- H3C Fixed Port Campus Switches Configuration Examples-6W104
 - 00-Applicable hardware and software versions
 - 01-Login Management Configuration Examples
 - 02-RBAC Configuration Examples
 - 03-Software Upgrade Examples
 - 04-ISSU Configuration Examples
 - 05-Software Patching Examples
 - 06-Ethernet Link Aggregation Configuration Examples
 - 07-Port Isolation Configuration Examples
 - 08-Spanning Tree Configuration Examples
 - 09-VLAN Configuration Examples
 - 10-VLAN Tagging Configuration Examples
 - 11-DHCP Snooping Configuration Examples
 - 12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
 - 13-IPv6 over IPv4 Tunneling with OSPFv3 Configuration Examples
 - 14-IPv6 over IPv4 GRE Tunnel Configuration Examples
 - 15-GRE with OSPF Configuration Examples
 - 16-OSPF Configuration Examples
 - 17-IS-IS Configuration Examples
 - 18-BGP Configuration Examples
 - 19-Policy-Based Routing Configuration Examples
 - 20-OSPFv3 Configuration Examples
 - 21-IPv6 IS-IS Configuration Examples
 - 22-Routing Policy Configuration Examples
 - 23-IGMP Snooping Configuration Examples
 - 24-IGMP Configuration Examples
 - 25-MLD Snooping Configuration Examples
 - 26-IPv6 Multicast VLAN Configuration Examples
 - 27-ACL Configuration Examples
 - 28-Traffic Policing Configuration Examples
 - 29-GTS and Rate Limiting Configuration Examples
 - 30-Traffic Filtering Configuration Examples
 - 31-AAA Configuration Examples
 - 32-Port Security Configuration Examples
 - 33-Portal Configuration Examples
 - 34-SSH Configuration Examples
 - 35-IP Source Guard Configuration Examples
 - 36-Ethernet OAM Configuration Examples
 - 37-CFD Configuration Examples
 - 38-DLDP Configuration Examples
 - 39-VRRP Configuration Examples
 - 40-BFD Configuration Examples
 - 41-NTP Configuration Examples
 - 42-SNMP Configuration Examples
 - 43-NQA Configuration Examples
 - 44-Mirroring Configuration Examples
 - 45-sFlow Configuration Examples
 - 46-OpenFlow Configuration Examples
 - 47-MAC Address Table Configuration Examples
 - 48-Static Multicast MAC Address Entry Configuration Examples
 - 49-IP Unnumbered Configuration Examples
 - 50-MVRP Configuration Examples
 - 51-MCE Configuration Examples
 - 52-Attack Protection Configuration Examples
 - 53-Smart Link Configuration Examples
 - 54-RRPP Configuration Examples
 - 55-BGP Route Selection Configuration Examples
 - 56-IS-IS Route Summarization Configuration Examples
 - 57-VXLAN Configuration Examples
 - 58-DRNI Configuration Examples
 - 59-IRF 3.1 Configuration Examples
 - 60-PTP Configuration Examples
 - 61-S-MLAG Configuration Examples
 - 62-Puppet Configuration Examples
 - 63-802.1X Configuration Examples
 - 64-MAC Authentication Configuration Examples
 - 65-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
 - 66-BIDIR-PIM Configuration Examples
 - 67-Congestion Avoidance and Queue Scheduling Configuration Examples
 - 68-Basic MPLS Configuration Examples
 - 69-MPLS L3VPN Configuration Examples
 - 70-MPLS OAM Configuration Examples
 - 71-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
 - 72-DRNI and EVPN Configuration Examples
 - 73-Multicast VPN Configuration Examples
 - 74-MPLS TE Configuration Examples
 - 75-Control Plane-Based QoS Policy Configuration Examples
 - 76-Priority Mapping and Queue Scheduling Configuration Examples
 - 77-ARP Attack Protection Configuration Examples
 - 78-IRF Software Upgrade Configuration Examples
 - 79-IRF Member Replacement Configuration Examples
 - 80-Layer 3 Multicast on Multicast Source-Side DR System Configuration Examples
 - 81-EVPN Multicast Configuration Examples
| 06-Ethernet Link Aggregation Configuration Examples | 220.23 KB |
Example: Configuring Layer 2 link aggregation
Example: Configuring Layer 2 aggregation load sharing
Example: Configuring Layer 2 link aggregation in an IRF fabric
Example: Configuring Layer 3 link aggregation
Example: Configuring Layer 3 aggregation load sharing
Introduction
This document provides Ethernet link aggregation configuration examples.
