- H3C Fixed Port Campus Switches Configuration Examples-6W104
 - 00-Applicable hardware and software versions
 - 01-Login Management Configuration Examples
 - 02-RBAC Configuration Examples
 - 03-Software Upgrade Examples
 - 04-ISSU Configuration Examples
 - 05-Software Patching Examples
 - 06-Ethernet Link Aggregation Configuration Examples
 - 07-Port Isolation Configuration Examples
 - 08-Spanning Tree Configuration Examples
 - 09-VLAN Configuration Examples
 - 10-VLAN Tagging Configuration Examples
 - 11-DHCP Snooping Configuration Examples
 - 12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
 - 13-IPv6 over IPv4 Tunneling with OSPFv3 Configuration Examples
 - 14-IPv6 over IPv4 GRE Tunnel Configuration Examples
 - 15-GRE with OSPF Configuration Examples
 - 16-OSPF Configuration Examples
 - 17-IS-IS Configuration Examples
 - 18-BGP Configuration Examples
 - 19-Policy-Based Routing Configuration Examples
 - 20-OSPFv3 Configuration Examples
 - 21-IPv6 IS-IS Configuration Examples
 - 22-Routing Policy Configuration Examples
 - 23-IGMP Snooping Configuration Examples
 - 24-IGMP Configuration Examples
 - 25-MLD Snooping Configuration Examples
 - 26-IPv6 Multicast VLAN Configuration Examples
 - 27-ACL Configuration Examples
 - 28-Traffic Policing Configuration Examples
 - 29-GTS and Rate Limiting Configuration Examples
 - 30-Traffic Filtering Configuration Examples
 - 31-AAA Configuration Examples
 - 32-Port Security Configuration Examples
 - 33-Portal Configuration Examples
 - 34-SSH Configuration Examples
 - 35-IP Source Guard Configuration Examples
 - 36-Ethernet OAM Configuration Examples
 - 37-CFD Configuration Examples
 - 38-DLDP Configuration Examples
 - 39-VRRP Configuration Examples
 - 40-BFD Configuration Examples
 - 41-NTP Configuration Examples
 - 42-SNMP Configuration Examples
 - 43-NQA Configuration Examples
 - 44-Mirroring Configuration Examples
 - 45-sFlow Configuration Examples
 - 46-OpenFlow Configuration Examples
 - 47-MAC Address Table Configuration Examples
 - 48-Static Multicast MAC Address Entry Configuration Examples
 - 49-IP Unnumbered Configuration Examples
 - 50-MVRP Configuration Examples
 - 51-MCE Configuration Examples
 - 52-Attack Protection Configuration Examples
 - 53-Smart Link Configuration Examples
 - 54-RRPP Configuration Examples
 - 55-BGP Route Selection Configuration Examples
 - 56-IS-IS Route Summarization Configuration Examples
 - 57-VXLAN Configuration Examples
 - 58-DRNI Configuration Examples
 - 59-IRF 3.1 Configuration Examples
 - 60-PTP Configuration Examples
 - 61-S-MLAG Configuration Examples
 - 62-Puppet Configuration Examples
 - 63-802.1X Configuration Examples
 - 64-MAC Authentication Configuration Examples
 - 65-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
 - 66-BIDIR-PIM Configuration Examples
 - 67-Congestion Avoidance and Queue Scheduling Configuration Examples
 - 68-Basic MPLS Configuration Examples
 - 69-MPLS L3VPN Configuration Examples
 - 70-MPLS OAM Configuration Examples
 - 71-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
 - 72-DRNI and EVPN Configuration Examples
 - 73-Multicast VPN Configuration Examples
 - 74-MPLS TE Configuration Examples
 - 75-Control Plane-Based QoS Policy Configuration Examples
 - 76-Priority Mapping and Queue Scheduling Configuration Examples
 - 77-ARP Attack Protection Configuration Examples
 - 78-IRF Software Upgrade Configuration Examples
 - 79-IRF Member Replacement Configuration Examples
 - 80-Layer 3 Multicast on Multicast Source-Side DR System Configuration Examples
 - 81-EVPN Multicast Configuration Examples
| 81-EVPN Multicast Configuration Examples | 117.79 KB |
Example: Configuring Layer 2 EVPN multicast
IGMP snooping restrictions and guideline
Distributed EVPN gateway restrictions and guideline
Verifying IGMP snooping and SMET routes
As shown in Figure 1, configure Layer 2 EVPN multicast as follows:
· Configure Leaf 1 and Leaf 2 as distributed EVPN gateways. Assign the multicast receivers attached to Leaf 1 and the multicast source attached to Leaf 2 to VXLAN 10.
