H3C Fixed Port Campus Switches Configuration Examples-6W105
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-6W105
Table of Contents
Related Documents
12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
Introduction
This document provides examples for configuring cross-subnet dynamic IP address allocation.
This document assumes that you have basic knowledge of DHCP.
Example: Configuring cross-subnet dynamic IP address allocation
As shown in Figure 1, a company's branches are on a different subnet from the headquarters. Device A acts as the gateway of the headquarters and Device B acts as the gateway for the branches.
Configure DHCP server on Device A to meet the following requirements:
·     The hosts at the headquarters obtain IP addresses in the range of 10.1.1.2 to 10.1.1.100.
·     The hosts at branch 1 obtain IP addresses in the range of 10.1.3.2 to 10.1.3.48. The hosts at branch 2 obtain IP addresses in the range of 10.1.3.49 to 10.1.3.100.
·     The hosts at the headquarters and branches obtain the DNS server address, the TFTP server address, the domain name suffix, and the gateway address through DHCP.
Configure DHCP relay agent on Device B to meet the following requirements:
·     The hosts at the branches obtain IP addresses and other configuration parameters from the DHCP server.
·     The hosts at the branches cannot access the network by using manually configured IP addresses.
·     The hosts at each branch obtain IP addresses from the address range assigned to the branch.
Figure 1 Network diagram
Device
IP address
Device
IP address
Device A
Vlan-int3
10.1.1.1/24
Device B
Vlan-int3
10.1.3.1/24
Vlan-int2
10.1.2.1/24
Vlan-int2
10.1.2.2/24
Analysis
To meet the network requirements, you must perform the following tasks:
·     Exclude the IP addresses of the DNS server and TFTP server from dynamic address allocation to prevent them from being assigned to hosts.
·     To prevent the hosts at the branches from using manually configured IP addresses to access the network, perform the following tasks:
¡     Enable the DHCP relay agent to record client information in DHCP relay entries.
¡     Enable IP source guard to filter incoming packets based on the DHCP relay entries.
·     To make sure the hosts in each branch obtain IP addresses from the address range assigned to the branch, perform the following tasks:
¡     Configure Option 82 on the DHCP relay agent.
¡     Create DHCP user classes for the branches and configure match rules based on Option 82 to match the branches on the DHCP server.
Hardware
Software version
S6812 switch series
S6813 switch series
Release 6615Pxx, Release 6628Pxx
S6550XE-HI switch series
Release 6008 and later, Release 8106Pxx
S6525XE-HI switch series
S5850 switch series
Release 8005 and later, Release 8106Pxx
S5570S-EI switch series
Release 11xx
S5560X-EI switch series
Release 63xx, Release 65xx, Release 6615Pxx, Release 6628Pxx
S5560X-HI switch series
S5500V2-EI switch series
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S switch
MS4520V2-24TP switch
Release 63xx
S6520X-HI switch series
S6520X-EI switch series
S6520X-SI switch series
S6520-SI switch series
S5000-EI switch series
MS4600 switch series
ES5500 switch series
S5560S-EI switch series
S5560S-SI switch series
Release 63xx
S5500V3-24P-SI
S5500V3-48P-SI
Release 63xx
S5500V3-SI switch series (except S5500V3-24P-SI and S5500V3-48P-SI)
Release 11xx
S5170-EI switch series
Release 11xx
S5130S-HI switch series
S5130S-EI switch series
S5130S-SI switch series
S5130S-LI switch series
Release 63xx
S5120V2-SI switch series
S5120V2-LI switch series
Release 63xx
S5120V3-EI switch series
Release 11xx
S5120V3-36F-SI
S5120V3-28P-HPWR-SI
S5120V3-54P-PWR-SI
Release 11xx
S5120V3-SI switch series (except S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI)
Release 63xx
S5120V3-LI switch series
Release 63xx
S3600V3-EI switch series
Release 11xx
S3600V3-SI switch series
Release 11xx
S3100V3-EI switch series
S3100V3-SI switch series
Release 63xx
S5110V2 switch series
Release 63xx
S5110V2-SI switch series
Not supported
S5000V3-EI switch series
S5000V5-EI switch series
Not supported
S5000E-X switch series
S5000X-EI switch series
Not supported
E128C switch
E152C switch
E500C switch series
E500D switch series
Release 63xx
MS4320V2 switch series
MS4320V3 switch series
MS4300V2 switch series
MS4320 switch series
MS4200 switch series
Release 63xx
WS5850-WiNet switch series
Release 63xx
WS5820-WiNet switch series
WS5810-WiNet switch series
Release 63xx
WAS6000 switch series
Not supported
IE4300-12P-AC switch
IE4300-12P-PWR switch
IE4300-M switch series
IE4320 switch series
Release 63xx
IE4520 switch series
Release 66xx
S5135S-EI switch
Release 6810 and later
To ensure correct DHCP address allocation by using Option 82, you must perform Option 82 configuration on both the DHCP server and the DHCP relay agent.
