- H3C Fixed Port Campus Switches Configuration Examples-6W104
 - 00-Applicable hardware and software versions
 - 01-Login Management Configuration Examples
 - 02-RBAC Configuration Examples
 - 03-Software Upgrade Examples
 - 04-ISSU Configuration Examples
 - 05-Software Patching Examples
 - 06-Ethernet Link Aggregation Configuration Examples
 - 07-Port Isolation Configuration Examples
 - 08-Spanning Tree Configuration Examples
 - 09-VLAN Configuration Examples
 - 10-VLAN Tagging Configuration Examples
 - 11-DHCP Snooping Configuration Examples
 - 12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
 - 13-IPv6 over IPv4 Tunneling with OSPFv3 Configuration Examples
 - 14-IPv6 over IPv4 GRE Tunnel Configuration Examples
 - 15-GRE with OSPF Configuration Examples
 - 16-OSPF Configuration Examples
 - 17-IS-IS Configuration Examples
 - 18-BGP Configuration Examples
 - 19-Policy-Based Routing Configuration Examples
 - 20-OSPFv3 Configuration Examples
 - 21-IPv6 IS-IS Configuration Examples
 - 22-Routing Policy Configuration Examples
 - 23-IGMP Snooping Configuration Examples
 - 24-IGMP Configuration Examples
 - 25-MLD Snooping Configuration Examples
 - 26-IPv6 Multicast VLAN Configuration Examples
 - 27-ACL Configuration Examples
 - 28-Traffic Policing Configuration Examples
 - 29-GTS and Rate Limiting Configuration Examples
 - 30-Traffic Filtering Configuration Examples
 - 31-AAA Configuration Examples
 - 32-Port Security Configuration Examples
 - 33-Portal Configuration Examples
 - 34-SSH Configuration Examples
 - 35-IP Source Guard Configuration Examples
 - 36-Ethernet OAM Configuration Examples
 - 37-CFD Configuration Examples
 - 38-DLDP Configuration Examples
 - 39-VRRP Configuration Examples
 - 40-BFD Configuration Examples
 - 41-NTP Configuration Examples
 - 42-SNMP Configuration Examples
 - 43-NQA Configuration Examples
 - 44-Mirroring Configuration Examples
 - 45-sFlow Configuration Examples
 - 46-OpenFlow Configuration Examples
 - 47-MAC Address Table Configuration Examples
 - 48-Static Multicast MAC Address Entry Configuration Examples
 - 49-IP Unnumbered Configuration Examples
 - 50-MVRP Configuration Examples
 - 51-MCE Configuration Examples
 - 52-Attack Protection Configuration Examples
 - 53-Smart Link Configuration Examples
 - 54-RRPP Configuration Examples
 - 55-BGP Route Selection Configuration Examples
 - 56-IS-IS Route Summarization Configuration Examples
 - 57-VXLAN Configuration Examples
 - 58-DRNI Configuration Examples
 - 59-IRF 3.1 Configuration Examples
 - 60-PTP Configuration Examples
 - 61-S-MLAG Configuration Examples
 - 62-Puppet Configuration Examples
 - 63-802.1X Configuration Examples
 - 64-MAC Authentication Configuration Examples
 - 65-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
 - 66-BIDIR-PIM Configuration Examples
 - 67-Congestion Avoidance and Queue Scheduling Configuration Examples
 - 68-Basic MPLS Configuration Examples
 - 69-MPLS L3VPN Configuration Examples
 - 70-MPLS OAM Configuration Examples
 - 71-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
 - 72-DRNI and EVPN Configuration Examples
 - 73-Multicast VPN Configuration Examples
 - 74-MPLS TE Configuration Examples
 - 75-Control Plane-Based QoS Policy Configuration Examples
 - 76-Priority Mapping and Queue Scheduling Configuration Examples
 - 77-ARP Attack Protection Configuration Examples
 - 78-IRF Software Upgrade Configuration Examples
 - 79-IRF Member Replacement Configuration Examples
 - 80-Layer 3 Multicast on Multicast Source-Side DR System Configuration Examples
 - 81-EVPN Multicast Configuration Examples
| 41-NTP Configuration Examples | 315.57 KB |
Example: Configuring the NTP client/server mode
Example: Configuring the NTP broadcast mode
Configuring Device A, Device B, Device D, and Device E
Example: Configuring the NTP multicast mode
Example: Configuring NTP client/server mode with authentication
Example: Configuring the IPv6 NTP client/server mode
Example: Configuring the IPv6 NTP multicast mode
Example: Configuring NTP broadcast mode with authentication
Introduction
This document provides NTP configuration examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of NTP.