· Configure Leaf 1, Leaf 2, and the RR to set up BGP EVPN peer relationships in AS 65000 of the overlay network. Configure the RR to reflect BGP EVPN routes between Leaf 1 and Leaf 2.
· Configure OSPF on Leaf 1, Leaf 2, and the RR for them to have Layer 3 connectivity on the underlay network.
Analysis
To enable Layer 2 multicast forwarding in the EVPN network, perform the following tasks:
· Enable IGMP snooping on the leaf devices for them to snoop the IGMP membership reports sent by the multicast receivers.
· For the leaf devices to create Layer 2 multicast forwarding entries, configure the leaf devices to advertise multicast group join requests through selective multicast Ethernet tag (SMET) routes.
    Hardware  |
    Software version  |
   S6812 switch series S6813 switch series  |
   Release 6615Pxx, Release 6628Pxx  |
   S6550XE-HI switch series  |
   Not supported  |
   S6525XE-HI switch series  |
   Not supported  |
   S5850 switch series  |
   Not supported  |
   S5570S-EI switch series  |
   Not supported  |
   S5560X-EI switch series  |
   Release 65xx, Release 6615Pxx, Release 6628Pxx  |
   S5560X-HI switch series  |
   S5500V2-EI switch series  |
   MS4520V2-30F switch  |
   MS4520V2-30C switch MS4520V2-54C switch  |
   MS4520V2-28S switch MS4520V2-24TP switch  |
   Not supported  |
   S6520X-HI switch series S6520X-EI switch series  |
   S6520X-SI switch series S6520-SI switch series  |
   S5000-EI switch series  |
   MS4600 switch series  |
   ES5500 switch series  |
   S5560S-EI switch series S5560S-SI switch series  |
   Not supported  |
   S5500V3-24P-SI switch S5500V3-48P-SI switch  |
   Not supported  |
   S5500V3-SI switch series (except S5500V3-24P-SI and S5500V3-48P-SI)  |
   Not supported  |
   S5170-EI switch series  |
   Not supported  |
   S5130S-HI switch series S5130S-EI switch series S5130S-SI switch series S5130S-LI switch series  |
   Not supported  |
   S5120V2-SI switch series S5120V2-LI switch series  |
   Not supported  |
   S5120V3-EI switch series  |
   Not supported  |
   S5120V3-36F-SI switch S5120V3-28P-HPWR-SI switch S5120V3-54P-PWR-SI switch  |
   Not supported  |
   S5120V3-SI switch series (except S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI)  |
   Not supported  |
   S5120V3-LI switch series  |
   Not supported  |
   S3600V3-EI switch series  |
   Not supported  |
   S3600V3-SI switch series  |
   Not supported  |
   S3100V3-EI switch series S3100V3-SI switch series  |
   Not supported  |
   S5110V2 switch series  |
   Not supported  |
   S5110V2-SI switch series  |
   Not supported  |
   S5000V3-EI switch series S5000V5-EI switch series  |
   Not supported  |
   S5000E-X switch series S5000X-EI switch series  |
   Not supported  |
   E128C switch E152C switch E500C switch series E500D switch series  |
   Not supported  |
   MS4320V2 switch series MS4320V3 switch series MS4300V2 switch series MS4320 switch series MS4200 switch series  |
   Not supported  |
   WS5850-WiNet switch series  |
   Not supported  |
   WS5820-WiNet switch series WS5810-WiNet switch series  |
   Not supported  |
   WAS6000 switch series  |
   Not supported  |
   IE4300-12P-AC switch IE4300-12P-PWR switch IE4300-M switch series IE4320 switch series  |
   Not supported  |
IGMP snooping configuration in a VSI takes effect only on the member ports in the VSI.
