- H3C Fixed Port Campus Switches Configuration Examples-6W104
 - 00-Applicable hardware and software versions
 - 01-Login Management Configuration Examples
 - 02-RBAC Configuration Examples
 - 03-Software Upgrade Examples
 - 04-ISSU Configuration Examples
 - 05-Software Patching Examples
 - 06-Ethernet Link Aggregation Configuration Examples
 - 07-Port Isolation Configuration Examples
 - 08-Spanning Tree Configuration Examples
 - 09-VLAN Configuration Examples
 - 10-VLAN Tagging Configuration Examples
 - 11-DHCP Snooping Configuration Examples
 - 12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
 - 13-IPv6 over IPv4 Tunneling with OSPFv3 Configuration Examples
 - 14-IPv6 over IPv4 GRE Tunnel Configuration Examples
 - 15-GRE with OSPF Configuration Examples
 - 16-OSPF Configuration Examples
 - 17-IS-IS Configuration Examples
 - 18-BGP Configuration Examples
 - 19-Policy-Based Routing Configuration Examples
 - 20-OSPFv3 Configuration Examples
 - 21-IPv6 IS-IS Configuration Examples
 - 22-Routing Policy Configuration Examples
 - 23-IGMP Snooping Configuration Examples
 - 24-IGMP Configuration Examples
 - 25-MLD Snooping Configuration Examples
 - 26-IPv6 Multicast VLAN Configuration Examples
 - 27-ACL Configuration Examples
 - 28-Traffic Policing Configuration Examples
 - 29-GTS and Rate Limiting Configuration Examples
 - 30-Traffic Filtering Configuration Examples
 - 31-AAA Configuration Examples
 - 32-Port Security Configuration Examples
 - 33-Portal Configuration Examples
 - 34-SSH Configuration Examples
 - 35-IP Source Guard Configuration Examples
 - 36-Ethernet OAM Configuration Examples
 - 37-CFD Configuration Examples
 - 38-DLDP Configuration Examples
 - 39-VRRP Configuration Examples
 - 40-BFD Configuration Examples
 - 41-NTP Configuration Examples
 - 42-SNMP Configuration Examples
 - 43-NQA Configuration Examples
 - 44-Mirroring Configuration Examples
 - 45-sFlow Configuration Examples
 - 46-OpenFlow Configuration Examples
 - 47-MAC Address Table Configuration Examples
 - 48-Static Multicast MAC Address Entry Configuration Examples
 - 49-IP Unnumbered Configuration Examples
 - 50-MVRP Configuration Examples
 - 51-MCE Configuration Examples
 - 52-Attack Protection Configuration Examples
 - 53-Smart Link Configuration Examples
 - 54-RRPP Configuration Examples
 - 55-BGP Route Selection Configuration Examples
 - 56-IS-IS Route Summarization Configuration Examples
 - 57-VXLAN Configuration Examples
 - 58-DRNI Configuration Examples
 - 59-IRF 3.1 Configuration Examples
 - 60-PTP Configuration Examples
 - 61-S-MLAG Configuration Examples
 - 62-Puppet Configuration Examples
 - 63-802.1X Configuration Examples
 - 64-MAC Authentication Configuration Examples
 - 65-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
 - 66-BIDIR-PIM Configuration Examples
 - 67-Congestion Avoidance and Queue Scheduling Configuration Examples
 - 68-Basic MPLS Configuration Examples
 - 69-MPLS L3VPN Configuration Examples
 - 70-MPLS OAM Configuration Examples
 - 71-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
 - 72-DRNI and EVPN Configuration Examples
 - 73-Multicast VPN Configuration Examples
 - 74-MPLS TE Configuration Examples
 - 75-Control Plane-Based QoS Policy Configuration Examples
 - 76-Priority Mapping and Queue Scheduling Configuration Examples
 - 77-ARP Attack Protection Configuration Examples
 - 78-IRF Software Upgrade Configuration Examples
 - 79-IRF Member Replacement Configuration Examples
 - 80-Layer 3 Multicast on Multicast Source-Side DR System Configuration Examples
 - 81-EVPN Multicast Configuration Examples
| 67-Congestion Avoidance and Queue Scheduling Configuration Examples | 92.44 KB |
Example: Configuring congestion avoidance and queue scheduling
Introduction
This document provides examples for configuring congestion avoidance and queue scheduling profiles.
This document assumes that you have basic knowledge of congestion avoidance and queue scheduling profiles.
As shown in Figure 1, three types of traffic come from the Internet to the device through the gateway.
· Voice traffic—Transmitted in VLAN 6 and carries 802.1p priority 6.
· Video traffic—Transmitted in VLAN 4 and carries 802.1p priority 4.
· Data traffic—Transmitted in VLAN 2 and carries 802.1p priority 2.