As shown in Figure 1, configure the NTP client/server mode so all devices can be synchronized to Device A, the NTP server.
   Hardware  |
   Software version  |
   S6812 switch series S6813 switch series  |
   Release 6615Pxx, Release 6628Pxx  |
   S6550XE-HI switch series  |
   Release 6008 and later, Release 8106Pxx  |
   S6525XE-HI switch series  |
   S5850 switch series  |
   Release 8005 and later  |
   S5570S-EI switch series  |
   Release 11xx  |
   S5560X-EI switch series  |
   Release 63xx, Release 65xx, Release 6615Pxx, Release 6628Pxx  |
   S5560X-HI switch series  |
   S5500V2-EI switch series  |
   MS4520V2-30F  |
   MS4520V2-30C MS4520V2-54C  |
   MS4520V2-28S MS4520V2-24TP  |
   Release 63xx  |
   ES5500 switch series  |
   S6520X-HI switch series S6520X-EI switch series  |
   S6520X-SI switch series S6520-SI switch series  |
   S5000-EI switch series  |
   MS4600 switch series  |
   S5560S-EI switch series S5560S-SI switch series  |
   Release 63xx  |
   S5500V3-24P-SI S5500V3-48P-SI  |
   Release 63xx  |
   S5500V3-SI switch series (except the S5500V3-24P-SI and S5500V3-48P-SI)  |
   Release 11xx  |
   S5170-EI switch series  |
   Release 11xx  |
   S5130S-HI switch series S5130S-EI switch series S5130S-SI switch series S5130S-LI switch series  |
   Release 63xx  |
   S5120V2-SI switch series S5120V2-LI switch series  |
   Release 63xx  |
   S5120V3-EI switch series  |
   Release 11xx  |
   S5120V3-36F-SI S5120V3-28P-HPWR-SI S5120V3-54P-PWR-SI  |
   Release 11xx  |
   S5120V3-SI switch serie (except the S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI)  |
   Release 63xx  |
   S5120V3-LI switch series  |
   Release 63xx  |
   S3600V3-EI switch series  |
   Release 11xx  |
   S3600V3-SI switch series  |
   Release 11xx  |
   S3100V3-EI switch series S3100V3-SI switch series  |
   Release 63xx  |
   S5110V2 switch series  |
   Release 63xx  |
   S5110V2-SI switch series  |
   Release 63xx  |
   S5000V3-EI switch series S5000V5-EI switch series  |
   Release 63xx  |
   S5000E-X switch series S5000X-EI switch series  |
   Release 63xx  |
   E128C E152C E500C switch series E500D switch series  |
   Release 63xx  |
   MS4320V2 switch series MS4320V3 switch series MS4300V2 switch series MS4320 switch series MS4200 switch series  |