In an EVPN VXLAN network, the IGMP snooping querier in a VSI does not include VLAN tags in IGMP general queries. As a best practice, do not enable the IGMP snooping querier in a VSI if the VSI uses the Ethernet access mode.
When you configure VSI interfaces on distributed EVPN gateways, follow these restrictions and guidelines:
· Do not assign reserved MAC addresses to VSI interfaces.
· You must assign the same MAC address to the VSI interfaces with L3 VXLAN IDs associated
· If you use the mac-address command to modify the MAC address of a L3 VXLAN ID associated VSI interface on a DR system, also modify the MAC address of the other L3 VXLAN ID associated VSI interfaces. These VSI interfaces must use the same MAC address.
· If a distributed EVPN gateway is connected to an IPv6 site, make sure the VSI interfaces with L3 VXLAN IDs associated use the same link-local address.
· On different distributed EVPN gateways, the VSI interface of a VXLAN must use the same IP address and MAC address to provide services.
· The L3 VXLAN ID of a VSI interface cannot be the same as the VXLAN ID specified by using the mapping vni command.
· As a best practice, do not use ARP flood suppression and local proxy ARP or ND flood suppression and local ND proxy together on distributed EVPN gateways. If both ARP flood suppression and local proxy ARP are enabled on a distributed EVPN gateway, only local proxy ARP takes effect. If both ND flood suppression and local ND proxy are enabled on a distributed EVPN gateway, only local ND proxy takes effect.
Procedures
Configuring Leaf 1
Setting the system operating mode to VXLAN
# Set system operating mode to VXLAN, save the running configuration, and reboot the device.
[Sysname] switch-mode 1
Reboot device to make the configuration take effect.
[Sysname] quit
<Sysname> reboot
Start to check configuration with next startup configuration file, please wait..
.......DONE!
Current configuration may be lost after the reboot, save current configuration?
