- H3C Fixed Port Campus Switches Configuration Examples-6W104
- 00-Applicable hardware and software versions
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-DHCP Snooping Configuration Examples
- 12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 13-IPv6 over IPv4 Tunneling with OSPFv3 Configuration Examples
- 14-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 15-GRE with OSPF Configuration Examples
- 16-OSPF Configuration Examples
- 17-IS-IS Configuration Examples
- 18-BGP Configuration Examples
- 19-Policy-Based Routing Configuration Examples
- 20-OSPFv3 Configuration Examples
- 21-IPv6 IS-IS Configuration Examples
- 22-Routing Policy Configuration Examples
- 23-IGMP Snooping Configuration Examples
- 24-IGMP Configuration Examples
- 25-MLD Snooping Configuration Examples
- 26-IPv6 Multicast VLAN Configuration Examples
- 27-ACL Configuration Examples
- 28-Traffic Policing Configuration Examples
- 29-GTS and Rate Limiting Configuration Examples
- 30-Traffic Filtering Configuration Examples
- 31-AAA Configuration Examples
- 32-Port Security Configuration Examples
- 33-Portal Configuration Examples
- 34-SSH Configuration Examples
- 35-IP Source Guard Configuration Examples
- 36-Ethernet OAM Configuration Examples
- 37-CFD Configuration Examples
- 38-DLDP Configuration Examples
- 39-VRRP Configuration Examples
- 40-BFD Configuration Examples
- 41-NTP Configuration Examples
- 42-SNMP Configuration Examples
- 43-NQA Configuration Examples
- 44-Mirroring Configuration Examples
- 45-sFlow Configuration Examples
- 46-OpenFlow Configuration Examples
- 47-MAC Address Table Configuration Examples
- 48-Static Multicast MAC Address Entry Configuration Examples
- 49-IP Unnumbered Configuration Examples
- 50-MVRP Configuration Examples
- 51-MCE Configuration Examples
- 52-Attack Protection Configuration Examples
- 53-Smart Link Configuration Examples
- 54-RRPP Configuration Examples
- 55-BGP Route Selection Configuration Examples
- 56-IS-IS Route Summarization Configuration Examples
- 57-VXLAN Configuration Examples
- 58-DRNI Configuration Examples
- 59-IRF 3.1 Configuration Examples
- 60-PTP Configuration Examples
- 61-S-MLAG Configuration Examples
- 62-Puppet Configuration Examples
- 63-802.1X Configuration Examples
- 64-MAC Authentication Configuration Examples
- 65-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 66-BIDIR-PIM Configuration Examples
- 67-Congestion Avoidance and Queue Scheduling Configuration Examples
- 68-Basic MPLS Configuration Examples
- 69-MPLS L3VPN Configuration Examples
- 70-MPLS OAM Configuration Examples
- 71-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 72-DRNI and EVPN Configuration Examples
- 73-Multicast VPN Configuration Examples
- 74-MPLS TE Configuration Examples
- 75-Control Plane-Based QoS Policy Configuration Examples
- 76-Priority Mapping and Queue Scheduling Configuration Examples
- 77-ARP Attack Protection Configuration Examples
- 78-IRF Software Upgrade Configuration Examples
- 79-IRF Member Replacement Configuration Examples
- 80-Layer 3 Multicast on Multicast Source-Side DR System Configuration Examples
- 81-EVPN Multicast Configuration Examples
| 29-GTS and Rate Limiting Configuration Examples | 138.76 KB |
Introduction
This document provides GTS and rate limiting configuration examples.
This document assumes that you have basic knowledge of GTS and rate limiting.
Example: Configuring GTS and rate limiting
As shown in Figure 1, the 15-Mbps dedicated line transmits the FTP traffic, business-specific application traffic, and IP voice traffic between the headquarters and branch of a company.
The following traffic policing settings have been configured on the edge device (Switch B) of the headquarters:
· CIR of 10 Mbps for IP voice traffic.
· CIR of 3 Mbps for business-specific application traffic.
· CIR of 7 Mbps for FTP traffic.
Configure traffic shaping on the edge device (Switch A) of the branch to buffer excess traffic of each traffic type.
Configure rate limiting on Switch A to limit the outgoing traffic rate to 15 Mbps.
Analysis
To meet the network requirements, you must perform the following tasks:
· To implement GTS, first determine the queue that transmits a type of traffic. In this example, the priorities of these types of traffic are not provided. You need to use priority marking to manually assign packets to different queues.
· You can manually assign packets to queues by marking DSCP values, 802.1p priority values, or local precedence values. To keep the contents of packets unchanged, mark local precedence values for packets.
