- H3C Fixed Port Campus Switches Configuration Examples-6W104
- 00-Applicable hardware and software versions
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-DHCP Snooping Configuration Examples
- 12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 13-IPv6 over IPv4 Tunneling with OSPFv3 Configuration Examples
- 14-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 15-GRE with OSPF Configuration Examples
- 16-OSPF Configuration Examples
- 17-IS-IS Configuration Examples
- 18-BGP Configuration Examples
- 19-Policy-Based Routing Configuration Examples
- 20-OSPFv3 Configuration Examples
- 21-IPv6 IS-IS Configuration Examples
- 22-Routing Policy Configuration Examples
- 23-IGMP Snooping Configuration Examples
- 24-IGMP Configuration Examples
- 25-MLD Snooping Configuration Examples
- 26-IPv6 Multicast VLAN Configuration Examples
- 27-ACL Configuration Examples
- 28-Traffic Policing Configuration Examples
- 29-GTS and Rate Limiting Configuration Examples
- 30-Traffic Filtering Configuration Examples
- 31-AAA Configuration Examples
- 32-Port Security Configuration Examples
- 33-Portal Configuration Examples
- 34-SSH Configuration Examples
- 35-IP Source Guard Configuration Examples
- 36-Ethernet OAM Configuration Examples
- 37-CFD Configuration Examples
- 38-DLDP Configuration Examples
- 39-VRRP Configuration Examples
- 40-BFD Configuration Examples
- 41-NTP Configuration Examples
- 42-SNMP Configuration Examples
- 43-NQA Configuration Examples
- 44-Mirroring Configuration Examples
- 45-sFlow Configuration Examples
- 46-OpenFlow Configuration Examples
- 47-MAC Address Table Configuration Examples
- 48-Static Multicast MAC Address Entry Configuration Examples
- 49-IP Unnumbered Configuration Examples
- 50-MVRP Configuration Examples
- 51-MCE Configuration Examples
- 52-Attack Protection Configuration Examples
- 53-Smart Link Configuration Examples
- 54-RRPP Configuration Examples
- 55-BGP Route Selection Configuration Examples
- 56-IS-IS Route Summarization Configuration Examples
- 57-VXLAN Configuration Examples
- 58-DRNI Configuration Examples
- 59-IRF 3.1 Configuration Examples
- 60-PTP Configuration Examples
- 61-S-MLAG Configuration Examples
- 62-Puppet Configuration Examples
- 63-802.1X Configuration Examples
- 64-MAC Authentication Configuration Examples
- 65-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 66-BIDIR-PIM Configuration Examples
- 67-Congestion Avoidance and Queue Scheduling Configuration Examples
- 68-Basic MPLS Configuration Examples
- 69-MPLS L3VPN Configuration Examples
- 70-MPLS OAM Configuration Examples
- 71-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 72-DRNI and EVPN Configuration Examples
- 73-Multicast VPN Configuration Examples
- 74-MPLS TE Configuration Examples
- 75-Control Plane-Based QoS Policy Configuration Examples
- 76-Priority Mapping and Queue Scheduling Configuration Examples
- 77-ARP Attack Protection Configuration Examples
- 78-IRF Software Upgrade Configuration Examples
- 79-IRF Member Replacement Configuration Examples
- 80-Layer 3 Multicast on Multicast Source-Side DR System Configuration Examples
- 81-EVPN Multicast Configuration Examples
| 26-IPv6 Multicast VLAN Configuration Examples | 136.42 KB |
Example: Configuring sub-VLAN-based IPv6 multicast VLANs
Example: Configuring port-based IPv6 multicast VLANs
Introduction
This document provides IPv6 multicast VLAN configuration examples.
This document assumes that you have basic knowledge of IPv6 multicast VLAN.
· VLAN 10 and VLAN 20 are Department 1 and Department 2, respectively.
· VLAN-interface 10 and VLAN-interface 20 on Layer 3 device Switch A are the gateways of VLAN 10 and VLAN 20, respectively.
· MLDv1 runs in VLAN 10 on Switch A, and MLDv1 snooping runs in VLAN 10 on Layer 2 device Switch B.
· The source sends IPv6 multicast data to IPv6 multicast group FF1E::101.
· Host A and Host B in VLAN 10 join IPv6 multicast group FF1E::101. They can receive the IPv6 multicast data that the source sends to the group.
Now, Host C and Host D in VLAN 20 also join the group to receive the IPv6 multicast data, as shown in Figure 2. You can enable MLDv1 for VLAN 20 on Switch A and MLDv1 snooping for VLAN 20 on Switch B. In this way, Host C and Host D can receive the data addressed to the group. However, this occupies a large amount of bandwidth and increases the burden on Switch A.