[Y/N]:y
Assigning IP addresses and configuring unicast routing
# Assign IP addresses to loopback interfaces and GigabitEthernet 1/0/3.
[Sysname] sysname Leaf1
[Leaf1] interface loopback 0
[Leaf1-LoopBack0] ip address 172.16.0.1 255.255.255.255
[Leaf1-LoopBack0] quit
[Leaf1] interface gigabitethernet 1/0/3
[Leaf1-GigabitEthernet1/0/3] port link-mode route
[Leaf1-GigabitEthernet1/0/3] ip address 12.1.1.1 24
[Leaf1-GigabitEthernet1/0/3] quit
# Configure OSPF for the devices to communicate at Layer 3 over the underlay network.
[Leaf1] router id 172.16.0.1
[Leaf1] ospf
[Leaf1-ospf-1] area 0
[Leaf1-ospf-1-area-0.0.0.0] network 172.16.0.1 0.0.0.0
[Leaf1-ospf-1-area-0.0.0.0] network 12.1.1.1 0.0.0.255
[Leaf1-ospf-1-area-0.0.0.0] quit
[Leaf1-ospf-1] quit
Configuring a VPN instance
# Create VPN instance vpn1 and configure an RD and route targets for it.
[Leaf1] ip vpn-instance vpn1
[Leaf1-vpn-instance-vpn1] route-distinguisher 1:1
[Leaf1-vpn-instance-vpn1] address-family ipv4
[Leaf1-vpn-ipv4-vpn1] vpn-target 2:2 import-extcommunity
[Leaf1-vpn-ipv4-vpn1] vpn-target 2:2 export-extcommunity
[Leaf1-vpn-ipv4-vpn1] quit
[Leaf1-vpn-instance-vpn1] address-family evpn
[Leaf1-vpn-evpn-vpn1] vpn-target 1:1 import-extcommunity
[Leaf1-vpn-evpn-vpn1] vpn-target 1:1 export-extcommunity
[Leaf1-vpn-evpn-vpn1] quit
[Leaf1-vpn-instance-vpn1] quit
Configuring a VSI interface
# Enable L2VPN.
[Leaf1] l2vpn enable
# Configure VSI interface 1.
[Leaf1] interface vsi-interface 1
[Leaf1-Vsi-interface1] ip binding vpn-instance vpn1
[Leaf1-Vsi-interface1] ip address 10.255.255.254 255.0.0.0
[Leaf1-Vsi-interface1] mac-address 0000-0001-0001
[Leaf1-Vsi-interface1] distributed-gateway local
[Leaf1-Vsi-interface1] quit
Configuring an EVPN instance
# Disable remote MAC address learning and remote ARP learning.
[Leaf1] vxlan tunnel mac-learning disable
[Leaf1] vxlan tunnel arp-learning disable
# Create VXLAN 10 on VSI vsi1, and specify VSI interface 1 as the gateway for the VXLAN.
[Leaf1] vsi vsi1
[Leaf1-vsi-vsi1] gateway vsi-interface 1
[Leaf1-vsi-vsi1] statistics enable
[Leaf1-vsi-vsi1] arp suppression enable
[Leaf1-vsi-vsi1] vxlan 10
[Leaf1-vsi-vsi1-vxlan-10] quit
# Configure an EVPN instance using VXLAN encapsulation, and configure an RD and route targets for it.
[Leaf1-vsi-vsi1] evpn encapsulation vxlan
[Leaf1-vsi-vsi1-evpn-vxlan] route-distinguisher auto
[Leaf1-vsi-vsi1-evpn-vxlan] vpn-target auto export-extcommunity
[Leaf1-vsi-vsi1-evpn-vxlan] vpn-target auto import-extcommunity
[Leaf1-vsi-vsi1-evpn-vxlan] quit
[Leaf1-vsi-vsi1] quit
Assigning L3 VXLAN IDs
# Assign a L3 VXLAN ID to VSI interface 2.
[Leaf1] interface vsi-interface 2
[Leaf1-Vsi-interface2] ip binding vpn-instance vpn1
[Leaf1-Vsi-interface2] l3-vni 10000
[Leaf1-Vsi-interface2] quit
Configuring BGP EVPN route advertisement
# Configure Leaf 1 to establish a BGP EVPN peer relationship with the RR.
[Leaf1] bgp 65000
[Leaf1-bgp-default] peer 172.16.10.1 as-number 65000
[Leaf1-bgp-default] peer 172.16.10.1 connect-interface loopback 0
[Leaf1-bgp-default] peer 172.16.10.1 password simple overlay
[Leaf1-bgp-default] address-family l2vpn evpn
[Leaf1-bgp-default-evpn] peer 172.16.10.1 enable
[Leaf1-bgp-default-evpn] quit
[Leaf1-bgp-default] quit
Mapping ACs to the VSI
# On GigabitEthernet 1/0/1, create Ethernet service instance 1 and map it to VSI vsi1.
[Leaf1] interface gigabitethernet 1/0/1
[Leaf1-GigabitEthernet1/0/1] port link-mode bridge
[Leaf1-GigabitEthernet1/0/1] port link-type trunk
[Leaf1-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[Leaf1-GigabitEthernet1/0/1] port trunk permit vlan 1000