   Release 63xx  |
   WS5850-WiNet switch series  |
   Release 63xx  |
   WS5820-WiNet switch series WS5810-WiNet switch series  |
   Release 63xx  |
   WAS6000 switch series  |
   Release 63xx  |
   IE4300-12P-AC & IE4300-12P-PWR IE4300-M switch series IE4320 switch series  |
   Release 63xx  |
Procedures
# Assign an IP address to VLAN-interface 2.
[DeviceA] interface Vlan-interface 2
[DeviceA-Vlan-interface2] ip address 1.0.1.11 24
[DeviceA-Vlan-interface2] quit
# Enable the NTP service.
[DeviceA] ntp-service enable
# Specify the local clock as the reference source, with the stratum level 2.
[DeviceA] ntp-service refclock-master 2
Configuring Device B
# Assign an IP address to VLAN-interface 2. (Details not shown.)
[DeviceB] ntp-service enable
# Specify Device A as the NTP server of Device B so that Device B is synchronized to Device A.
[DeviceB] ntp-service unicast-server 1.0.1.11
Configuring Device C
<DeviceC> system-view
[DeviceC] ntp-service enable
# Specify Device A as the NTP server of Device C so that Device C is synchronized to Device A.
[DeviceC] ntp-service unicast-server 1.0.1.11
# Verify that Device B has synchronized to Device A, and the clock stratum level is 3 on Device B and 2 on Device A.
[DeviceB] display ntp-service status
Clock status: synchronized
Clock stratum: 3
System peer: 1.0.1.11
Local mode: client
Reference clock ID: 1.0.1.11
Leap indicator: 00
Clock jitter: 0.003479 s
Stability: 0.000 pps
Clock precision: 2^-19
Root delay: 1.95313 ms
Root dispersion: 28.38135 ms
Reference time: d5ed8cd5.577006ea Wed, Sep 25 2019 16:24:53.341
System poll interval: 64 s
# Verify that an IPv4 NTP association has been established between Device B and Device A.
[DeviceB] display ntp-service sessions
source reference stra reach poll now offset delay disper
[12345]1.0.1.11 127.127.1.0 2 255 64 38 -10.22 1.9531 3.3416
Total sessions: 1
   NOTE: · For the S6550XE-HI switch series and the S6525XE-HI switch series, the value is 2^-21 for the Clock precision field in the output from the display ntp-service status command. · For the S6812 switch series, S6813 switch series, and S5850 switch series, the value is 2^-23 for the Clock precision field in the output from the display ntp-service status command. · For the S5170-EI switch series and S5570S-EI switch series, the value is 2^-18 for the Clock precision field in the output from the display ntp-service status command.  |
Configuration files
· Device A:
interface Vlan-interface2
ip address 1.0.1.11 255.255.255.0
ntp-service enable
· Device B:
ip address 1.0.1.12 255.255.255.0
ntp-service enable
· Device C:
ip address 1.0.1.13 255.255.255.0
ntp-service enable
As shown in Figure 2, configure the NTP broadcast mode so all devices on the same network segment can be synchronized to Device C, the NTP server.
    Hardware  |
    Software version  |
   Release 11xx  |
   MS4520V2-30F  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 11xx  |
   Release 11xx  |
   Release 63xx  |
   Release 63xx  |
   Release 11xx  |
   Release 11xx  |
   S5120V3-SI switch series (except the S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI)  |
   Release 63xx  |
   Release 63xx  |
   Release 11xx  |
   Release 11xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
Procedures
[DeviceC] ntp-service refclock-master 2
[DeviceC] interface Vlan-interface 2
[DeviceC-Vlan-interface2] ip address 3.0.1.31 24
# Configure Device C to operate in broadcast server mode and send broadcast messages from VLAN-interface 2.
[DeviceC-Vlan-interface2] ntp-service broadcast-server
# Configure Device A to operate in broadcast client mode and receive broadcast messages on VLAN-interface 2.
[DeviceA-Vlan-interface2] ntp-service broadcast-client
# Configure Device B, Device D, and Device E in the same way Device A is configured. (Details not shown.)
# Verify that Device A has synchronized to Device C, and the clock stratum level is 3 on Device A and 2 on Device C.
[DeviceA-Vlan-interface2] display ntp-service status
Clock stratum: 3
System peer: 3.0.1.31
Local mode: bclient
Reference clock ID: 3.0.1.31
Leap indicator: 00
Clock jitter: 0.000061 s
Root delay: 0.00000 ms
Root dispersion: 7951.43127 ms
Reference time: d5ee8d88.2faabed0 Thu, Sep 26 2019 10:40:08.186
# Verify that an IPv4 NTP association has been established between Device A and Device C.
[DeviceA-Vlan-interface2] display ntp-service sessions
[1234]3.0.1.31 127.127.1.0 2 254 64 82 -2.190 0.0000 7937.5
Total sessions: 1
Configuration files
· Device C:
ip address 3.0.1.31 255.255.255.0
ntp-service enable
· Device A:
ip address 3.0.1.33 255.255.255.0
ntp-service enable
· Device B:
ip address 3.0.1.30 255.255.255.0
ntp-service enable
· Device D:
ip address 3.0.1.32 255.255.255.0
ntp-service enable
· Device E:
ip address 3.0.1.34 255.255.255.0
ntp-service enable
As shown in Figure 3, configure the NTP multicast mode so all devices on different network segments can be synchronized to Device C, the NTP server.
