- H3C Fixed Port Campus Switches Configuration Examples-6W104
 - 00-Applicable hardware and software versions
 - 01-Login Management Configuration Examples
 - 02-RBAC Configuration Examples
 - 03-Software Upgrade Examples
 - 04-ISSU Configuration Examples
 - 05-Software Patching Examples
 - 06-Ethernet Link Aggregation Configuration Examples
 - 07-Port Isolation Configuration Examples
 - 08-Spanning Tree Configuration Examples
 - 09-VLAN Configuration Examples
 - 10-VLAN Tagging Configuration Examples
 - 11-DHCP Snooping Configuration Examples
 - 12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
 - 13-IPv6 over IPv4 Tunneling with OSPFv3 Configuration Examples
 - 14-IPv6 over IPv4 GRE Tunnel Configuration Examples
 - 15-GRE with OSPF Configuration Examples
 - 16-OSPF Configuration Examples
 - 17-IS-IS Configuration Examples
 - 18-BGP Configuration Examples
 - 19-Policy-Based Routing Configuration Examples
 - 20-OSPFv3 Configuration Examples
 - 21-IPv6 IS-IS Configuration Examples
 - 22-Routing Policy Configuration Examples
 - 23-IGMP Snooping Configuration Examples
 - 24-IGMP Configuration Examples
 - 25-MLD Snooping Configuration Examples
 - 26-IPv6 Multicast VLAN Configuration Examples
 - 27-ACL Configuration Examples
 - 28-Traffic Policing Configuration Examples
 - 29-GTS and Rate Limiting Configuration Examples
 - 30-Traffic Filtering Configuration Examples
 - 31-AAA Configuration Examples
 - 32-Port Security Configuration Examples
 - 33-Portal Configuration Examples
 - 34-SSH Configuration Examples
 - 35-IP Source Guard Configuration Examples
 - 36-Ethernet OAM Configuration Examples
 - 37-CFD Configuration Examples
 - 38-DLDP Configuration Examples
 - 39-VRRP Configuration Examples
 - 40-BFD Configuration Examples
 - 41-NTP Configuration Examples
 - 42-SNMP Configuration Examples
 - 43-NQA Configuration Examples
 - 44-Mirroring Configuration Examples
 - 45-sFlow Configuration Examples
 - 46-OpenFlow Configuration Examples
 - 47-MAC Address Table Configuration Examples
 - 48-Static Multicast MAC Address Entry Configuration Examples
 - 49-IP Unnumbered Configuration Examples
 - 50-MVRP Configuration Examples
 - 51-MCE Configuration Examples
 - 52-Attack Protection Configuration Examples
 - 53-Smart Link Configuration Examples
 - 54-RRPP Configuration Examples
 - 55-BGP Route Selection Configuration Examples
 - 56-IS-IS Route Summarization Configuration Examples
 - 57-VXLAN Configuration Examples
 - 58-DRNI Configuration Examples
 - 59-IRF 3.1 Configuration Examples
 - 60-PTP Configuration Examples
 - 61-S-MLAG Configuration Examples
 - 62-Puppet Configuration Examples
 - 63-802.1X Configuration Examples
 - 64-MAC Authentication Configuration Examples
 - 65-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
 - 66-BIDIR-PIM Configuration Examples
 - 67-Congestion Avoidance and Queue Scheduling Configuration Examples
 - 68-Basic MPLS Configuration Examples
 - 69-MPLS L3VPN Configuration Examples
 - 70-MPLS OAM Configuration Examples
 - 71-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
 - 72-DRNI and EVPN Configuration Examples
 - 73-Multicast VPN Configuration Examples
 - 74-MPLS TE Configuration Examples
 - 75-Control Plane-Based QoS Policy Configuration Examples
 - 76-Priority Mapping and Queue Scheduling Configuration Examples
 - 77-ARP Attack Protection Configuration Examples
 - 78-IRF Software Upgrade Configuration Examples
 - 79-IRF Member Replacement Configuration Examples
 - 80-Layer 3 Multicast on Multicast Source-Side DR System Configuration Examples
 - 81-EVPN Multicast Configuration Examples
| 15-GRE with OSPF Configuration Examples | 90.37 KB |
Introduction
This document provides GRE with OSPF configuration examples.