This document assumes that you have basic knowledge of Ethernet link aggregation.
As shown in Figure 1, both Device A and Device B forward traffic from VLAN 10 and VLAN 20.
Configure link aggregation on Device A and Device B to meet the following requirements:
· VLAN 10 on Device A can communicate with VLAN 10 on Device B.
· VLAN 20 on Device A can communicate with VLAN 20 on Device B.
Analysis
To enable traffic from VLAN 10 and VLAN 20 to pass through Layer 2 aggregate interface Bridge-aggregation 1, perform the following tasks:
· Configure Layer 2 aggregate interface Bridge-aggregation 1 as a trunk port.
· Assign the aggregate interface to VLAN 10 and VLAN 20.
    Hardware  |
    Software version  |
   S6812 switch series S6813 switch series  |
   Release 6615Pxx, Release 6628Pxx  |
   S6550XE-HI switch series  |
   Release 6008 and later, Release 8106Pxx  |
   S6525XE-HI switch series  |
   S5850 switch series  |
   Release 8005 and later  |
   S5570S-EI switch series  |
   Release 11xx  |
   S5560X-EI switch series  |
   Release 63xx, Release 65xx, Release 6615Pxx, Release 6628Pxx  |
   S5560X-HI switch series  |
   S5500V2-EI switch series  |
   MS4520V2-30F switch  |
   MS4520V2-30C switch MS4520V2-54C switch  |
   MS4520V2-28S switch MS4520V2-24TP switch  |
   Release 63xx  |
   S6520X-HI switch series S6520X-EI switch series  |
   S6520X-SI switch series S6520-SI switch series  |
   S5000-EI switch series  |
   MS4600 switch series  |
   ES5500 switch series  |
   S5560S-EI switch series S5560S-SI switch series  |
   Release 63xx  |
   S5500V3-24P-SI switch S5500V3-48P-SI switch  |
   Release 63xx  |
   S5500V3-SI switch series (except S5500V3-24P-SI and S5500V3-48P-SI)  |
   Release 11xx  |
   S5170-EI switch series  |
   Release 11xx  |
   S5130S-HI switch series S5130S-EI switch series S5130S-SI switch series S5130S-LI switch series  |
   Release 63xx  |
   S5120V2-SI switch series S5120V2-LI switch series  |
   Release 63xx  |
   S5120V3-EI switch series  |
   Release 11xx  |
   S5120V3-36F-SI switch S5120V3-28P-HPWR-SI switch S5120V3-54P-PWR-SI switch  |
   Release 11xx  |
   S5120V3-SI switch series (except S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI)  |
   Release 63xx  |
   S5120V3-LI switch series  |
   Release 63xx  |
   S3600V3-EI switch series  |
   Release 11xx  |
   S3600V3-SI switch series  |
   Release 11xx  |
   S3100V3-EI switch series S3100V3-SI switch series  |
   Release 63xx  |
   S5110V2 switch series  |
   Release 63xx  |
   S5110V2-SI switch series  |
   Release 63xx  |
   S5000V3-EI switch series S5000V5-EI switch series  |
   Release 63xx  |
   S5000E-X switch series S5000X-EI switch series  |
   Release 63xx  |
   E128C switch E152C switch E500C switch series E500D switch series  |
   Release 63xx  |
   MS4320V2 switch series MS4320V3 switch series MS4300V2 switch series MS4320 switch series MS4200 switch series  |
   Release 63xx  |
   WS5850-WiNet switch series  |
   Release 63xx  |
   WS5820-WiNet switch series WS5810-WiNet switch series  |
   Release 63xx  |
   WAS6000 switch series  |
   Release 63xx  |
   IE4300-12P-AC switch IE4300-12P-PWR switch IE4300-M switch series IE4320 switch series  |
   Release 63xx  |
When you configure Layer 2 link aggregation, follow these restrictions and guidelines:
· When you assign a port to an aggregation group, the recommended configuration procedure is as follows:
a. Use the display this command in interface view to check the following attribute configurations of the port:
- Port isolation.