[Leaf1-GigabitEthernet1/0/1] service-instance 1
[Leaf1-GigabitEthernet1/0/1-srv1] encapsulation s-vid 1000
[Leaf1-GigabitEthernet1/0/1-srv1] statistics enable
[Leaf1-GigabitEthernet1/0/1-srv1] xconnect vsi vsi1
[Leaf1-GigabitEthernet1/0/1-srv1] quit
[Leaf1-GigabitEthernet1/0/1] quit
# On GigabitEthernet 1/0/2, create Ethernet service instance 1 and map it to VSI vsi1.
[Leaf1] interface gigabitethernet 1/0/2
[Leaf1-GigabitEthernet1/0/2] port link-mode bridge
[Leaf1-GigabitEthernet1/0/2] port link-type trunk
[Leaf1-GigabitEthernet1/0/2] undo port trunk permit vlan 1
[Leaf1-GigabitEthernet1/0/2] port trunk permit vlan 1001
[Leaf1-GigabitEthernet1/0/2] service-instance 1
[Leaf1-GigabitEthernet1/0/2-srv1] encapsulation s-vid 1001
[Leaf1-GigabitEthernet1/0/2-srv1] statistics enable
[Leaf1-GigabitEthernet1/0/2-srv1] xconnect vsi vsi1
[Leaf1-GigabitEthernet1/0/2-srv1] quit
[Leaf1-GigabitEthernet1/0/2] quit
Configuring IGMP snooping
# Enable IGMP snooping globally.
[Leaf1] igmp-snooping
[Leaf1-igmp-snooping] global-enable
[Leaf1-igmp-snooping] quit
# Configure IGMP snooping for VSI vsi1.
[Leaf1] vsi vsi1
[Leaf1-vsi-vsi1] igmp-snooping enable
[Leaf1-vsi-vsi1] igmp-snooping drop-unknown
[Leaf1-vsi-vsi1] igmp-snooping proxy enable
# Configure Leaf 2 as an IGMP querier.
[Leaf1-vsi-vsi1] igmp-snooping querier
Configuring Leaf 2
[Sysname] quit
<Sysname> reboot
.......DONE!