Configure congestion avoidance and queue scheduling on the device to meet the following requirements:
· The voice traffic, video traffic, and data traffic are scheduled in the ratio of 1:2:2 when congestion occurs.
· WRED drop is used when serious congestion occurs.
Analysis
To configure congestion avoidance and queue scheduling, you must perform the following tasks:
· To assign different types of traffic to different queues, configure the inbound interface to trust the 802.1p priority in packets.
· To schedule the three types of traffic in the ratio of 1:2:2, assign their queues to one WRR group and configure weights for these queues.
· To minimize performance degradation for different types of traffic, use the drop parameters in Table 1.
    Traffic type  |
    Packet color  |
    Lower limit  |
    Upper limit  |
    Drop probability  |
   Voice  |
   Yellow  |
   1000  |
   1500  |
   3%  |
   Red  |
   500  |
   1000  |
   30%  |
   Video  |
   Yellow  |
   1000  |
   1500  |
   2%  |
   Red  |
   500  |
   1000  |
   20%  |
   Data  |
   Yellow  |
   1000  |
   1500  |
   1%  |
   Red  |
   500  |
   1000  |
   10%  |
   Hardware  |
   Software version  |
   S6812 switch series S6813 switch series  |
   Release 6615Pxx, Release 6628Pxx  |
   S6550XE-HI series  |
   Release 6008 and later, Release 8106Pxx  |
   S6525XE-HI series  |
   S5850 series  |
   Release 8005 and later  |
   S5570S-EI switch series  |
   Release 11xx  |
   S5560X-EI switch series  |
   Release 65xx, Release 6615Pxx, Release 6628Pxx  |
   S5560X-HI switch series  |
   S5500V2-EI switch series  |
   MS4520V2-30F switch  |
   MS4520V2-30C switch MS4520V2-54C switch  |
   MS4520V2-28S switch MS4520V2-24TP switch  |
   Release 65xx  |
   S6520X-HI switch series S6520X-EI switch series  |
   S6520X-SI switch series S6520-SI switch series  |
   S5000-EI switch series  |
   MS4600 switch series  |
   ES5500 switch series  |
   S5560S-EI switch series S5560S-SI switch series  |
   Not supported  |
   S5500V3-24P-SI S5500V3-48P-SI  |
   Not supported  |
   S5500V3-SI switch series (except S5500V3-24P-SI and S5500V3-48P-SI)  |
   Release 11xx  |
   S5170-EI switch series  |
   Release 11xx  |
   S5130S-HI switch series S5130S-EI switch series S5130S-SI switch series S5130S-LI switch series  |
   Not supported  |
   S5120V2-SI switch series S5120V2-LI switch series  |
   Not supported  |
   S5120V3-EI switch series  |
   Release 11xx  |
   S5120V3-36F-SI S5120V3-28P-HPWR-SI S5120V3-54P-PWR-SI  |
   Release 11xx  |
   S5120V3-SI switch series (except S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI)  |
   Not supported  |
   S5120V3-LI switch series  |
   Not supported  |
   S3600V3-EI switch series  |
   Release 11xx  |
   S3600V3-SI switch series  |
   Release 11xx  |
   S3100V3-EI switch series S3100V3-SI switch series  |
   Not supported  |
   S5110V2 switch series  |
   Not supported  |
   S5110V2-SI switch series  |
   Not supported  |
   S5000V3-EI switch series S5000V5-EI switch series  |
   Not supported  |
   S5000E-X switch series S5000X-EI switch series  |
   Not supported  |
   E128C E152C E500C switch series E500D switch series  |
   Not supported  |
   MS4320V2 switch series MS4320V3 switch series MS4300V2 switch series MS4320 switch series MS4200 switch series  |