    Hardware  |
    Software version  |
   Release 11xx  |
   Release 63xx, Release 65xx, and Release 6615Pxx, Release 6628Pxx  |
   MS4520V2-30F  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 11xx  |
   Release 11xx  |
   Release 63xx  |
   Release 63xx  |
   Release 11xx  |
   Release 11xx  |
   Release 63xx  |
   Release 63xx  |
   Release 11xx  |
   Release 11xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
Procedures
# Configure Device C to operate in multicast server mode and send multicast messages from VLAN-interface 2.
[DeviceC-Vlan-interface2] ntp-service multicast-server
Configuring Device D
<DeviceD> system-view
[DeviceD] ntp-service enable
[DeviceD] interface Vlan-interface 2
[DeviceD-Vlan-interface2] ip address 3.0.1.32 24
# Configure Device D to operate in multicast client mode and receive multicast messages on VLAN-interface 2.
[DeviceD-Vlan-interface2] ntp-service multicast-client
# Configure Device B to operate in multicast client mode and receive multicast messages on VLAN-interface 2.
[DeviceB-Vlan-interface2] ntp-service multicast-client
[DeviceB-Vlan-interface2] quit
Because Device A and Device C are on different subnets, you must enable the multicast functions on Device B before Device A can receive multicast messages from Device C.
# Enable IP multicast routing and IGMP.
[DeviceB] multicast routing
[DeviceB] interface vlan-interface 2
[DeviceB-Vlan-interface2] pim dm
[DeviceB] vlan 3
[DeviceB-vlan3] port GigabitEthernet 1/0/1
[DeviceB-vlan3] quit
[DeviceB] interface vlan-interface 3
[DeviceB-Vlan-interface3] ip address 1.0.1.10 24
[DeviceB-Vlan-interface3] igmp enable
[DeviceB-Vlan-interface3] igmp static-group 224.0.1.1
[DeviceB-Vlan-interface3] quit
[DeviceB] igmp-snooping
[DeviceB-igmp-snooping] quit
[DeviceB] interface GigabitEthernet 1/0/1
[DeviceB-GigabitEthernet1/0/1] igmp-snooping static-group 224.0.1.1 vlan 3
# Assign an IP address to VLAN-interface 3.
[DeviceA] interface Vlan-interface 3
[DeviceA-Vlan-interface3] ip address 1.0.1.11 24
# Configure Device A to operate in multicast client mode and receive multicast messages on VLAN-interface 3.
[DeviceA-Vlan-interface3] ntp-service multicast-client
[DeviceA-Vlan-interface3] display ntp-service status
Clock stratum: 3
Local mode: bclient
Leap indicator: 00
Root delay: 1.69373 ms
Root dispersion: 1950.18005 ms
Reference time: d5ee9b15.2f3a684d Thu, Sep 26 2019 11:37:57.184
Configuration files
· Device A:
ntp-service enable
interface Vlan-interface3
· Device B:
ntp-service enable
multicast routing
igmp-snooping
pim dm
ip address 1.0.1.10 255.255.255.0
igmp enable
port access vlan 3
· Device C:
ntp-service enable
· Device D:
ntp-service enable
As shown in Figure 4, configure the NTP client/server mode so all devices can be synchronized to Device A, the NTP server. Configure NTP authentication on Device A, Device B, and Device C.
    Hardware  |
    Software version  |
   Release 11xx  |
   MS4520V2-30F  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 11xx  |
   Release 11xx  |
   Release 63xx  |
   Release 63xx  |
   Release 11xx  |
   Release 11xx  |
   Release 63xx  |
   Release 63xx  |
   Release 11xx  |
   Release 11xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
Procedures
# Enable NTP authentication on Device A.
[DeviceA] ntp-service authentication enable
# Set an authentication key, and input the key in plain text.
[DeviceA] ntp-service authentication-keyid 42 authentication-mode md5 simple aNiceKey
# Specify the key as a trusted key.
[DeviceA] ntp-service reliable authentication-keyid 42
# Enable NTP authentication on Device B.
[DeviceB] ntp-service authentication enable
[DeviceB] ntp-service authentication-keyid 42 authentication-mode md5 simple aNiceKey
[DeviceB] ntp-service reliable authentication-keyid 42
# Specify Device A as the NTP server of Device B, and associate the server with key 42.
[DeviceB] ntp-service unicast-server 1.0.1.11 authentication-keyid 42
# Enable NTP authentication on Device C.
[DeviceC] ntp-service authentication enable
[DeviceC] ntp-service authentication-keyid 42 authentication-mode md5 simple aNiceKey