To avoid the problems, you can configure a sub-VLAN-based IPv6 multicast VLAN on Switch B.
Analysis
To meet the network requirements, you must perform the following tasks:
· Create VLAN 30 on Switch A and Switch B, and assign GigabitEthernet 1/0/1 on them to VLAN 30 as tagged VLAN members.
· Create VLAN-interface 30 on Switch A, and enable MLD on the interface.
· Enable MLD snooping for VLAN 10 through VLAN 30 on Switch B.
· Configure VLAN 30 on Switch B as an IPv6 multicast VLAN, and assign VLAN 10 and VLAN 20 to IPv6 multicast VLAN 30 as sub-VLANs.
Hardware |
Software version |
S6812 switch series S6813 switch series |
Release 6615Pxx, Release 6628Pxx |
S6550XE-HI switch series |
Release 6008 and later, Release 8106Pxx |
S6525XE-HI switch series |
S5850 switch series |
Release 8005 and later |
S5570S-EI switch series |
Release 11xx |
S5560X-EI switch series |
Release 63xx, Release 65xx, Release 6615Pxx, Release 6628Pxx |
S5560X-HI switch series |
S5500V2-EI switch series |
MS4520V2-30F switch |
MS4520V2-30C switch MS4520V2-54C switch MS4520V2-28S switch MS4520V2-24TP switch |
MS4520V2-28S MS4520V2-24TP |
Release 63xx |
S6520X-HI switch series S6520X-EI switch series |
S6520X-SI switch series S6520-SI switch series |
S5000-EI switch series |
MS4600 switch series |
ES5500 switch series |
S5560S-EI switch series S5560S-SI switch series |
Release 63xx |
S5500V3-24P-SI S5500V3-48P-SI |
Release 63xx |
S5500V3-SI switch series (except S5500V3-24P-SI and S5500V3-48P-SI) |
Release 11xx |
S5170-EI switch series |
Release 11xx |
S5130S-HI switch series S5130S-EI switch series S5130S-SI switch series S5130S-LI switch series |
Release 63xx |
S5120V2-SI switch series S5120V2-LI switch series |
Release 63xx |
S5120V3-EI switch series |
Release 11xx |
S5120V3-36F-SI S5120V3-28P-HPWR-SI S5120V3-54P-PWR-SI |
Release 11xx |
S5120V3-SI switch series (except S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI) |
Release 63xx |
S5120V3-LI switch series |
Release 63xx |
S3600V3-EI switch series |
Release 11xx |
S3600V3-SI switch series |
Release 11xx |
S3100V3-EI switch series S3100V3-SI switch series |
Release 63xx |
S5110V2 switch series |
Release 63xx |
S5110V2-SI switch series |
Release 63xx |
S5000V3-EI switch series S5000V5-EI switch series |
Release 63xx |
S5000E-X switch series S5000X-EI switch series |
Release 63xx |
E128C switch E152C switch E500C switch series E500D switch series |
Release 63xx |
MS4320V2 switch series MS4320V3 switch series MS4300V2 switch series MS4320 switch series MS4200 switch series |
Release 63xx |
WS5850-WiNet switch series |
Release 63xx |
WS5820-WiNet switch series WS5810-WiNet switch series |
Release 63xx |
WAS6000 switch series |
Release 63xx |
IE4300-12P-AC switch IE4300-12P-PWR switch IE4300-M switch series IE4320 switch series |
Release 63xx |
When you configure sub-VLAN-based IPv6 multicast VLANs, follow these restrictions and guidelines:
· As a best practice, do not configure IPv6 multicast VLANs on the device enabled with IPv6 multicast routing.
· The IPv6 address assigned to the VLAN interface of the IPv6 multicast VLAN must be unique on the user network.
Procedures
1. Assign IPv6 addresses to VLAN-interface 10 and VLAN-interface 20 on Switch A. (Details not shown.)
2. Configure a unicast routing protocol so that all devices on the network are interoperable at the network layer. (Details not shown.)