[Y/N]:y
[Sysname] sysname Leaf2
[Leaf2] interface loopback 0
[Leaf2-LoopBack0] ip address 172.16.0.2 255.255.255.255
[Leaf2-LoopBack0] quit
[Leaf2] interface gigabitethernet 1/0/3
[Leaf2-GigabitEthernet1/0/3] port link-mode route
[Leaf2-GigabitEthernet1/0/3] ip address 13.1.1.2 24
[Leaf2-GigabitEthernet1/0/3] quit
[Leaf2] router id 172.16.0.2
[Leaf2] ospf
[Leaf2-ospf-1] area 0
[Leaf2-ospf-1-area-0.0.0.0] network 172.16.0.2 0.0.0.0
[Leaf2-ospf-1-area-0.0.0.0] network 13.1.1.2 0.0.0.255
[Leaf2-ospf-1-area-0.0.0.0] quit
[Leaf2-ospf-1] quit
[Leaf2] ip vpn-instance vpn1
[Leaf2-vpn-instance-vpn1] route-distinguisher 1:1
[Leaf2-vpn-instance-vpn1] address-family ipv4
[Leaf2-vpn-ipv4-vpn1] vpn-target 2:2 import-extcommunity
[Leaf2-vpn-ipv4-vpn1] vpn-target 2:2 export-extcommunity
[Leaf2-vpn-ipv4-vpn1] quit
[Leaf2-vpn-instance-vpn1] address-family evpn
[Leaf2-vpn-evpn-vpn1] vpn-target 1:1 import-extcommunity
[Leaf2-vpn-evpn-vpn1] vpn-target 1:1 export-extcommunity
[Leaf2-vpn-evpn-vpn1] quit
[Leaf2-vpn-instance-vpn1] quit
# Enable L2VPN.
[Leaf2] l2vpn enable
[Leaf2] interface vsi-interface 1
[Leaf2-Vsi-interface1] ip binding vpn-instance vpn1
[Leaf2-Vsi-interface1] ip address 10.255.255.254 255.0.0.0
[Leaf2-Vsi-interface1] mac-address 0000-0001-0001
[Leaf2-Vsi-interface1] distributed-gateway local
[Leaf2-Vsi-interface1] quit
[Leaf2] vxlan tunnel mac-learning disable
[Leaf2] vxlan tunnel arp-learning disable
[Leaf2] vsi vsi1
[Leaf2-vsi-vsi1] gateway vsi-interface 1
[Leaf2-vsi-vsi1] statistics enable
[Leaf2-vsi-vsi1] arp suppression enable
[Leaf2-vsi-vsi1] vxlan 10
[Leaf2-vsi-vsi1-vxlan-10] quit
[Leaf2-vsi-vsi1] evpn encapsulation vxlan
[Leaf2-vsi-vsi1-evpn-vxlan] route-distinguisher auto
[Leaf2-vsi-vsi1-evpn-vxlan] vpn-target auto export-extcommunity
[Leaf2-vsi-vsi1-evpn-vxlan] vpn-target auto import-extcommunity
[Leaf2-vsi-vsi1-evpn-vxlan] quit
[Leaf2-vsi-vsi1] quit
[Leaf2] interface vsi-interface 10000
[Leaf2-Vsi-interface10000] ip binding vpn-instance vpn1
[Leaf2-Vsi-interface10000] l3-vni 10000
[Leaf2-Vsi-interface10000] quit
# Configure Leaf 2 to establish a BGP EVPN peer relationship with the RR.
[Leaf2] bgp 65000
[Leaf2-bgp-default] peer 172.16.10.1 as-number 65000
[Leaf2-bgp-default] peer 172.16.10.1 connect-interface loopback 0
[Leaf2-bgp-default] peer 172.16.10.1 password simple overlay
[Leaf2-bgp-default] address-family l2vpn evpn
[Leaf2-bgp-default-evpn] peer 172.16.10.1 enable
[Leaf2-bgp-default-evpn] quit
[Leaf2-bgp-default] quit
[Leaf2] interface gigabitethernet 1/0/1
[Leaf2-GigabitEthernet1/0/1] port link-mode bridge
[Leaf2-GigabitEthernet1/0/1] port link-type trunk
[Leaf2-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[Leaf2-GigabitEthernet1/0/1] port trunk permit vlan 1002
[Leaf2-GigabitEthernet1/0/1] storm-constrain control shutdown
[Leaf2-GigabitEthernet1/0/1] service-instance 1
[Leaf2-GigabitEthernet1/0/1-srv1] encapsulation s-vid 1002
[Leaf2-GigabitEthernet1/0/1-srv1] statistics enable
[Leaf2-GigabitEthernet1/0/1-srv1] xconnect vsi vsi1
[Leaf2-GigabitEthernet1/0/1-srv1] quit
[Leaf2-GigabitEthernet1/0/1] quit
[Leaf2] vsi vsi1
[Leaf2-vsi-vsi1] igmp-snooping enable
[Leaf2-vsi-vsi1] igmp-snooping drop-unknown
[Leaf2-vsi-vsi1] igmp-snooping proxy enable
[Leaf2-vsi-vsi1] igmp-snooping querier
Configuring the RR
[Sysname] quit
<Sysname> reboot
.......DONE!