- QinQ.
- VLAN.
- VLAN mapping.
b. If any of the above configurations exist, use the undo forms of the corresponding commands to remove these configurations. This enables the port to use the default attribute configurations.
c. Assign the port to the aggregation group.
· In a static aggregation group, the Selected state of a port is not affected by whether the peer port is added to an aggregation group and is Selected. As a result, the Selected state of a port might be different from the Selected state of the peer port. When both ends support static aggregation and dynamic aggregation, use dynamic aggregation.
· You cannot assign a port to a Layer 2 aggregation group when MAC authentication, port security mode, or 802.1X is configured or enabled on the port.
Procedures
1. Configure Device A:
# Create VLAN 10, and assign port GigabitEthernet 1/0/4 to VLAN 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port gigabitethernet 1/0/4
[DeviceA-vlan10] quit
# Create VLAN 20, and assign port GigabitEthernet 1/0/5 to VLAN 20.
[DeviceA] vlan 20
[DeviceA-vlan20] port gigabitethernet 1/0/5
[DeviceA-vlan20] quit
# Create Layer 2 aggregate interface Bridge-aggregation 1. Use one of the following methods as needed.
¡ Use the static aggregation mode to create Layer 2 aggregate interface Bridge-aggregation 1.
[DeviceA] interface bridge-aggregation 1
[DeviceA-Bridge-Aggregation1] quit
¡ Use the dynamic aggregation mode to create Layer 2 aggregate interface Bridge-aggregation 1.
[DeviceA-Bridge-Aggregation1] link-aggregation mode dynamic
# Assign ports GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3 to aggregation group 1.
[DeviceA] interface range gigabitethernet 1/0/1 to gigabitethernet 1/0/3
[DeviceA-if-range] port link-aggregation group 1
[DeviceA-if-range] quit
# Configure Layer 2 aggregate interface Bridge-aggregation 1 as a trunk port.
[DeviceA-Bridge-Aggregation1] port link-type trunk
Configuring GigabitEthernet1/0/1 done.
Configuring GigabitEthernet1/0/2 done.
Configuring GigabitEthernet1/0/3 done.
# Assign the aggregate interface to VLANs 10 and 20.
[DeviceA-Bridge-Aggregation1] port trunk permit vlan 10 20
2. Configure Device B in the same way Device A is configured. (Details not shown.)
# Display detailed information about the link aggregation groups on Device A.
· Link aggregation configuration information when the static aggregation mode is used:
[DeviceA] display link-aggregation verbose
Port: A -- Auto port, M -- Management port, R -- Reference port
G -- Defaulted, H -- Expired
Aggregation Interface: Bridge-Aggregation1
Aggregation Mode: Static
Management VLANs: None
Port Status Priority Oper-Key
GE1/0/1(R) S 32768 1
GE1/0/2 S 32768 1
GE1/0/3 S 32768 1
The output shows that all member ports in the local aggregation group are in the Selected state. The Selected states of the local member ports are not affected by the Selected states of the peer member ports.
· Link aggregation configuration information when the dynamic aggregation mode is used:
Creation Mode: Manual
Aggregation Mode: Dynamic
System ID: 0x8000, 000f-e234-5678
Local:
Port Status Priority Index Oper-Key Flag
GE1/0/1 S 32768 2 1 {ACDEF}
GE1/0/2 S 32768 3 1 {ACDEF}
GE1/0/3 S 32768 4 1 {ACDEF}
Remote:
Actor Priority Index Oper-Key SystemID Flag
GE1/0/1(R) 32768 2 1 0x8000, a4e5-c316-0100 {ACDEF}
GE1/0/2 32768 3 1 0x8000, a4e5-c316-0100 {ACDEF}
GE1/0/3 32768 4 1 0x8000, a4e5-c316-0100 {ACDEF}
The output shows that the local member ports and the corresponding peer member ports are all Selected. In the dynamic link aggregation mode, each local member port and its peer member port have the same Selected state through exchanging LACPDUs. The user data traffic can be forwarded correctly.
Configuration files
    IMPORTANT: Support for the port link-mode bridge command depends on the device model.  |
· Device A:
vlan 10
interface GigabitEthernet1/0/4
port access vlan 10
vlan 20
interface GigabitEthernet1/0/5
port access vlan 20
¡ In the static aggregation mode:
interface Bridge-Aggregation1
¡ In the dynamic aggregation mode:
· Device B:
The configuration file on Device B is the same as the configuration file on Device A.