   Not supported  |
   WS5850-WiNet switch series  |
   Not supported  |
   WS5820-WiNet switch series WS5810-WiNet switch series  |
   Not supported  |
   WAS6000 switch series  |
   Not supported  |
   IE4300-12P-AC IE4300-12P-PWR IE4300-M switch series IE4320 switch series  |
   Not supported  |
Procedures
1. Allow VLANs for different types of traffic to pass through:
# Create three VLANs .
[Device] vlan 2
[Device-vlan2] quit
[Device] vlan 4
[Device-vlan4] quit
[Device] vlan 6
[Device-vlan6] quit
# Assign interfaces to VLANs.
[Device] interface ten-gigabitethernet 1/0/28
[Device-Ten-Gigabitethernet1/0/28] port link-type trunk
[Device-Ten-Gigabitethernet1/0/28] port trunk permit vlan 2 4 6
[Device-Ten-Gigabitethernet1/0/28] quit
[Device-Gigabitethernet1/0/1] port link-type trunk
[Device-Gigabitethernet1/0/1] port trunk permit vlan 2 4 6
[Device-Gigabitethernet1/0/1] quit
[Device-Gigabitethernet1/0/2] port link-type trunk
[Device-Gigabitethernet1/0/2] port trunk permit vlan 2 4 6
[Device-Gigabitethernet1/0/2] quit
2. Configure interface Gigabitethernet 1/0/28 to trust the 802.1p priority in packets.
[Device-Ten-Gigabitethernet1/0/28] qos trust dot1p
3. Configure WRR on Gigabitethernet 1/0//1 and Gigabitethernet 1/0//2:
# Display the 802.1p-to-local precedence map to determine the local precedence for each type of traffic.
[Device] display qos map-table inbound dot1p-lp
MAP-TABLE NAME: dot1p-lp TYPE: pre-define
IMPORT : EXPORT
0 : 2
1 : 0
2 : 1
3 : 3
4 : 4
5 : 5
6 : 6
7 : 7
# Enable weight-based WRR on Gigabitethernet 1/0/1.
[Device-Gigabitethernet1/0/1] qos wrr weight
# Configure the weights of queue 1 (for data traffic), queue 4 (for video traffic), and queue 6 (for voice traffic) as 2, 2, and 1, respectively.
[Device-Gigabitethernet1/0/1] qos wrr 1 group 1 weight 2
[Device-Gigabitethernet1/0/1] qos wrr 4 group 1 weight 2
[Device-Gigabitethernet1/0/1] qos wrr 6 group 1 weight 1
# Enable weight-based WRR on Gigabitethernet 1/0/2.
[Device-Gigabitethernet1/0/2] qos wrr weight
[Device-Gigabitethernet1/0/2] qos wrr 1 group 1 weight 2
[Device-Gigabitethernet1/0/2] qos wrr 4 group 1 weight 2
[Device-Gigabitethernet1/0/2] qos wrr 6 group 1 weight 1
4. Configure congestion avoidance:
# Configure a WRED table.
[Device] qos wred queue table droppolicy
[Device-wred-table-droppolicy] queue 6 drop-level 1 low-limit 1000 high-limit 1500 discard-probability 3
[Device-wred-table-droppolicy] queue 6 drop-level 2 low-limit 500 high-limit 1000 discard-probability 30
[Device-wred-table-droppolicy] queue 4 drop-level 1 low-limit 1000 high-limit 1500 discard-probability 2
[Device-wred-table-droppolicy] queue 4 drop-level 2 low-limit 500 high-limit 1000 discard-probability 20
[Device-wred-table-droppolicy] queue 1 drop-level 1 low-limit 1000 high-limit 1500 discard-probability 1
[Device-wred-table-droppolicy] queue 1 drop-level 2 low-limit 500 high-limit 1000 discard-probability 10
[Device-wred-table-droppolicy] quit
# Apply the WRED table to interfaces Gigabitethernet 1/0/1 and Gigabitethernet 1/0/2.
[Device-Gigabitethernet1/0/1] qos wred apply droppolicy
[Device-Gigabitethernet1/0/2] qos wred apply droppolicy
# Verify the WRR configuration on interfaces Gigabitethernet 1/0/1 and Gigabitethernet 1/0/2.
[Device] display qos queue wrr interface
Interface: Gigabitethernet1/0/1
Output queue: Weighted Round Robin queuing
Queue ID Queue name Group Weight
0 be 1 1
1 af1 1 2
2 af2 1 3
3 af3 1 4
4 af4 1 2
5 ef 1 9
6 cs6 1 1
7 cs7 1 15
Interface: Gigabitethernet1/0/2
0 be 1 1
1 af1 1 2
2 af2 1 3
3 af3 1 4
4 af4 1 2
5 ef 1 9
6 cs6 1 1
7 cs7 1 15
# Display the WRED table configuration.
Table name: droppolicy
Table type: Queue based WRED
QID gmin gmax gprob ymin ymax yprob rmin rmax rprob exponent ECN
0 100 1000 10 100 1000 10 100 1000 10 9 N
1 100 1000 10 1000 1500 1 500 1000 10 9 N
2 100 1000 10 100 1000 10 100 1000 10 9 N
3 100 1000 10 100 1000 10 100 1000 10 9 N
4 100 1000 10 1000 1500 2 500 1000 20 9 N
5 100 1000 10 100 1000 10 100 1000 10 9 N
6 100 1000 10 1000 1500 3 500 1000 30 9 N
7 100 1000 10 100 1000 10 100 1000 10 9 N
Configuration files
vlan 1
vlan 2
vlan 4
vlan 6
interface Gigabitethernet1/0/1
port link-mode bridge
port trunk permit vlan 1 to 2 4 6
qos wrr weight
qos wrr af1 group 1 weight 2
qos wrr af4 group 1 weight 2
qos wrr cs6 group 1 weight 1
interface Gigabitethernet1/0/2
qos wrr weight
interface Ten-Gigabitethernet1/0/28
return