3. Configure Switch A:
# Enable IPv6 multicast routing.
[SwitchA-mrib6] quit
# Create VLAN 30, configure GigabitEthernet 1/0/1 as a hybrid port, and assign it to VLAN 30 as a tagged VLAN member.
[SwitchA] vlan 30
[SwitchA-vlan30] quit
[SwitchA-GigabitEthernet1/0/1] port link-type hybrid
[SwitchA-GigabitEthernet1/0/1] port hybrid vlan 30 tagged
# Create VLAN-interface 30, assign it an IPv6 address, and enable MLD on it.
[SwitchA] interface vlan-interface 30
[SwitchA-Vlan-interface30] ipv6 address 2001::1 64
[SwitchA-Vlan-interface30] mld enable
[SwitchA-Vlan-interface30] quit
# Create VLAN 40, and assign GigabitEthernet 1/0/2 to VLAN 40.
[SwitchA] vlan 40
[SwitchA-vlan40] port gigabitethernet 1/0/2
[SwitchA-vlan40] quit
# Create VLAN-interface 40, assign it an IPv6 address, and enable IPv6 PIM-DM on it.
[SwitchA] interface vlan-interface 40
[SwitchA-Vlan-interface40] ipv6 address 1::1 64
[SwitchA-Vlan-interface40] ipv6 pim dm
[SwitchA-Vlan-interface40] quit
4. Configure Switch B:
# Enable MLD snooping globally.
[SwitchB] mld-snooping
[SwitchB-mld-snooping] quit
# Create VLAN 10, and enable MLD snooping for VLAN 10.
[SwitchB] vlan 10
[SwitchB-vlan10] mld-snooping enable
[SwitchB-vlan10] quit
# Create VLAN 20, and enable MLD snooping for VLAN 20.
[SwitchB] vlan 20
[SwitchB-vlan20] mld-snooping enable
[SwitchB-vlan20] quit
# Create VLAN 30, and enable MLD snooping for VLAN 30.
[SwitchB] vlan 30
[SwitchB-vlan30] mld-snooping enable
[SwitchB-vlan30] quit
# Configure GigabitEthernet 1/0/1 as a hybrid port, and assign it to VLAN 30 as a tagged VLAN member.
[SwitchB-GigabitEthernet1/0/1] port link-type hybrid
# Configure VLAN 30 as an IPv6 multicast VLAN, and assign VLAN 10 and VLAN 20 to IPv6 multicast VLAN 30 as sub-VLANs.
[SwitchB] ipv6 multicast-vlan 30
[SwitchB-ipv6-mvlan-30] subvlan 10 20
[SwitchB-ipv6-mvlan-30] quit
# Display information about all IPv6 multicast VLANs on Switch B.
[SwitchB] display ipv6 multicast-vlan
Total 1 IPv6 multicast VLANs.
IPv6 multicast VLAN 30:
Sub-VLAN list(2 in total):
10,20
Port list(0 in total):
# Display information about multicast groups in IPv6 multicast VLANs on Switch B.
[SwitchB] display ipv6 multicast-vlan group
Total 1 entries.
IPv6 multicast VLAN 30: Total 1 entries.
(::, FF1E::101)
Sub-VLANs (2 in total):
VLAN 10
VLAN 20
The output shows that IPv6 multicast VLAN (VLAN 30) contains sub-VLANs VLAN 10 and VLAN 20. Switch B will forward IPv6 multicast data for VLAN 30 to VLAN 10 and VLAN 20.
Configuration files
IMPORTANT: Support for the port link-mode bridge command depends on the device model. |
· Switch A:
vlan 10
vlan 20
vlan 30
vlan 40
interface Vlan-interface10
ipv6 address 2002::1/64
interface Vlan-interface20
ipv6 address 2003::1/64
interface Vlan-interface30
ipv6 address 2001::1/64
mld enable
interface Vlan-interface40
ipv6 address 1::1/64
ipv6 pim dm
port hybrid vlan 1 untagged
port access vlan 40
· Switch B:
mld-snooping
vlan 10
mld-snooping enable
vlan 20
mld-snooping enable
vlan 30
mld-snooping enable
subvlan 10 20
port access vlan 10
port access vlan 10
interface GigabitEthernet1/0/4
port access vlan 20
interface GigabitEthernet1/0/5
port access vlan 20
As shown in Figure 3:
Now, Host C and Host D in VLAN 20 also join the group to receive the IPv6 multicast data, as shown in Figure 4. You can enable MLDv1 for VLAN 20 on Switch A and MLDv1 snooping for VLAN 20 on Switch B. In this way, Host C and Host D can receive the data addressed to the group. However, this occupies a large amount of bandwidth and increases the burden on Switch A.
To avoid the problems, you can configure a port-based IPv6 multicast VLAN on Switch B.
Analysis
· On Switch B, configure the ports that have receiver hosts attached as hybrid ports, and assign the ports to their port VLAN IDs and VLAN 30 as untagged VLAN members.
· On Switch B, configure VLAN 30 as an IPv6 multicast VLAN, and assign the ports that have receiver hosts attached to IPv6 multicast VLAN 30.
· Enable MLD snooping for VLAN 10, VLAN 20, and VLAN 30 on Switch B.