As shown in Figure 2, both Device A and Device B forward traffic for VLAN 10 and VLAN 20.
· Configure Layer 2 static aggregation groups 1 and 2 on both Device A and Device B.
· Configure link aggregation group 1 to forward traffic for VLAN 10.
· Configure link aggregation group 2 to forward traffic for VLAN 20.
· Configure link aggregation groups 1 and 2 to load share traffic across aggregation group member ports.
¡ Configure link aggregation group 1 to load share packets based on source MAC addresses.
¡ Configure link aggregation group 2 to load share packets based on destination MAC addresses.
Analysis
To enable the aggregate interfaces to forward traffic for VLAN 10 and VLAN 20, perform the following tasks:
· Assign Layer 2 aggregate interface Bridge-aggregation 1 to VLAN 10.
· Assign Layer 2 aggregate interface Bridge-aggregation 2 to VLAN 20.
For Bridge-aggregation 1 and Bridge-aggregation 2 to load share traffic across their Selected ports, set the load sharing mode in aggregate interface view.
   Hardware  |
   Software version  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
1. Use the display this command in interface view to check the following attribute configurations of the port:
¡ Port isolation.
¡ QinQ.
¡ VLAN.
¡ VLAN mapping.
2. If any of the above configurations exist, use the undo forms of the corresponding commands to remove these configurations. This enables the port to use the default attribute configurations.
3. Assign the port to the aggregation group.
Procedures
Configuring Device A
# Create VLAN 10, and assign GigabitEthernet 1/0/5 to VLAN 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port gigabitethernet 1/0/5
# Create VLAN 20, and assign GigabitEthernet 1/0/6 to VLAN 20.
[DeviceA] vlan 20
[DeviceA-vlan20] port gigabitethernet 1/0/6
# Create Layer 2 aggregate interface Bridge-Aggregation 1. Configure Layer 2 aggregation group 1 to load share packets based on source MAC addresses.
[DeviceA-Bridge-Aggregation1] link-aggregation load-sharing mode source-mac
# Assign GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to link aggregation group 1.
[DeviceA-GigabitEthernet1/0/1] port link-aggregation group 1
[DeviceA-GigabitEthernet1/0/2] port link-aggregation group 1
# Configure Layer 2 aggregate interface Bridge-Aggregation 1 as an access port and assign it to VLAN 10.
[DeviceA-Bridge-Aggregation1] port access vlan 10
# Create Layer 2 aggregate interface Bridge-Aggregation 2. Configure Layer 2 aggregation group 2 to load share packets based on destination MAC addresses.
[DeviceA] interface bridge-aggregation 2
[DeviceA-Bridge-Aggregation2] link-aggregation load-sharing mode destination-mac
[DeviceA-Bridge-Aggregation2] quit
# Assign GigabitEthernet 1/0/3 and GigabitEthernet 1/0/4 to link aggregation group 2.
[DeviceA-GigabitEthernet1/0/3] port link-aggregation group 2
[DeviceA] interface gigabitethernet 1/0/4
[DeviceA-GigabitEthernet1/0/4] port link-aggregation group 2
[DeviceA-GigabitEthernet1/0/4] quit
# Configure Layer 2 aggregate interface Bridge-Aggregation 2 as an access port and assign it to VLAN 20.
[DeviceA-Bridge-Aggregation2] port access vlan 20
Configuring GigabitEthernet1/0/4 done.
Configuring Device B
# Display detailed information about all aggregation groups on Device A.
Port Status: S -- Selected, U -- Unselected , I -- Individual
GE1/0/2 S 32768 1
Aggregation Interface: Bridge-Aggregation2
GE1/0/3(R) S 32768 2
GE1/0/4 S 32768 2
The output shows that:
· Both link aggregation groups 1 and 2 load share traffic.
· Each aggregation group contains two Selected ports.
# Display all the group-specific load sharing modes on Device A.
[DeviceA]display link-aggregation load-sharing mode interface Bridge-Aggregation 1
Bridge-Aggregation1 load-sharing mode:
source-mac address
[DeviceA]display link-aggregation load-sharing mode interface Bridge-Aggregation 2
Bridge-Aggregation2 load-sharing mode:
destination-mac address
· Link aggregation group 1 distributes packets based on source MAC addresses.