This document assumes that you have basic knowledge of GRE and OSPF.
Example: Configuring GRE with OSPF
As shown in Figure 1, Device A is the gateway of the headquarters. Device B and Device C are the gateways of Branch 1 and Branch 2, respectively. The gateways have obtained public IP addresses from an ISP and can communicate with one another. Configure GRE with OSPF to meet the following requirements:
· The headquarters and the branches communicate with one another through the GRE tunnels established between the headquarters and the branches.
· The gateways learn the routes reaching the destination networks through the tunnel interfaces.
   Device  |
   Interface  |
   IP address  |
   Device  |
   Interface  |
   IP address  |
   Device A  |
   Vlan-int10  |
   191.2.1.1/24  |
   Device B  |
   Vlan-int10  |
   191.3.1.1/24  |
   Vlan-int20  |
   10.1.1.1/24  |
   Vlan-int20  |
   10.7.1.1/24  |
   Tunnel1  |
   10.5.1.1/24  |
   Tunnel1  |
   10.5.1.2/24  |
   Tunnel2  |
   10.6.1.1/24  |
   Device C  |
   Vlan-int10  |
   191.4.1.1/24  |
   Vlan-int20  |
   10.8.1.1/24  |
   Tunnel2  |
   10.6.1.2/24  |
    Hardware  |
    Software version  |
   S6812 switch series S6813 switch series  |
   Release 6615Pxx, Release 6628Pxx  |
   S6550XE-HI switch series  |
   Release 6008 and later, Release 8106Pxx  |
   S6525XE-HI switch series  |
   S5850 switch series  |
   Release 8005 and later  |
   S5570S-EI switch  |
   Not supported  |
   S5560X-EI switch series  |
   Release 63xx, Release 65xx, Release 6615Pxx, Release 6628Pxx  |
   S5560X-HI switch series  |
   S5500V2-EI switch series  |
   MS4520V2-30F switch  |
   MS4520V2-30C switch MS4520V2-54C switch  |
   MS4520V2-28S switch MS4520V2-24TP switch  |
   Release 63xx  |
   S6520X-HI switch series S6520X-EI switch series  |
   S6520X-SI switch series S6520-SI switch series  |
   S5000-EI switch series  |
   MS4600 switch series  |
   ES5500 switch series  |
   S5560S-EI switch series S5560S-SI switch series  |
   Release 63xx  |
   S5500V3-24P-SI switch S5500V3-48P-SI switch  |
   Release 63xx  |
   S5500V3-SI switch series (except the S5500V3-24P-SI and S5500V3-48P-SI switches)  |
   Not supported  |
   S5170-EI switch series  |
   Not supported  |
   S5130S-HI switch series S5130S-EI switch series S5130S-SI switch series S5130S-LI switch series  |
   Not supported  |
   S5120V2-SI switch series S5120V2-LI switch series  |
   Not supported  |
   S5120V3-EI switch series  |
   Not supported  |
   S5120V3-36F-SI switch S5120V3-28P-HPWR-SI switch S5120V3-54P-PWR-SI switch  |
   Not supported  |
   S5120V3-SI switch series (except the S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI switches)  |
   Not supported  |
   S5120V3-LI switch series  |
   Not supported  |
   S3600V3-EI switch series  |
   Not supported  |
   S3600V3-SI switch series  |
   Not supported  |
   S3100V3-EI switch series S3100V3-SI switch series  |
   Not supported  |
   S5110V2 switch series  |
   Not supported  |
   S5110V2-SI switch series  |
   Not supported  |
   S5000V3-EI switch series S5000V5-EI switch series  |
   Not supported  |
   S5000E-X switch series S5000X-EI switch series  |
   Not supported  |
   E128C switch E152C switch E500C switch series E500D switch series  |
   Not supported  |
   MS4320V2 switch series MS4320V3 switch series MS4300V2 switch series MS4320 switch series MS4200 switch series  |
   Not supported  |
   WS5850-WiNet switch series  |
   Release 63xx  |
   WS5820-WiNet switch series WS5810-WiNet switch series  |
   Not supported  |
   WAS6000 switch series  |
   Not supported  |
   IE4300-12P-AC switch IE4300-12P-PWR switch IE4300-M switch series IE4320 switch series  |
   Not supported  |
Procedures
Before configuring GRE and OSPF, configure an IPv4 routing protocol on the gateways so that they can reach one another. (Details not shown.)
