- H3C Fixed Port Campus Switches Configuration Examples-6W104
 - 00-Applicable hardware and software versions
 - 01-Login Management Configuration Examples
 - 02-RBAC Configuration Examples
 - 03-Software Upgrade Examples
 - 04-ISSU Configuration Examples
 - 05-Software Patching Examples
 - 06-Ethernet Link Aggregation Configuration Examples
 - 07-Port Isolation Configuration Examples
 - 08-Spanning Tree Configuration Examples
 - 09-VLAN Configuration Examples
 - 10-VLAN Tagging Configuration Examples
 - 11-DHCP Snooping Configuration Examples
 - 12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
 - 13-IPv6 over IPv4 Tunneling with OSPFv3 Configuration Examples
 - 14-IPv6 over IPv4 GRE Tunnel Configuration Examples
 - 15-GRE with OSPF Configuration Examples
 - 16-OSPF Configuration Examples
 - 17-IS-IS Configuration Examples
 - 18-BGP Configuration Examples
 - 19-Policy-Based Routing Configuration Examples
 - 20-OSPFv3 Configuration Examples
 - 21-IPv6 IS-IS Configuration Examples
 - 22-Routing Policy Configuration Examples
 - 23-IGMP Snooping Configuration Examples
 - 24-IGMP Configuration Examples
 - 25-MLD Snooping Configuration Examples
 - 26-IPv6 Multicast VLAN Configuration Examples
 - 27-ACL Configuration Examples
 - 28-Traffic Policing Configuration Examples
 - 29-GTS and Rate Limiting Configuration Examples
 - 30-Traffic Filtering Configuration Examples
 - 31-AAA Configuration Examples
 - 32-Port Security Configuration Examples
 - 33-Portal Configuration Examples
 - 34-SSH Configuration Examples
 - 35-IP Source Guard Configuration Examples
 - 36-Ethernet OAM Configuration Examples
 - 37-CFD Configuration Examples
 - 38-DLDP Configuration Examples
 - 39-VRRP Configuration Examples
 - 40-BFD Configuration Examples
 - 41-NTP Configuration Examples
 - 42-SNMP Configuration Examples
 - 43-NQA Configuration Examples
 - 44-Mirroring Configuration Examples
 - 45-sFlow Configuration Examples
 - 46-OpenFlow Configuration Examples
 - 47-MAC Address Table Configuration Examples
 - 48-Static Multicast MAC Address Entry Configuration Examples
 - 49-IP Unnumbered Configuration Examples
 - 50-MVRP Configuration Examples
 - 51-MCE Configuration Examples
 - 52-Attack Protection Configuration Examples
 - 53-Smart Link Configuration Examples
 - 54-RRPP Configuration Examples
 - 55-BGP Route Selection Configuration Examples
 - 56-IS-IS Route Summarization Configuration Examples
 - 57-VXLAN Configuration Examples
 - 58-DRNI Configuration Examples
 - 59-IRF 3.1 Configuration Examples
 - 60-PTP Configuration Examples
 - 61-S-MLAG Configuration Examples
 - 62-Puppet Configuration Examples
 - 63-802.1X Configuration Examples
 - 64-MAC Authentication Configuration Examples
 - 65-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
 - 66-BIDIR-PIM Configuration Examples
 - 67-Congestion Avoidance and Queue Scheduling Configuration Examples
 - 68-Basic MPLS Configuration Examples
 - 69-MPLS L3VPN Configuration Examples
 - 70-MPLS OAM Configuration Examples
 - 71-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
 - 72-DRNI and EVPN Configuration Examples
 - 73-Multicast VPN Configuration Examples
 - 74-MPLS TE Configuration Examples
 - 75-Control Plane-Based QoS Policy Configuration Examples
 - 76-Priority Mapping and Queue Scheduling Configuration Examples
 - 77-ARP Attack Protection Configuration Examples
 - 78-IRF Software Upgrade Configuration Examples
 - 79-IRF Member Replacement Configuration Examples
 - 80-Layer 3 Multicast on Multicast Source-Side DR System Configuration Examples
 - 81-EVPN Multicast Configuration Examples
| 00-Applicable hardware and software versions | 14.24 KB |
This manual is applicable to the following switches and software versions:
    Switches  |
    Software versions  |
   H3C S6812 Switch Series H3C S6813 Switch Series  |
   Release 6615P03 and later  |
   H3C S6550XE-HI Switch Series H3C S6525XE-HI Switch Series  |
   Release 6008 and later  |
   H3C S6520X-HI Switch Series H3C S6520X-EI Switch Series H3C S6520X-SI Switch Series H3C S6520-SI Switch Series H3C S5560X-HI Switch Series H3C S5000-EI Switch Series H3C MS4600 Switch Series  |
   Release 6308 and later  |
   H3C S5850 Switch Series  |
   Release 8005 and later  |
   H3C S5570S-EI Switch Series  |
   Release 1106 and later  |
   H3C S5560X-EI Switch Series H3C S5500V2-EI Switch Series  |
   H3C S5560S-EI Switch Series H3C S5560S-EI Switch Series H3C S3100V3-EI Switch Series H3C S3100V3-SI Switch Series H3C E500C Switch Series H3C E500D Switch Series  |
   Release 6309P01 and later  |
   H3C S5560S-SI Switch Series H3C MS4200 Switch Series  |
   Release 6310 and later  |
   H3C S5500V3-SI Switch Series (except S5500V3-24P-SI and S5500V3-48P-SI switches)  |
   S5500V3-24P-SI & S5500V3-48P-SI switches E128C & E152C switches  |
   H3C S5170-EI Switch Series  |
   H3C S5130S-EI Switch Series H3C S5130S-HI Switch Series  |
   H3C S5110V2 Switch Series H3C S5110V2-SI Switch Series H3C S5130S-SI Switch Series H3C S5130S-LI Switch Series H3C S5120V2-SI Switch Series H3C S5000V3-EI Switch Series H3C S5000E-X Switch Series  |
   H3C S5120V3-EI Switch Series S5120V3-36F-SI & S5120V3-28P-HPWR-SI & S5120V3-54P-PWR-SI switches  |
   H3C S5000X-EI Switch Series H3C MS4320V3 Switch Series H3C S5120V3-LI Switch Series H3C S5120V3-SI Switch Series (except S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI)  |
   Release 6329 and later  |
   H3C S5120V2-LI Switch Series H3C MS4300V2 Switch Series H3C MS4320 Switch Series H3C MS4320V2 Switch Series  |
   Release 6308P01 and later  |
   H3C S5000V5-EI Switch Series  |
   H3C S3600V3-EI Switch Series H3C S3600V3-SI Switch Series  |
   H3C IE4300-12P-AC & IE4300-12P-PWR switches H3C E4300-M Switch Series H3C IE4320 Switch Series  |
   H3C ES5500 Switch Series  |
   Release 6317P01 and later  |
   H3C MS4520V2-30F switches  |
   Release 6312P01 and later  |
   H3C MS4520V2-28S & MS4520V2-24TP switches  |
   Release 6312P03 and later  |
   H3C MS4520V2-30C & MS4520V2-54C switches  |
   Release 6510P01 and later  |
   H3C WAS6000 Switch Series H3C WS5810-WiNet Switch Series H3C WS5820-WiNet Switch Series H3C WS5850-WiNet Switch Series  |