· Link aggregation group 2 distributes packets based on destination MAC addresses.
Configuration files
· Device A:
vlan 10
port access vlan 10
vlan 20
interface GigabitEthernet1/0/6
port access vlan 10
port access vlan 10
port access vlan 10
port access vlan 10
interface Bridge-Aggregation2
port access vlan 20
port access vlan 20
port access vlan 20
· Device B:
On the network as shown in Figure 3, perform the following tasks:
· Set up a two-chassis IRF fabric at the access layer and a two-chassis IRF fabric at the distribution layer of the enterprise network.
· Configure link aggregation to improve the reliability of the links between the access-layer and distribution-layer IRF fabrics and implement load sharing.
· Run LACP MAD on the two IRF fabrics to detect IRF split.
    Hardware  |
    Software version  |
   Release 11xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 11xx  |
   Release 11xx  |
   Release 63xx  |
   Release 63xx  |
   Release 11xx  |
   Release 11xx  |
   Release 63xx  |
   Release 63xx  |
   Release 11xx  |
   Release 11xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
When you configure Layer 2 link aggregation in an IRF fabric, follow these restrictions and guidelines:
· IRF physical ports must be set to the bridge mode.
· When you bind physical ports to an IRF port, you must set all the physical ports to operate in either normal or enhanced mode.
· The physical ports of two connected IRF ports must operate in the same mode: normal or enhanced. For more information about the binding mode of the IRF physical ports, see IRF Configuration Guide.
- Port isolation.
- QinQ.
- VLAN.
- VLAN mapping.
Procedures
1. Configure IRF on Device A:
# Shut down GigabitEthernet 1/0/1.
[DeviceA-GigabitEthernet1/0/1] shutdown
# Bind GigabitEthernet 1/0/1 to IRF port 1/1.
[DeviceA] irf-port 1/1
[DeviceA-irf-port1/1] port group interface gigabitethernet 1/0/1
You must perform the following tasks for a successful IRF setup:
Save the configuration after completing IRF configuration.
Execute the "irf-port-configuration active" command to activate the IRF ports.
[DeviceA-irf-port1/1] quit
# Bring up GigabitEthernet1/0/1, and save the configuration.
[DeviceA-GigabitEthernet1/0/1] undo shutdown
[DeviceA] save
# Activate the IRF port configuration.
[DeviceA] irf-port-configuration active
2. Configure IRF on Device B:
# Change the member ID of Device B to 2, and reboot the device to validate the change.
[DeviceB] irf member 1 renumber 2
Renumbering the member ID may result in configuration change or loss. Continue? [Y/N]:y
[DeviceB] quit
<DeviceB> reboot
# Shut down Gigabitethernet 2/0/1.
[DeviceB] interface gigabitethernet 2/0/1
[DeviceB-GigabitEthernet2/0/1] shutdown
[DeviceB-GigabitEthernet2/0/1] quit
# Bind GigabitEthernet 2/0/1 to IRF port 2/2.
[DeviceB] irf-port 2/2
[DeviceB-irf-port2/2] port group interface gigabitethernet 2/0/1
[DeviceB-irf-port2/2] quit
# Bring up GigabitEthernet 2/0/1, and save the configuration.
[DeviceB-GigabitEthernet2/0/1] undo shutdown
[DeviceB] save
[DeviceB] irf-port-configuration active
Device A and Device B perform master election, and the one that has lost the election reboots to form an IRF fabric with the master. In this example, Device B reboots.
# Use the display irf command to verify that Device A has become the Master device.
[DeviceA] display irf
MemberID Role Priority CPU-Mac Description
*+1 Master 1 00a0-fc00-5801 ---
2 Standby 1 00e0-fc58-1235 ---
The bridge MAC of the IRF is: 00a0-fc00-5800
Auto upgrade : yes
Mac persistent : 6 min
Domain ID : 0
Auto merge : yes
3. Configure a Layer 2 aggregation group on Device A:
# Create Layer 2 aggregate interface Bridge-Aggregation 1, and configure the link aggregation mode as dynamic.
# Assign ports GigabitEthernet 1/0/9, GigabitEthernet1/0/10, GigabitEthernet 2/0/9, and GigabitEthernet 2/0/10 to link aggregation group 1.