Procedures
Configuring Device A
# Assign GigabitEthernet 1/0/2 to VLAN 2.
[DeviceA] vlan 2
[DeviceA-vlan2] port gigabitethernet 1/0/2
[DeviceA-vlan2] quit
# Assign an IP address to VLAN-interface 2.
[DeviceA] interface vlan-interface 2
[DeviceA-Vlan-interface2] ip address 10.1.2.1 24
[DeviceA-Vlan-interface2] quit
# Assign GigabitEthernet 1/0/1 to VLAN 3.
[DeviceA] vlan 3
[DeviceA-vlan3] port gigabitethernet 1/0/1
[DeviceA-vlan3] quit
# Assign an IP address to VLAN-interface 3.
[DeviceA] interface vlan-interface 3
[DeviceA-Vlan-interface3] ip address 10.1.1.1 24
[DeviceA-Vlan-interface3] quit
# Enable DHCP.
[DeviceA] dhcp enable
# Enable DHCP server on VLAN-interface 2.
[DeviceA-Vlan-interface2] dhcp select server
# Enable DHCP server on VLAN-interface 3.
[DeviceA-Vlan-interface3] dhcp select server
# Create DHCP address pool 1.
[DeviceA] dhcp server ip-pool 1
# Specify the subnet and address range for dynamic address allocation.
[DeviceA-dhcp-pool-1] network 10.1.1.0 mask 255.255.255.0
[DeviceA-dhcp-pool-1] address range 10.1.1.2 10.1.1.100
# Specify the DNS server address, TFTP server address, domain name suffix, and gateway address to be assigned to clients.
[DeviceA-dhcp-pool-1] dns-list 10.1.1.3
[DeviceA-dhcp-pool-1] tftp-server ip-address 10.1.1.4
[DeviceA-dhcp-pool-1] domain-name com
[DeviceA-dhcp-pool-1] gateway-list 10.1.1.1
# Exclude the IP addresses of the DNS server and TFTP server from dynamic address allocation.
[DeviceA-dhcp-pool-1] forbidden-ip 10.1.1.3 10.1.1.4
[DeviceA-dhcp-pool-1] quit
# Apply the DHCP address pool to VLAN-interface 3.
[DeviceA-Vlan-interface3] dhcp server apply ip-pool 1
# Create DHCP user class aa for the hosts at branch 1. Configure a match rule to match DHCP requests in which the fifth and sixth bytes of Option 82 are 0x0001. The string 0x0001 indicates that the clients are connected to interface GigabitEthernet 1/0/1.
[DeviceA] dhcp class aa
[DeviceA-dhcp-class-aa] if-match option 82 hex 0001 offset 4 length 2
[DeviceA-dhcp-class-aa] quit
# Create DHCP user class bb for the hosts at branch 2. Configure a match rule to match DHCP requests in which the fifth and sixth bytes of Option 82 are 0x0003. The string 0x0003 indicates that the clients are connected to interface GigabitEthernet 1/0/3.