Hardware |
Software version |
S6812 switch series S6813 switch series |
Release 6615Pxx, Release 6628Pxx |
S6550XE-HI switch series |
Release 6008 and later, Release 8106Pxx |
S6525XE-HI switch series |
S5850 switch series |
Release 8005 and later |
S5570S-EI switch series |
Release 11xx |
S5560X-EI switch series |
Release 63xx, Release 65xx, Release 6615Pxx, Release 6628Pxx |
S5560X-HI switch series |
S5500V2-EI switch series |
MS4520V2-30F switch |
MS4520V2-30C switch MS4520V2-54C switch |
MS4520V2-28S switch MS4520V2-24TP switch |
Release 63xx |
S6520X-HI switch series S6520X-EI switch series |
S6520X-SI switch series S6520-SI switch series |
S5000-EI switch series |
MS4600 switch series |
ES5500 switch series |
S5560S-EI switch series S5560S-SI switch series |
Release 63xx |
S5500V3-24P-SI S5500V3-48P-SI |
Release 63xx |
S5500V3-SI switch series (except S5500V3-24P-SI and S5500V3-48P-SI) |
Release 11xx |
S5170-EI switch series |
Release 11xx |
S5130S-HI switch series S5130S-EI switch series S5130S-SI switch series S5130S-LI switch series |
Release 63xx |
S5120V2-SI switch series S5120V2-LI switch series |
Release 63xx |
S5120V3-EI switch series |
Release 11xx |
S5120V3-36F-SI S5120V3-28P-HPWR-SI S5120V3-54P-PWR-SI |
Release 11xx |
S5120V3-SI switch series (except S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI) |
Release 63xx |
S5120V3-LI switch series |
Release 63xx |
S3600V3-EI switch series |
Release 11xx |
S3600V3-SI switch series |
Release 11xx |
S3100V3-EI switch series S3100V3-SI switch series |
Release 63xx |
S5110V2 switch series |
Release 63xx |
S5110V2-SI switch series |
Release 63xx |
S5000V3-EI switch series S5000V5-EI switch series |
Release 63xx |
S5000E-X switch series S5000X-EI switch series |
Release 63xx |
E128C switch E152C switch E500C switch series E500D switch series |
Release 63xx |
MS4320V2 switch series MS4320V3 switch series MS4300V2 switch series MS4320 switch series MS4200 switch series |
Release 63xx |
WS5850-WiNet switch series |
Release 63xx |
WS5820-WiNet switch series WS5810-WiNet switch series |
Release 63xx |
WAS6000 switch series |
Release 63xx |
IE4300-12P-AC switch IE4300-12P-PWR switch IE4300-M switch series IE4320 switch series |
Release 63xx |
The port link-mode command is not supported on the following switches and the port link-mode bridge command does not appear in their configuration files.
· S5130S-HI series.
· S5130S-EI series.
· S3100V3-EI series.
· E128C switch.
· E152C switch.
· E500C series.
· E500D series.
· IE4300-12P-AC switch
· IE4300-12P-PWR switch.
· IE4300-M series.
· IE4320 series.
Procedures
Before configuring GTS and rate limiting, make sure there is network connectivity between the branch and headquarters.
This section does not describe the configurations for enabling network connectivity.
Configuring priority marking
1. Create three traffic classes to match the three traffic types:
# Configure basic IPv4 ACL 2000 to match IP voice traffic (traffic from subnet 192.168.3.0/24).
[SwitchA] acl basic 2000
[SwitchA-acl-ipv4-basic-2000] rule permit source 192.168.3.0 0.0.0.255
# Create a class named voice, and use ACL 2000 as the match criterion.
[SwitchA] traffic classifier voice
[SwitchA-classifier-voice] if-match acl 2000
[SwitchA-classifier-voice] quit
# Configure basic IPv4 ACL 2001 to match application traffic (traffic from subnet 192.168.2.0/24).
[SwitchA] acl basic 2001
[SwitchA-acl-ipv4-basic-2001] rule permit source 192.168.2.0 0.0.0.255
[SwitchA-acl-ipv4-basic-2001] quit
# Create a class named service, and use ACL 2001 as the match criterion.
[SwitchA] traffic classifier service
[SwitchA-classifier-service] if-match acl 2001
[SwitchA-classifier-service] quit
# Configure advanced IPv4 ACL 3000 to match FTP traffic (traffic from subnet 192.168.1.0/24 and with destination port number 20).