[DeviceC] ntp-service reliable authentication-keyid 42
# Specify Device A as the NTP server of Device C, and associate the server with key 42.
[DeviceC] ntp-service unicast-server 1.0.1.11 authentication-keyid 42
Clock stratum: 3
Local mode: client
Leap indicator: 00
Clock jitter: 0.005096 s
Root delay: 0.00655 ms
Root dispersion: 1.15869 ms
Reference time: d0c62687.ab1bba7d Mon, Sep 30 2019 16:06:26.764
[1245]1.0.1.11 127.127.1.0 2 1 64 519 -0.0 0.0065 0.0
Total sessions : 1
Configuration files
· Device A:
ntp-service enable
ntp-service authentication-keyid 42 authentication-mode md5 cipher $c$3$4j3SKCgQWBK3Un41B9U0JXzJX9i7IuNoSqi
· Device B:
ntp-service enable
ntp-service authentication-keyid 42 authentication-mode md5 cipher $c$3$22eIc8l796cpudZqiaAZ2SLzIfrgzFTVYn8X
· Device C:
ntp-service enable
ntp-service authentication-keyid 42 authentication-mode md5 cipher $c$3$XJzVmJ1TJbWyYAXpPXxF7JiEOZag8CehibM8
Example: Configuring SNTP
As shown in Figure 5, configure SNTP so all devices can be synchronized to Device A, the NTP server.
    Hardware  |
    Software version  |
   Release 11xx  |
   MS4520V2-30F  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 11xx  |
   Release 11xx  |
   Release 63xx  |
   Release 63xx  |
   Release 11xx  |
   Release 11xx  |
   Release 63xx  |
   Release 63xx  |
   Release 11xx  |
   Release 11xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
Procedures
# Enable the SNTP service.
[DeviceB] sntp enable
# Specify Device A as the NTP server for Device B.
[DeviceB] sntp unicast-server 1.0.1.11
[DeviceC] sntp enable
# Specify Device A as the NTP server for Device C.
[DeviceC] sntp unicast-server 1.0.1.11
# Verify that an SNTP association has been established between Device B and Device A, and Device B has synchronized to Device A.
[DeviceB] display sntp sessions
SNTP server Stratum Version Last receive time
1.0.1.11 2 4 Thu, Sep 26 2019 17:25:09.121 (Synced)
Configuration files
· Device A:
ntp-service enable
· Device B:
sntp enable
· Device C:
sntp enable
As shown in Figure 1, configure the IPv6 NTP client/server mode so all devices can synchronize to Device A, the NTP server.
Figure 6 Network diagram
    Hardware  |
    Software version  |
   Release 11xx  |
   MS4520V2-30F  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 11xx  |
   Release 11xx  |
   Release 63xx  |
   Release 63xx  |
   Release 11xx  |
   Release 11xx  |
   Release 63xx  |
   Release 63xx  |
   Release 11xx  |
   Release 11xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
Procedures
# Assign an IPv6 address to VLAN-interface 2.
[DeviceA] interface vlan-interface 2
[DeviceA-Vlan-interface2] ipv6 address 3000::34 64
# Assign an IPv6 address to each interface. (Details not shown.)
[DeviceB] ntp-service unicast-server 3000::34
[DeviceC] ntp-service unicast-server 3000::34
Clock stratum: 3
System peer: 3000::34
Local mode: client
Reference clock ID: 95.197.17.40
Leap indicator: 00
# Verify that an IPv6 NTP association has been established between Device B and Device A.
[DeviceB] display ntp-service ipv6 sessions
Source: [12345] 3000::34
Reference: 127.127.1.0 Clock stratum: 2
Reachabilities: 3 Poll interval: 64
Last receive time: 62 Offset: 0.1272
Roundtrip delay: 1.8158 Dispersion: 188.47
Total sessions: 1
Configuration files
· Device A:
ipv6 address 3000::34/64
ntp-service enable
· Device B:
ipv6 address 3000::35/64
ntp-service enable
ntp-service ipv6 unicast-server 3000::34
· Device C:
ipv6 address 3000::36/64
ntp-service enable
As shown in Figure 3, configure the IPv6 NTP multicast mode so all devices on different network segments can synchronize to Device C, the NTP server.
Figure 7 Network diagram
    Hardware  |
    Software version  |
   Release 11xx  |
   MS4520V2-30F  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 11xx  |
   Release 11xx  |
   Release 63xx  |
   Release 63xx  |
   Release 11xx  |
   Release 11xx  |
   Release 63xx  |
   Release 63xx  |
   Release 11xx  |
   Release 11xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
Procedures
# Configure routing protocols so that all devices can reach each other. (Details not shown.)
[DeviceC-Vlan-interface2] ipv6 address 3000::2 64
# Configure Device C to operate in IPv6 multicast server mode and send multicast messages from VLAN-interface 2.
[DeviceC-Vlan-interface2] ntp-service ipv6 multicast-server ff24::1
[DeviceC-Vlan-interface2] quit
# Configure routing protocols and assign an IP address to each interface so that all devices can reach each other. (Details not shown.)