Configuring Device A
# Configure VLAN-interface 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port GigabitEthernet 1/0/1
[DeviceA-vlan10] quit
[DeviceA-vlan-interface10] ip address 191.2.1.1 255.255.255.0
[DeviceA-vlan-interface10] quit
# Configure other interfaces in the same way VLAN-interface 10 is configured. (Details not shown.)
# Create service loopback group 1 and specify tunnel services for the group, and then add GigabitEthernet 1/0/3 to the group. (This step is required for the S6550XE-HI, S6525XE-HI, and S5850 switch series to receive and send tunnel packets.)
[DeviceA] service-loopback group 1 type tunnel
[DeviceA-GigabitEthernet1/0/3] port service-loopback group 1
# Create a tunnel interface Tunnel 1, and specify the tunnel mode as GRE/IPv4.
[DeviceA] interface tunnel 1 mode gre
# Configure an IP address for the tunnel interface Tunnel 1.
[DeviceA-Tunnel1] ip address 10.5.1.1 24
# Configure the source interface of the tunnel interface Tunnel 1 as VLAN-interface 10.
[DeviceA-Tunnel1] source vlan-interface 10
# Configure the destination address of the tunnel interface Tunnel 1 as the IP address of VLAN-interface 10 on Device B.
[DeviceA-Tunnel1] destination 191.3.1.1
[DeviceA-Tunnel1] quit
# Create a tunnel interface Tunnel 2, and specify the tunnel mode as GRE/IPv4.
[DeviceA] interface tunnel 2 mode gre
# Configure an IP address for the tunnel interface Tunnel 2.
[DeviceA-Tunnel2] ip address 10.6.1.1 24
# Configure the source interface of the tunnel interface Tunnel 2 as VLAN-interface 10.
[DeviceA-Tunnel2] source vlan-interface 10
# Configure the destination address of the tunnel interface Tunnel 2 as the IP address of VLAN-interface 10 on Device C.
[DeviceA-Tunnel2] destination 191.4.1.1
[DeviceA-Tunnel2] quit
# Configure the OSPF router ID as 10.6.1.1.
[DeviceA] router id 10.6.1.1
# Enable OSPF process 1.
[DeviceA] ospf 1
# Create OSPF area 0.
[DeviceA-ospf-1] area 0
# Enable OSPF on interfaces whose primary IP addresses are on network 10.1.1.0/24, 10.5.1.0/24, or 10.6.1.0/24 in area 0.
[DeviceA-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] network 10.5.1.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] network 10.6.1.0 0.0.0.255