[SwitchA] acl advanced 3000
[SwitchA-acl-ipv4-adv-3000] rule permit tcp destination-port eq 20 source 192.168.1.0 0.0.0.255
[SwitchA-acl-ipv4-adv-3000] quit
# Create a class named ftp, and use ACL 3000 as the match criterion.
[SwitchA] traffic classifier ftp
[SwitchA-classifier-ftp] if-match acl 3000
[SwitchA-classifier-ftp] quit
2. Create three traffic behaviors:
# Create a behavior named voice, and configure the behavior to mark packets with local precedence 6 (corresponding to queue 6).
[SwitchA] traffic behavior voice
[SwitchA-behavior-voice] remark local-precedence 6
[SwitchA-behavior-voice] quit
# Create a behavior named service, and configure the behavior to mark packets with local precedence 4 (corresponding to queue 4).
[SwitchA] traffic behavior service
[SwitchA-behavior-service] remark local-precedence 4
[SwitchA-behavior-service] quit
# Create a behavior named ftp, and configure the behavior to mark packets with local precedence 2 (corresponding to queue 2).
[SwitchA] traffic behavior ftp
[SwitchA-behavior-ftp] remark local-precedence 2
[SwitchA-behavior-ftp] quit
3. Configure and apply a QoS policy:
# Create a QoS policy named shaping, and associate the three classes with their respective behaviors in the QoS policy.
[SwitchA] qos policy shaping
[SwitchA-qospolicy-shaping] classifier voice behavior voice
[SwitchA-qospolicy-shaping] classifier service behavior service
[SwitchA-qospolicy-shaping] classifier ftp behavior ftp
[SwitchA-qospolicy-shaping] quit
# Apply the QoS policy shaping to the inbound direction of GigabitEthernet 1/0/2.
[SwitchA] interface gigabitethernet 1/0/2
[SwitchA-GigabitEthernet1/0/2] qos apply policy shaping inbound
[SwitchA-GigabitEthernet1/0/2] quit
Configuring GTS
# Configure GTS on GigabitEthernet 1/0/1 to set the CIR to 10 Mbps for queue 6 (IP voice traffic).
[SwitchA-GigabitEthernet1/0/1] qos gts queue 6 cir 10240
# Configure GTS on GigabitEthernet 1/0/1 to set the CIR to 3 Mbps for queue 4 (application traffic).
[SwitchA-GigabitEthernet1/0/1] qos gts queue 4 cir 3072
# Configure GTS on GigabitEthernet 1/0/1 to set the CIR to 7 Mbps for queue 2 (FTP traffic).
[SwitchA-GigabitEthernet1/0/1] qos gts queue 2 cir 7168
Configuring rate limiting
# Configure rate limiting on GigabitEthernet 1/0/1 to set the CIR to 15 Mbps for outgoing traffic.
[SwitchA-GigabitEthernet1/0/1] qos lr outbound cir 15360
# Verify the priority marking settings of GigabitEthernet 1/0/2.
<Sysname> display qos policy interface inbound
Direction: Inbound
Policy: shaping
Classifier: voice
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: voice
Marking:
Remark local-precedence 6
Classifier: service
Operator: AND
Rule(s) :
If-match acl 2001
Behavior: service
Marking:
Remark local-precedence 4
Classifier: ftp
Operator: AND
Rule(s) :
If-match acl 3000
Behavior: ftp
Marking:
Remark local-precedence 2
# Verify the GTS settings on GigabitEthernet 1/0/1.
Rule: If-match queue 6
CIR 10240 (kbps), CBS 640000 (Bytes)
Rule: If-match queue 4
CIR 3072 (kbps), CBS 192000 (Bytes)
Rule: If-match queue 2
CIR 7168 (kbps), CBS 448000 (Bytes)
# Verify the rate limiting settings on GigabitEthernet 1/0/1.
Direction: Outbound
CIR 15360 (kbps), CBS 960000 (Bytes)
Configuration files
acl basic 2000
rule 0 permit source 192.168.3.0 0.0.0.255
acl basic 2001
rule 0 permit source 192.168.2.0 0.0.0.255
acl advanced 3000
rule 0 permit tcp source 192.168.1.0 0.0.0.255 destination-port eq ftp-data
traffic classifier ftp operator and
if-match acl 3000
traffic classifier service operator and
if-match acl 2001
traffic classifier voice operator and
if-match acl 2000
qos policy shaping
qos lr outbound cir 15360 cbs 960000
qos gts queue 6 cir 10240 cbs 640000
qos gts queue 4 cir 3072 cbs 192000
qos gts queue 2 cir 7168 cbs 448000
return