# Configure Device D to operate in IPv6 multicast client mode and receive multicast messages on VLAN-interface 2.
[DeviceD-Vlan-interface2] ntp-service ipv6 multicast-client ff24::1
[DeviceD-Vlan-interface2] quit
# Configure Device B to operate in IPv6 multicast client mode and receive multicast messages on VLAN-interface 2.
[DeviceB-Vlan-interface2] ntp-service ipv6 multicast-client ff24::1
Because Device A and Device C are on different subnets, you must enable IPv6 multicast functions on Device B before Device A can receive multicast messages from Device C.
# Enable IPv6 multicast functions.
[DeviceB] ipv6 multicast routing
[DeviceB-mrib6] quit
[DeviceB-Vlan-interface2] ipv6 pim dm
[DeviceB] vlan 3
[DeviceB-Vlan-interface3] mld enable
[DeviceB-Vlan-interface3] mld static-group ff24::1
[DeviceB] mld-snooping
[DeviceB-mld-snooping] quit
[DeviceB-GigabitEthernet1/0/1] mld-snooping static-group ff24::1 vlan 3
# Configure Device A to operate in IPv6 multicast client mode and receive multicast messages on VLAN-interface 3.
[DeviceA-Vlan-interface3] ntp-service ipv6 multicast-client ff24::1
[DeviceA-Vlan-interface3] quit
[DeviceA] display ntp-service status
Clock stratum: 3
System peer: 3000::2
Local mode: bclient
Reference clock ID: 165.84.121.65
Leap indicator: 00
Configuration files
· Device A:
ntp-service enable
ipv6 address 2000::1/64
· Device B:
ntp-service enable
mld-snooping
ipv6 address 3000::1/64
ipv6 pim dm
ipv6 address 2000::2/64
mld enable
port access vlan 3
· Device C:
ntp-service enable
ipv6 address 3000::2/64
· Device D:
ntp-service enable
ipv6 address 3000::3/64
As shown in Figure 4, configure NTP broadcast mode so all devices can synchronize to Device A, the NTP server. Configure NTP authentication on Device A, Device B, and Device C.
Figure 8 Network diagram
    Hardware  |
    Software version  |
   Release 11xx  |
   MS4520V2-30F  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 11xx  |
   Release 11xx  |
   Release 63xx  |
   Release 63xx  |
   Release 11xx  |
   Release 11xx  |
   Release 63xx  |
   Release 63xx  |
   Release 11xx  |
   Release 11xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
   Release 63xx  |
Procedures
Configure Device C
# Specify the local clock as the reference source, with the stratum level 2 on Device C.
# Enable NTP authentication on Device C. Configure an NTP authentication key, with the key ID of 88 and key value of 123456. Input the key in plain text, and specify it as a trusted key.
[DeviceC] ntp-service authentication-keyid 88 authentication-mode md5 simple 123456
[DeviceC] ntp-service reliable authentication-keyid 88
# Specify Device C as an NTP broadcast server, and associate key 88 with Device C.
[DeviceC] interface vlan-interface 2
[DeviceC-Vlan-interface2] ntp-service broadcast-server authentication-keyid 88
Configure Device A
# Enable NTP authentication on Device A. Configure an NTP authentication key, with the key ID of 88 and key value of 123456. Input the key in plain text, and specify it as a trusted key.
[DeviceA] ntp-service authentication-keyid 88 authentication-mode md5 simple 123456
[DeviceA] ntp-service reliable authentication-keyid 88
# Configure Device A to operate in NTP broadcast client mode and receive NTP broadcast messages on VLAN-interface 2.
[DeviceA-Vlan-interface2] ip address 3.0.1.33 24
Clock stratum: 3
Local mode: bclient
Leap indicator: 00
Clock jitter: 0.000092 s
Root delay: 2.42615 ms
Root dispersion: 1950.98877 ms
Reference time: d5eed631.2f498d71 Thu, Sep 26 2019 15:50:09.184
Configuration files
· Device A, Device B, Device D, and Device E:
ntp-service enable
ntp-service authentication-keyid 88 authentication-mode md5 cipher $c$3$pU6KvpS80MadhM2zM
CCSR07HX4qEbJhHvQ==
· Device C:
ntp-service enable
ntp-service authentication-keyid 88 authentication-mode md5 cipher $c$3$iJudDKiqCVO+gOaG53
63/fz4M3dQvHo2Fw==
ntp-service refclock-master 3