Hardware |
Hardware |
Release 11xx |
MS4520V2-30C switch MS4520V2-54C switch |
Release 63xx |
Release 63xx |
Release 63xx |
Release 11xx |
Release 11xx |
Release 63xx |
Release 63xx |
Release 11xx |
Release 11xx |
Release 63xx |
Release 63xx |
Release 11xx |
Release 11xx |
Release 63xx |
Release 63xx |
Release 63xx |
Release 63xx |
Release 63xx |
Release 63xx |
Release 63xx |
Release 63xx |
Release 63xx |
Release 63xx |
Release 63xx |
When you configure port-based IPv6 multicast VLANs, follow these restrictions and guidelines:
· As a best practice, do not configure IPv6 multicast VLANs on a device enabled with IPv6 multicast routing.
· A port can belong to only one IPv6 multicast VLAN.
Procedures
[SwitchA] vlan 30
[SwitchA] vlan 40
[SwitchB] vlan 10
[SwitchB] vlan 20
[SwitchB] vlan 30
# Configure GigabitEthernet 1/0/2 as a hybrid port.
[SwitchB] interface gigabitethernet 1/0/2
[SwitchB-GigabitEthernet1/0/2] port link-type hybrid
# Set the PVID of GigabitEthernet 1/0/2 to VLAN 10, and assign the port to VLAN 10 and VLAN 30 as an untagged VLAN member.
[SwitchB-GigabitEthernet1/0/2] port hybrid pvid vlan 10
[SwitchB-GigabitEthernet1/0/2] port hybrid vlan 10 30 untagged
# Configure GigabitEthernet 1/0/3 as a hybrid port.
[SwitchB] interface gigabitethernet 1/0/3
[SwitchB-GigabitEthernet1/0/3] port link-type hybrid
# Set the PVID of GigabitEthernet 1/0/3 to VLAN 10, and assign the port to VLAN 10 and VLAN 30 as an untagged VLAN member.
[SwitchB-GigabitEthernet1/0/3] port hybrid pvid vlan 10
[SwitchB-GigabitEthernet1/0/3] port hybrid vlan 10 30 untagged
[SwitchB-GigabitEthernet1/0/3] quit
# Configure GigabitEthernet 1/0/4 as a hybrid port.
[SwitchB] interface gigabitethernet 1/0/4
[SwitchB-GigabitEthernet1/0/4] port link-type hybrid
# Set the PVID of GigabitEthernet 1/0/4 to VLAN 20, and assign the port to VLAN 20 and VLAN 30 as an untagged VLAN member.
[SwitchB-GigabitEthernet1/0/4] port hybrid pvid vlan 20
[SwitchB-GigabitEthernet1/0/4] port hybrid vlan 20 30 untagged
[SwitchB-GigabitEthernet1/0/4] quit
# Configure GigabitEthernet 1/0/5 as a hybrid port.
[SwitchB] interface gigabitethernet 1/0/5
[SwitchB-GigabitEthernet1/0/5] port link-type hybrid
# Set the PVID of GigabitEthernet 1/0/5 to VLAN 20, and assign the port to VLAN 20 and VLAN 30 as an untagged VLAN member
[SwitchB-GigabitEthernet1/0/5] port hybrid pvid vlan 20
[SwitchB-GigabitEthernet1/0/5] port hybrid vlan 20 30 untagged
[SwitchB-GigabitEthernet1/0/5] quit
5. Configure VLAN 30 as an IPv6 multicast VLAN, and assign GigabitEthernet 1/0/1 through GigabitEthernet 1/0/5 to IPv6 multicast VLAN 30.
[SwitchB-ipv6-mvlan-30] port gigabitethernet 1/0/2 to gigabitethernet 1/0/5
# Display information about IPv6 multicast VLANs on Switch B.
Sub-VLAN list(0 in total):
Port list(4 in total):
GE1/0/2
GE1/0/3
GE1/0/4
GE1/0/5
# Display information about dynamic MLD snooping group entries.
[SwitchB] display mld-snooping group
Total 1 entries.
(::, FF1E::101)
Host ports (4 in total):
GE1/0/2 (00:03:23)
GE1/0/3 (00:04:07)
GE1/0/4 (00:04:16)
GE1/0/5 (00:05:10)
The output shows that MLD snooping maintains the user ports in the multicast VLAN (VLAN 30). Switch B will forward the IPv6 multicast data of VLAN 10 through these user ports.
Configuration files
· Switch A:
vlan 10
vlan 20
vlan 30
vlan 40
mld enable
ipv6 pim dm
port access vlan 40
· Switch B:
mld-snooping
vlan 10
mld-snooping enable
vlan 20
mld-snooping enable
vlan 30
mld-snooping enable
ipv6 port multicast-vlan 30