Configuring Device B
[DeviceB] vlan 10
[DeviceB-vlan10] port GigabitEthernet 1/0/1
[DeviceB-vlan10] quit
[DeviceB] interface vlan-interface 10
[DeviceB-vlan-interface10] ip address 191.3.1.1 255.255.255.0
[DeviceB-vlan-interface10] quit
[DeviceB] service-loopback group 1 type tunnel
[DeviceB] interface gigabitethernet 1/0/3
[DeviceB-GigabitEthernet1/0/3] port service-loopback group 1
[DeviceB] interface tunnel 1 mode gre
[DeviceB-Tunnel1] ip address 10.5.1.2 24
[DeviceB-Tunnel1] source Vlan-interface 10
# Configure the destination address of the tunnel interface Tunnel 1 as the IP address of VLAN-interface 10 on Device A.
[DeviceB-Tunnel1] destination 191.2.1.1
[DeviceB-Tunnel1] quit
# Configure the OSPF router ID as 10.7.1.1.
[DeviceB] router id 10.7.1.1
[DeviceB] ospf 1
[DeviceB-ospf-1] area 0
# Enable OSPF on interfaces whose primary IP addresses are on network 10.7.1.0/24 or 10.5.1.0/24 in area 0.
[DeviceB-ospf-1-area-0.0.0.0] network 10.7.1.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.0] network 10.5.1.0 0.0.0.255
Configuring Device C
<DeviceC> system-view
[DeviceC] vlan 10
[DeviceC-vlan10] port GigabitEthernet 1/0/1
[DeviceC-vlan10] quit
[DeviceC] interface Vlan-interface 10
[DeviceC-Vlan-interface10] ip address 191.4.1.1 255.255.255.0
[DeviceC-Vlan-interface10] quit
[DeviceC] service-loopback group 1 type tunnel
[DeviceC] interface gigabitethernet 1/0/3
[DeviceC-GigabitEthernet1/0/3] port service-loopback group 1
[DeviceC-GigabitEthernet1/0/3] quit
[DeviceC] interface tunnel 2 mode gre
[DeviceC-Tunnel2] ip address 10.6.1.2 24
[DeviceC-Tunnel2] source Vlan-interface 10
# Configure the destination address of the tunnel interface Tunnel 2 as the IP address of VLAN-interface 10 on Device A.
[DeviceC-Tunnel2] destination 191.2.1.1
[DeviceC-Tunnel2] quit
# Configure the OSPF router ID as 10.8.1.1.
[DeviceC] router id 10.8.1.1
[DeviceC] ospf 1
[DeviceC-ospf-1] area 0
# Enable OSPF on interfaces whose primary IP addresses are on network 10.8.1.0/24 or 10.6.1.0/24 in area 0.
[DeviceC-ospf-1-area-0.0.0.0] network 10.8.1.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] network 10.6.1.0 0.0.0.255
# Verify that Host A can ping Host B successfully.
C:\> ping 10.7.1.2
Pinging 10.7.1.2 with 32 bytes of data:
Reply from 10.7.1.2: bytes=32 time=19ms TTL=253
Reply from 10.7.1.2: bytes=32 time<1ms TTL=253
Ping statistics for 10.7.1.2:
Minimum = 0ms, Maximum = 19ms, Average = 4ms
# Verify that Host A can ping Host C successfully.
C:\> ping 10.8.1.2
Pinging 10.8.1.2 with 32 bytes of data:
Reply from 10.8.1.2: bytes=32 time=18ms TTL=253
Reply from 10.8.1.2: bytes=32 time<1ms TTL=253
Ping statistics for 10.8.1.2:
# Verify that Host B can ping Host C successfully.
C:\> ping 10.8.1.2
Reply from 10.8.1.2: bytes=32 time=20ms TTL=251
Reply from 10.8.1.2: bytes=32 time<1ms TTL=251
Configuration files
   IMPORTANT: Support for the port link-mode bridge command depends on the device model.  |
· Device A
vlan 10
vlan 20
interface Vlan-interface10
interface Vlan-interface20
port access vlan 10
port access vlan 20
interface Tunnel1 mode gre
source vlan-interface10
ip address 10.5.1.1 255.255.255.0
interface Tunnel2 mode gre
ip address 10.6.1.1 255.255.255.0
router id 10.6.1.1
ospf 1
area 0.0.0.0
· Device B
vlan 10
vlan 20
ip address 10.7.1.1 255.255.255.0
port access vlan 10
port access vlan 20
source Vlan-interface10
ip address 10.5.1.2 255.255.255.0
router id 10.7.1.1
ospf 1
area 0.0.0.0
· Device C
vlan 10
vlan 20
ip address 10.8.1.1 255.255.255.0
port access vlan 10
port access vlan 20
ip address 10.6.1.2 255.255.255.0
router id 10.8.1.1
ospf 1
area 0.0.0.0