[Y/N]:y
# Assign IP addresses to loopback interfaces, GigabitEthernet 1/0/1, and GigabitEthernet 1/0/2.
[Sysname] sysname RR
[RR] interface loopback 0
[RR-LoopBack0] ip address 172.16.10.1 255.255.255.255
[RR-LoopBack0] quit
[RR] interface gigabitethernet 1/0/1
[RR-GigabitEthernet1/0/1] port link-mode route
[RR-GigabitEthernet1/0/1] ip address 12.1.1.3 24
[RR-GigabitEthernet1/0/1] quit
[RR] interface gigabitethernet 1/0/2
[RR-GigabitEthernet1/0/2] port link-mode route
[RR-GigabitEthernet1/0/2] ip address 13.1.1.3 24
[RR-GigabitEthernet1/0/2] quit
[RR] router id 172.16.10.1
[RR] ospf
[RR-ospf-1] area 0
[RR-ospf-1-area-0.0.0.0] network 172.16.10.1 0.0.0.0
[RR-ospf-1-area-0.0.0.0] network 12.1.1.3 0.0.0.255
[RR-ospf-1-area-0.0.0.0] network 13.1.1.3 0.0.0.255
[RR-ospf-1-area-0.0.0.0] quit
[RR-ospf-1] quit
# Assign Leaf 1 and Leaf 2 to IBGP peer group leaf.
[RR] bgp 65000
[RR-bgp-default] group leaf internal
[RR-bgp-default] peer leaf connect-interface loopback 0
[RR-bgp-default] peer leaf password simple overlay
[RR-bgp-default] peer 172.16.0.1 group leaf
[RR-bgp-default] peer 172.16.0.2 group leaf
# Configure the device as an RR, configure it to establish BGP EVPN peer relationships with IBGP peer group leaf, and disable route target filtering of received BGP EVPN routes.
[RR-bgp-default] address-family l2vpn evpn
[RR-bgp-default-evpn] undo policy vpn-target
[RR-bgp-default-evpn] peer leaf enable
[RR-bgp-default-evpn] peer leaf reflect-client
[RR-bgp-default-evpn] quit
Verifying routing information
# Verify that the leaf devices and the RR have learned one another's OSPF routes and can communicate at Layer 3 over the underlay network.
[Leaf1] display ip routing-table
Destinations : 16 Routes : 16
0.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
12.1.1.0/24 Direct 0 0 12.1.1.1 GE1/0/3
12.1.1.0/32 Direct 0 0 12.1.1.1 GE1/0/3
12.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
12.1.1.255/32 Direct 0 0 12.1.1.1 GE1/0/3
13.1.1.0/24 O_INTRA 10 2 12.1.1.3 GE1/0/3
127.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
172.16.0.1/32 Direct 0 0 127.0.0.1 InLoop0
172.16.0.2/32 O_INTRA 10 2 12.1.1.3 GE1/0/3
172.16.10.1/32 O_INTRA 10 1 12.1.1.3 GE1/0/3
224.0.0.0/4 Direct 0 0 0.0.0.0 NULL0
224.0.0.0/24 Direct 0 0 0.0.0.0 NULL0
255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
# Verify that the leaf devices and the RR have established BGP EVPN peer relationships with one another.
[Leaf1] display bgp peer l2vpn evpn
BGP local router ID: 172.16.0.1
Local AS number: 65000
Total number of peers: 1 Peers in established state: 1
* - Dynamically created peer
^ - Peer created through link-local address
172.16.10.1 65000 24 27 0 4 00:14:59 Established
Verifying VSI configuration
# Verify that VXLAN tunnels and ACs are correctly mapped to VSI vsi1.
[Leaf1] display l2vpn vsi verbose
VSI Name: Auto_L3VNI10000_2
VSI Index : 1
VSI State : Down
MTU : 1500
Bandwidth : -
Broadcast Restrain : -
Multicast Restrain : -
Unknown Unicast Restrain: -
MAC Learning : Enabled
MAC Table Limit : -
MAC Learning rate : -
Drop Unknown : -
Flooding : Enabled
Statistics : Disabled
Gateway Interface : VSI-interface 2
VXLAN ID : 10000
VSI Name: vsi1
VSI Index : 0
VSI State : Up
MTU : 1500
Bandwidth : -
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
Statistics : Enabled
Input Statistics :
Octets :0
Packets :0
Errors :0
Discards :0
Output Statistics :
Octets :0
Packets :0
Errors :0
Discards :0
Gateway Interface : VSI-interface 1
VXLAN ID : 10
Tunnels:
Tunnel Name Link ID State Type Flood proxy
Tunnel0 0x5000000 UP Auto Disabled
ACs:
