vni 10000
bgp 65000
 peer 172.16.10.1 connect-interface LoopBack0
 peer 172.16.10.1 password cipher $c$3$cLxsbhBfj0xOTCgIQD1N6k3oJBamRAhZ5d8=
return
·     Leaf 2:
 sysname Leaf2
 address-family ipv4
 address-family evpn
ospf 1
 area 0.0.0.0
  network 13.1.1.0 0.0.0.255
igmp-snooping
 global-enable
 l2vpn enable
vsi vsi1
 statistics enable
 vxlan 10
interface LoopBack0
 service-instance 1
  statistics enable
  xconnect vsi vsi1
 ip address 13.1.1.1 255.255.255.0
 l3-vni 10000
bgp 65000
 peer 172.16.10.1 password cipher $c$3$saE3frSy9IuWBPp1FJT7L952YRagb0D9Ioo=
return
·     RR:
 sysname RR
ospf 1
 area 0.0.0.0
interface LoopBack0
 ip address 12.1.1.3 255.255.255.0
 ip address 13.1.1.3 255.255.255.0
bgp 65000
 group leaf internal
 peer leaf connect-interface LoopBack0
 peer leaf password cipher $c$3$91PuaavWEYHlqhaILQV5i5G828J3vG+g67I=
  peer leaf enable
return
不同款型规格的资料略有差异, 详细信息请向具体销售和400咨询。 H3C保留在没有任何通知或提示的情况下对资料内容进行修改的权利!