[DeviceA] dhcp class bb
[DeviceA-dhcp-class-bb] if-match option 82 hex 0003 offset 4 length 2
[DeviceA-dhcp-class-bb] quit
# Create DHCP address pool 2.
[DeviceA] dhcp server ip-pool 2
# Specify the subnet for dynamic address allocation.
[DeviceA-dhcp-pool-2] network 10.1.3.0 mask 255.255.255.0
# Specify address range 10.1.3.2 to 10.1.3.48 for DHCP user class aa.
[DeviceA-dhcp-pool-2] class aa range 10.1.3.2 10.1.3.48
# Specify address range 10.1.3.49 to 10.1.3.100 for DHCP user class bb.
[DeviceA-dhcp-pool-2] class bb range 10.1.3.49 10.1.3.100
[DeviceA-dhcp-pool-2] tftp-server ip-address 10.1.1.4
[DeviceA-dhcp-pool-2] dns-list 10.1.1.3
[DeviceA-dhcp-pool-2] domain-name com
[DeviceA-dhcp-pool-2] gateway-list 10.1.3.1
[DeviceA-dhcp-pool-2] quit
# Apply the DHCP address pool to VLAN-interface 2.
[DeviceA-Vlan-interface2] dhcp server apply ip-pool 2
# Configure a static route to subnet 10.1.3.0/24.
[DeviceA] ip route-static 10.1.3.0 24 10.1.2.2
Configuring Device B
[DeviceB] vlan 2
[DeviceB-vlan2] port gigabitethernet 1/0/2
[DeviceB-vlan2] quit
[DeviceB] interface vlan-interface 2
[DeviceB-Vlan-interface2] ip address 10.1.2.2 24
[DeviceB-Vlan-interface2] quit
# Assign GigabitEthernet 1/0/1 and GigabitEthernet 1/0/3 to VLAN 3.
[DeviceB] vlan 3
[DeviceB-vlan3] port gigabitethernet 1/0/1
[DeviceB-vlan3] port gigabitethernet 1/0/3
[DeviceB-vlan3] quit
[DeviceB] interface vlan-interface 3
[DeviceB-Vlan-interface3] ip address 10.1.3.1 24
[DeviceB-Vlan-interface3] quit
# Enable DHCP.
[DeviceB] dhcp enable
# Enable DHCP relay agent on VLAN-interface 3.
[DeviceB-Vlan-interface3] dhcp select relay
# Specify the IP address of the DHCP server.
[DeviceB-Vlan-interface3] dhcp relay server-address 10.1.2.1
# Enable the DHCP relay agent to support Option 82.
[DeviceB-Vlan-interface3] dhcp relay information enable
# Enable recording of client information in DHCP relay entries.
[DeviceB] dhcp relay client-information record
# Enable IPv4 source guard on VLAN-interface 3 to filter incoming packets by source IPv4 addresses and source MAC addresses.
[DeviceB-Vlan-interface3] ip verify source ip-address mac-address
# Configure a static route to subnet 10.1.1.0/24.
[DeviceB] ip route-static 10.1.1.0 24 10.1.2.1
# Verify that the IP address 10.1.3.3 has been assigned to a client.
<DeviceA> display dhcp server ip-in-use ip 10.1.3.3
IP address       Client identifier/    Lease expiration      Type
                 Hardware address
10.1.3.3         0033-6365-352e-6136-  Jan  2 00:34:02 2016  Auto(C)
                 6466-2e65-3133-392d-
                 5465-6e2d-4769-6761-
                 6269-7445-7468-6572-
                 6e65-7431-2f30-2f35-
                 31
# Verify that the hosts at each branch can obtain IP addresses from the address range assigned to the branch. This example uses a host at branch 2.
C:\Documents and Settings\aa>ipconfig
Windows IP Configuration
Ethernet adapter aa:
        Connection-specific DNS Suffix  . : domain-name com
        IP Address. . . . . . . . . . . . : 10.1.3.3
        Subnet Mask . . . . . . . . . . . : 255.255.255.0
        IPv6 Address. . . . . . . . . . . : fe80::20f:3dff:fe80:2b38%4
        Default Gateway . . . . . . . . . : 10.1.3.1
# Manually assign IP address 10.1.3.87 to a host at branch 2, and verify that the host cannot access the TFTP server. (Details not shown.)
Configuration files
IMPORTANT
IMPORTANT:
Support for the port link-mode bridge command depends on the device model.
·     Device A:
 dhcp enable
vlan 2 to 3
dhcp class aa
dhcp class bb
 dns-list 10.1.1.3
 domain-name com
 forbidden-ip 10.1.1.4
 dns-list 10.1.1.3
 domain-name com
interface Vlan-interface2
 ip address 10.1.2.1 255.255.255.0
interface Vlan-interface3
 port access vlan 3
 port access vlan 2
·     Device B:
 dhcp enable
vlan 2 to 3
 ip address 10.1.2.2 255.255.255.0
 ip address 10.1.3.1 255.255.255.0
 dhcp select relay
 port access vlan 3
 port access vlan 2
 port access vlan 3
不同款型规格的资料略有差异, 详细信息请向具体销售和400咨询。 H3C保留在没有任何通知或提示的情况下对资料内容进行修改的权利!