AC Link ID State Type
GE1/0/1 srv1 0 Up Manual
GE1/0/2 srv1 1 Up Manual
# Verify that IGMP snooping is enabled on a per-VSI basis on the leaf devices.
[Leaf1] display igmp-snooping vsi vsi1
IGMP snooping information: VSI vsi1
IGMP snooping: Enabled
Drop-unknown: Enabled
Version: 2
Host-aging-time: 260s
Router-aging-time: 260s
Max-response-time: 10s
Last-member-query-interval: 1s
Querier: Enabled (IP:10.255.255.254, Expires: 00:01:39)
Querier-election: Disabled
Query-interval: 125s
General-query source IP: 10.255.255.254
Special-query source IP: 10.255.255.254
Report source IP: 10.255.255.254
Leave source IP: 10.255.255.254
Proxy: Enabled
IPP: -(Link ID: 0xffff)
# Verify that Leaf 1 has a dynamic IGMP snooping group entry for multicast group (0.0.0.0, 225.0.0.1).
[Leaf1] display igmp-snooping group
Total 1 entries.
VSI vsi1: Total 1 entries.
Host ports (1 in total):
GE1/0/1 (Link ID 0) (00:03:42)
# Verify that Leaf 1 has created an SMET route.
[Leaf1] display evpn route smet
VSI name: vsi1
Source address :
Group address : 225.0.0.1
Local version : v2
ACs :
AC Link ID Flags
GE1/0/1 srv1 0 Local
# Verify that Leaf 2 has received the SMET route created by Leaf 1.
[Leaf2] display evpn route smet
VSI name: vsi1
Source address :
Local version : -
Peers :
Nexthop Tunnel name Link ID Remote version
172.16.0.1 Tunnel0 0x5000000 v2
[Leaf2] display igmp-snooping evpn-group
Total 1 entries.
Tun0 (VXLAN ID 10)
Configuration files
· Leaf 1:
sysname Leaf1
address-family ipv4
address-family evpn
ospf 1
area 0.0.0.0
network 12.1.1.0 0.0.0.255
igmp-snooping
global-enable
l2vpn enable
vsi vsi1
statistics enable
vxlan 10
service-instance 1
statistics enable
xconnect vsi vsi1
service-instance 1
statistics enable
xconnect vsi vsi1
interface LoopBack0
combo enable copper
ip address 12.1.1.1 255.255.255.0
interface Vsi-interface1
interface Vsi-interface2
l3-vni 10000
bgp 65000
peer 172.16.10.1 connect-interface LoopBack0
peer 172.16.10.1 password cipher $c$3$cLxsbhBfj0xOTCgIQD1N6k3oJBamRAhZ5d8=
return
· Leaf 2:
sysname Leaf2
address-family ipv4
address-family evpn
ospf 1
area 0.0.0.0
network 13.1.1.0 0.0.0.255
igmp-snooping
global-enable
l2vpn enable
vsi vsi1
statistics enable
vxlan 10
interface LoopBack0
service-instance 1
statistics enable
xconnect vsi vsi1
ip address 13.1.1.1 255.255.255.0
l3-vni 10000
bgp 65000
peer 172.16.10.1 password cipher $c$3$saE3frSy9IuWBPp1FJT7L952YRagb0D9Ioo=
return
· RR:
sysname RR
ospf 1
area 0.0.0.0
interface LoopBack0
ip address 12.1.1.3 255.255.255.0
ip address 13.1.1.3 255.255.255.0
bgp 65000
group leaf internal
peer leaf connect-interface LoopBack0
peer leaf password cipher $c$3$91PuaavWEYHlqhaILQV5i5G828J3vG+g67I=
peer leaf enable
return