[DeviceA] interface range gigabitethernet 1/0/9 to gigabitethernet 1/0/10
gigabitethernet 2/0/9 to gigabitethernet 2/0/10
[DeviceA]
Configure LACP MAD on the IRF fabric:
# Set the domain ID of the IRF fabric to 1.
# Enable LACP MAD on Bridge-Aggregation 1.
[DeviceA] interface Bridge-Aggregation 1
[DeviceA-Bridge-Aggregation1] mad enable
[Current domain is: 1]:
The assigned domain ID is: 1
MAD LACP only enable on dynamic aggregation interface.
4. Configure IRF on Device C in the same way IRF is configured on Device A. (Details not shown.)
5. Configure IRF on Device D in the same way IRF is configured on Device B. (Details not shown.)
Device C and Device D perform master election, and the one that has lost the election reboots to form an IRF fabric with the master. In this example, Device C reboots.
6. Configure a Layer 2 dynamic aggregation group Bridge-Aggregation 1 on Device C in the same way Bridge-Aggregation 1 is configured on Device A. (Details not shown.)
7. Configure LACP MAD on the IRF fabric:
# Set the domain ID of the IRF fabric to 2.
<DeviceC> system-view
[DeviceC] irf domain 2
[DeviceC] interface Bridge-Aggregation 1
[DeviceC-Bridge-Aggregation1] mad enable
[Current domain is: 2]:
The assigned domain ID is: 2
# Display the information about the link aggregation groups on Device A.
System ID: 0x8000, 00a0-fc00-5800
Local:
GE1/0/9(R) S 32768 10 1 {ACG}
GE1/0/10 S 32768 11 1 {ACG}
GE2/0/9 S 32768 138 1 {ACG}
GE2/0/10 S 32768 139 1 {ACG}
Remote:
GE1/0/9 32768 0 0 0x8000, 0000-0000-0000 {EF}
GE1/0/10 32768 0 0 0x8000, 0000-0000-0000 {EF}
GE2/0/9 32768 0 0 0x8000, 0000-0000-0000 {EF}
GE2/0/10 32768 0 0 0x8000, 0000-0000-0000 {EF}
# Shut down physical IRF port GigabitEthernet 2/0/1 on Device B.
A log message appears on Device A.
[DeviceA]%Jul 9 16:52:41:734 2016 DeviceA STM/3/STM_LINK_DOWN: IRF port 1 went down.
%Jul 9 16:52:41:800 2016 DeviceA IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/1 changed to down.
%Jul 9 16:52:41:854 2016 DeviceA IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/1 changed to down.
%Jul 9 16:52:41:867 2016 DeviceA DEV/3/BOARD_REMOVED: Board was removed from slot 2, type is Simware.
The output shows that IRF split occurs on the distribution layer because GigabitEthernet 2/0/1 that is bound to IRF port 2/2 is physically down.
Configuration files
· Device A:
irf domain 1
irf mac-address persistent timer
irf auto-update enable
irf auto-merge enable
undo irf link-delay
irf member 1 priority 1
irf member 2 priority 1
irf-port 1/1
port group interface GigabitEthernet1/0/1
irf-port 2/2
port group interface GigabitEthernet2/0/1
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet2/0/9
interface GigabitEthernet2/0/10
· Device C:
The configuration file on Device C is similar as the configuration file on Device A.
On the network as shown in Figure 4, perform the following tasks:
· Configure a Layer 3 dynamic aggregation group on both Device A and Device B.
· Configure IP addresses and subnet masks for the corresponding Layer 3 aggregate interfaces.
   Hardware  |
   Software version  |
   Release 11xx  |
   MS4520V2-28S MS4520V2-24TP  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 11xx  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Release 11xx  |
   Release 11xx  |
   Not supported  |
   Not supported  |
   Not supported  |
   Release 63xx  |
   Not supported  |
   Not supported  |
   Not supported  |
   Release 63xx  |
   Not supported  |
   Not supported  |
   Not supported  |
If you use the S5570S-EI, S5500V3-SI, S3600V3-EI, or S3600V3-SI switch series, reserve local VLAN interface resources by using the reserve-vlan-interface command before you switch Layer 2 Ethernet interfaces to Layer 3 Ethernet interfaces or create Layer 3 aggregate interfaces. For more information about VLAN interface resource reservation, see the VLAN configuration and commands for the products.
Procedures
# Create Layer 3 aggregate interface Route-Aggregation 1. Use one of the following methods as needed.
¡ Use the static aggregation mode to create Layer 3 aggregate interface Route-Aggregation 1.
[DeviceA] interface route-aggregation 1
¡ Use the dynamic aggregation mode to create Layer 3 aggregate interface Route-Aggregation 1.
[DeviceA-Route-Aggregation1] link-aggregation mode dynamic
# Configure an IP address and subnet mask for Layer 3 aggregate interface Route-Aggregation 1.
[DeviceA-Route-Aggregation1] ip address 192.168.1.1 24
[DeviceA-Route-Aggregation1] undo shutdown
[DeviceA-Route-Aggregation1] quit
[DeviceA-if-range] port link-mode route
[DeviceA-if-range] undo shutdown
GE1/0/1 S 32768 1
GE1/0/2 S 32768 1
GE1/0/3 S 32768 1
The output shows that all member ports in the local aggregation group are in Selected state. The Selected states of the local member ports are not affected by the Selected states of the peer member ports.
Local:
GE1/0/1(R) S 32768 2 1 {ACDEF}
Remote:
GE1/0/1 32768 2 1 0x8000, 68fa-34f2-0200 {ACDEF}
GE1/0/2 32768 3 1 0x8000, 68fa-34f2-0200 {ACDEF}
GE1/0/3 32768 4 1 0x8000, 68fa-34f2-0200 {ACDEF}
Configuration files
· Device A:
interface route-aggregation1
Device B:
The configuration file on Device B is similar as the configuration file on Device A.
As shown in Figure 5, configure link aggregation on Device A and Device B to meet the following requirements:
· Configure Layer 3 static aggregation groups 1 and 2 on both Device A and Device B.
· Assign IP addresses and subnet masks to the Layer 3 aggregate interfaces of the aggregation groups.
¡ Configure link aggregation group 1 to load share packets based on source IP addresses.
¡ Configure link aggregation group 2 to load share packets based on destination IP addresses.
   Hardware  |
   Software version  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
You can set the global or group-specific load sharing mode. A link aggregation group preferentially uses the group-specific load sharing mode. If the group-specific load sharing mode is not available, the group uses the global load sharing mode. This example uses group-specific load sharing mode configuration.
Procedures
# Configure Layer 3 aggregation group 1 to load share packets based on source IP addresses.
[DeviceA-Route-Aggregation1] link-aggregation load-sharing mode source-ip
# Create Layer 3 aggregate interface Route-Aggregation 2.
[DeviceA] interface route-aggregation 2
# Configure Layer 3 aggregation group 2 to load share packets based on destination IP addresses.
[DeviceA-Route-Aggregation2] link-aggregation load-sharing mode destination-ip
# Configure an IP address and subnet mask for Layer 3 aggregate interface Route-Aggregation 2.
[DeviceA-Route-Aggregation2] ip address 192.168.2.1 24
[DeviceA-Route-Aggregation2] quit
[DeviceA] interface range gigabitethernet 1/0/1 gigabitethernet 1/0/2
# Assign Layer 3 Ethernet interfaces GigabitEthernet 1/0/3 and GigabitEthernet 1/0/4 to aggregation group 2.
[DeviceA] interface range gigabitethernet 1/0/3 gigabitethernet 1/0/4
[DeviceA-if-range] port link-aggregation group 2
GE1/0/2 S 32768 1
Aggregate Interface: Route-Aggregation2
GE1/0/4 S 32768 2
[DeviceA] display link-aggregation load-sharing mode interface
Route-Aggregation1 load-sharing mode:
source-ip address
Route-Aggregation2 load-sharing mode:
destination-ip address
· Link aggregation group 1 distributes packets based on source IP addresses.
· Link aggregation group 2 distributes packets based on destination IP addresses.
Configuration files
· Device A:
interface Route-Aggregation1
interface Route-Aggregation2
ip address 192.168.2.1 255.255.255.0
· Device B:
The configuration file on Device B is similar to the configuration file on Device A.
